Zoom Ierakstīts Jūnijs 18, 2009 Share Ierakstīts Jūnijs 18, 2009 (labots) Es tiku līdz izmēģinājumam. Pie 8. punkta. Testējot filmu man OUTPUT logā izmetās šis: TypeError: Error #1088: The markup in the document following the root element must be well-formed. at tut_vg_fla::MainTimeline/fileLoaded() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at flash.net::URLLoader/onComplete() import flash.display.*; import flash.errors.*; import flash.events.*; import flash.net.*; urlReques.load(new URLRequest("gp.xml")); //var urlRequest:URLRequest = new URLRequest("gp.xml"); var urlLoader:URLLoader = new URLLoader(); urlLoader.addEventListener(Event.COMPLETE,fileLoaded); urlLoader.load(urlRequest); var myXML:XML = new XML(); myXML.ignoreWhitespace = true; var xmlList:XMLList; var arrayName:Array = new Array(); var arrayTitle:Array = new Array(); var arrayDate:Array = new Array(); var arrayFull:Array = new Array(); function fileLoaded(event:Event):void{ var myXML:XML = new XML(event.target.data); xmlList = myXML.children(); for(var i:int=0; i< xmlList.length(); i++){ var xmlName:String = xmlList[i].name; var xmlTitle:String = xmlList[i].title; var xmlDate:String = xmlList[i].date; var xmlFull:String = xmlList[i].full; arrayName.push(xmlName); arrayTitle.push(xmlTitle); arrayDate.push(xmlDate); arrayFull.push(xmlFull); if(i == xmlList.length() - 1){ updateText(); } } } messageText.htmlText = "Esi pirmais kas ieraksti"; var maximumMessages:Number = 5; var currentMessages:Number = 0; function updateText(){ messageText.htmlText = ""; for(var i = currentMessages; i<maximumMessages; i++){ messageText.htmlText += ("<b><u>Vards: </u></b>" + arrayName[i]); messageText.htmlText += ("<b><u>Tema: </u></b>" + arrayTitle[i]); messageText.htmlText += ("<b><u>Datums: </u></b>" + arrayDate[i]); messageText.htmlText += ("<b><u>Teksts: </u></b>" + arrayFull[i]); messageText.htmlText += ("---------------------------------------"); } currentMessages=i; scroller.scrollTarget = messageText; nextBt.addEventListener(MouseEvent.MOUSE_UP,nextFunc); prevBt.addEventListener(MouseEvent.MOUSE_UP,prevFunc); function nextFunc(event:MouseEvent){ messageText.htmlText=""; maximumMessages += 5; updateText(); prevBt.enabled = true } function prevFunc (event:MouseEvent){ messageText.htmlText = ""; maximumMessages -= 5; currentMessages -= 10; nextBt.enabled = true; updateText(); if(currentMessages<=5){ prevBt.enabled = false; } } if (arrayName.length <= maximumMessages){ maximumMessages = arrayName.length; nextBt.enabled = false; } if (currentMessages < 0){ currentMessages = 0; maximumMessages = 5; nextBt.enabled = true; } if (i == xmlList.length() - 1){ updateText(); } if (i > 4){ nextBt.enabled = true; } nextBt.enabled = false; prevBt.enabled = false; } Meklēju Google, bet tāpat neko neatradu. Šī problēma citiem ar ir aktuāla, bet risinājums vēl nav rasts - man. Tad nu pajautāšu. Varbūt kādam ir bijusi šāda problēma? Pamācība te: http://flash.tutsplus.com/tutorials/xml/bu...ctionscript-30/ Labots Jūnijs 18, 2009 - Zoom Link to comment Share on other sites More sharing options...
