Vai kāds ir mēģinājis rakstīt vīrusu?
Guest Astroxs
Guest kaalis
mosha aizsuuti shito. lai pats nokompilee un palaizh...
#include <iostream>
using namespace std;
int main() {
cout << "viirusa examplen";
system("dir"); // principaa te var ielikt da jebkuru komandu
// bet taa kaa neesu ljauns un neko sliktu nerakstiishu
system("pause");
return 0;
open source... ;)
© kaalis 2004
Viens labs viiruss' date=' kas nedaudz pachakareejas ap hdd :)
X5O!P%@AP[4PZX54(P^)7CC)7}$$H+H*
Jaaieraksta ar notepad jaunaa teksta dokumentaa un jaasaglabaa kaa .exe izpildaamais fails. Par sekaam neatbildu.[/quote']
tas ir
EICAR-STANDARD-ANTIVIRUS-TEST -FILE
un kas tas ir ?
Guest kaalis
tas ir
un kas tas ir ?
source: http://www.eicar.org/anti_virus_test_file.htm
The Anti-Virus test file
(read the complete text, it contains important information)
Version of 1 May 2003
If you are active in the anti-virus research field, then you will regularly receive requests for virus samples. Some requests are easy to deal with: they come from fellow-researchers whom you know well, and whom you trust. Using strong encryption, you can send them what they have asked for by almost any medium (including across the Internet) without any real risk.
Other requests come from people you have never heard from before. There are relatively few laws (though some countries do have them) preventing the secure exchange of viruses between consenting individuals, though it is clearly irresponsible for you simply to make viruses available to anyone who asks. Your best response to a request from an unknown person is simply to decline politely.
A third set of requests come from exactly the people you might think would be least likely to want viruses "users of anti-virus software".
They want some way of checking that they have deployed their software correctly, or of deliberately generating a "virus incident in order to test their corporate procedures, or of showing others in the organisation what they would see if they were hit by a virus".
Obviously, there is considerable intellectual justification for testing anti-virus software against real viruses. If you are an anti-virus vendor, then you do this (or should do it!) before every release of your product, in order to ensure that it really works. However, you do not (or should not!) perform your tests in a "real" environment. You use (or should use!) a secure, controlled and independent laboratory environment within which your virus collection is maintained.
Using real viruses for testing in the real world is rather like setting fire to the dustbin in your office to see whether the smoke detector is working. Such a test will give meaningful results, but with unappealing, unacceptable risks.
Since it is unacceptable for you to send out real viruses for test or demonstration purposes, you need a file that can safely be passed around and which is obviously non-viral, but which your anti-virus software will react to as if it were a virus.
If your test file is a program, then it should also produce sensible results if it is executed. Also, because you probably want to avoid shipping a pseudo-viral file along with your anti-virus product, your test file should be short and simple, so that your customers can easily create copies of it for themselves.
The good news is that such a test file already exists. A number of anti-virus researchers have already worked together to produce a file that their (and many other) products "detect" as if it were a virus.
Agreeing on one file for such purposes simplifies matters for users: in the past, most vendors had their own pseudo-viral test files which their product would react to, but which other products would ignore.
This test file has been provided to text link button for distribution as the "text link button Standard Anti-Virus Test File", and it satisfies all the criteria listed above. It is safe to pass around, because it is not a virus, and does not include any fragments of viral code. Most products react to it as if it were a virus (though they typically report it with an obvious name, such as "EICAR-AV-Test").
The file is a legitimate DOS program, and produces sensible results when run (it prints the message "EICAR-STANDARD-ANTIVIRUS-TEST-FILE!").
It is also short and simple - in fact, it consists entirely of printable ASCII characters, so that it can easily be created with a regular text editor. Any anti-virus product that supports the text link button test file should detect it in any file providing that the file starts with the following 68 characters, and is exactly 68 bytes long:
X5O!P%@AP[4PZX54(P^)7CC)7}$EICAR-STANDARD-ANTIVIRUS-TEST-FILE!$H+H*
The first 68 characters is the known string. It may be optionally appended by any combination of whitespace characters with the total file length not exceeding 128 characters. The only whitespace characters allowed are the space character, tab, LF, CR, CTRL-Z. To keep things simple the file uses only upper case letters, digits and punctuation marks, and does not include spaces. The only thing to watch out for when typing in the test file is that the third character is the capital letter "O", not the digit zero.
You are encouraged to make use of the text link button test file. If you are aware of people who are looking for real viruses "for test purposes", bring the test file to their attention. If you are aware of people who are discussing the possibility of an industry-standard test file, tell them about www.eicar.org, and point them at this article.
In order to facilitate various scenarios, we provide 4 files for download. The first, eicar.com, contains the ASCII string as described above. The second file, eicar.com.txt, is a copy of this file with a different filename. Some readers reported problems when downloading the first file, which can be circumvented when using the second version. Just download and rename the file to "eicar.com". That will do the trick. The third version contains the test file inside a zip archive. A good anti-virus scanner will spot a 'virus' inside an archive. The last version is a zip archive containing the third file. This file can be used to see whether the virus scanner checks archives more than only one level deep.
Once downloaded run your AV scanner. It should detect at least the file "eicar.com". Good scanners will detect the 'virus' in the single zip archive and may be even in the double zip archive. Once detected the scanner might not allow you any access to the file(s) anymore. You might not even be allowed by the scanner to delete these files. This is caused by the scanner which puts the file into quarantaine. The test file will be treated just like any other real virus infected file. Read the user's manual of your AV scanner what to do or contact the vendor/manufacturer of your AV scanner.
maaksla nenoveco :O)
Neceros preciizi... manpraat majeejaa virusa kods bija ~140baitiem
Uztaisi tagad neasmaa kautko apm tikpat kompaktu :)
Es saprot ka tas nav aktuaali.. cik tas viirus liels.. bet taa ir dalja no maakslas.. uztaisiit kompaktu' date=' mazu un lai straadaa. Uztaisiit lielu viirusu VB maak katrs :O)[/quote']
Man mazākais ASM vīrus bija 122 baiti, bet ja lietoja 286 instrukcijas, tad vēl mazāks :)
driiksta zinaat ko tas darija?
Vietas truukuma deelj tas nedariija neko labu vai sliktu, tikai vairojaas caur COM failiem.
Priekš kam vīrusi, no tiem jau pašam nav nekāda labuma, labāk pie kādas normālas progammas instalācijas piekabināt spywārīti, kas teiksim logo visas lietotāja darbības, taisa skrīnšotus un sūta datus uz norādīto meilu vai ftp serveri, vārdu sakot pilnīgi labdabīga programmiņa un «iebarot» šo programmas instalāciju, lai viņš uzinstalē uz sava datora, kādam kolēģim, draugam, draudzenei, lai teiksim zinātu ko viņa dara, kad tevis nav klāt. :)
