Guest atis Ierakstīts Jūlijs 9, 2004 Share Ierakstīts Jūlijs 9, 2004 checking for g++... g++ checking for C++ compiler default output file name... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for a BSD-compatible install... /usr/bin/install -c checking for gawk... gawk checking for pkg-config... /usr/bin/pkg-config [color=darkred]checking for mozilla-plugin... Package mozilla-plugin was not found in the pkg-config search path. Perhaps you should add the directory containing `mozilla-plugin.pc' to the PKG_CONFIG_PATH environment variable No package 'mozilla-plugin' found configure: error: Unable to find gecko sdk[/color] ???? Link to comment Share on other sites More sharing options...
GonZOo Jūlijs 9, 2004 Share Jūlijs 9, 2004 Cik saprotu tas ir W$ Media playera sajukshana ar Uguns lapsu ? Eu! es sev arii tadu gribu ka saucas!!! Link to comment Share on other sites More sharing options...
Guest shal3r Jūlijs 9, 2004 Share Jūlijs 9, 2004 Cik saprotu tas ir W$ Media playera sajukshana ar Uguns lapsu ?Eu! es sev arii tadu gribu ka saucas!!! Nee... ir taads visu laiku labaakais video pleijeris - "mplayer for linux". Paraadi man kaadu aatraaku/stabilaaku un es tev uzlikshu alinju . mplayerplug-in ir mplayer modifikaacija prieksh mozilla saimes paarluukiem Link to comment Share on other sites More sharing options...
Guest atis Jūlijs 15, 2004 Share Jūlijs 15, 2004 Nu nedienas man ar to pluginu. Tagad tv.lv skan bet nerāda. Nu manuprāt nav kautkas tur ar tiem kodekiem. Nevajag vinam tos kodekus kautkādus vēl papildus salikt? Un kur viņus īsti jāliek, lai mplayers atrod? Link to comment Share on other sites More sharing options...
Guest atis Jūlijs 15, 2004 Share Jūlijs 15, 2004 Jā, kodekus vajadzēja pieāķēt. Viss rullz, tikai nesaprotu, kurš gudrītis izdomāja tam pluginam laika skaitīšanu uz bildes uzlikt. Dīvaini tie izstrādātāji... Link to comment Share on other sites More sharing options...
