Jetijs Ierakstīts Marts 7, 2009 Share Ierakstīts Marts 7, 2009 Paarinstaleeju 7 gadus veco noname lapsi. Knapi tiikla karti dabuuju pie dziiviibas, bet skanju nekaadi nevaru dabuut. Everests saka, ka nepiecieshams draiveris shitam "intel 82801DBM ICH4M AC'97 Audio controller" Visur, kur piedaavaa lejupielaadeet, tie linki beigaas nestraadaa. Citur prasa naudu. Pirmaas 4 lapas googlee izpeetiiju jo kaartiigi, neko nevaru atrast. Lapsis ir kautkaads barebone, kas pirkts M79 2002 gadaa. Reku everesta info: --------[ EVEREST Home Edition © 2003-2005 Lavalys, Inc. ]------------------------------------------------------------ Version EVEREST v2.20.405 Homepage http://www.lavalys.com/ Report Type Report Wizard Computer JET-8AI70XZYM1X Generator Jetijs Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP Retail) Date 2009-03-08 Time 01:41 --------[ CPU ]--------------------------------------------------------------------------------------------------------- CPU Properties: CPU Type Mobile Intel Pentium M 705, 1500 MHz (15 x 100) CPU Alias Banias CPU Stepping B1 Instruction Set x86, MMX, SSE, SSE2 Original Clock 1500 MHz Engineering Sample No L1 Code Cache 32 KB L1 Data Cache 32 KB L2 Cache 1 MB (On-Die, ATC, Full-Speed) CPU Physical Info: Package Type 479 Ball uFCBGA / 478 Pin uFCPGA Transistors 77 million Process Technology 6M, 0.13 um, CMOS, Cu, Low-K Die Size 83 mm2 Core Voltage 0.956 - 1.484 V I/O Voltage 0.956 - 1.484 V Typical Power 4.0 - 24.5 W (depending on clock speed) Maximum Power 4.2 - 31.2 W (depending on clock speed) CPU Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/browse/processor.htm CPU Utilization: CPU #1 24 % --------[ CPUID ]------------------------------------------------------------------------------------------------------- CPUID Properties: CPUID Manufacturer GenuineIntel CPUID CPU Name Intel® Pentium® M processor 1500MHz CPUID Revision 00000695h IA Brand ID 16h (Intel Pentium M) Platform ID 06h (Mobile uPGA2) IA CPU Serial Number Unknown Microcode Update Revision 5 HTT / CMP Units 0 / 0 Instruction Set: 64-bit x86 Extension (AMD64, EM64T) Not Supported Alternate Instruction Set Not Supported AMD 3DNow! Not Supported AMD 3DNow! Professional Not Supported AMD Enhanced 3DNow! Not Supported AMD Extended MMX Not Supported Cyrix Extended MMX Not Supported IA-64 Not Supported IA MMX Supported IA SSE Supported IA SSE 2 Supported IA SSE 3 Not Supported CLFLUSH Instruction Supported CMPXCHG8B Instruction Supported CMPXCHG16B Instruction Not Supported Conditional Move Instruction Supported MONITOR / MWAIT Instruction Not Supported RDTSCP Instruction Not Supported SYSCALL / SYSRET Instruction Not Supported SYSENTER / SYSEXIT Instruction Supported VIA FEMMS Instruction Not Supported Security Features: Advanced Cryptography Engine (ACE) Not Supported Data Execution Prevention (DEP, NX, EDB) Not Supported Hardware Random Number Generator (RNG) Not Supported Montgomery Multiplier & Hash Engine Not Supported Processor Serial Number (PSN) Not Supported Power Management Features: Automatic Clock Control Supported Enhanced Halt State (C1E) Not Supported Enhanced SpeedStep Technology (EIST, ESS) Supported, Enabled Frequency ID Control Not Supported LongRun Not Supported LongRun Table Interface Not Supported PowerSaver 1.0 Not Supported PowerSaver 2.0 Not Supported PowerSaver 3.0 Not Supported Processor Duty Cycle Control Supported Software Thermal Control Not Supported Temperature Sensing Diode Not Supported Thermal Monitor 1 Supported Thermal Monitor 2 Supported Thermal Monitoring Not Supported Thermal Trip Not Supported Voltage ID Control Not Supported CPUID Features: 36-bit Page Size Extension Not Supported Address Region Registers (ARR) Not Supported CPL Qualified Debug Store Not Supported Debug Trace Store Supported Debugging Extension Supported Fast Save & Restore Supported Hyper-Threading Technology (HTT) Not Supported L1 Context ID Not