DIY lampu pastūzis austiņām - Aegis
MarisO
Vai kāds no bootistiem strādā pie šāda te pastūža?  Tas laikam ir labs?  Kāds ir jūsu viedoklis par to?
https://www.head-fi.org/threads/aegis-diy-tube-headphone-amplifier.965530/
https://www.diyaudio.com/community/threads/aegis-diy-tube-headphone-amplifier.399473/#post-7354944
pxl_20230310_231254258-jpg.1175520
Aegis is a two-stage transformer coupled single-ended amplifier. It features a tube-rectified
CLCRCRC linear power supply, a choke-loaded cathode-biased 6SL7 gain stage that is capacitor coupled
to a triode-strapped power pentode output stage. While Aegis is compatible with several power pentodes,
EL34 will be referred to for the remainder of the document. The most notable feature of the amplifier is
its output stage as power pentode is wired as a cathode follower with the output transformer in its
cathode. Because the cathode follower power stage does not provide any voltage gain, all of the voltage
gain for the amplifier is generated by the 6SL7 input stage. However, a transformer-coupled cathode
follower power stage provides lower distortion and a lower output impedance relative to a conventional
series feed power stage. In addition, it removes the need for a cathode bypass capacitor common in
cathode-biased series feed output stages. The output transformer has taps for both low impedance
headphones (32-150ohms) and high impedance headphones (150ohms+). It generates roughly 2W into
32ohms on the low impedance setting, and 2W into 150ohms on the high impedance setting.
Edited by MarisO
Viedoklis - priekš kam austiņām tādu monstru?
  • Atbalstu 2
Ar manu pastūzi tur bija tāda problēma, ka tas ģenerēja troksni (50hz laikam) vienā kanālā (labajā).
Tad es apmainīju vietām tube heater vadus (tie iet no barošanas trafa) , right power tube <-> 6SL7 tubes heater un tas palīdzēja.
( to ieteica šī pastūža shēmas autors )
Vai tas nozīme, ka mans barošanas trafs ir defektīvs?
Edited by MarisO
pirms 5 stundām , ivo teica:
Priekš https://www.modhouseaudio.com/tungsten/tungsten
esot ideāls pastūzis  (tā vismaz iekš headfi saka).  Sensitivity: 76db/mW
Man gan nav tagad nekādas planar magnetic austiņas.   Bet nu mani ZMF skan lieliski.
Edited by MarisO
Montējot rodas parazītiskās kapacitātes un induktivitātes. No tā arī maiņstrāvas fons vai pat ģenerācija.
Ar tiem transformatoriem jau arī lampu entuziasti visādi eksperimentē. Piemēram, starp tīkla primāro tinumu un sekundāro tinumu ir satīta elektriski izolēta folija ar izvadu, ko vieno pie masas.
Gan jau kvēli lampai var padot arī līdzstrāvas veidā, tikai, ja prasti liks tiltiņu un kondensatoru, tad tā kvēle būs niknāka, tur jādarbojas ar tinumu skaitu vai kādu papildu pretestību.
Lampu pastūžu barošanas un izejas trafi ir vesela biznesa nozare.
https://www.vivatubes.com/transformers/
https://www.evatco.com.au/transformers/
https://www.diyaudio.com/community/threads/toroidal-transformer-on-tube-amp.206186/
https://www.antekinc.com/as-8t650-tube-amp-transformer/
https://www.toroidal-transformer.com/shop/high-end-audio/power-transformers/311/1n1729-power-transformer-for-tube-amplifiers--22va-.html
https://www.toroidal-transformer.com/shop/high-end-audio/output-transformers.html
Edited by Raimonds1
Pirms 24 minūtēm , MarisO teica:
Man bija tranzistoru jaudas pastiprinātājs un tam ieejā biju salicis pagarus vadus un tad nu vienā knālā tas uztvēra kaut kādu garo viļņu staciju!
Es jau domāju, ka šī reliģija ir zudusi nebūtībā. Izrādās, ka nē. 🤣
Šādas lampas
Nez, ko nozīmē tas Ia=42.0 (nu gan jau mA)
Edited by Jurkins
Daudzas austiņas (ZMF ir 300 omi) neskan nemaz tik labi, ja tās lieto ar low impedance solid state pastūzi.
