Homer J. Simpson Ierakstīts Septembris 16, 2014 Share Ierakstīts Septembris 16, 2014 Radās doma palielināt ram no esošajiem 4gb uz 8gb, bet ir dažas neskaidrības - labāk esot, ja ram darbojas dual channel, bet tad tiem jābūt pilnīgi vienādiem? vai arī var ņemt tādu pašu pēc specifikācijām, bet cita ražotāja? Kā arī kam ir jāpievērš uzmanība, lai nenopirktu tādu, kas neder, piemēram, ir non ecc, ar ecc, non buffered, buffered utt. plate gigabyte ga-h61m-s1 rev 3.0 2 ram sloti, viens brīvs no ražotāja lapas 2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB. Dual channel memory architecture Support for DDR3 1333/1066/800 MHz memory modules Support for non-ECC memory modules Support for Extreme Memory Profile (XMP) memory modules * To support XMP memory, you must install an Intel 22nm (Ivy Bridge) CPU. tagad vienā slotā stāv šāds : Link to comment Share on other sites More sharing options...
intervall Septembris 16, 2014 Share Septembris 16, 2014 Tak nopērc identisku moduli. Var likt jebkādu, skaties, lai ir vienādi taimingi, frekvences,ss vai ds. Tev vajag non-ecc,unbuffered. Link to comment Share on other sites More sharing options...
Homer J. Simpson Septembris 16, 2014 Author Share Septembris 16, 2014 šāds derēs ? http://www.ebay.co.uk/itm/4GB-1x4GB-DDR3-1600MHz-PC3-12800-Non-ECC-Unbuffered-240-pin-Desktop-Memory-RAM-/321461854566?pt=UK_Computing_ComputerComponents_MemoryRAM_JN&hash=item4ad89ea166 Link to comment Share on other sites More sharing options...
MetalOxygen Septembris 16, 2014 Share Septembris 16, 2014 derēs. bet nav pat ebay jāmeklē, redz kur par praktiski to pašu cenu tepat latvijā: http://www.1a.lv/datoru_komponentes/ram_flash_atminas/crucial_4gb_ddr3_pc312800_cl11_ct51264ba160bj Link to comment Share on other sites More sharing options...
Homer J. Simpson Septembris 16, 2014 Author Share Septembris 16, 2014 tas gan, bet ērtāk ir tepat uz pastu aiziet nekā braukt uz Rīgu dēļ viena rama, ja būtu jāsteidzas, tad cita lieta Link to comment Share on other sites More sharing options...
Borja Septembris 16, 2014 Share Septembris 16, 2014 Windows ta kaads? Ja 32bit, tad nav jeegas, vai arii jaapaarinstalee uz 64bit versiju. Link to comment Share on other sites More sharing options...
Homer J. Simpson Septembris 16, 2014 Author Share Septembris 16, 2014 protams, ka 64 bit, ar 32 bit nevarēja pat visus 4gb izmantot, cik atceros Link to comment Share on other sites More sharing options...
raiviic Septembris 16, 2014 Share Septembris 16, 2014 (labots) ērtāk ir tepat uz pastu aiziet nekā braukt uz Rīgu dēļ viena rama Vēl ērtāk ir, ja tev piegādā līdz durvīm. Sen jau man no visiem intrneta veikaliem piegādā mājās un tas nav Rīgā. Protams, uz centu3,14sējiem tas neattiecas . Labots Septembris 16, 2014 - raiviic 1 Link to comment Share on other sites More sharing options...
ggg97 Septembris 16, 2014 Share Septembris 16, 2014 Man no 1A nāk uz pasta staciju - bezmaksas. Bet tas ir tad, ja nav jāsteidzas. Link to comment Share on other sites More sharing options...
nnoname Septembris 16, 2014 Share Septembris 16, 2014 un ja jāsteidzas, tad ko - pats brauc uz mārupi vai maskačku? Link to comment Share on other sites More sharing options...
Rubenis Septembris 16, 2014 Share Septembris 16, 2014 tas gan, bet ērtāk ir tepat uz pastu aiziet nekā braukt uz Rīgu dēļ viena rama, ja būtu jāsteidzas, tad cita lieta Da labi. Pasta stacija - bezmaksas sūtīšana, piegādi līdz durvīm arī var dabūt. Bet ja pasūtīsi no ebay, tad ar garantiju vari nerēķināties. Vietējiem vismaz garantija nāk. Link to comment Share on other sites More sharing options...
ggg97 Septembris 16, 2014 Share Septembris 16, 2014 un ja jāsteidzas, tad ko - pats brauc uz mārupi vai maskačku? Uz Mūkusalas... Link to comment Share on other sites More sharing options...
Homer J. Simpson Septembris 18, 2014 Author Share Septembris 18, 2014 viena lieta tomēr paliek neskaidra kādu form factor jāizvēlas,plates ražotāja lapā ir rakstīts, ka dimm, bet viņi ir vairāki veidi 168 pin, 204 pin un 240 pin, kā lai zina kuru vajag? Link to comment Share on other sites More sharing options...
Rubenis Septembris 18, 2014 Share Septembris 18, 2014 (labots) viena lieta tomēr paliek neskaidra kādu form factor jāizvēlas DDR3 dektop rams 4Gb non-ecc. Kur tu atradi iespēju vēl pinus meklēt, es nezinu. 240 pin, ja tas tev ļauj labāk gulēt. Labots Septembris 18, 2014 - Rubenis Link to comment Share on other sites More sharing options...
