aivarito Ierakstīts Marts 18, 2009 Share Ierakstīts Marts 18, 2009 (labots) Sveiki ! Tātad problēma ir sekojoša : ISP piesaista i-netu MAC adresei . Ja interneta kabelis ir pieslēgts pa taisno pie PC , tad ātrums ir 8Mbiti/s . Tiklīdz tiek slēgts caur rūteri , interneta ātrums samazinās 3 x reizes , uz ~ 2.3Mbiti/s . Tad nu vēlējos noskaidrot , kas būtu jādara , lai i-neta ātrums būtu tāds pats kā slēdzot pa tiešo pie pc ! 1) Ko darīju :visām tīklu kartēm uzliku vienu un to pašu mac adresi 2) Rūterim pie general settings : uzliku to pašu mac adresi 3) Visur IP atrod automātiski 4) Dynamic IP - hostname - nav : mac adrese : piesaistītā Static IP : IP address assigned by your Service Provider : mans ip Subnet Mask : 255.255.255.0 DNS Address : mans ip Service Provider Gateway Address : PPPoE - neaiztikts PPTP - mac adrese nomainīta , ip atrod : automātiski L2TP - mac adrese nomainīta , ip atrod : automātiski Telstra Big Pond - neaiztikts DNS - ip DDNS - neaiztikts UPnP Settings - DISABLED Slēgts : Bez modēma : kabelis iekšā rūterī WAN izejā . Un tad no rūtera iet 3 x vadi katrs uz savu pc tīkla karti . OS : Windows XP SP3 . Info par rūteri : With the multi-homing function, you can lease up to 2 different types of WAN lines (T1、xDSL、Cable) from different ISPs. The router can let each user in your office make use of all of the WANs simultaneously without changing any configuration of his/her PC. The router can dynamically direct each of the LAN clients to a suitable WAN line according to the max bandwidth and current loading of the WAN lines. You also can configurate a WAN line to act as a backup to another one. This backup WAN line is not active in the beginning. When the other WAN line fails, the system will activate the backup WAN line and redirect the network traffic to the backup WAN line NAT/NAPT IP Sharing # Obtains WAN IP by PPPoE/Static IP/PPTP/DHCP/L2TP # Multi-Homing – WAN Port Load Balancing and Failover # SPI Anti-DoS Firewall # Virtual Server, Virtual DMZ # Supports DDNS (DynDNS/TZO) # Supports Special Applications (Port Triggers) # VPN Pass Through (IPSec/PPTP/L2TP) # QoS, DHCP Server # Web User Interface (Remote Configuration) # System Status (Port Connectivity) # Security Log, Firmware Upgrade Paldies par atbildēm jau iepriekš ! Labots Marts 19, 2009 - aivarito Link to comment Share on other sites More sharing options...
Inspektors Caps Marts 18, 2009 Share Marts 18, 2009 (labots) 1) Ko darīju :visām tīklu kartēm uzliku vienu un to pašu mac adresi Pag, pag... LAN tiiklaa visiem vienaadas MAC? Saac ar MAC atlikshanu visaam atpakalj uz origjinaalajaam un tad peec visu kompju restarta veelreiz notestee to aatrumu! Rootera WAN (aareejo) MAC, protams, liec kaada nu vajadziiga, pat ja taa sakriit ar kaadu no ieksheejaa tiikla MAC. Bet galvenais neveido situaaciju, kad LAN tiiklaa ir vienaadas MAC!!! Labots Marts 18, 2009 - Inspektors Caps Link to comment Share on other sites More sharing options...
