VIL Ierakstīts Jūlijs 29, 2004 Share Ierakstīts Jūlijs 29, 2004 Šodien pakustināju Sandru, palaidu dažādus benčmarkus. Tā kā man ir interesanta mātesplate ASUS P4P800 Deluxe, nopublicēšu savus Memory bandwidth rezultātus un piedāvāju to izdarīt arī jums. (nevainīga interese) RAM Bandwidth Int Buffered iSSE2 : 4827MB/sRAM Bandwidth Float Buffered iSSE2 : 4797MB/s Int/Float Bandwidth Efficiency : 75% (estimated) Model : ASUSTeK Computer Inc 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 200MHz (800MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 6400MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.5-3-3-6CL 1CMD Bank 1 : 512MB DDR-SDRAM 2.5-3-3-6CL 1CMD Channels : 2 Speed : 2x 200MHz (400MHz data rate) Width : 64-bit Performance Acceleration Technology : Yes Maximum Memory Bus Bandwidth : 6400MB/s (estimated) Link to comment Share on other sites More sharing options...
iki Jūlijs 29, 2004 Share Jūlijs 29, 2004 Labi, taa kaa man ir liidziiga plate Asus P4P800-E Deluxe, tad interesanti saliidzinaat: RAM Bandwidth Int Buffered iSSE2 4765 MB/s RAM Bandwidth Float Buffered iSSE2 4762 MB/s Model : ASUSTeK Computer Inc 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 200MHz (800MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 6400MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 3.0-3-3-8CL 1CMD Channels : 2 Speed : 2x 200MHz (400MHz data rate) Width : 64-bit Performance Acceleration Technology : Yes Maximum Memory Bus Bandwidth : 6400MB/s (estimated) Rezultaati gan katru reizi var nedaudz atshkjirties atkariibaa no atminjas noslogojuma Link to comment Share on other sites More sharing options...
Guest No-man Jūlijs 29, 2004 Share Jūlijs 29, 2004 Ja nebūtu grūti kāds varētu iemest linku uz šo benchmarku. Link to comment Share on other sites More sharing options...
mrlobber Jūlijs 29, 2004 Share Jūlijs 29, 2004 Šodien pakustināju Sandru, palaidu dažādus benčmarkus. Tā kā man ir interesanta mātesplate ASUS P4P800 Deluxe, nopublicēšu savus Memory bandwidth rezultātus un piedāvāju to izdarīt arī jums. (nevainīga interese)RAM Bandwidth Int Buffered iSSE2 : 4827MB/sRAM Bandwidth Float Buffered iSSE2 : 4797MB/s Int/Float Bandwidth Efficiency : 75% (estimated) Bet ko darīt tiem, kas uz AMD? Abas platformas nebūs salīdzināmas... Link to comment Share on other sites More sharing options...
Guest fufelBOY Jūlijs 29, 2004 Share Jūlijs 29, 2004 RAM Bandwidth Int Buffered iSSE2 : 526MB/sRAM Bandwidth Float Buffered iSSE2 : 510MB/s Int/Float Bandwidth Efficiency : 88% (estimated) Model : Intel Corporation 82815/EM/EP/P 815/EM/EP/P (Solano) Host to I/O Hub Bridge Front Side Bus Speed : 1x 75MHz (75MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 600MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 128MB SDRAM 3-2-2-0CL Bank 1 : 128MB SDRAM 3-2-2-0CL Speed : 1x 112MHz (112MHz data rate) Width : 64-bit Maximum Memory Bus Bandwidth : 896MB/s (estimated) Link to comment Share on other sites More sharing options...
VIL Jūlijs 29, 2004 Author Share Jūlijs 29, 2004 Ja nebūtu grūti kāds varētu iemest linku uz šo benchmarku. http://www.sisoftware.net/ sadaļa "download" Bet ko darīt tiem, kas uz AMD? Abas platformas nebūs salīdzināmas... Inteļi mērās savā starpā, bet AMDešņiki savā. Kas man no ši pasākuma interesē: a) intel: 875 vs 865 b) intel/amd: atmiņas taimingu ietekme uz rezultātu c) amd/intel: kādu % sasniedzam no teorētiskā maksimuma Link to comment Share on other sites More sharing options...
mrlobber Jūlijs 29, 2004 Share Jūlijs 29, 2004 Lai notiek, iemetīšu vienu vecu ekrānšāviņu (jauns nebūs, jo šobrīd ņemos ar 512Mb atmiņas moduļiem, kas uz nForce2 ir posts un bēdas): RAM Bandwidth Int Buffered : 3843MB/s RAM Bandwidth Float Buffered : 3600MB/s Int/Float Bandwidth Efficiency : 96% / 90% (estimated) Pārējais pēc atmiņas: DFI nForce2 Ultra Infinity FSB: 250 x 2 (500 Mhz data rate) Maximum Bus Bandwidth: 4000 Mb/s Channels: dual Bank0: 256MB DDR-SDRAM 2-2-3-11CL 1CMD Bank1: 256MB DDR-SDRAM 2-2-3-11CL 1CMD [/img] Link to comment Share on other sites More sharing options...
