Armands_79 Ierakstīts Novembris 19, 2013 Share Ierakstīts Novembris 19, 2013 Sveiki!Vēlētos uzzināt ekspertu viedokli par to kāds recīvers būtu piemerotāks šada tipa akustiskajām sistēmām.Doma saslēgt visas septiņas kopā. Tātad 7.1 tipa recīvers vajadzīgs? Vai kāds var minēt kādu konkrētu modeli, kāds būtu labāks?-------------------------------------------------------------------------------------------------http://www.backoffice.be/prod_uk/Eltax/10400_eltax_silverstone_220_left_right_čannel_speakers_.asp----------------------------------------------------------------------------Product Description Eltax Silverstone 220 - left / right čannel speakersProduct Type Left / right čannel speakersDimensions (WxDxH) 22 cm x 23.5 cm x 79 cmWeight 9.6 kgMedia Type 2 speakersSpeaker Type 2-way - passiveNominal (RMS) Output Power 100 WattMax Output Power 200 WattResponse Bandwidth 45 - 20000 HzInput Impedance 4/8 OhmConnectivity Tečnology WiredSpeaker System Details 2 x right/left čannel speaker - 45 - 20000 Hz - 4/8 Ohm-------------------------------------------------------------------------------------------------http://www.eltax.com/en/model/228_Universe-5-pack.html------------------------------------------------------------------------------------SPECIFICATIONSRecommended amplifier: Up to 130 Watt per čannel.FrontSystem: 3-way bass reflexLong term max power: 100 WattŠort term max power: 200 WattFrequency range (+/- 4dB): 45 Hz - 20 kHzSensitivity (2,83V / 1M): 88 dBImpedance: 4-8 OTwēter: 25mm, soft domeMidrange: 165mmWōfer: 165mmRearSystem: 2-wayLong term max power: 40 WattŠort term max power: 60 WattFrequency range (+/- 4dB): 70 Hz - 20 kHzSensitivity (2,83V / 1M): 88 dBImpedance: 4-8 OTwēter: 19mm, soft dome neodyniumWōfer: 100mmCenterSystem: 2-wayLong term max power: 70 WattŠort term max power: 120 WattFrequency range (+/- 4dB): 80 Hz - 20 kHzSensitivity (2,83V / 1M): 88 dBImpedance: 4-8 OTwēter: 25mm, šielded soft domeWōfer: 2 x 100mm šieldedPaldiess Link to comment Share on other sites More sharing options...
alusbundza Novembris 19, 2013 Share Novembris 19, 2013 rešu piedāvājums taču netrūkst, lietoti, jauni, pērc vienu nost un spraud tās tumbeles klāt lētā gala reši pārsvarā visi vienādi sūdi....un der tikai filmu skatīšanai Link to comment Share on other sites More sharing options...
spainiss2 Novembris 19, 2013 Share Novembris 19, 2013 Jā,no lētā gala visi vienādi būs. Pēc 400 eiro jau ir jāskatās,kas lācītim vēderā! Link to comment Share on other sites More sharing options...
Armands_79 Novembris 19, 2013 Author Share Novembris 19, 2013 Kāda brenda recīveri būtu labāki? Harman Kardon, Onkyo, Marianz? Vēlams virs 100 w uz kanālu? Link to comment Share on other sites More sharing options...
Konstatators Novembris 19, 2013 Share Novembris 19, 2013 (labots) Nu rešu spečoki, iesakiet cilvim kādu foršu 20kg resi par 2 štukām baksu ar reāliem 100w uz kanālu... Vaig takš, vaig vismaz simtu, zinies... Labots Novembris 19, 2013 - Konstatators Link to comment Share on other sites More sharing options...
Fruzz Novembris 19, 2013 Share Novembris 19, 2013 Kas tas ir recīvers? Link to comment Share on other sites More sharing options...
spainiss2 Novembris 19, 2013 Share Novembris 19, 2013 Yamahas piektā sērija jebkura gada modelis būs ar atliektiem galiem tām tumbiņām... Link to comment Share on other sites More sharing options...
Andromedi4 Novembris 21, 2013 Share Novembris 21, 2013 (labots) Sveiks, varu savejo xxxxxxxxxxxxxxxx pardot pa XX LVL. tam ir 5.1 un otra zona vel divam tumbam. ta ka varesi pieslegt visas 7.1 . ja interese raksti... Pārdošanas sludinājumiem ir sava vieta forumā. Labots Novembris 21, 2013 - DAFUQ Link to comment Share on other sites More sharing options...
ju Novembris 21, 2013 Share Novembris 21, 2013 Ko tu mēģini cilvēkam iesmērēt? Tur jau tāpat būs 5.1, nevis 7.1., ja jau tiešām to gribas. Skandas jau tāpat var salsēgt, kaut simtu klāt. Link to comment Share on other sites More sharing options...
Armands_79 Novembris 22, 2013 Author Share Novembris 22, 2013 Tad kāds būtu labāks? Virs 100 w uz izeju vai tomēr kā? Kāds būtu labākais variants?? Link to comment Share on other sites More sharing options...
mafijs Novembris 22, 2013 Share Novembris 22, 2013 http://www.harmankardon.com/HI-IN/Products/Pages/ProductSupportDetails.aspx?PID=AVR%20760/230 Link to comment Share on other sites More sharing options...
Alex G Decembris 20, 2013 Share Decembris 20, 2013 (labots) Cambridge Audio A/V 7+1 resīveri Azur 551R, Azur 651. Aizliegts reklamēt konkurētas lapas/veikalus. Labots Decembris 20, 2013 - Aigarsclp Interneta veikala reklamēšana. Link to comment Share on other sites More sharing options...