Supported Local APIC On Chip Not Supported Machine Check Architecture (MCA) Supported Machine Check Exception (MCE) Supported Memory Configuration Registers (MCR) Not Supported Memory Type Range Registers (MTRR) Supported Model Specific Registers (MSR) Supported Page Attribute Table (PAT) Supported Page Global Extension Supported Page Size Extension (PSE) Supported Pending Break Event Supported Physical Address Extension (PAE) Not Supported Secure Virtual Machine Extensions (Pacifica) Not Supported Self-Snoop Not Supported Time Stamp Counter (TSC) Supported Virtual Machine Extensions (Vanderpool) Not Supported Virtual Mode Extension Supported CPUID Registers (CPU #1): CPUID 00000000 00000002-756E6547-6C65746E-49656E69 CPUID 00000001 00000695-00000816-00000180-A7E9F9BF CPUID 00000002 02B3B001-00000000-00000000-2C043087 CPUID 80000000 80000004-00000000-00000000-00000000 CPUID 80000001 00000000-00000000-00000000-00000000 CPUID 80000002 20202020-20202020-65746E49-2952286C CPUID 80000003 6E655020-6D756974-20295228-7270204D CPUID 80000004 7365636F-20726F73-30303531-007A484D MSR Registers: MSR 00000017 0014-0000-D000-87B1 MSR 0000002A 0000-0000-43C8-0000 MSR 0000008B 0000-0005-0000-0000 MSR 0000011E 0000-0000-0034-072B MSR 00000198 0610-0F31-0600-0610 MSR 00000199 0000-0000-0000-0610 MSR 0000019A 0000-0000-0000-0008 MSR 0000019B 0000-0000-0000-0000 MSR 0000019C 0000-0000-0000-0000 MSR 0000019D 0000-0000-0001-081A MSR 000001A0 0000-0000-0011-1088 --------[ Motherboard ]------------------------------------------------------------------------------------------------- Motherboard Properties: Motherboard ID MONTARA0.86C.0018.D.0307011032 Motherboard Name Unknown Front Side Bus Properties: Bus Type Intel NetBurst Bus Width 64-bit Real Clock 100 MHz (QDR) Effective Clock 400 MHz Bandwidth 3200 MB/s Memory Bus Properties: Bus Type DDR SDRAM Bus Width 64-bit Real Clock 133 MHz (DDR) Effective Clock 267 MHz Bandwidth 2133 MB/s Chipset Bus Properties: Bus Type Intel Hub Interface Bus Width 8-bit Real Clock 67 MHz (QDR) Effective Clock 267 MHz Bandwidth 267 MB/s --------[ Memory ]------------------------------------------------------------------------------------------------------ Physical Memory: Total 1014 MB Used 346 MB Free 668 MB Utilization 34 % Swap Space: Total 2445 MB Used 220 MB Free 2224 MB Utilization 9 % Virtual Memory: Total 3459 MB Used 566 MB Free 2893 MB Utilization 16 % Physical Address Extension (PAE): Supported by Operating System Yes Supported by CPU No Active No --------[ SPD ]--------------------------------------------------------------------------------------------------------- [ DIMM1: A-DATA SCPGC1A160BZ ] Memory Module Properties: Module Name A-DATA SCPGC1A160BZ Serial Number None Manufacture Date Week 48 / 2008 Module Size 1024 MB (2 ranks, 4 banks) Module Type Unbuffered Memory Type DDR SDRAM Memory Speed PC3200 (200 MHz) Module Width 64 bit Module Voltage SSTL 2.5 Error Detection Method None Refresh Rate Reduced (7.8 us), Self-Refresh Memory Timings: @ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) @ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) Memory Module Features: Early RAS# Precharge Not Supported Auto-Precharge Not Supported Precharge All Not Supported Write1/Read Burst Not Supported Buffered Address/Control Inputs Not Supported Registered Address/Control Inputs Not Supported On-Card PLL (Clock) Not Supported Buffered DQMB Inputs Not Supported Registered DQMB Inputs Not Supported Differential Clock Input Supported Redundant Row Address Not Supported --------[ Chipset ]----------------------------------------------------------------------------------------------------- [ North Bridge: Intel Montara-GM i855GM ] North Bridge Properties: North Bridge Intel Montara-GM i855GM Revision / Stepping 02 / A2 Package Type 732 Pin Micro-FCBGA Package Size 3.75 cm x 3.75 cm Core Voltage 1.2 V In-Order Queue Depth 12 Memory