ChiekuRs Jūlijs 29, 2004 Share Jūlijs 29, 2004 Int Buffered aEMMX/aSSE 1834 Mb/s Float Buffered aEMMX/aSSE 1693 Mb/s Bandwidth Efficiency : 86/80% (estimated) System Chipset Model : VIA Technologies Inc VT8366/A,VT8367 Apollo KT266/A,KT333 CPU to PCI Bridge Front Side Bus Speed : 2x 133MHz (266MHz data rate) Max. Bus Bandwidth : 2128MB/s (estimated) Logical/Chipset Memory Banks Bank 0 Setting : 256MB DDR-SDRAM 2.5-3-3CL 2CMD Memory Bus Speed : 2x 166MHz (332MHz data rate) Max. Memory Bandwidth : 2656MB/s (estimated) Link to comment Share on other sites More sharing options...
IMAGin Jūlijs 30, 2004 Share Jūlijs 30, 2004 Pagaidaam varu padaliities ar savu maajas pc sniegumu, veelaak arii citus iemeegjinaashu Benchmark Results RAM Bandwidth Int Buff'd iSSE2 : 2554MB/s RAM Bandwidth Float Buff'd iSSE2 : 2552MB/s Bandwidth Efficiency : 91% (estimated) un 91% (estimated) Chipset: Model : Holco Ent Co Ltd/Shuttle Computer 82845G/GL/GE Brookdale Host-Hub Interface Bridge (B1-step) Front Side Bus Speed : 4x 132MHz (528MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 4224MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 256MB DDR-SDRAM 1.5-2-2-5CL 1CMD Bank 1 : 256MB DDR-SDRAM 1.5-2-2-5CL 1CMD Speed : 2x 176MHz (352MHz data rate) Width : 64-bit Maximum Memory Bus Bandwidth : 2816MB/s (estimated) Taa izskataas ka man no intelistiem pagaidaam ir vislielaakaa izmantoshanas efektivitaate - 91% Kas interesanti - shaadi pashi rezultaati bija arii ar shvkaakiem taimingiem liidz pat 2,5-2-2-6, taalaak uz augshu neskatiijos... Link to comment Share on other sites More sharing options...
Devil_Inside Jūlijs 30, 2004 Share Jūlijs 30, 2004 Neliels kloķis IMAGin Int Buffered iSSE2 (Integer STREAM) Results Breakdown Assignment : 3082MB/s Scaling : 3094MB/s Addition : 3232MB/s Triad : 3227MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 119% (estimated) Float Buffered iSSE2 (Float STREAM) Results Breakdown Assignment : 3102MB/s Scaling : 3098MB/s Addition : 3230MB/s Triad : 3242MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 119% (estimated) Test Status Memory Used by Test : 127MB NUMA Support : No SMP Test : No Total Test Threads : 1 SMT Test : No Dynamic MP/MT Load Balance : No Processor Affinity : No Chipset 1 Model : Dell Computer Corp 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 133MHz (532MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 4256MB/s (estimated) Logical/Chipset 1 Memory Banks Speed : 2x 166MHz (332MHz data rate) Width : 64-bit Maximum Memory Bus Bandwidth : 2656MB/s (estimated) Features MMX Technology : Yes SSE Technology : Yes SSE2 Technology : Yes SSE3 Technology : No HTT - Hyper-Threading Technology : No Link to comment Share on other sites More sharing options...
IMAGin Jūlijs 30, 2004 Share Jūlijs 30, 2004 Neliels kloķis IMAGin Hehe Kas tad taa iisti tev ir par plati un chipsetu 845 vai 865? Un vispaar... nav godiigi manu veco Celeroninju shitaa apbizhot Taa jau tas ir max ko no shiis maatenes var izspiest, tb nedod lielaaku fsb par 132 Eeem... un ja nav nosleepums ramam kaadi taimingi? Link to comment Share on other sites More sharing options...
