Ungus Ierakstīts Septembris 24, 2008 Share Ierakstīts Septembris 24, 2008 (labots) Sveiki. Ipašumā kādu laiku atpakaļ nonāca signalizācijas modulis ar visiem pričendāļiem. Tagad ir vajadzība to uzstādīt. Vissir izdarīts, tikai nav zināmi nevieni kodi, bet zinu, ka to var nonullēt. Tikai tie modeļi un nonullēšana atšķiras. Vienam bij PRG+z1 salaist uz "īso" kā teikt. Kā ir ar šo? Būšu pateicīgs par infu Vai tiešām neviens par signalizācijām te fišku nerubī? :-o Labots Septembris 24, 2008 - Ungus Link to comment Share on other sites More sharing options...
oxx Septembris 24, 2008 Share Septembris 24, 2008 To restore the factory default programming: 1 Remove power from the system by disconnecting the AC and battery 2 Remove any connections to the Zone 1 and PGM terminals 3 Connect the Zone 1 and PGM terminals together 4 With the Zone 1 and PGM terminals connected, apply AC power to the system 5 Wait for 20 seconds after applying power and then remove the connection between the Zone 1 and PGM terminals 6 The system’s factory default programming has now been restored. Note that if the Installer’s Lockout feature had been enabled, the Installer’s Code and the Downloading Access Code will not be reset to the default settings. pc2525p.pdf Link to comment Share on other sites More sharing options...
Ungus Septembris 24, 2008 Author Share Septembris 24, 2008 (labots) Paldies Oxx!!! Labots Septembris 24, 2008 - Ungus Link to comment Share on other sites More sharing options...