Timings: CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 2T RAS Precharge (tRP) 2T RAS Active Time (tRAS) 6T Row Refresh Cycle Time (tRFC) 10T Write Recovery Time (tWR) 2T Memory Slots: DRAM Slot #1 1024 MB (PC3200 DDR SDRAM) Integrated Graphics Controller: Graphics Controller Type Intel Extreme Graphics 2 Graphics Controller Status Enabled Graphics Frame Buffer Size 8 MB Chipset Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/browse/chipsets.htm Driver Download http://support.intel.com/support/chipsets/index.htm [ South Bridge: Intel 82801DBM ICH4-M ] South Bridge Properties: South Bridge Intel 82801DBM ICH4-M Revision / Stepping 83 / B1 Package Type 421 Pin BGA Package Size 3.1 cm x 3.1 cm Core Voltage 1.5 V AC'97 Audio Controller: Audio Controller Type Intel 82801DB(M) ICH4 Codec Name Cirrus Logic CS4299 Codec ID 43525934h S/PDIF Output Not Supported Chipset Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/browse/chipsets.htm Driver Download http://support.intel.com/support/chipsets/index.htm --------[ BIOS ]-------------------------------------------------------------------------------------------------------- BIOS Properties: BIOS Type Phoenix System BIOS Date 07/01/03 Video BIOS Date Unknown BIOS Manufacturer: Company Name Phoenix Technologies Ltd. Product Information http://www.phoenix.com/en/products/default.htm BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40 Problems & Suggestions: Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today! Suggestion System BIOS is more than 2 years old. Update it if necessary. --------[ PCI / PnP Audio ]--------------------------------------------------------------------------------------------- Intel 82801DBM ICH4-M - AC'97 Audio Controller [b-1] PCI Link to comment Share on other sites More sharing options...
Gestapo Marts 7, 2009 Share Marts 7, 2009 SP ir trešā? Link to comment Share on other sites More sharing options...
Jetijs Marts 7, 2009 Author Share Marts 7, 2009 otraa. domaa ar tresho viss aizies pats par sevi? Link to comment Share on other sites More sharing options...
Grisha Marts 7, 2009 Share Marts 7, 2009 Esi ieksh driverguide? http://members.driverguide.com/index.php?a...p;st=1236469720 Link to comment Share on other sites More sharing options...
Jetijs Marts 7, 2009 Author Share Marts 7, 2009 neesmu gan, tur taks jaamaksaa, ja? Link to comment Share on other sites More sharing options...
Guest ADEX Marts 7, 2009 Share Marts 7, 2009 Man sanāk, ka šite kaut kam vajadzētu derēt: http://downloadcenter.intel.com/filter_res...mp;submit=Go%21 Link to comment Share on other sites More sharing options...
Jetijs Marts 7, 2009 Author Share Marts 7, 2009 ADEX, tos es visus jau izmeeginaaju, tur tik shipseta un grafikas draiveri ir, bet skanja kaa nav taa nav. Link to comment Share on other sites More sharing options...
Grisha Marts 7, 2009 Share Marts 7, 2009 it kaa nee. Ja nesanaak, pieregjistreeties, tad novilkshu tev vinjus. Prieksh draiveriem, ja neskaita oficiaalaas lapas, tad shii ir viennoziimiigi labaakaa. izmantoju jau n-tos gadus.. . Link to comment Share on other sites More sharing options...
amo Marts 8, 2009 Share Marts 8, 2009 (labots) Shito meeginaaji? Te arii ir Labots Marts 8, 2009 - amo Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 (labots) Shito meeginaaji? neiet tavs links. un otrajaa ir jaapieregistreejas, lai kaut ko dabuutu a confimaacijas links uz epastu nenaak. grisha, check PM Labots Marts 8, 2009 - Jetijs Link to comment Share on other sites More sharing options...
Gestapo Marts 8, 2009 Share Marts 8, 2009 Domāju, ka tikai sifiliss pats no sevis var pārņemt pusi no smadzenēm, bet "neticami bet fakts stilā" antīkām skaņas kartelēm patīk sp3, jo ir izdevies kaut kā neticamā kārtā, caur to iebarot hvz draiverus. moš šitas + sp3 bet nekādus panākumus negarantēju p.s. 0,7 > es (ja kļūdas) Link to comment Share on other sites More sharing options...
