AcId Augusts 10, 2007 Share Augusts 10, 2007 A tev vispār ira kādi faili/whatewer kas ar directx ir saistīti? Ko Everests saka? Link to comment Share on other sites More sharing options...
Guest drunk_lizard Augusts 10, 2007 Share Augusts 10, 2007 mini vai zini topic autors meegjinaajis vistas skinu uzmest..... djebil... Link to comment Share on other sites More sharing options...
humors Augusts 10, 2007 Author Share Augusts 10, 2007 kādu vēl vistas skinu? vsp stulbs esi :?: Link to comment Share on other sites More sharing options...
AcId Augusts 10, 2007 Share Augusts 10, 2007 re ko man google pavēstīja: Click on you start menu in Windows and select Run and type in Dxdiag and click OK. This will run the DirectX diagnostic program. If you get an error when you click OK that says "Windows cannot find Dxdiag..." or something similar, ]then you do not have DirectX installed. Otherwise you might be asked if it's ok to run the DirectX diagnostic utility, and if so, select OK. DirectX Version is on the System Tab, toward the bottom. It should be DirectX 9.0c Link to comment Share on other sites More sharing options...
Devil_Inside Augusts 10, 2007 Share Augusts 10, 2007 Meklē dxdiag.exe iekš WINDOWS\System32, ja tur tāda nav tad velc jaunāko augusta relīzi. Link to comment Share on other sites More sharing options...
humors Augusts 11, 2007 Author Share Augusts 11, 2007 nav iekš windows/system32, ieinstalējot augusta, 2007 gada relīzi arī nav un, kad meklē ar search palīdzību, tad arī neko neatrod... Link to comment Share on other sites More sharing options...
VIL Augusts 11, 2007 Share Augusts 11, 2007 1) pameklē uz cietņa dxdiag.exe 2) pārbaudi PATH, vai šī vieta ir ierakstīta 3) ja nav, tad ieraksti 4) ja ir, tad laiks pāriet uz Linux Link to comment Share on other sites More sharing options...
humors Augusts 11, 2007 Author Share Augusts 11, 2007 dxdiag.exe nevaru nekur atrast, nekur nav tas fails kā es varu pārbaudīt vai tā vieta ir ierakstīta? Link to comment Share on other sites More sharing options...