Edited by MarisO
Nu tak saproti, ka 300 omu austiņas nevar izkustināt ar 5V barošanu.
Un tur ņepričom ne solid state ne low impedance.
Edited by Jurkins
Tas nav dēļ barošanas.  Ir pastūži , kuriem output impedance var pārslēgt.   Man bija tāds ECP T4.
Krietni labāka skaņa ir high-z režīmā (300 omu ausīm).   Ko tad viņam mainās skaņa.  Aegis ir tāpat.
Paskat kautvai šo video
Edited by MarisO
Nu pretestība ir atšķirīga.
Visi taču tā saka, ka pastūža output impedance "ideāli" ir 1/8 no austiņu impedance.   Vai tad tas ir izdomājums?
output impedance lampiniekiem (īpaši OTL) ir lielāka nekā solid state pastūzim, kuriem tā bieži ir zem 1 oma.
Vai tad tas nav iemesls kāpēc 300 omu ZMF ausis neskan tik lieliski ar tādu pastūzi , kuram output impedance ir 1 oms?
Tad tur tā attiecība ir 1/300, kas ir radikāli atšķirīgs no 1/8.
Edited by MarisO
Ak dievs! Šausmas. Fiziku skolā nemācīja? 🤣
Ja pastūzim barošana ir 5V (PC un citi tagadējie krāmi), tad var dabūt max amplitūdu < 2.5V (tiltā <5). Tas ir amplitūdas jaudu uz 300 omiem 0.02W (tiltā 0.08) Un, protams, ka tās ausis ņihuja neskan. Un visas šitās huiņas par output impedance atstājiet marketopederastiem.
Paņem normālu pastūzi ar +/-25V barošanu, pieslēdz 300 omu ausis un priecājies.
Edited by Jurkins
  • Atbalstu 1
Domā, ka tās ir muļķības, kas piemēram ir šeit:
Damping factor, the ability of the amp to physically control the driver is determined by the ratio of the output impedance of the amp to the impedance of the headphones.
Vai tam damping factor nav nekādas nozīmes?  Manuprāt, tur ir pamatoti izskaidrots kāpēc tas nav mazsvarīgi.
Pirms 44 minūtēm , MarisO teica:
Nevis ideaali ar 1/8 austinju pretestiibu, bet 1/8 vai zemaaku. Kaada jeega taisiit pastiprinaataaju, kas skanees tikai ar 300 omu ausiim, ja ir labi pastiprinaataaja (OI zem 1 oma), kas vienliidz labi kustinaas gan 10, gan 600 omu ausis... nu jaa, lampu tur nebuus.
Vienlīdz labi?   Tā ideja, ka 300 omu austiņām ir labāk lietot pastūzi ar augstākiem omiem ir ļoti populāra "audiofīļu" vidū.
ZMF speciāli uztaisīja pastūzi ar 47 omiem (dēļ 300 omu austiņām):   https://shop.zmfheadphones.com/products/homage
Skaņa diezgan būtiski mainās, ja pastūzim tie omi ir pārslēdzami un tos pamaina.  Varbūt, ka tur mainās vēl kādi parametri.
Reku šim pašam Aegis tos omus var pārslēgt, lai tas būtu piemērots gan zemu omu, gan augstu omu austiņām.
Kāpēc ta tos vajag pārslēgt?
Man bija šāds te ECP pastūzis.  Viņam tā skaņa bija meh , ja tas bija ieslēgts uz zemajiem omiem.
Edited by MarisO
Pastuuzis ar augstu OI kombinaacijaa ar nepiemeerotaam ausiim dod aaraa nelineaaru frekvenchu joslu, kas, iespeejams, kkaadaa gadiijumaa uz ausi skanees labaak kaa lineaaraa frekvenchu josla. Sava veida EQ - "tube magic". Domaaju, ka to visu var nomeeriit.
pirms 6 stundām , jozhix teica:
Pasarg, dievs! Tu visu fīlingu šitā sasipīsi.
Edited by Jurkins
  • Haha 1
pirms 11 stundām , Raimonds1 teica:
Nobildē to visu tumsā.
