Guest albins-b Ierakstīts Decembris 9, 2006 Share Ierakstīts Decembris 9, 2006 Cik saprotu tad šim nevar pacelt FSB frekvenci uz 133 Mhz... vai ari tomer var... tieši interese pacelt FSB frekvenci no 100 uz 133,jo citu iemeslu ka procesoru neredzu kapec man tas neizdodas, jo parejie komponeti cik saprotu uz 133 FSB strada... CPU Properties: CPU Type AMD Duron XP CPU Alias Morgan CPU Stepping A1 CPU Speed: CPU Clock 1299.72 MHz CPU Multiplier 13.0x CPU FSB 99.98 MHz (original: 100 MHz) Memory Bus 133.30 MHz CPU Cache: L1 Code Cache 64 KB L1 Data Cache 64 KB L2 Cache 64 KB (On-Die, Full-Speed) Motherboard Properties: Motherboard Name ECS K7VTA3 v3 (5 PCI, 1 AGP, 1 CNR, 3 DDR DIMM, Audio) Chipset Properties: Motherboard Chipset VIA VT8367 Apollo KT333 Memory Timings 2.5-3-3-7 (CL-RCD-RP-RAS) SPD Memory Modules: DIMM1: Xerox MALABS 128 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) DIMM2 128 MB PC2100 DDR SDRAM (2.5-3-3-7 @ 142 MHz) (2.0-3-3-6 @ 133 MHz) DIMM3: 256UDTUG3B 256 MB PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz) Graphics Processor Properties: DirectX 4.09.00.0904 (DirectX 9.0c) Video Adapter nVIDIA GeForce2 MX/MX 400 GPU Code Name NV11 (AGP 4x 10DE / 0110, Rev B2) GPU Clock 200 MHz Memory Clock 166 MHz Link to comment Share on other sites More sharing options...
Plumbums Decembris 9, 2006 Share Decembris 9, 2006 Aizmirsti par 133mhz FSBus ar Duron "Morgan" shie vairaak par 112mhz nedzenas. Link to comment Share on other sites More sharing options...
Guest Kasparz Decembris 9, 2006 Share Decembris 9, 2006 ugu, ugu plumbum, d***t gan nevajag. Iedod man to morganu, redzēsi i 200+FSB. Ja līkas rokas, nevajag dzelžus vainot Link to comment Share on other sites More sharing options...
Plumbums Decembris 9, 2006 Share Decembris 9, 2006 Bez atlokotiem reizinatajiem 200mhz fsb sasniegt nevar,dazhi Morgan'i ar multiepler x7(13def) gaaja arii uz 200fsb. Link to comment Share on other sites More sharing options...
Guest albins-b Decembris 11, 2006 Share Decembris 11, 2006 kasparz varbut vismaz kadu linku kur aprakstīts kā un ko darīt, un kas atbilstu realitātei lai varētu tomer vismaz tos 133 FSB pacelt.... jo izrakņājoties pa visādiem saitiem varēju izlobīt tikai to, ka ja sazimeshu tos L1 visus kopa, tad vareshu reizinātājus mainīt, bet kur tieshi to darīt BIOS vai ari uz procesora man tā ari skaidrs nekļuva... jo BIOS vienigais ko atradu bija iespēja pacelt lidz 120/33 MHz bet rezultāts ka sistēma nepalaižas pēc tam... vienīgi ja kautkādas papildus iespējas atveras kad tos L1 savieno....?!? saprotu ka tiem kas to ir darījuši manas problēmas liekas smieklīgas... bet nu katrs ar kautko ir sācis.... un iespējams kļūdijies... vienkārši šis man pieejamais komplekts ir jau tik morāli novecojis, ka nav jau vairs bail kautko arī pabakstīt..... Link to comment Share on other sites More sharing options...
Guest Kasparz Decembris 11, 2006 Share Decembris 11, 2006 Ar tavu KT333 plati - NEKĀ. Link to comment Share on other sites More sharing options...
Guest albins-b Decembris 11, 2006 Share Decembris 11, 2006 Nja, palasijos vēl, un laikam bus žēl tā laika ko prasīs pacelt virs 110/33 Mhz, kas man tagad stabili strādā un varēju Biosā pacelt.... jo ja jau vairākums saka ka virs 125 sistēma paliek nestabila, tad laikam ja galīgi būs žēl mest šito dzelzi ārā, tad jaiegādā vien būs Athlon procis.... lietots.... Link to comment Share on other sites More sharing options...
