HIGH-Zen Posted April 29, 2024 Share Posted April 29, 2024 Normāls OEM Windows 11 Pro. Uz virtuālās mašīnas arī nav tā wingeta. Link to comment Share on other sites More sharing options...
AndrisBB Posted April 29, 2024 Share Posted April 29, 2024 Nutad vecs Windows If you haven't updated the App Installer in a while, you can face issues in running Winget and managing packages. Winget is included only in version 1.11. 11451 or higher of the App Installer. If you have a version older than that, you cannot use Winget from the terminal. Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 29, 2024 Share Posted April 29, 2024 Zb tas winget-s, kamēr es čakarējos un drudžaini mēģinu atjaunināt Windows-u, tas mierīgi sēž C:\Users\User\AppData\Local\Microsoft\WindowsApps un neliekas ne zinis. Link to comment Share on other sites More sharing options...
AndrisBB Posted April 29, 2024 Share Posted April 29, 2024 Un tev PowerShells vispār 'skatās' tur? (lai atrastu winget) Link to comment Share on other sites More sharing options...
PC_RAT Posted April 29, 2024 Share Posted April 29, 2024 Pirms 12 minūtēm , HIGH-Zen teica: tas mierīgi sēž C:\Users\User\AppData\Local\Microsoft\WindowsApps un neliekas ne zinis. 😄 Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 29, 2024 Share Posted April 29, 2024 Pirms 3 minūtēm , AndrisBB teica: Un tev PowerShells vispār 'skatās' tur? Acīmredzot neskatās. Ja raksta pilnu ceļu, tad viss notiek. Tīri tā neko verķis. 1 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 29, 2024 Share Posted April 29, 2024 echo %PATH% Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 29, 2024 Share Posted April 29, 2024 PS C:\Users\User> echo %PATH% %PATH% PS C:\Users\User> cmd C:\Users\User>echo %PATH% C:\MinGW64\bin; C:\MinGW64\libexec\gcc\x86_64-w64-mingw32\13.1.0; C:\Program Files\Common Files\Oracle\Java\javapath; C:\Program Files (x86)\Common Files\Oracle\Java\javapath; C:\Windows\system32; C:\Windows; C:\Windows\System32\Wbem; C:\Windows\System32\WindowsPowerShell\v1.0\; C:\Windows\System32\OpenSSH\; C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common; C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR; C:\WINDOWS\system32; C:\WINDOWS; C:\WINDOWS\System32\Wbem; C:\WINDOWS\System32\WindowsPowerShell\v1.0\; C:\WINDOWS\System32\OpenSSH\; C:\Program Files\Steel Bank Common Lisp\; C:\Program Files\dotnet\; C:\Program Files\Git\cmd; C:\Python312\Scripts\; C:\Python312\; C:\Users\User\AppData\Local\Programs\Python\Launcher\ 1 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 29, 2024 Share Posted April 29, 2024 Iekš PS jau laikam $env:path Bet nu pieliec pie PATH C:\Users\User\AppData\Local\Microsoft\WindowsApps un būs Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 29, 2024 Share Posted April 29, 2024 Pa lielam tur viss ir winget-a repozitorijā, bet nu šis tas tomēr pietrūkst: Name Id Version ---------------------------------------------------------------------------------------------- Alarm Alarm_is1 2.0.7 Geany-Plugins 1.38 Geany-Plugins 1.38 GoldenDict GoldenDict Unknown K-Lite Mega Codec Pack 17.3.4 KLiteCodecPack_is1 17.3.4 WinCDEmu WinCDEmu 4.1 qBittorrent 4.4.5 qBittorrent 4.4.5 LibreOffice 7.5.3.2 {063CC195-EEF8-4601-89C6-CB18230BD5E6} 7.5.3.2 Avidemux VC++ 64bits {1c2d931a-4f4b-4d12-9868-948693a754b7} 2.8.1 CDBurnerXP {7E265513-8CDA-4631-B696-F40D983F3B07}_is1 4.5.8.7128 nexusfile (5.4.1.5623) {8F8DA566-4D72-4934-865E-214347365EED}} Unknown Latvian (Apostrofs v1.0; punkts) {A4C7BB3F-B150-4C96-951A-74F818673D93} 1.0.3.40 DefenderUI version 1.16 {D60974B4-94D2-4A22-A4B9-4C2E0E264B7B}_is 1 1.16 Detect It Easy Cathy FolderSize (RoteBetaSoftware) HWiNFO64 HxD 1 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 29, 2024 Share Posted April 29, 2024 Cik tur tā darba, pieliec savus repo ar sourcēm usage: winget source [<command>] [<options>] The following sub-commands are available: add Add a new source list List current sources update Update current sources remove Remove current sources reset Reset sources export Export current sources Link to comment Share on other sites More sharing options...