Guest ADEX Marts 8, 2009 Share Marts 8, 2009 Vispār, jāpiekrīt Gestapo - MS draudzējas ar inteli. Pirms pāris dienām pārinstalēju vienu HP Vectra ar Intel čipsetu. Čipseta draiveri atradu Intel lapā. Skaņa bija (instalēju no diska, kurā jau integrēta SP3), bet, kad aizvilkos uz update.microsoft.com, tur iekš Hardware man piedāvāja jaunāku skaņas draiveri. Tikai neņem Express, bet Custom, citādi Hardware apdeitus nepiedāvās. Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 (labots) nu tie draiveri ko man grisha atsuutiija no driverguide arii nekaadu rezultaatu nedod. Laikam jaameegina taa servisa paka buus. Vispaar mauciiba kaut kaada. Labots Marts 8, 2009 - Jetijs Link to comment Share on other sites More sharing options...
Gestapo Marts 8, 2009 Share Marts 8, 2009 Vispaar mauciiba kaut kaada. Nu sveiki, a ko bīdi mirušus lapšus? Vopšim dod zināt kā izdevās pēc sp3, varbūt vēl kādu viedu padomu dosim lūkot vaigā. ;| Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 kaads katram giimis, tam ar taadu jaadziivo! Link to comment Share on other sites More sharing options...
viesturs0711 Marts 8, 2009 Share Marts 8, 2009 (labots) moš tai Drivergidaa kaartiigaak jaapameklee, var kaadu citu variantu atrast ) Man te arii vienam kompim skaņas karte, intel čipseta, un nociinijos kaadu pusdienu kameer atradu draiveri (peec nosaukuma nesakrita, bet straadaaja). Labots Marts 8, 2009 - viesturs0711 Link to comment Share on other sites More sharing options...
Gestapo Marts 8, 2009 Share Marts 8, 2009 kaads katram giimis, tam ar taadu jaadziivo! Nu katrs jau par Slakteri nepiedzimst Link to comment Share on other sites More sharing options...
Grisha Marts 8, 2009 Share Marts 8, 2009 Iespeejams atradu, bet maitas driverguidaa, uzlikushi tagad briesmiigus ik nedeeljas limitus.. . . Meegjinaaju ar pieregoties ar citu e-pastu, bet tur ar iemeta magjiskajaa aplii.. . Ja nu kaas tur veel ir pieregjistreejies, reku links: http://members.driverguide.com/index.php?a...p;st=1236472575 un sheit konkreetaaks: http://members.driverguide.com/driver/deta...dc8a3469a855cfd Link to comment Share on other sites More sharing options...
Guest ADEX Marts 8, 2009 Share Marts 8, 2009 un sheit konkreetaaks: http://members.driverguide.com/driver/deta...dc8a3469a855cfd Te būs: http://yy.lv/upload/down.php?f=28639 Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 pieregistreejos un dabuuju to failu - saka ka driver not found. Link to comment Share on other sites More sharing options...
Guest ADEX Marts 8, 2009 Share Marts 8, 2009 MS apdeitos nav? Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 tas ir kaa? SP3 pagaidaam lejupielaadeejas. Link to comment Share on other sites More sharing options...
Guest ADEX Marts 8, 2009 Share Marts 8, 2009 Nē, update.microsoft.com Uzliec to ActiveX, uzliec WGA, tad paņem Custom, un tur būs Hardware. Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 tanii lappa man piedaavaa 2 iespeejas - express un custom. Ja panjemu custom, tad shis nocheko kaadi pudeiti man nav un piedaavaa "download and install now" neko citu. Link to comment Share on other sites More sharing options...
Gestapo Marts 8, 2009 Share Marts 8, 2009 gaidam sp3 + rest. )) vēl jau agrs. Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 nu sp3 jau 86% nolaadeejies Link to comment Share on other sites More sharing options...
Gestapo Marts 8, 2009 Share Marts 8, 2009 Tev ineta pieslēgums ir ātrs kā piedzēries iKaunis. Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 n`e, parasti nav ne vainas, muuviji naak pus stundaa. Shodien tik viss velkas. Laikam tas speciaali lai mani kaitinaatu Link to comment Share on other sites More sharing options...
