Usukss Ierakstīts Jūlijs 31, 2006 Share Ierakstīts Jūlijs 31, 2006 Sveiki. Ko jus teiktu par manu izveli Varbut kas ir labaks par so cenu ( 50ls ) TRUST 450W POWER SUPPLY UNIT PW-5200 Technical Specifications 450 real Watt power supply unit Form factor: ATX 12Volt v2.01 120 mm ball bearing fan Noise level 22 dB(a) Input voltage: 220 - 240 VAC Motherboard connector: 24 pin (detachable to 20 pin) 4-pin 12V2 connector (compatible with Intel socket 775) 6x peripheral, 2x floppy drive, 4x S-ATA connectors Including PCI Express 6-pin VGA connector for powering your power consuming PCI card(s) (meets high-end PCI exp.150W req.) Passive Power Factor Correction (PFC) Temperature controlled fan: 1000 - 1700 RPM Easy removable grip connectors Cables protected by cable harnass TÜV, NEMKO, CE LVD and CB approved Product size (H x W x D in mm): 85 x 150 x 140 Paldies jau pasaku ieprieks. Link to comment Share on other sites More sharing options...
Gigenieks Jūlijs 31, 2006 Share Jūlijs 31, 2006 kapēc taisi vairākas identiskas tēmas :evil: ? :twisted: Link to comment Share on other sites More sharing options...
joks7 Jūlijs 31, 2006 Share Jūlijs 31, 2006 Droši ka nogļukoja inets! Link to comment Share on other sites More sharing options...