Grisha Marts 19, 2009 Share Marts 19, 2009 Jaabriinaas ka vispaar kaut kas straadaa peec shitaadaam izdariibaam. Visa probleema ir turr, ka ruuteris atrodas pagrabaa. Par to savu ruuteri esi sapmamojis visu, iznjemot to, kas tas taads ir. Kaa sleedz kopaa tehniku? Jaaziilee mums? Kaadu Os lieto, jaaziiee atkal? Ej uz ziilniechu salonu un prasi tur, ja nejeedz izlasiit paaris rindinjas ieksh foruma noteikumiem. Link to comment Share on other sites More sharing options...
aivarito Marts 19, 2009 Author Share Marts 19, 2009 Jaabriinaas ka vispaar kaut kas straadaa peec shitaadaam izdariibaam. Visa probleema ir turr, ka ruuteris atrodas pagrabaa. Par to savu ruuteri esi sapmamojis visu, iznjemot to, kas tas taads ir. Kaa sleedz kopaa tehniku? Jaaziilee mums? Kaadu Os lieto, jaaziiee atkal? Ej uz ziilniechu salonu un prasi tur, ja nejeedz izlasiit paaris rindinjas ieksh foruma noteikumiem. 63,67% ir Windows XP lietotāju , tāpēc jau tev gluži nav jabūt zilniecei ar maģiskām spējām . 2. Ja tā būtu kāda nestandarta OS , tad jau tas tiktu pieminēts . Slēgts : Bez modēma : kabelis iekšā rūterī WAN izejā . Un tad no rūtera iet 3 x vadi katrs uz savu pc tīkla karti . Link to comment Share on other sites More sharing options...
zulus Marts 19, 2009 Share Marts 19, 2009 Ja tu pa taisno laid uz PC tad ir tas tavs aatrums, bet ja sadali to i-netu uz 3 datoriem, tad loģiski, ka ātrums kritīsies 3 reizes, ja uz visiem netu lieto:) Link to comment Share on other sites More sharing options...
aivarito Marts 19, 2009 Author Share Marts 19, 2009 Ja tu pa taisno laid uz PC tad ir tas tavs aatrums, bet ja sadali to i-netu uz 3 datoriem, tad loģiski, ka ātrums kritīsies 3 reizes, ja uz visiem netu lieto:) To es zinu , bet ātrums ir 3 x reizes mazāks , kad abi pārējie ir izslēgti . Link to comment Share on other sites More sharing options...
wilz Marts 19, 2009 Share Marts 19, 2009 (labots) Rūterī nav veiktas kādas manipulācijas ar prioritātes sadali? Labots Marts 19, 2009 - wilz Link to comment Share on other sites More sharing options...
aivarito Marts 19, 2009 Author Share Marts 19, 2009 Rūterī nav veiktas kādas manipulācijas ar prioritātes sadali? Nē Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 man ir ari problema ar ruuteri! sanienots man ir taa: neta vads modema,modemai 4 izejais, viena iet uz stacionaro, pie otra pievienots ruuteris! problema tada ka man portativajam nets dazreiz pazud, vai ir leens! tas ir lkm tikai tad kad stacionaraja palaist dc++ vai qtorenti! Vai man pareizi ir pievienots ruuteris?vai vaina nevaretu buut draiveros? aa un vai var kka uzlabot atrumu caur ruuteeri? Link to comment Share on other sites More sharing options...
Guest ADEX Aprīlis 9, 2009 Share Aprīlis 9, 2009 Lattelecom līnijas caurlaidība nav bezgalīga. Tas ir normāli, ka otram kompim nokrīt ātrums, ja pirmais ir aizsitis visu trubu. Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 un no ta kaa savienots nav atkarigs tas? nevar kka uztaisit, ja stacionaraja ir ieslegts dc++ vai qtorents, bet uz portativa nebremze nets? Link to comment Share on other sites More sharing options...
Guest ADEX Aprīlis 9, 2009 Share Aprīlis 9, 2009 Var. Pievelkot vēl vienu telefona līniju no LTC. Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 tu domaa jaunu telefona liiniju? vai arii es galig nesaprotu? un kaa tada gadijuma buutu jasavieno? Link to comment Share on other sites More sharing options...
