Guest Praktiskais Ierakstīts Februāris 3, 2006 Share Ierakstīts Februāris 3, 2006 Nu nekadigi netieku datora (10.10.10.2) IIS (80 portam klat). Vai kads varetu man palidzet noskaidrot kur problema? ip cef no ip dhcp use vrf connected ! ip dhcp pool sdm-pool import all network 10.10.10.0 255.255.255.248 default-router 10.10.10.1 dns-server 159.xxx.xxx.65 159.xxx.60.20 lease 0 2 ! ! ip name-server 159.xxx.xxx.65 ip name-server 159.148.60.20 ip inspect name SDM_LOW cuseeme ip inspect name SDM_LOW dns ip inspect name SDM_LOW ftp ip inspect name SDM_LOW h323 ip inspect name SDM_LOW https ip inspect name SDM_LOW icmp ip inspect name SDM_LOW imap ip inspect name SDM_LOW pop3 ip inspect name SDM_LOW netshow ip inspect name SDM_LOW rcmd ip inspect name SDM_LOW realaudio ip inspect name SDM_LOW rtsp ip inspect name SDM_LOW esmtp ip inspect name SDM_LOW sqlnet ip inspect name SDM_LOW streamworks ip inspect name SDM_LOW tftp ip inspect name SDM_LOW tcp ip inspect name SDM_LOW udp ip inspect name SDM_LOW vdolive ! ! username admin privilege 15 password 0 Password ! ! ! ! ! ! interface Loopback0 description $FW_INSIDE$ ip address 200.200.100.1 255.255.255.0 ! interface FastEthernet0 description WAN$FW_OUTSIDE$$ETH-WAN$ ip address 159.xxx.xxx.103 255.255.255.192 ip verify unicast reverse-path ip nat outside ip inspect SDM_LOW out ip virtual-reassembly duplex auto speed auto ! interface FastEthernet1 no ip address duplex auto speed auto ! interface FastEthernet2 description LAN-1 switchport trunk native vlan 2 switchport mode trunk ! interface Vlan1 description Management interfeiss$FW_INSIDE$$ETH-SW-LAUNCH$$INTF-INFO-FE 2$ ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! interface Vlan2 description LAN-1.1 ip address 10.10.10.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Async1 no ip address encapsulation slip ! ip classless ip route 0.0.0.0 0.0.0.0 159.xxx.xxx.126 permanent ip route 10.0.0.0 255.0.0.0 10.10.10.0 ip route 10.10.10.0 255.255.255.0 10.10.10.0 ! ! ip http server ip http port 8080 ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 3 interface FastEthernet0 overload ip nat inside source static tcp 10.10.10.2 80 interface FastEthernet0 80 ! ip access-list standard access-list permit any ! access-list 1 remark SDM_ACL Category=2 access-list 1 permit 10.10.10.0 0.0.0.255 access-list 2 remark SDM_ACL Category=2 access-list 2 permit 10.10.10.0 0.0.0.255 access-list 3 remark SDM_ACL Category=2 access-list 3 permit 10.10.10.0 0.0.0.255 access-list 101 permit tcp any host 159.xxx.xxx.103 eq www no cdp run ! ! Link to comment Share on other sites More sharing options...
