HELP! Nobruka disks
Lieta
Kurš varētu palīdzēt savest kārtībā cietni, nep..išot datus?
# gdisk -l /dev/sda
GPT fdisk (gdisk) version 1.0.5
Warning! Disk size is smaller than the main header indicates! Loading
secondary header from the last sector of the disk! You should use 'v' to
verify disk integrity, and perhaps options on the experts' menu to repair
the disk.
Caution: invalid backup GPT header, but valid main header; regenerating
backup header from main header.
Warning! One or more CRCs don't match. You should repair the disk!
Main header: OK
Backup header: ERROR
Main partition table: OK
Backup partition table: ERROR
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/sda: 17579413694 sectors, 8.2 TiB
Model: WDC WD100EFAX-68
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): E965D649-FADC-4450-BB9A-EA0B7E6191DE
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 2048, last usable sector is 19532873694
Partitions will be aligned on 2048-sector boundaries
Total free space is 0 sectors (0 bytes)
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048       671090687   320.0 GiB   8300
   2       671090688     19532873694   8.8 TiB     8300
Ir:
Jābūt
Disk /dev/sda: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors
Šobrīd sanāk, ka otrā partīcija ir lielāka par disku.
Ko smārts rāda?
Labais tonis ir klonēt uz citu disku ar piem. ddrescue un tad mocīt kopiju.
Labi, ka tad, kad ar šito čakarējos vēl nebija 6TB+ hdd :)
Ir arī gadījies ka kabelis gļukains.
Smārts rādīja šo:
root@lieta:/home/lieta# smartctl -a /dev/sda
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.11.0-38-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD100EFAX-68LHPN0
Serial Number:    JEJ5YALM
LU WWN Device Id: 5 000cca 267dee302
Firmware Version: 83.H0A83
User Capacity:    9 000 659 811 328 bytes [9,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Nov 23 17:16:48 2021 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
Bet es jau pats sāku niekoties ar to disku. Izpildīju sekojošo:
# hdparm -N /dev/sda
/dev/sda:
 max sectors   = 17579413694/19532873728, HPA is enabled
# hdparm -N p19532873728 /dev/sda
/dev/sda:
 setting max visible sectors to 19532873728 (permanent)
 max sectors   = 19532873728/19532873728, HPA is disabled
un aizlaidu viņu pavisam pie dieviem. Šobrīd viņu pat BIOS vairs neredz.
Domāju ka nekas traģisks vēl nav noticis. Nestreb karstu ar šīm lietām, bišķi vairāk pagūglē un palasi.
Ja dati svarīgi tad nes vien datu atjaunošnas specam,
man ļoti labi ir palīdzējis Tritons 29413995 20+ gadus darbojas šajā biznesā  Bet lēti nebūs par šiem lielajiem diskiem.
pirms 9 stundām , ImissimI teica:
Šķiet, ka tev taisnība. Nomainot kabeli disks aizgāja.
  • Haha 2
Es pa šo frumu agrāk rakājos, kad vajadzēja kādas cietā diska mistērijas risināt - https://forum.hddguru.com/
Tur var diezgan padziļinātu info izkast.
Kabeļa nomaiņa arī sākotnējo problēmu atrisināja?
Palaid smārta testu kaut vai -t short un iemet reportu.
pirms 1 stundas , ImissimI teica:
Iespējams, ka sākotnējo problēmu atrisināja
$ sudo smartctl -a /dev/sda
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.11.0-40-generic] (local build)
User Capacity:    10 000 831 348 736 bytes [10,0 TB]
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Nov 24 16:36:11 2021 EET
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (1105) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   129   129   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   168   168   024    Pre-fail  Always       -       425 (Average 360)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       33
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       22328
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       919
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       919
194 Temperature_Celsius     0x0002   154   154   000    Old_age   Always       -       42 (Min/Max 22/58)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     22328         -
# 2  Short offline       Completed without error       00%     22321         -
# 3  Short offline       Completed without error       00%     22312         -
# 4  Extended offline    Interrupted (host reset)      90%     22310         -
# 5  Short offline       Completed without error       00%     22304         -
# 6  Short offline       Completed without error       00%     22280         -
# 7  Short offline       Completed without error       00%     22256         -
# 8  Short offline       Completed without error       00%     22232         -
# 9  Short offline       Completed without error       00%     22207         -
#10  Extended offline    Completed without error       00%     22205         -
#11  Short offline       Completed without error       00%     22183         -
#12  Short offline       Completed without error       00%     22159         -
#13  Short offline       Completed without error       00%     22135         -
#14  Short offline       Completed without error       00%     22111         -
#15  Short offline       Completed without error       00%     22087         -
#16  Short offline       Completed without error       00%     22063         -
#17  Short offline       Completed without error       00%     22039         -
#18  Extended offline    Completed without error       00%     22036         -
#19  Short offline       Completed without error       00%     22015         -
#20  Short offline       Completed without error       00%     21991         -
#21  Short offline       Completed without error       00%     21967         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
jautājums tikai, kurš to HPA tam diskam tur uzmeta.
agrāk bija manītas plates, kur BIOS taisija mazu HPA un pirmā diska, lai būtu kur backupus likt..
bet nu te jau 1TB..