Guest ADEX Aprīlis 9, 2009 Share Aprīlis 9, 2009 Vienu datoru pie vienas telefona līnijas, otru - pie otras. Katrai savs modēms, protams. Tu tak internetu no Lattelecom ņem, vai ne? Link to comment Share on other sites More sharing options...
janka71 Aprīlis 9, 2009 Share Aprīlis 9, 2009 zīmelim i bļin man iestādē nets sāk bremzēt ka palaiižu torentus un dc pļusu, help plīz man downloudojas ar 1,5mbps un uploudojas ar 2.mbps, bet piedāvā tikai 1mbps abos virzienos..., bet nets velkas Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 Vienu datoru pie vienas telefona līnijas, otru - pie otras. Katrai savs modēms, protams. Tu tak internetu no Lattelecom ņem, vai ne? ja lattelekom zīmelim i bļin man iestādē nets sāk bremzēt ka palaiižu torentus un dc pļusu, help plīz man downloudojas ar 1,5mbps un uploudojas ar 2.mbps, bet piedāvā tikai 1mbps abos virzienos..., bet nets velkas nesapratu kas tas tev bija domats!!! Link to comment Share on other sites More sharing options...
specuks Aprīlis 9, 2009 Share Aprīlis 9, 2009 Ko var nemties, noperkat tacu normalu routeri - nedaudz ierobezojat upload /download , prioretizejiet vajadzigo trafiku un viss lidos. Es tos letos SOHO devaisus vispar par routeriem neuzskatu. Link to comment Share on other sites More sharing options...
janka71 Aprīlis 9, 2009 Share Aprīlis 9, 2009 un no ta kaa savienots nav atkarigs tas? nevar kka uztaisit, ja stacionaraja ir ieslegts dc++ vai qtorents, bet uz portativa nebremze nets? apturi dcpļusu kā teicu, tad net nebremzēs. :-D help plīz norāvu rokasbremzi, un mašina knapi kust no vietas. :-D Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 Ko var nemties, noperkat tacu normalu routeri - nedaudz ierobezojat upload /download , prioretizejiet vajadzigo trafiku un viss lidos. Es tos letos SOHO devaisus vispar par routeriem neuzskatu. upload/download jaierobezo kam? dc++? tam datoram kuram ruteris pieslegts? Link to comment Share on other sites More sharing options...
Guest ADEX Aprīlis 9, 2009 Share Aprīlis 9, 2009 DC, protams, jāierobežo. Rūterim ta priekš kam? Tur jau tā viss ierobežots. Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 Limitē trafiku, lieto kaut vai to pašu NetLimiter, saliec down, up limitus katrai progai, uzstellē garantētos limitus, kurai progai nepieciešams, piemēram kaut kāda e-radio klausīšanai ar Winamp.. Beigta balle Nevar ar N klases automobīli WRC braukt.. Link to comment Share on other sites More sharing options...
specuks Aprīlis 9, 2009 Share Aprīlis 9, 2009 Nu logiski ka datoriem kas sledzas pie iekseja tikla. + vel var uzlikt prioritati uz 80 portu. LTC veidigiem pieslegumiem izteikti pieaug pings un sak bremzet ja kaut viena virziena tiek sasniegts max atrums. Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 Par LTC MK netu, uplod visiem p2p ir jāpiegriež <10kB/s, savādāk normāli pasērfot nav iespējams.. Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 Limitē trafiku, lieto kaut vai to pašu NetLimiter, saliec down, up limitus katrai progai, uzstellē garantētos limitus, kurai progai nepieciešams, piemēram kaut kāda e-radio klausīšanai ar Winamp.. Beigta balle Nevar ar N klases automobīli WRC braukt.. ar NetLimiter man limitus mainit uz portativa vai stacionara kuram ruteris ir klat? Link to comment Share on other sites More sharing options...
Pirkss Aprīlis 9, 2009 Share Aprīlis 9, 2009 LTC MK apstrīms ir ap 512Kbps Ja neaprobežo p2p klientu apetītu uz joslu, tad pie niknas vilkšanas pārējais apstājas. Kruti džeki protams mājās liek provaideru klases Cisco rūterus, tie nav nekādi lētuči ziimels - ierobežo sava p2p klienta apetīti. Vairumam p2p klientu to var izdarīt pašā klientā, nekādi netlimiteri nav nepieciešami. Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 Liec uz tām stacijām, kur dzenā p2p, piegriez tik cik vajag.. Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 nja visi raksta uzliec priotitati 80 portam, pieregule to un sito, bet kur un ka to precizi izdarit?!?! Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 #25 +1 Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 #25 +1 #1 tak nav risinajums bet problema! aa un vel kad pie joda ir p2p!? un kur var vinu ierobezot?! Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 (labots) Gaidi, ka ar karoti mutē ielies? Nu nez, man slinkums šobrīt tutorialus rakstīt.. Keywordi ir iedoti, meklē šeit, ja nevari, dod tam, kurš jēdz. Edit. Kas ir p2p? - peer to peer Labots Aprīlis 9, 2009 - indigo Link to comment Share on other sites More sharing options...
