lipka
Kā pareizi sagatavot dekoderi lietošanai.
Viss elementārais ir salikts gan kanāli,gan emulatori,bet nav skaidrs kā tos palaist.Caur zilo pogu piedāvā tikai Common interface.Kur man atrast Emu ? Virsū stāv Black Hole 2.1.0.1 Caur pluginiem arī nepiedāvā.Gisclubu izlasījos krustu šķērsu un nekur to nepiemin.Nesaprotu kā iekurbulēt kaut vai to pašu wicard,vai mgcamd.
laikamTak
Main functions of the buttons on the remote
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Audio menu
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)
Addons
Green button and then Yellow button takes you to:-
Dedicated server for BlackHole addons
Download and install additional packages from the Black Hole server
Infobar / OSD
Analog Clock Gui
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of BlackHole Panels
Blue Panel
Extra Settings
Black Hole Speed Up
Black Hole Cron Manager (Manage schedules)
OSD Settings (OSD configuration)
Devices Manager
Usb Format Wizard
Kernel Modules Manager(Kernel module operator)
Inadyn Settings (Configure Inadyn)
Swap File Settings (Configure File Swap)
Hard Disk Settings (Configure Hard Drive)
OpenVPN Panel ( OpenVPN Panel)
Samba / CIFS Panel ( Samba Panel)
NFS Server Panel ( NFS server Panel)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
1 - Gui Setting (Gui configurations)
2 - Service Information (information system)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Global settings (global settings EPG)
Setting Provider (ISP settings)
Green Panel
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Addons Download Manager (Manager for package downloading)
Online Feeds Settings update
Online Black Hole image update
Manual Install BH packges (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Red Panel
BH Parallel Universe Teleportation
Labots - laikamtak
Tā arī nesaprotu,kā iekurbulēt to EMU.
Iepriekš bija Vu+solo2 un zem zilās pogas viss bija,bet šim nekā :meeting:
Iesaku uzlikt Pli 4.0, un ar multiquick pluginu uzlikt emu uz zilaas pogas. Vienkaarsaak jau ir ielikt emu ar roku, tas ir iekopeet visu savaas vietaas. Bet ar Pli vareesi arii novilkt no pluginiem.
Cik ieprieks esmu iztesteejis visaadus imidzus, esmu viennoziimiigi palicis pie PLI.
Ja Vu+ ir klons tad japiemeklee attieciigo imidzu un nedrigst atjaunot ar pulti softu protams.
Parastam Vu solo klonam no aliexpress derees imidzs no Ferrari.
Ja originaals, tad nem no PLI maajaslapas.
Labots - Aivis2
Man ar šiem Vu+ saskarsme ir tikai otro reizi.Lasot forumus visur slavē BH ,tāpēc ar liku.Kā es varu noteikt origināls,vai ne.Ņēmu no Unisata un teica,ka origināls.Kā saka ticu uz vārda,bet pārliecināties derētu.
PLI mājas lapā images ir beta versijā.Ko tas nozīmē beta.
Un kas var notikt,ja uz klona uzliek originālo versiju?
Te ir salīdzinājumi klons vai origināls!http://satsis.info/res/4143-v-prodazhe-poyavilis-poddelki-vu-solo.html
Tas par Betu!Beta versija ir oficiāli publicēta produkta versija ar vairumu paredzēto funkciju; to izmanto ārējai testēšanai, problemātisku konfigurāciju noteikšanai, ieteikumu un priekšlikumu vākšanai.Un tā tālāk.
Labots - goicis
Tev vienkārši jānokačā emulators ar scriptu skripts jāiemet attiecīgajā mapē , tad caur zilo pogu tev piedāvās  izvēlēties attiecīgo emulatoru
Labots - roko
Uzliku PLI no ofic mājas lapas un viss aizgāja.Značit original.Visi emu darbojas, ātrumi labi.Pārējās lietas paeksperimentēšu.Vienīgais caur Dreamset ieliekot savu kanālu sarakstu,dažiem pazūd signāls.Pa jaunam noskanēt arī neizdodas.Tāda nav un viss.Varētu būt,ka saraksts ir jākārto pa jaunam ,jau no noskanētajiem.
  • 4 years later...
Ir pagājuši daži gadi un laikiem mainoties mainās prasības.Ir vajadzība uz VU+Solo dabūt iekšā virszemes tv kanālus caur USB DVB-T puļķi.Kādreiz bija dabujami VU+USB Turbo Tuner,bet tagad tādus vairs nemana.Pats lietoju VU+Zero ar DVB-T puļķi uz RTL 2832 čipa un viss darbojas nevainojami.Pirmsākumos draiveri vajadzēja iebakstīt ar roku pēc instrukcijas,bet tagad to var novilkt no fiida.Uz VU+Zero tas viss strādā,bet uz VU+Solo nesanāk.Kamī varētu būt vaine un vai ir kāds,kas skatās virszemi uz VU+Solo?
Turbo tuneri var pasūtīt iekš Ebay (pārdevējs no Tallinas, atnāk nedēļas laikā).