Guest ADEX Marts 8, 2009 Share Marts 8, 2009 Reku šitā: Bet vispirms tomēr uzliec SP3. Link to comment Share on other sites More sharing options...
binladens Marts 8, 2009 Share Marts 8, 2009 (labots) A kas par lapsi, meklē pēc modeļa, ja neatrod, pēc mātesplates... Tas nav ļaunākais gadījums anyway, manam hp ir 100 draiveri kas iet bet ne ar vienu skaņa ārā nenāk laigan visi der un nekādas problēmas neatrod... Anyway kas par lapsi? Par sp3 nu nez moš kko dod, liku ar vai bez tikuntā skaņa neiet vai draiveru "pieņemamību maina nezinu" Paskatīšos tev draiverus ja atradīšu uzrakstīšu... Kāpēc jums liekas ka jāmeklē intel bla bla bla... think different http://www.nodevice.com/driver/CS4299/get43197.html http://drivers.softpedia.com/progDownload/...nload-2273.html Labots Marts 8, 2009 - binladens Link to comment Share on other sites More sharing options...
dexterlabs Marts 8, 2009 Share Marts 8, 2009 izmēģini device menagerī update driver,citreiz notiek brīnumi. Link to comment Share on other sites More sharing options...
nigerskijs gangsterskijs Marts 8, 2009 Share Marts 8, 2009 Man reiz tā iznāca ar vienu galda datoru, Everests radija ka ir Intel, un nederēja neviens draiveris, beigas izradijas ka tas ir kaut kads realtek chips. Varb;ut iebūtojies ar kādu Linux Live CD tiem parasti ir visi draiveri un apskaties, kas tad tev īsti ir par skaņaskari Link to comment Share on other sites More sharing options...
dexterlabs Marts 8, 2009 Share Marts 8, 2009 http://forums.majorgeeks.com/showthread.php?t=161055 mošk noder. varbūt pirms instalē draiveri vajag uzmest kb888111 Link to comment Share on other sites More sharing options...
amo Marts 8, 2009 Share Marts 8, 2009 (labots) neiet tavs links.un otrajaa ir jaapieregistreejas, lai kaut ko dabuutu a confimaacijas links uz epastu nenaak. grisha, check PM Nesanaak man pievienot failu :evil: Labots Marts 8, 2009 - amo Link to comment Share on other sites More sharing options...
dexterlabs Marts 8, 2009 Share Marts 8, 2009 kopar audio karti saka siw ?? Link to comment Share on other sites More sharing options...
Mezavecis Marts 8, 2009 Share Marts 8, 2009 (labots) Ē, tā var izmēģināt visus 1000 AC97 draiverus. Vajag precīzu laptopa modeli, kas rakstīts apakšā. Vēl tāda lieta - everests melo par skaņas kartēm. Nekad nav precīzu modeli izdevis ārā. Diez vai SP3 palīdzēs. Draiverus jaunus tas nesatur. Labots Marts 8, 2009 - mezhavecis Link to comment Share on other sites More sharing options...
raiviic Marts 8, 2009 Share Marts 8, 2009 (labots) Hmmmm, visi tik meklē Intelim. Ja nu tā uzmanīgi izlasīto šo: AC'97 Audio Controller:Audio Controller Type Intel 82801DB(M) ICH4 Codec Name Cirrus Logic CS4299 un pameklētu ? Protams, iespējams, smagi kļūdos, svētki sākās jau vakar :pohas: . Labots Marts 8, 2009 - raiviic Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 SP3 neliidzeeja. Laptopa modelja arii nav, kaa jau teicu tad tas ir kaut kaads latvijaa komplekteets barebone noname strunts, pirkts ieksh m70 pirms 7 gadiem. Lapsim uz dibena tikai seerijas numurs ir rakstsiits. Tas neko nedos. Moz ir kaads cits diagnostikas toolis ar ko preciizaak apskatiit lapsha iekshas? Link to comment Share on other sites More sharing options...
Pirkss Marts 8, 2009 Share Marts 8, 2009 Saprotu, ka izklausās stulbi, bet var paprovēt tā: http://downloadcenter.intel.com/Detail_Des...al〈=eng Link to comment Share on other sites More sharing options...
Jetijs Marts 8, 2009 Author Share Marts 8, 2009 Hmmmm, visi tik meklē Intelim. Ja nu tā uzmanīgi izlasīto šo: un pameklētu ? Protams, iespējams, smagi kļūdos, svētki sākās jau vakar :pohas: . `Sito tikko pameeginaaju - kapa klusums. Paldies visiem kas paliidzeeja. Forsi, ka tik daudzi pieteicaas Beigaas atradu straadaajoshu draiveri no shitaa strunta dviinjubraalja lapsha AMILO M7400 Bet vispaar vaaks. :woot: :woot: :woot: :woot: :woot: Link to comment Share on other sites More sharing options...