Jurkins Posted April 29, 2024 Share Posted April 29, 2024 pirms 2 stundām , AndrisBB teica: Nutad vecs Windows Man uz 10-tā ir. Pat nezināju, ka tāds ir. Izskatās, ka vajadzēs iemācīties paspēlēties ar šo. Link to comment Share on other sites More sharing options...
INTRASERVERNET Posted April 29, 2024 Author Share Posted April 29, 2024 Kamdel caut PowerShell vai Terminal, ja ir WingetUI? https://github.com/marticliment/WingetUI Link to comment Share on other sites More sharing options...
Jurkins Posted April 30, 2024 Share Posted April 30, 2024 pirms 6 stundām , INTRASERVERNET teica: Kamdel caut PowerShell vai Terminal Īsti vīri tak raksta tikai konsolē 🤣. 1 Link to comment Share on other sites More sharing options...
PC_RAT Posted April 30, 2024 Share Posted April 30, 2024 Pirms 57 minūtēm , Jurkins teica: Īsti vīri tak raksta tikai konsolē Ir jauns trends: The startx command is a handy shell script that will pass on command-line options to the X server for your X sessions 😉 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 pirms 7 stundām , INTRASERVERNET teica: Kamdel caut PowerShell vai Terminal, ja ir WingetUI? https://github.com/marticliment/WingetUI Var jau arī caur UI, ja tā labāk patīk. Bet ja vajag kautko automatizēt, nokompilēt, atinstalēt, pieinstalēt uut, tad UI diezko nepalīdz. Piemēram katru dienu servers kautko uzbuildo, ieliek repo, palaiž Win VM, pieinstalē, kautko, notestē utt. 1 Link to comment Share on other sites More sharing options...
PC_RAT Posted April 30, 2024 Share Posted April 30, 2024 Pirms 10 minūtēm , AndrisBB teica: Bet ja vajag kautko automatizēt, nokompilēt, atinstalēt, pieinstalēt uut Tā jau ir. Link to comment Share on other sites More sharing options...
PC_RAT Posted April 30, 2024 Share Posted April 30, 2024 pirms 13 stundām , Jurkins teica: paspēlēties ar šo. Vajag - vajag - viss jaunais ir jāizprovē. Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 Vispār jau MS pašiem ir pilns ar visādiem rīkiem, kas padara dzīvi vieglāku iekš Win https://learn.microsoft.com/en-us/windows/powertoys/ 1 Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 (edited) Uz virtuālā Win 11 Pro winget nav, bet to var dabūt uzinstalējot WingetUI. WingetUI ir laba fiška Package Bundles, kur var pats ielādēt jau sagatavotu softa sarakstu, lai nav katru reizi no jauna jāmeklē un jāklikšķina. Novērotās winget problēmas ir - neatjauno VLC media player. Visādi citādi abi darbojas, tikai WingetUI ir diezgan lēns. Edit: Tomēr paša veidotie skripti vēl var palīdzēt pieinstalēt programmas, kuras nav repozitorijā un arī nokonfigurēt softu, un ja vajag, tad uzlikt arī zāles (piemēram, Microsoft Office). Edited April 30, 2024 by HIGH-Zen 1 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 (edited) Pirms 16 minūtēm , HIGH-Zen teica: Uz virtuālā Win 11 Pro winget nav, bet to var dabūt uzinstalējot WingetUI. Kā tad nu nav, kur tad es viņu lietoju? Edited April 30, 2024 by AndrisBB Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 (edited) Nomierinies, es runāju par savu versiju. Man jaunākas Win 11 Pro versijas virtuālajā mašīnā (iekš Virtualbox) uzkaras, tāpēc esmu spiests lietot vecāku versiju. Edited April 30, 2024 by HIGH-Zen Link to comment Share on other sites More sharing options...
