SADP Application Error (0xc000007b)
Gatis Veinbergs
Ok var tulkot latviski kā Labi. Tas, ja nesaproti kur tagad jāspiež.
Nepieciešams vairāk informācijas.
Gatis Veinbergs
Pirms 9 minūtēm , e = d teica:
Savas asprātības vari paturēt pie sevis.
Ir nepieciešama programma kuru datorā lejupielādēju un uzinstalēju ,bet nevaru palaist dēļ ši errora !
Kas par programmu?
Vai vispār ir strādājusi uz win 11?
Vaitad google vairs nestrādā
There are many reasons behind the Windows error code 0xc000007b and this part lists the most common ones.
The error code means an invalid image format. Specifically, you are attempting to start an application which is designed to run on 64-bit operating system. But your computer is running 32-bit Windows. The 32 bit application cannot load a 64 bit dll, thus the mixing up 32 bit with 64 bit environment brings about problem.
0xc000007b error is also has something to do with programs installed on your computer such as .NET Framework, Direct X and Microsoft Visual C++. It tends to appear when you try to launch high graphic games like Far Cry Assassins without updating to .net Framework. When .NET framework is absent from your computer, you'll not be able to run apps build on it.
Labots - AndrisBB
Pirms 3 minūtēm , jema teica:
C++ paka
Vajadzētu līdzēt, piekrītu.
Taču kļūda bija cita, ja liek bez C++.
Manā gadijumā problēmu atrisināja abas x86/x64 instalācijas.
https://support.microsoft.com/lv-lv/topic/update-for-visual-c-2013-redistributable-package-d8ccd6a5-4e26-c290-517b-8da6cfdf4f10
