Guest Crossha1R^ Ierakstīts Augusts 25, 2007 Share Ierakstīts Augusts 25, 2007 Man kautkas noticis ar up gandriiz vispar nav, meerot speedtest.net reti ka vispaar meera up kas vareetu buut noticies? tas jau ir vairaak kaa meenesi Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 tas ir jautaajums provaideram Link to comment Share on other sites More sharing options...
Tontons Augusts 25, 2007 Share Augusts 25, 2007 Ja tas notiek reizi mēnesī, tad tās ir UP mēnešreizes. Ja Tu paprovētu ko sakarīgāk un sīkāk pastāstī par savu problēmu, tad arī būtu sakarīgas atbildes. Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 (labots) Bija jau un neko nepaliidzeeja nu tur iisti nav ko stastiit uttorrent vispar up atrums palicis mo 0kb/sec lidz 5kb/sec retums ka bishki vairaak nezinu kas pa vainu Labots Augusts 25, 2007 - Crossha1R^ Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 provaiders? ip ir aareeja vai lokaala? kas tev tiesji neuplaudojas? Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 Man ir router bet tas neko nemaina - esmu megjinaajis Link to comment Share on other sites More sharing options...
torch Augusts 25, 2007 Share Augusts 25, 2007 Uz jautājumiem atbildēt nemāki? "provaiders? ip ir aareeja vai lokaala? kas tev tiesji neuplaudojas?" Un vsp, maini provaideri tad. Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 www.ilva.lv lokaalaa nekas Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 DC++ serveris failu apmaiņai hub.ilva.lv te arii nekas nekust? patiesiibaa bez uploada nevar straadaat tcp/ip protokols.... visdriizaakais provs apgriezis p2p.... Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 Man jau kaadu laiku nestraada hub.ilva.lv raada - *** Connecting to hub.ilva.lv... *** Connected <VerliHub> This Hub is running version 0.9.8c ILVANET special mod (Tue Mar 8 11:00:00 CET 2005) of VerliHub (RunTime:2days 13hours ). <VerliHub> This hub is enhanced by plugman for Verlihub. <VerliHub> You share 0MB, but the min share is 50MB. (Active:50MB / passive 50) *** Redirect request received to a hub that's already connected *** Disconnected es jau nezinu kas ir p2p Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 You share 0MB, but the min share is 50MB. tu esi alnis? Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 (labots) aa sapratu izdariiju taa Un ko man tagat tur izdariit? esmu iekshaa Labots Augusts 25, 2007 - Crossha1R^ Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 :> Uninstall DC Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 pameegjini lejuplaadeet populaaru failu es nez, kkaadu bumsaabumsaa gabalu apskaties, vai no tevis kaads kko velk Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 man var teikt hub ilva ir tas pats kas lanaa atrums man tur buus baigais down bet up nez Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 tiesji taapeec es tev ieteicu lokaalo hub! paskaties kaads up ja up ir normaals, tad tavaa galaa viss kaartiibaa un ej lamaat provaideri domaaju, ka liidz apstaaklja noskaidrosjanai teema izsmelta..... Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 Nelamaajies bet dc++ var kautkaa redzeet kuru failu viss vairaak velk? Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 ja tu domaa no hub, tad nee ko velk no tevis - protams var apskatiit.... es tak nezinu, kas jums tur sjobriid populaars kkaads tokiohotelis vai kaukaadi bumsaabumsaa Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 Es jau domāju, ka tas ir mīts.. pa cilvēkiem ar pilnīgi gludām smadzenēm :> MAN NAF UPLODA!?!?!?!?!?!? Pēc brīža.. A... pa.. man kaut kas bija jāšārē O_o ?! Vēl pēc brīža.. nošārēju.. NAV UPLODA!!! A čuķ čuķ pakustināt pelēko vielu un padomāt kāpēc ? Padomāt kad vispār var būt uplods ? Tā tīri teorētiski uplods var būt tad, kad kādam savajagas kaut ko no tā, kas ir tev. Nav uploda...tātad.. nevienam nav vajadzīgi tie mēsli ko tu nošārēji. Un DC gadijumā vispār neredzu īpašu jēgu ņaudēt pa to ka nav uploda. Tur tak nav ratio.. kam tev tur kaut kāds uplods? Viss, kas tev ir svarīgi.. iekurbulēt DC active modē.. usjo. Pagooglē DC Active mode. Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 (labots) Velis es nelietoju dc++ es tikai utorrent un tur pat nav nekaads atrums esmu meerijis atrumu un man upload atrumu nemeera dc++ ka atrod kadu failu tir ir kautkaads slot 9/24 varbuut tas ir kautkads cik velk un cik var max ? Labots Augusts 25, 2007 - Crossha1R^ Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 (labots) Pirmīt tika pieminēts DC. brrrr... "nav nekaads atrums esmu meerijis atrumu un man upload atrumu nemeera" Moš iemācies cilvēcīgi aprakstīt, kas tev tur ir/nav ? P.S "dc++ ka atrod kadu failu tir ir kautkaads slot 9/24 varbuut tas ir kautkads cik velk un cik var max ? " Tu tak DC nelieto.. tikkai torrent.. :> Labots Augusts 25, 2007 - Velis Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 padodos... aizeju uz bodi Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 tagat bij dc++ kadu laiku 130kIb/s Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 (labots) Izlasi Raksts postu #19 Lēni un nesteidzoties. Ja nepielec.. lasi kamēr pielēks. Labots Augusts 25, 2007 - Velis Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 uttorrent vispar up atrums palicis mo 0kb/sec lidz 5kb/sec retums ka bishki vairaak es tikai utorrent un tur pat nav nekaads atrums esmu meerijis atrumu un man upload atrumu nemeera Es jau domāju, ka tas ir mīts.. pa cilvēkiem ar pilnīgi gludām smadzenēm :> nav komentaaru.... Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 Izlasi Raksts postu #19 Lēni un nesteidzoties. Ja nepielec.. lasi kamēr pielēks. domaa ka esmu stulbs? man visu laiku bija vis kartiibaa ar aatrumu bet jau meeneesi uttorent up atrums gandriz vispar nav nekaa interneta vairaakas vietaas meeriju atrumu un nemeera tieshi up !!!!!! Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 izlasi #2 ja iisti nesaproti, tad lasi kameer sapratiisi. Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 Saprotu taksh Buus jaasauc vinji!! Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 "domaa ka esmu stulbs? " Nu.. ja tā godīgi.. man sāk likties ka tā varētu būt :> Lasi vēl un vēl to #19 Tas, ka tev nav uploda.. var būt arī tāpēc, ka nevienam nevajag to ko no tevis var novilkt. Testēt augšuplādes ātrumu nav jēgas. ISP var nošeipot tieši P2P. Nezinu kur tu meklēji tos ātruma testus.. googlē ierakstot "speed test" pirmais links ir http://www.speedtest.net/ Tur ir i DL ij UL. Pie kam i LV i ārzemes. Palūri savā līgumā kāds tev vispār ir tas interneta pieslēgums.. līdz cik LV un līdz cik ārzemju DL/UL. Ir liela starpība vai slēdzas pie LV p2p vai pie ārzemju. Nu un + tas ka torrentam kuru tu velc var arī nebūt ličeru.. vai sīderu ir tik daudz, ka tev no tā uploda nekas netiek. Tās tak elementāras lietas.. tiešām pats nevari aizdomāties? Link to comment Share on other sites More sharing options...
Mr. Nejēga Augusts 25, 2007 Share Augusts 25, 2007 Nu zini, Veli, liekas pašam tev Kroka izšķīdusi kautkur smadzeņu šķirdumā.. Palasi pašu pirmo postu.. Jā, augšā, peles rulli/ritjoslu lietot māki.. Man kautkas noticis ar up gandriiz vispar nav, meerot speedtest.net reti ka vispaar meera up Lai būtu skaidrs, meerot speedtest.net reti ka vispaar meera up .. Un tu tagad baigo varoni tēlojot iesaki aiziet uz speedtest.net.. Jā, cilvēks te ir nekompetents P2P lietās, bet nav ko viņu padarīt pa lielāku muļķi kā īstenībā! Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 25, 2007 Share Augusts 25, 2007 "domaa ka esmu stulbs? " godiigi pateikt? tu autora pirmo postu vispaari izlasiiji? Link to comment Share on other sites More sharing options...
wooz Augusts 25, 2007 Share Augusts 25, 2007 Kā var būt ātrums, ja nav ņēmēju failam Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 " meerot speedtest.net reti ka vispaar meera up .." Palaidu garām speedtest.net :> Bet pie vainas ir autora izteiksmes veids.. raksta nedaudz kropli un teikums ir 3x jāpārlasa lai saprastu ko viņš ir domājis. Starp citu.. izteiksmes veids arī liecina pa cilvēka attīstības līmeni :> So.. Ok. Spīd TesC NevienM33r str@dā! Ko t@s war noz1m3t? Tur t@k ir wes3l@ kaudze ar testu serveriem.. augšuplādes tests nenotiek ne uz viena no tiem vai tikai uz atsevišķiem? Tie ir LV vai ārzemju serveri? Ibo ja pie vainas nav softs (maz ticams) tad paliek vadi un ruteris/modems kā arī ISP.. Mazums ISPam gļuko tīkls :> Tagad pēc tiem negaisiem daudziem ISPiem tīkla aparatūras biki pasvila :> Link to comment Share on other sites More sharing options...
Guest Crossha1R^ Augusts 25, 2007 Share Augusts 25, 2007 ai nu vienlaga varbuut jus nesaprataat bet ir njeemeeji un tas taa bet es kautkvai megjinu bildi ielikt vinja nokaraas nu ka man bija normals atrums man vienmeer ir meerits ka bija meistari ta ar teica ka kautkas ir nevis anu njeemeeju ai nu vienlaga varbuut jus nesaprataat bet ir njeemeeji un tas taa bet es kautkvai megjinu bildi ielikt vinja nokaraas Link to comment Share on other sites More sharing options...
Guest Velis Augusts 25, 2007 Share Augusts 25, 2007 Puika... zaepal. Iemācies rakstīt. Izlasi http://www.boot.lv/forums/index.php?showtopic=61210 Link to comment Share on other sites More sharing options...
