leon Ierakstīts Augusts 26, 2010 Share Ierakstīts Augusts 26, 2010 Interesē kādas iespējas, vai kāds ir mēģinājis. Ir CCcam un Mgcam. Tehniskā informācija SKYBOX S9 HD PVR receiver General Specifications: * 300 MHz MIPS Processor - Linux Operating System * Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1; * Fully compliant MPEG-2 MP@HL & MP@ML; * Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3); * SCPC & MCPC receivable from C/Ku band satellites; * multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported) * NIT search supported; * Support MHEG-5; * Support HDMI 1.3; * Support PVR(store in USB disk); * Multimedia files playback(by USB); * Support Electronic Program Guide(EPG) for 7 days; * Teletext and subtitle out through OSD; * Support multi-lingual DVB subtitle and teletext; * Automatic and manual channel scan options; * automatic service scan * channel-change time < 1 second * OSD in many languages and skin-support * Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable; * LED Display * Multiple display mode: 1080i/720p/570p/576i/480p; * MPEG-2 / H.264 Hardware decoding * Videotext Decoder * Analog audio output: stereo(L+R); * Digital audio output: S/PDIF by coaxial and optical; * S/PDIF Interface for digital bit stream out (AC-3) * YCbCr available; * 2 x Scart (RGB, FBAS or S-Video) * Screen format:auto, 4:3, and 16:9; * Upgrade software through USB2.0 port; * Powerful program management function, parent lock; * CA 1x slot and CI 1xslot * 10/100Mbit Ethernet Interface * directly bouquet-lists būtojas ļoti ātri, ir redzēts dzīvē - mazliet vairāk par 10 sek. jautājums ir vai var pieslēgties pa LAN? un kādas ir atsauksmes. Link to comment Share on other sites More sharing options...
MaskaV Augusts 26, 2010 Share Augusts 26, 2010 * 10/100Mbit Ethernet Interface Bet kas tad tā ir,ja ne LAN? Link to comment Share on other sites More sharing options...
leon Augusts 27, 2010 Author Share Augusts 27, 2010 Nu Lan ports ir, bet 21 ports klusē, pēc Ip pingojas ! Kāds nezin kādā formātā šim jāraksta ignore.list un replace.list, kaut kā standarta veidā negrib sagremot ! Cik noprotu tad priority.list nevar ierakstīt. Link to comment Share on other sites More sharing options...
sashock Augusts 27, 2010 Share Augusts 27, 2010 Aizdomas ka tik nav S5 klons. Kādu softu šim brīnumam lej iekšā. Link to comment Share on other sites More sharing options...
Rudiger Augusts 27, 2010 Share Augusts 27, 2010 Tas ir ķīniešu pašu izgudrojums -Solomend 800HD pvr/ Openbox S9 / Skybox S9 / Sathawk u.c nosaukumi.Ar Openboksu nekā kopīga nav, vienīgi korpuss līdzīgs.Par softa atbalstu arī vēl grūti spriest.Procesors ALI 3602 300Mhz.Salīdzinājumam-Openbox S5/7/9, Ipbox ,Octagon, Opticum 9500 ir 400 Mhz Sti71xx.Cik var saprast, iebūvēti CCCam un MgCamd.Konfigu failus var ieliet caur USB ar flešu vai caur DCC.Atsauksmes nekādas izcilās nav-vienīgais pluss, zemā cena -But i´ve seen in China Online stores for only 480 yuan..56€!!!! Link to comment Share on other sites More sharing options...
Fitz Augusts 27, 2010 Share Augusts 27, 2010 Cena tiešām 86 usd http://www.aliexpress.com/product-gs/333959322-HD-Satellite-TV-receiver-openbox-skybox-S9-wholesalers.html Gan jau šis brīnums arī parādīsies LV Link to comment Share on other sites More sharing options...