Devil_Inside Jūlijs 30, 2004 Share Jūlijs 30, 2004 Neliels kloķis IMAGin Hehe Kas tad taa iisti tev ir par plati un chipsetu 845 vai 865? Un vispaar... nav godiigi manu veco Celeroninju shitaa apbizhot Taa jau tas ir max ko no shiis maatenes var izspiest, tb nedod lielaaku fsb par 132 Eeem... un ja nav nosleepums ramam kaadi taimingi? Atmiņa: Type : DDR-SDRAM PC2700 Frequency : 166 MHz FSB/DRAM Multiplier : 4/5x Channels : Dual Mode : Linear ECC Diagnostic : No CAS Latency (tCL) : 2.5 clocks RAS to CAS (tRCD) : 3 clocks RAS Precharge (tRP) : 3 clocks Cycle Time (tRAS) : 7 clocks Plate: NorthBridge : Intel i865P/i848P SouthBridge : 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge NorthBridge Information : Architecture : Hub Manufacturer : Intel Revision : A2 Front Side Bus Speed : 133 MHz Bus Speed : 532 MHz (QDR) Memory Bus Speed : 166.2 MHz PAT - Performance Accelerat... Yes P.S. Tests tika laists just for fun netaisot ciet visus softus uz kompja kas bez restarta strādā jau 26 dienas. Link to comment Share on other sites More sharing options...
josi Jūlijs 30, 2004 Share Jūlijs 30, 2004 oj pagiras shodien kaa muura maajaabet nu gailiitis ir jaanomeera Nekas, nodosi pudeles, varēsi atkal ko labu iepirkt Rezultāti uz i865G: 2xDDR333/Int Video 3316/3294 2xDDR400/Int Video 3823/3822 2xDDR333/Ext Video 3747/3729 Link to comment Share on other sites More sharing options...
kiwi Jūlijs 30, 2004 Share Jūlijs 30, 2004 Vajadzētu jau vismaz ddr400 atmiņu, bet skatos, ka labi iet arī ar Kingston PC2700. Starp citu rezultāti atšķiras, ja BIOS uzliek Turbo mode un enable acceleration. VIL un IKI: Man tā pati plate, bet kāpēc man nav Performance Acceleration Technology ieslēgts? Kaut kā iekš BIOS nemanīju, jo tas it kā tikai 875 čipsetam. Varbūt tāpēc, ka klokoju. SiSoftware Sandra Benchmark Results RAM Bandwidth Int Buff'd iSSE2 : 4920MB/s RAM Bandwidth Float Buff'd iSSE2 : 4906MB/s Int Buff'd iSSE2 (Integer STREAM) Results Breakdown Assignment : 4886MB/s Scaling : 4876MB/s Addition : 4967MB/s Triad : 4951MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 84% (estimated) Float Buff'd iSSE2 (Float STREAM) Results Breakdown Assignment : 4872MB/s Scaling : 4860MB/s Addition : 4952MB/s Triad : 4942MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 83% (estimated) Performance Test Status Run ID : MIAMI on piektdiena, 2004. gada 30. jūlijā at 9:57:52 Memory Used by Test : 512MB NUMA Support : No SMP Test : No Total Test Threads : 1 SMT Test : Yes Number of Test SMT (per CPU) : 2 Dynamic MP/MT Load Balance : No Processor Affinity : P0 Page Size : 4kB Use Large Memory Pages : No Chipset 1 Model : ASUSTeK Computer Inc 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 230MHz (920MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 7360MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.5-4-4-8CL 1CMD Bank 1 : 512MB DDR-SDRAM 2.5-4-4-8CL 1CMD Channels : 2 Speed : 2x 184MHz (368MHz data rate) Width : 64-bit Performance Acceleration Technology : No Maximum Memory Bus Bandwidth : 5888MB/s (estimated) Link to comment Share on other sites More sharing options...
Guest Jūlijs 30, 2004 Share Jūlijs 30, 2004 RAM Bandwidth Int Buff'd iSSE2 : 5260MB/s RAM Bandwidth Float Buff'd iSSE2 : 5256MB/s Model : ASUSTeK Computer Inc 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 250MHz (1000MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 8000MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.5-3-3-8CL 1CMD Bank 2 : 256MB DDR-SDRAM 2.5-3-3-8CL 1CMD Channels : 2 Speed : 2x 200MHz (400MHz data rate) Bet nu es spēlēju negodīgi, man redz uz doto brīdi ir ieklokota fsb un procis. Vispār pie lielākās staipīšanas, ar DDR400 ir izdevies iegūt rezultus ap 5800. Link to comment Share on other sites More sharing options...