Diemžēl viņš vairāk netirgo. Unisatā arī vairs neesot. Toties Lukasā ir https://lukass.lv/foto-un-video/televizori-un-piederumi/satelittelevizijas-komplekti-sat-un-tv-skivji/vu-turbo-usb-dvb-c-t2-hybrid-tuner?p=741449
Uz Uno kastes savā laikā izdevās piekurbulēt DVB-T puļķi ar Microtune AF9135 čipu.
Iekš fīda draiveri dvb-usb-it913x(1.0-r0.11).
Labots - base7
It kā derot visiem modeļiem.
Papildināts. Vajag apskatīties, ja iekš fīda (Openpli, piem.) ir novelkami turbo draiveri, tad būtu jāiet.
Labots - base7
Tiku pie DVB-T Turbo Tuner un viss darbojas uz pirmā.Savukārt RTL2832 neredz.Novilku dažādus draiverus,bet nepalīdz.
Labots - lipka
  • 11 months later...
 Šodien tika rokā tāds aparāts pēc pāršūšanas melns ekrāns, kā labot?
Televizors kā reiz kā nākas, LG UHD. Mēģināju pat caur vadu šūt, nepadevās, tikko sāk 30 sek. Flash complette, sliktākais, ka aparāts nav mans
Izskatās,ka klons!Base7 adresē dotajā mēģināji versiju no Ferrari?
Jā tāpat melna bilde. Izjaucu aparātu domāju ka būc kā 800dreamam sim karte. Ni šiem nav.  Tagad nokačāju backup mēģināšu to iešūt. Līdz tam stāvēja vti 4,1
Mans Solo2 (oriģināls) izskatās, ka atstiepa pekas. Pēc restarta paliek booting... ekrānā un tālāk neiet.
Kad tā gadījās pirmo reizi, uzliku jaunāko BH imagi, visu saliku no jauna un darbojās kādu mēnesi, līdz vienā brīdī atkal tas pats. Atkal pārliku imagi, it kā viss OK, bet pēc pēdējā restarta pēc wicard uzlikšanas, atkal nepamodās.
Nopirku vietā zero 4k un tagad domāju - ir vērts mēģināt reanimēt solo2? Man viņš tomēr labāk patika nekā jaunais zero, kam:
1. nevar HDD ielikt;
2. tikai viens USB ports, kurš aizņemts ar w-fi adapteri;
3. pults IR uztvērējs vadā - diezgan nejēdzīgs un  neērts risinājums;
4. barošanas bloks apvienots ar kontaktdakšu, kas arī manā gadījumā rada zināmas neērtības
Tas, ka viņam 4k man pagaidām neko nedod, jo TV tāpat tikai 720p atbalsta :D
Labots - ivo
  • 2 weeks later...
Pirms 3 minūtēm , osis2 teica:
visu lieko
man jau tur nekā lieka nav. Ok, bija 2 softcami, pietiek ar vienu.
Vakar uzliku svaigu open Vix, viss it kā ok, ielādējas būs jāsaliek visi settingi un jāpatestē pie TV.
Bet nu, kaut kāds fizisks defekts tur tomēr droši vien ir, jo visu laiku atmiņas pietika un pēkšņi nepietiek.
2020.12.7. , 10:10, ivo teica:
Es arī iedomājos, ja man siet grīstē vecais Uno, vai vispār vērts mūsdienās pirkt kādu dārgo aparātu, ņemot vērā IPTV popularitāti. Agrāk skatijos uz Uno 4K (dēļ HDD), bet tagad vairāk sliecos uz kādu lēto Zero rev.2 vai Zero 4K. Tiesa, viņiem atkal nav ne usb pietiekamā daudzumā, ne HDD ieliekams.
Pirms 14 minūtēm , base7 teica:
Jā, tā diemžēl ir, un nav arī iebūvētā wi-fi. Būtu vismaz 2 gab. USB paredzējuši.
Bet maksāt gandrīz 2x lielāku ciparu par Uno 4k neredzēju jēgu.
Viens tuneris man pietiek un var pieslēgt USB hubu, ja vajag ārējo flešku iespraust. Citādi vienīgais USB ports aizņemts ar W-Fi adapteri.
2020.12.22. , 10:41, base7 teica:
Jā,nekur pagaidām sat tv  nepazudīs un aparātu ražotāji zina,ko vajaga skatītājam...
Labu laiku atpakaļ pārdevu solo2 un solo 4K un vietā nopirku Openbox  AS4K Pro CI UHD(adrioid),bet sapratu,ka beigās tomēr pietrūks enigmas 2 ar ko paspēlēties-pavadīt brīvo laiku un noriskēju pa labu  dreambox one-esmu apmierināts...Ieslēdzot mani laipni aicina,ko vēlos DreamOS vai Android SDcard un strādā labi.Protams ir plusi un mīnusi,bet entuziasti pie tā visa strādā...
Labots - kapars71
  • Atbalstu 1