sashock Augusts 28, 2010 Share Augusts 28, 2010 (labots) Procesors ALI 3602 300Mhz.Salīdzinājumam-Openbox S5/7/9, Ipbox ,Octagon, Opticum 9500 ir 400 Mhz Sti71xx.Cik var saprast, iebūvēti CCCam un MgCamd.56€!!!! Ja priekš Linux biku pa maz, bet ja aparāts nav Linux tipa Opticum 403, GoldenMedia 9060/80 uz kuriem arī ir šis procesors, tad tā proča pilnīgi pietiek, lai skatītos pilnvērtīgi HD kanālus, apskatītu JPEG izlaistu cauri MP3, bet nepietiek dukas priekš DIVX nerunājot par MKV. Bet nu izskatās ka HD resīveri vairs nebūs nekāda ekskluzīvā manta drīz visur tirgos pa 40Ls kā SD tjūnerus Labots Augusts 28, 2010 - sashock Link to comment Share on other sites More sharing options...
gix Augusts 28, 2010 Share Augusts 28, 2010 main feature: This receiver has all the functions of dreambox ; It is the cheapest HD receiver; Can be used around the world; Linux Operative System ; HD CPU;Available tuners: DVB-S2; Vajag kādam pasūtināt, tad arī aizies, šitāda cena ir ceļama, pat krizee. Link to comment Share on other sites More sharing options...
MaskaV Augusts 28, 2010 Share Augusts 28, 2010 Tas,ka Linux,vēl nenozīmē neko.Tiklīdz varēs liet iekšā Enigmu2,tad viss būs o.k. Link to comment Share on other sites More sharing options...
Aivis2 Augusts 28, 2010 Share Augusts 28, 2010 (labots) Nu nav viņam tāda cena! Šajā pašā Aliexpress - $92.78 x 1 + $67.03 = US $159.81 - Tas ir ar piegādi uz LV! No Aliexpress praktiski nekad nevar dabuut par to cenu kura ir viszemaakaa. Taa kaa beigaas nekaads mazais cipars nesanaak. Šeit ir kas līdzīgs un nedaudz lētāk - http://www.aliexpress.com/product-gs/332962041-MPEG4-H-264-FTA-receiver-HD-set-top-box-HD-decode-wholesalers.html Labots Augusts 28, 2010 - Aivis2 Link to comment Share on other sites More sharing options...
leon Augusts 28, 2010 Author Share Augusts 28, 2010 Nu uztvērējs ir uz rokām, it kā viss notiek tikai nevar ne caur 21 ne 23 ne 80 portu pieslēgties. Nav iespēja ieliet priority.list, līdz ar to citreiz kanāli pārslēdzas atrāk citreiz lēnāk, tas ir kodētie. Un nevaru nekā saprast ar to ignore un replace list, nu nekā man viņš negrib viņus atpazīt! (standarta mgcamd izpildījumā) Ugrade notiek caur USB. Link to comment Share on other sites More sharing options...
Rudiger Augusts 28, 2010 Share Augusts 28, 2010 Lasīju, ka var ieliet tikai newcamd.list vai cccam.prio un nekādus citus failus... Link to comment Share on other sites More sharing options...
norico Oktobris 30, 2010 Share Oktobris 30, 2010 Arī es esmu dabūjis divus šitos brīnumus, pagaidām testēju. SKY UK medus tek ideāli, nav nekādu problēmu. Ar DRE Crypt gan pagaidām nekas nesanāk, jāgaida jaunāks softs. Bilde uz HD kanāliem ir laba. Cena gan šiem ir cēlusies, es savējos par 115 EUR gabalā ņēmu. Link to comment Share on other sites More sharing options...
Fitz Oktobris 30, 2010 Share Oktobris 30, 2010 (labots) Nu nav viņam tāda cena! Šajā pašā Aliexpress - $92.78 x 1 + $67.03 = US $159.81 - Tas ir ar piegādi uz LV! No Aliexpress praktiski nekad nevar dabuut par to cenu kura ir viszemaakaa. Taa kaa beigaas nekaads mazais cipars nesanaak. Rakstat aliexpress pārdevējam, lai sūta ar "China post registered mail/Honkong post (lai būtu free shipping)" un būs jums free shipping. Tas, ka to nepiedāvā defaultā uz LV - pofig, pārdevējs izmainīs rēkinā summu, kas maksājama un lieta darīta. Vidējais shipping laiks pēc samaksas veikšanas - 14-18 dienas. Pats esmu pārliecinājies jau 2X par to. Konkrēti šim variantam ir free shipping uz Latviju ar DHL vai China Post: http://www.aliexpres.../skybox-s9.html Tā vismaz atbild pārdevējs. Labots Novembris 1, 2010 - stumbrerro Link to comment Share on other sites More sharing options...