Pirkss Aprīlis 9, 2009 Share Aprīlis 9, 2009 p2p ir visi DC++ un torrent klienti piemēram. Nu tās programmas ar kurām Tu kačā. Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 taa Netlimiter pagaidam izskatas gudra proga, man likt mazaku upload tur kur es gribu lai atrak strada? Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 Piegriez upload visiem DC un TORRENT klientiem, uzliec uz 8kB/s un enjoy! Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 Piegriez upload visiem DC un TORRENT klientiem, uzliec uz 8kB/s un enjoy! tas man jaliec datoram pie kura ruuteris? un tad viss tikai upload dc un torrentiem? aa un tai NetLimiter jabut vislaik ieslegtai? Link to comment Share on other sites More sharing options...
specuks Aprīlis 9, 2009 Share Aprīlis 9, 2009 Maarci 2mbit un 5mbit LTC pieslegumiem upload nekad nav bijis 512kbit. Pie 450kbit UDP trafika tur pingi jau ir pari 500ms Maksimums 410-420kbit ja gribi lai kaut kas cits kaut cik normali griezas. Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 (labots) Ziimels. Ok, esmu pārissimtgramus iedzēris, bet vienalga nevaru uztvert to, ko tu raksti.. Pēdējo postu necitējam.. Labots Aprīlis 9, 2009 - indigo Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 (labots) tai progai jabut vislaik ieslegtai? un un kura datora man tos upload likt, tam kuram ruuteris pieslegts? ar to progu download nekam nevajag regulet? ja es uzlieku down limit lielaku exploreram man kkas mainisies? Labots Aprīlis 9, 2009 - ziimels Link to comment Share on other sites More sharing options...
AK-47 Aprīlis 9, 2009 Share Aprīlis 9, 2009 (labots) 1. Uzinstalē NetLimiter uz to/tām kastēm ar kurām tu velc/zodz! 2. Netlimiterim ieķeksē uploda limitus konkrētai p2p programai(DC, uTorrent, BitTorrent etc.) uz 5-10kB/s 3. NetLimiters tev griezīsies backvokālā, tu viņu pat nemanīsi, aktivizēsies pie startupa un būs paslēpies tray'ā. 4. Kas vēl nav saprotams? tulīt iepostēšu NetLim skrīnšotu.. Labots Aprīlis 9, 2009 - indigo Link to comment Share on other sites More sharing options...
ziimels Aprīlis 9, 2009 Share Aprīlis 9, 2009 1. Uzinstalē NetLimiter uz to/tām kastēm ar kurām tu velc/zodz!2. Netlimiterim ieķeksē uploda limitus konkrētai p2p programai(DC, uTorrent, BitTorrent etc.) uz 5-10kB/s 3. NetLimiters tev griezīsies backvokālā, tu viņu pat nemanīsi, aktivizēsies pie startupa un būs paslēpies tray'ā. 4. Kas vēl nav saprotams? tulīt iepostēšu NetLim skrīnšotu.. tatad man tas ir jadara uz datora pie kura ir ruteris, jo kad uz vina palaidis dc vai torentus tas neietekmes manu neta darbibu uz portativa? Link to comment Share on other sites More sharing options...
Guest ADEX Aprīlis 9, 2009 Share Aprīlis 9, 2009 (labots) ziimels, paskaties, tev Brain devaisam Disable poga nav iesprūdusi nospiestā stāvoklī? Uz šito jautājumu augstāk jau ir atbildēts, un ne vienu reizi viein. Labots Aprīlis 9, 2009 - ADEX Link to comment Share on other sites More sharing options...