Jā, un pastiprinātāju nemaz iekšā neslēdz, lai plašāka tēma diskusijai.😀
pirms 7 stundām , MarisO teica:
Kāpēc tam ir piecas izejas ar dažādiem omiem?   Cilvēki saka, ka ir nozīme kurā izejā austiņas tiek ieštepselētas.
Nu tak paskaties pats. Un tad iedomājies Rizejas vietā vietā kompleksu Zizejas un R slodzes vietā kompleksu Zslodzes.
Veči, vai tad neziniet, ka mērījums ietekmē procesu. Kā ar to elektronu un divām spraugām. Vot nomēri pastiprinātāju un fīlings pazūd.
Edited by Jurkins
Ir labi, ka ir tāds hobijs. Tur ir daudz ko darīt un kā izvērsties.
Nedaudz pamatu. Nekādas skaņas, tikai baterijas un lampas.
24 voltu 24 vatu pretestība pie 24 voltu barošanas. Strāva 24/24=1 ampērs. Jauda 24 volti reiz 1 ampērs = 24 vati. Pretestība ir 24 volti dalīts ar 1 ampēru ir 24 omi.
Tā pati pretestība 12 voltiem.24 omu pretestība pie 12 voltiem. Strāva 0.5 ampēri. Jauda 12 volti reiz 0.5 ampēri ir 6 vati.
Tas viss līdzstrāvai, nekādas maiņstrāvas, nekāda transformatora.
Ar transformatoru var pastiprinātāja izejas spriegumu gan samazināt, kai tas darbina zemomīgas tumbas no lampu pastiprinātāja, gan paaugstināt, lai tas darbina augstomīgas austiņas no zema sprieguma tranzistoru pastiprinātāja. To gan parast nedara.
Tai pamatteorijā ir kadi pārdesmit šādi te sīkumi, ko vajadzētu pastudēt.
Bija kaut kāda shēma, kur lampu pastiprinātāju būvētāji bija izdomājuši, ka tas izejas trafs tak maitā to skaņu un vai kaut kā nevar to zemomīgo slodzi ieslēgt izejā vispār bez transformatora. Ja pareizi atceros, tur bija kaut kādas lieljaudas lampas, ļoti zems anodspriegums, tilta slēgums, jaudas zudumi un vai tik, nebija arī pārtinuši skaļruņa spoli ar tievāku vadu, lai lielāka pretestība. Vai arī bija piemeklējuši kaut kādu īpašu skaļruni.
pirms 6 stundām , Didzis teica:
Nu patīk audiofīliem tie lampu pastiprinātāja specifiskie kropļojumi un ''siltā'' skaņa. Tas gan galīgi nenozīmē, ka lampinieks precīzi skan tapat, kā studija skaņu režisors to vēlējies.
Jā, protams, tā ir gan.   Tās ZMF austiņas arī ir uztjūnētas tā, lai "labāk" (nevis lineāri un pareizi) skan.  Nevienu neinteresē, ko skaņu režisors ir vēlējies. 👍
pirms 3 stundām , Raimonds1 teica:
Tas ir OTL - output transformer less pastūzis.  Tādu ir daudz. Arī ZMF tāds ir https://shop.zmfheadphones.com/collections/amps-dacs/products/decware-zmf-otl
Edited by MarisO
  • Atbalstu 1
pirms 10 stundām , jozhix teica:
Manuprāt tas damping factor ietekmē arī decay - cik ātri tā skaņa mainās.    ZMF austiņām arī koks (tā cietība) to ietekmē. 👍
Pirms 52 minūtēm , MarisO teica:
ZMF austiņām
ZMF, protams, taisa skaistas lietas. Interesanti, ka The Headphone Show vairaaki modelji tika ljoti augsti noveerteeti, kameer ASR ne par Atticus ne Caldera meeriijumiem nebija sajuusmaa. Es taa sapratu, ka vinji tur izdomaa pashi savas liiknes.
Un vispār jau arī katra indivīda dzirde nav nekāds lineārais frekvenču diapazona uztvērējs.
Kāds tjūnings padomā - skaņas līmeņa indikatori, kvēles un anodsprieguma soft starts vai vēl kas?