VIL Jūlijs 30, 2004 Author Share Jūlijs 30, 2004 Vajadzētu jau vismaz ddr400 atmiņu, bet skatos, ka labi iet arī ar Kingston PC2700. Starp citu rezultāti atšķiras, ja BIOS uzliek Turbo mode un enable acceleration. VIL un IKI: Man tā pati plate, bet kāpēc man nav Performance Acceleration Technology ieslēgts? Kaut kā iekš BIOS nemanīju, jo tas it kā tikai 875 čipsetam. Varbūt tāpēc, ka klokoju. PAT ir fīča, kas vārdā tika nosaukta tikai līdz ar canterwood čipseta parādīšanos DDR400 režīmā. DDR333 kā uz canterwood, tā arī uz springdale lieliski izmanto PAT un lieki par to nebļaustās. Ar DDR333 uz P4P800 neesmu darbojies. Ja PAT neparādās DDR400 režīmā, tad pēdējais brīdis to ieslēgt. Links uz aprakstu, kā to izdarīt: http://www.xbitlabs.com/articles/mainboard...s-p4p800_8.html Again the results are the same: the highest performance is achieved with Performance Mode=Turbo and Memory Acceleration Mode=Auto. These are the settings we would strongly recommend to ASUS P4P800 with. The instruction to enable the HyperPath technology by setting Memory Acceleration Mode=Enabled is completely wrong. So, it is not only Intel that misleads the users. As we see, ASUS is also not that sinless. Es pats treknināto parametru kopu lietoju, bet neesmu skatījies, kā šie parametri sasaucas kopā ar overkloku. Liriska atkāpe: I believe this short explanation has made it somewhat clearer to you now what hides behind PAT technology in reality. This way, ASUS’ trick with enabling PAT in its ASUS P4P800 is of no mystery any more. When 800MHz bus is activated, the mainboard sets the FSB frequency to 200MHz, but doesn’t report it to the chipset, as Intel’s reference design requires. As a result, the chipset thinks that the bus frequency is still 533MHz, and hence the memory is addressed in a shorter and faster way without any additional buffers. As you see, everything is as simple as ABC. This is exactly the reason why other mainboard manufacturers started using “fast mode” for work with the memory subsystem for the bus frequency of 800MHz and speeded up their i865PE based solutions up to i875P based ones. Link to comment Share on other sites More sharing options...
Guest Jūlijs 30, 2004 Share Jūlijs 30, 2004 Man personīgi stāv Performance Mode=Turbo and Memory Acceleration Mode=Enabled. Kaut gan, ja PAT ieslēdzas tikai uz 1:1 fsb:atmiņa divaideri, tad, pie klokošanas tā nav aktīva mana gadienā. (stāv 1,66 divaideris (DDR320), pret 2, kas ir DDR400). Link to comment Share on other sites More sharing options...
Guest No-man Jūlijs 30, 2004 Share Jūlijs 30, 2004 Še kur manējie Benchmark Results RAM Bandwidth Int Buff'd iSSE2 : 2472MB/s RAM Bandwidth Float Buff'd iSSE2 : 2487MB/s Int Buff'd iSSE2 (Integer STREAM) Results Breakdown Assignment : 2478MB/s Scaling : 2475MB/s Addition : 2469MB/s Triad : 2469MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 93% (estimated) Float Buff'd iSSE2 (Float STREAM) Results Breakdown Assignment : 2491MB/s Scaling : 2491MB/s Addition : 2482MB/s Triad : 2484MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 94% (estimated) Chipset 1 Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Front Side Bus Speed : 4x 133MHz (532MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 4256MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 256MB DDR-SDRAM 2.5-3-3-7CL 1CMD Bank 2 : 256MB DDR-SDRAM 2.5-3-3-7CL 1CMD Channels : 1 Speed : 2x 166MHz (332MHz data rate) Width : 64-bit Performance Acceleration Technology : Yes Maximum Memory Bus Bandwidth : 2656MB/s (estimated) Link to comment Share on other sites More sharing options...