INTRASERVERNET Posted April 30, 2024 Author Share Posted April 30, 2024 Vispar brinums, ka cilveki vel joprojam lieto tadus K-Lite Codec Pack, CDBurnerXP, WinCDEmu... Respektivi paskatijos no tiem ninite vai ka saucas kir var sataisit savu bundle man der tikai Firefox un Powertoys, vc_rest64, tas ari viss. Citadi tie ir bezjedzigi. 1 Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 Pirms 1 minūtes , INTRASERVERNET teica: Vispar brinums, ka cilveki vel joprojam lieto tadus K-Lite Codec Pack, CDBurnerXP, WinCDEmu... K-Lite Codec Pack - jaunākā kodeku paka kopā ar Media Player Classic. Var lietot VLC vietā. CDBurnerXP - māk ātri izveidot iso failu. WinCDEmu - ja vajag ātri piemontēt iso failu kā fizisku disku. ... Link to comment Share on other sites More sharing options...
INTRASERVERNET Posted April 30, 2024 Author Share Posted April 30, 2024 Lai nu kaa dvix, xvid u.c. divainju formatu era sen jau beigusies, neredzu iemeslu piemeram atseviskam video atskanotajam. Gan ari WinCDEmu, ja vien neizmanto kaut kadus kreisos CD. Varbut esmu parak vecs lai piekakatu datoru ar liekiem su... 1 Link to comment Share on other sites More sharing options...
biivers Posted April 30, 2024 Share Posted April 30, 2024 jau kopš W10 laikiem *.iso montējas caur failu pārlūku :/ Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 Vaitad mūsdienās ir kādi kodeki, kuri pa lielam netiek dekodēti iekš hārdwāres un visas tās pakas ir pilnīgi bezjēdzīgas? 1 stundu atpakaļ, HIGH-Zen teica: tāpēc esmu spiests lietot vecāku versiju. Nu tad tā arī būtu teicis ka lieto vecas versijas, nevis ka specifiski dēļ VM kautkas atšķiras un nav. Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 Pirms 29 minūtēm , biivers teica: *.iso montējas caur failu pārlūku Un kā tu izvēlēsies zem kura burta montēt? Pirms 10 minūtēm , AndrisBB teica: Vaitad mūsdienās ir kādi kodeki, kuri pa lielam netiek dekodēti iekš hārdwāres Tas notiek ārkārtīgi reti, ka trūkst kodeku, bet gadās https://youtu.be/lJQKCih2KLw Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 Pirms 1 minūtes , HIGH-Zen teica: Tas notiek ārkārtīgi reti, ka trūkst kodeku, bet gadās Nu i izmet tādu failu miskastē, lai nevairojas tie kreisie kodeki 😂 1 Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 (edited) Ir pašam gadījies, kad CRACKL@B DVD programmu uzlaušanas info un rīki (neatceros vairs kura gada), tur video bija ar pavisam eksotisku kodeku, kura nebija pat K-Lite Codec Pack-ā, diskā bija atsevišķā mapē, no kuras bija jāinstalē lai vispār varētu kaut ko skatīties. Edit: Tas bija CRACKL@B.DVD.2011.iso TechSmith Screen Capture Codec http://www.techsmith.com/codecs.asp uz šo brīdi tas kodeks ir iekš K-Lite Codec Pack un arī VLC. Edited April 30, 2024 by HIGH-Zen 1 Link to comment Share on other sites More sharing options...
