Stagars 2 Posted March 9, 2018 Share Posted March 9, 2018 Vai iespējams kur atrast draiverus HP LASERJET 6L printerim priekš Window 7 / 64. Man kaut kā neizdodas. 1 Quote Link to post Share on other sites
snukurins 44 Posted March 9, 2018 Share Posted March 9, 2018 Izskatās ka viņam vispār nekad nav bijuši 64bitu draiveri. Ar šo iebūvēto neiet? Quote Link to post Share on other sites
snukurins 44 Posted March 9, 2018 Share Posted March 9, 2018 Atradās vēl šāds: Instructions for Installing HP Laserjet 6l on Windows 8 or 10 Computer 1. Before doing anything, click on "Windows Update" and let it run (takes a few minutes). If you didn’t have the correct driver before then that should give it to you. 2. Control Panel - Devices and Printers 3. Click on "Add a Printer" 4. Click on "The printer that I want isn't listed" 5. For "Parallel to USB" connection, choose "Add a local printer or network printer with manual settings" 6. Pick an existing port. I use a cable that has LPT port (Parallel plug) at one end, USB at the other end. So my choice is USB001 (Virtual printer port for USB). Change it if it says “LPT 1” if necessary. 7. Now you see the list of manufacturers and models. 8. Select HP as the model, and select HP "LaserJet 6L" as the printer. Without Windows Update, it will only show "HP LaserJet 6 PS Class Driver", which causes the problem. Stick to "HP LaserJet 6L" 9. The rest is straight forward. Print a test page and check if it comes out right. If the above doesn’t work, try swapping USB ports on computer (USB 2 to USB 3 or vice-versa). The above was successful for me in Windows 10, 64bit. 1 Quote Link to post Share on other sites
Stagars 2 Posted March 9, 2018 Author Share Posted March 9, 2018 Kaut kā neizdodas. 1 Quote Link to post Share on other sites
