BoondS Ierakstīts Oktobris 12, 2004 Share Ierakstīts Oktobris 12, 2004 uzgaaju internetveikalu, kur LCD monitors 17 collas ar response time 12 sec maksaa tikai 199 LS http://www.univeikals.lv/product_info.php?...roducts_id=1780 Kaadas atsauksmes par sho modeli? Vai iespeejams ka kriitas cenas LCD monitoriem un vai tika straujsh kritums kaa shajaa gadiijumaa? Link to comment Share on other sites More sharing options...
TritoN Oktobris 12, 2004 Share Oktobris 12, 2004 uzgaaju internetveikalu, kur LCD monitors 17 collas ar response time 12 sec maksaa tikai 199 LShttp://www.univeikals.lv/product_info.php?...roducts_id=1780 Kaadas atsauksmes par sho modeli? Vai iespeejams ka kriitas cenas LCD monitoriem un vai tika straujsh kritums kaa shajaa gadiijumaa? Kur Tu redzi ka 12 ? es atradu ka shamejam ir Response Time (R/F) 5ms / 15ms (Typical) Link to comment Share on other sites More sharing options...
BoondS Oktobris 12, 2004 Author Share Oktobris 12, 2004 http://www.neovouk.com/products/F-417.htm Panel Size 17" (432mm) Brightness 260cd/m2 (Typical) Contrast Ratio 450:1 (Typical) Viewing Angle (H/V) 150o / 135o (Typical) Display Resolution SXGA 1280 x 1024 Input Signal Analog Response Time 4ms / 12ms (Typical) Net Dimension 377 x 373 x 200mm (14.9" x 14.7" x 7.9") Net Weight 5.0Kg (11.0lbs) Link to comment Share on other sites More sharing options...
Guest Oktobris 12, 2004 Share Oktobris 12, 2004 Vispar jau pec iestaashanas ES LCD monju cenas paceelas ~10% Link to comment Share on other sites More sharing options...
TritoN Oktobris 12, 2004 Share Oktobris 12, 2004 http://www.neovouk.com/products/F-417.htm Panel Size 17" (432mm) Brightness 260cd/m2 (Typical) Contrast Ratio 450:1 (Typical) Viewing Angle (H/V) 150o / 135o (Typical) Display Resolution SXGA 1280 x 1024 Input Signal Analog Response Time 4ms / 12ms (Typical) Net Dimension 377 x 373 x 200mm (14.9" x 14.7" x 7.9") Net Weight 5.0Kg (11.0lbs) Nu blaa , ieks pdf faila mazliet savadaaki parameti http://www.neovo.ru/products/pdf/F-417.pdf Link to comment Share on other sites More sharing options...
