Kungs Ierakstīts Novembris 22, 2010 Share Ierakstīts Novembris 22, 2010 Sveiki. Vai kāds nevarētu palīdzēt pārveidot programmas kodu tā lai tiktu pielietots ''alkatīgais algoritms''? #include<iostream> using namespace std; #define SIZE 10 //izveidojam strukturu objektiem struct Object{ int weight; int value; }; Object obj[size] = { {10,18}, {11,20}, {12,17}, {13,19}, {14,25},{15,21},{16,27},{17,23},{18,25},{19,24}}; int limw, totv, maxv; //svara limits, kopeja vertiba, max sasniegta vertiba int s[size]; //vektors rada kadi priekshmeto ir tekosha bridi int opt_s[size]; //vektors rada kadi priekshmeti ir maksimalas vertibas izkartojuma un maxv ir ta vertiba void saveOptS() { //paligfunkcija maksimala izkartojuma pieshkirshanai for (int i=0; i<SIZE; i++) { opt_s[i] = s[i]; } } void getMax(int i, int tw, int av) { int av1; if (i == SIZE) { if (av > maxv) { saveOptS(); maxv = av; cout <<"I'm in the nested if" <<endl; } return; } if ( (tw+obj[i].weight) <= limw ) { cout <<"obj[i] = " <<obj[i].weight <<endl; // cout <<"maxv = " <<maxv <<endl; s[i] = 1; getMax(i+1,tw+obj[i].weight,av); s[i] = 0; } av1 = av-obj[i].value; if ( av1>maxv) getMax(i+1,tw,av1); // cout <<"av1 = " <<av1 <<endl; //cout <<"maxv = " <<maxv <<endl; } int main() { int i, w_count = 0, v_count = 0; limw = 70; cout <<"limw = " <<limw <<endl; for (totv = i = 0; i < SIZE; i++) { totv += obj[i].value; } //cout <<"totv = " <<totv <<endl; getMax(0,0,totv); for (i = 0; i < SIZE; i++){ if (opt_s[i]) { w_count += obj[i].weight; v_count += obj[i].value; } cout <<"obj[" <<i <<"].weight = " <<obj[i].weight; cout <<" obj[" <<i <<"].value = " <<obj[i].value; cout <<" opt_s[" <<i <<"] = " <<opt_s[i] <<endl; } cout <<"w_count = " <<w_count; cout <<" v_count = " <<v_count <<endl; for (i = 0; i < SIZE; i++) { cout <<s[i] <<" "; } cout << endl; system("pause"); return 0; } Link to comment Share on other sites More sharing options...
