Guest nils9 Ierakstīts Novembris 25, 2006 Share Ierakstīts Novembris 25, 2006 Kā atgūt Xp izskatu no šā te ja man nepiedāvā tādu iespēju ? Link to comment Share on other sites More sharing options...
Guest ADEX Novembris 25, 2006 Share Novembris 25, 2006 Start > Control Panel > System > Advanced Nospied Settings (augšējo) un Visual Effects tabā izvēlies Let Windows choose... vai Adjust for Best Appearance > OK > OK Link to comment Share on other sites More sharing options...
Guest nils9 Novembris 25, 2006 Share Novembris 25, 2006 Saliku, bet vienalga man neljauj izveeleeties Xp stilu un ir tas kontuurainais dizains.. tur kaut veel nav jaadara ? :s Link to comment Share on other sites More sharing options...
Murlo Novembris 25, 2006 Share Novembris 25, 2006 To, ko tev ieteica ADEX Start > Control Panel > System > AdvancedNospied Settings (augšējo) un Visual Effects tabā izvēlies Let Windows choose... vai Adjust for Best Appearance > OK > OK njem nost. Atstķeksē tikai "Show translucent selection rectangle"; "Use a background image for each folder type"; "Use common tasks in folders" un "Use visual styles on wondows and buttons". Lai aktivizeetu Windows XP themes: Start-> run-> ieraksti services.msc. Apaksha buus Themes. Uzspied ar labo peles pogu virsuu un izveelies Properties. Kad atveersies ieksheejais logs nomaini Startup type uz Automatic. Nospied Apply un Start pie Service status, then OK. Link to comment Share on other sites More sharing options...
Guest nils9 Novembris 25, 2006 Share Novembris 25, 2006 paldies Murlo, man viss aizgaaja Link to comment Share on other sites More sharing options...
