StulbsTuVai... Ierakstīts Oktobris 4, 2012 Share Ierakstīts Oktobris 4, 2012 Nav iespejams atvert majaslapas-microsoft.com,kaspersky.com un tamlidzigi. Znacit ir viruss. Ka lai to zarazu dabu lauka no datora? Paldies jau ieprieks. Link to comment Share on other sites More sharing options...
Willy Oktobris 4, 2012 Share Oktobris 4, 2012 http://www.freedrweb.com/cureit/?lng=en Link to comment Share on other sites More sharing options...
StulbsTuVai... Oktobris 4, 2012 Author Share Oktobris 4, 2012 Nevar atvert linku Bet ideja skaidra. Link to comment Share on other sites More sharing options...
StulbsTuVai... Oktobris 4, 2012 Author Share Oktobris 4, 2012 Izskeneju gan ar cureit,gan ar spybot. Tapat problema paliek....kautgan atrada dazhus drankjus datora. Link to comment Share on other sites More sharing options...
e = d Oktobris 4, 2012 Share Oktobris 4, 2012 jāuzlej napalms un jāpielaiž uguns. 1 Link to comment Share on other sites More sharing options...
Swaps Oktobris 4, 2012 Share Oktobris 4, 2012 (labots) Paskaties C:\Windows\System32\Drivers\etc\hosts failu Tur varētu būt visas tās lapas sarakstītas. Ja ir, tad dzēs tik ārā un mēģini atkal tik kādai no tām klāt. To hosts failu uz vietas saglabāt visdrīzāk neļaus, vari iekopēt uz dektopa, izrediģēt un tad atpakaļ. Labots Oktobris 4, 2012 - Swaps Link to comment Share on other sites More sharing options...
StulbsTuVai... Oktobris 4, 2012 Author Share Oktobris 4, 2012 Ar napalmu diez vai bus lidzets. Un hosts faila neatradu neko tadu. # Copyright © 1993-1999 Microsoft Corp.# # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # This HOSTS file created by Dr.Web Anti-rootkit API 127.0.0.1 localhost Link to comment Share on other sites More sharing options...
Firza Oktobris 4, 2012 Share Oktobris 4, 2012 Novelc no Microsoft programmu "Autoruns", uztaisi startup logu un ieliec to kaut kur, lai kāds var apskatīties. Bez informācijas par to kādas programmas Tev tur palaižas automātiski, visi ieteikumi ir tikai tāda zīlēšana kafijas biezumos, un labakajā gadijumā tā būs tāda "mērīšanās krāniņim", kur katrs ieteiks savu iecienīto antivīrusu, vai programmu vīrusu likvidēšanai. Link to comment Share on other sites More sharing options...
ImissimI Oktobris 4, 2012 Share Oktobris 4, 2012 Pēdējo reizi kaut ko tādu redzēju Conficker izpildījumā un tas bija ļoooti sen. Bezmaz katram antivīrusam ir savs removal toolis spešalī priekš confickera, MS msrt arī tika galā. Link to comment Share on other sites More sharing options...
McB Oktobris 5, 2012 Share Oktobris 5, 2012 Jāmācās domāt, lai turpmāk tādu drazu nesarautu. Pirms palaid šaubīgus failus - pārbaudi tos http://virustotal.com Un ja ir sarauti, tad jāizvērtē vai gadijumā nav pienācis Vistas pussabrukšanas laiks un nevajag pārinstalēt, vai tomēr pietiks ar tīrīšanu. Ja tīrīšana tad dara to ar Dr.Web LiveCD. Un nevis kaukādiem kjūritiem.. Link to comment Share on other sites More sharing options...