biivers Posted April 30, 2024 Share Posted April 30, 2024 1 stundu atpakaļ, HIGH-Zen teica: Un kā tu izvēlēsies zem kura burta montēt? Disku pārvaldniekā tak var nomainīt. Protams, ja to ir nepieciešams darīt ik pēc 15 minūtēm ,tad varbūt ir cita lieta. 1 Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 (edited) Ok, failu menedžeru kopsavilkums: NexusFile Double Commander Total Commander (maksas) OneCommander (Microsoft Store) Sigma File Manager (Microsoft Store) Multi Commander kāds lieto vēl kaut ko? Vai arī no nosauktajām. Edited April 30, 2024 by HIGH-Zen Link to comment Share on other sites More sharing options...
Guncha Posted April 30, 2024 Share Posted April 30, 2024 Altap Salamander 1 Link to comment Share on other sites More sharing options...
Lin Posted April 30, 2024 Share Posted April 30, 2024 Unreal Commander 1 Link to comment Share on other sites More sharing options...
AndrisBB Posted April 30, 2024 Share Posted April 30, 2024 Kotad Far Manager neviens vairs nelieto? Tam varētu būt pat visjēdzīgākais interfeiss, salīdzinot ar tādu NexuFile, kur acis sāk asīņot uz screenšotu vien paskatoties 😂 1 1 Link to comment Share on other sites More sharing options...
Edis7 Posted April 30, 2024 Share Posted April 30, 2024 Pirms 41 minūtēm , AndrisBB teica: Kotad Far Manager neviens vairs nelieto? No DOSīgajiem menedžeriem es lietoju TC. (Total Commander) Es pat nezinu vai viņš šobrīd >For Free< , bet ir Ok, jo ikdienā nesēžu darbā pie datora. Link to comment Share on other sites More sharing options...
HIGH-Zen Posted April 30, 2024 Share Posted April 30, 2024 29.04.2024. , 12:01, raiviic teica: Vai tai Dark tēmai iespējams melnajam mainīt intensitāti? Visos softos, kur vien iespējams, mainu uz tumši pelēku. Pilnīgi melns un spilgtu krāsu burti nav laba doma, ja mīli savas acis. Tomēr izrādās, ka var. Var mainīt skinu un arī krāsas. View->Skin Tools menu -> Options -> Color tab (Background) Kā piemērs: Neliels apraksts. Help-s. 1 stundu atpakaļ, AndrisBB teica: salīdzinot ar tādu NexuFile, kur acis sāk asīņot uz screenšotu vien paskatoties 😂 Visu var pielāgot. Man personīgi patīk default-ā krāsu tēma. Link to comment Share on other sites More sharing options...
binary Posted April 30, 2024 Share Posted April 30, 2024 1 stundu atpakaļ, Edis7 teica: No DOSīgajiem menedžeriem es lietoju TC. (Total Commander) Es pat nezinu vai viņš šobrīd >For Free< , bet ir Ok, jo ikdienā nesēžu darbā pie datora. TC jau nu gan nav "DOSīgs", turklāt tas nekad(?) nav bijis bezmaksas. 1 Link to comment Share on other sites More sharing options...
Edis7 Posted April 30, 2024 Share Posted April 30, 2024 1 stundu atpakaļ, binary teica: TC jau nu gan nav "DOSīgs" Tādā gadījumā tavuprāt viņš ir? >A DOS, or disk operating system, is an operating system that runs from a disk drive. < 1 Link to comment Share on other sites More sharing options...
raiviic Posted April 30, 2024 Share Posted April 30, 2024 (edited) Pirms 34 minūtēm , Edis7 teica: A DOS, or disk operating system Nu ja tā spried, tad jau visas OS, kuras bootojas no diska, ir "DOSīgas" (pie tam DOS pietika ar disketi)😁. DOSīgs var būt tikai softs, kuru darbināšanai nepieciešams DOS > visi Windows līdz 3.1, Norton Commander, kā tur saucās tas Word priekštecis (baltie burti uz zilā fonā) un vēl kaudze visādu. Edited April 30, 2024 by raiviic Link to comment Share on other sites More sharing options...
