Guest pleeeesis Ierakstīts Septembris 4, 2007 Share Ierakstīts Septembris 4, 2007 Tātad jautājums par īpašajām kamerām, kuras ir apveltītas ar lielu FPS. Vai viņas ir pieejamas Latvijā ? Vai ir iespējams kaut kā pasūtīt no ārzemēm un cik tas galu galā arī maksātu ( protams, ka lielā mēra atkarīgs no kameras ) Būšu ļoti pateicīgs par noderīgu info. Link to comment Share on other sites More sharing options...
Mezavecis Septembris 4, 2007 Share Septembris 4, 2007 Pēc tavām domām, kas skaitās liels FPS? Link to comment Share on other sites More sharing options...
Guest pleeeesis Septembris 4, 2007 Share Septembris 4, 2007 Nu protams nekas kruts, bet nu 500+ vai 1000 FPS būtu ar atliektiem galiem... Link to comment Share on other sites More sharing options...
Armijs Septembris 4, 2007 Share Septembris 4, 2007 (labots) Ohohohoh.... 500+ fps, tu maz jedz ko runaa ??? Cik miljoni tev ir ? Mhmm, shodien ko jaunu uzzināju :oops: high speed camera is a device used for recording slow-motion playback films, or used for scientific study of transient phenomena. A normal motion picture is filmed and played back at 24 frames per second, while television uses 25 frames/s (PAL) to 29.97 frames/s (NTSC). High speed cameras can film up to 250,000 frames/s by running the film over a rotating prism or mirror instead of using a shutter, thus reducing the need for moving parts. Using this technique one can stretch one second to more than 10 minutes of playback time (super slow motion). The fastest cameras are generally in use in scientific research, military test and evaluation, and industry. An example of an industrial application is crash testing to better document the crash and what happens to the automobile and passengers during a crash. A problem for high speed cameras is the needed exposure for the film, so one needs very bright light to be able to film at 40,000 frame/s sometimes leading to the subject of examination being destroyed because of the heat of the lighting. Even higher speed imaging is possible using specialized electronic charge-coupled device (CCD) imaging systems which can achieve speeds of up to or in excess of 25 million frames per second. Recent advances in the form of image converter devices are able to provide temporal resolutions of less than 50 picoseconds, equivalent to over 50,000,000,000 frames per second. These instruments operate by converting the incident light (consisting of photons) into a stream of electrons which are then deflected onto a photoanode, back into photons, which can then be recorded onto either film or CCD Labots Septembris 4, 2007 - Armijs Link to comment Share on other sites More sharing options...
Krishius Septembris 4, 2007 Share Septembris 4, 2007 Vecīt, nesapņo Diez vai tu to varēsi atļauties. Šķiet, ka lētākais variants būs kāda lietota 16mm kinokamera, kura spēj rakstīt līdz 500 fps. Bet nu ja naudas ir gana, tad teiksim šis (bez 15 000$ kabatā vari pat īpaši netecināt siekalas ) Link to comment Share on other sites More sharing options...
Guest abc Septembris 4, 2007 Share Septembris 4, 2007 (labots) pameklējot internetā var redzēt, ka daudzi piedāvā noīrēt. Labots Septembris 4, 2007 - abc Link to comment Share on other sites More sharing options...
Krishius Septembris 4, 2007 Share Septembris 4, 2007 (labots) abc - taa ir 35mm kinokamera Labots Septembris 4, 2007 - Krishius Link to comment Share on other sites More sharing options...
XRS Septembris 4, 2007 Share Septembris 4, 2007 (labots) casio prezenteja tipa ultra zoom tiikko ar 60 fps/sec JPG formata. muahahahha. jautajas - praktisks pielietojums!!? edit - sori, neapskatijos kaads topics, es par foto biju domajis Labots Septembris 4, 2007 - XRS Link to comment Share on other sites More sharing options...
Krishius Septembris 4, 2007 Share Septembris 4, 2007 (labots) Sony FX7 piedāvā slow-motion režīmu ar 4kaartiigu palēninājumu. Tiesa, viņš ir baisi sūdīgs - briesmīga kompresijas izkropļota bilde, kas HDV režīmā izskatās pēc sūdīga ar fotokameru filmēta video (gan izšķirtspējas, gan kompresijas gļuku ziņā). Lai gan uz DV (SD) jams varētu izskatīties labāk. Neesmu provējis. Un ja nu kādu interesē pilnīgas izvirtības, tad palasās šito (piebildīšu - tā ir tikai sistēmas kamera, kurai vajag vēl attiecīgu videokontrolieri un serveri, uz kura rakstīt 10 Gbps strīmu caur optiku vai 3 HD-SDI pieslēgumiem) Labots Septembris 4, 2007 - Krishius Link to comment Share on other sites More sharing options...
Guest abc Septembris 4, 2007 Share Septembris 4, 2007 Pasaule jau nesākās ar digitālo ēru, ātrās kameras bija arī filmu laikos. Bet nu, pareizi vien ir, tas vairs nav aktuāli. Link to comment Share on other sites More sharing options...