Guest digitaly Jūlijs 30, 2004 Share Jūlijs 30, 2004 Viniigais rezultaati katru reizi bija savaataaki Float SSE Cache/Memory Results Breakdown Processor Model : AMD Athlon(tm) 64 3400+ Speed : 2.55GHz L2 On-board Cache : 1024kB ECC Synchronous Write-Back (16-way, 128 byte line size) Features SSE Technology : Yes SSE2 Technology : Yes SSE3 Technology : Yes EMMX - Extended MMX Technology : No HTT - Hyper-Threading Technology : No Chipset 1 Model : VIA Technologies Inc VT8366/A,VT8367 Apollo KT400/A,KT333 CPU to PCI Bridge Front Side Bus Speed : 4x 300MHz (1200MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 6144MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 2.5-3-3-7CL 2CMD Bank 2 : 512MB DDR-SDRAM 2.5-3-3-7CL 2CMD Bank 3 : 512MB DDR-SDRAM 2.5-3-3-7CL 2CMD Bank Interleave : 4-way Speed : 3x 400MHz (368MHz data rate) Width : 64-bit Maximum Memory Bus Bandwidth : 6100MB/s (estimated) Link to comment Share on other sites More sharing options...
VIL Jūlijs 30, 2004 Author Share Jūlijs 30, 2004 Viniigais rezultaati katru reizi bija savaataaki Iepostē vismaz kādus no tiem. Link to comment Share on other sites More sharing options...
VIL Jūlijs 30, 2004 Author Share Jūlijs 30, 2004 Jau dariits ;D Sorry, bet nevaru ieraudzīt... Tam vajadzētu būt kaut kam tādam: RAM Bandwidth Int Buffered iSSE2 : 4827MB/sRAM Bandwidth Float Buffered iSSE2 : 4797MB/s Int/Float Bandwidth Efficiency : 75% (estimated) Link to comment Share on other sites More sharing options...
Guest Jūlijs 30, 2004 Share Jūlijs 30, 2004 Nu man ta: RAM Bandwidth Int Buffered iSSE2: 3424 RAM Bandwidth Float Buffered iSSE2: 3113 Int/Float Bandwidth Efficiency : 93% / 84% (estimated) Bank 2 : 256MB DDR-SDRAM 3-3-3-6CL 2CMD Speed : 2x230MHz (460MHz data rate) Parastais Kingston DDR400 vairak nevelk:( Maximum Bus Bandwidth : 3680MB/s (estimated) 2josi: Cik uz tava gailisa rada??? Link to comment Share on other sites More sharing options...
Guest Jūlijs 30, 2004 Share Jūlijs 30, 2004 Jocigas lietas:P Panjemu FSB100 x2 un gribeju savu Mobile bartonu @ 2,2GHz un uztaisit vislabako efektivitati tacu Multipiler 22 rezultats 600MHz Multipiler 20 rezultats 1250MHz Kape ta??? Kautkads ierobezojums??? Link to comment Share on other sites More sharing options...
IMAGin Augusts 5, 2004 Share Augusts 5, 2004 Luuk ar nokaveeshanos mans darba raadiijums: SiSoftware Sandra Benchmark Results RAM Bandwidth Int Buff'd iSSE2 : 5815MB/s RAM Bandwidth Float Buff'd iSSE2 : 5813MB/s Int Buff'd iSSE2 (Integer STREAM) Results Breakdown Assignment : 5688MB/s Scaling : 5678MB/s Addition : 5948MB/s Triad : 5947MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 76% (estimated) Float Buff'd iSSE2 (Float STREAM) Results Breakdown Assignment : 5678MB/s Scaling : 5672MB/s Addition : 5953MB/s Triad : 5950MB/s Data Item Size : 16-bytes Buffering Used : Yes Offset Displacement Used : Yes Bandwidth Efficiency : 76% (estimated) Chipset 1 Model : Epox Computer Co Ltd 82875P,E7210 Memory Controller Hub Front Side Bus Speed : 4x 239MHz (956MHz data rate) Width : 64-bit Maximum Bus Bandwidth : 7648MB/s (estimated) Logical/Chipset 1 Memory Banks Bank 0 : 512MB DDR-SDRAM 3.0-4-4-8CL 1CMD Bank 1 : 512MB DDR-SDRAM 3.0-4-4-8CL 1CMD Channels : 2 Speed : 2x 239MHz (478MHz data rate) Width : 64-bit Performance Acceleration Technology : No Maximum Memory Bus Bandwidth : 7648MB/s (estimated) Features (W)MMX Technology : Yes SSE Technology : Yes SSE2 Technology : Yes SSE3 Technology : Yes HTT - Hyper-Threading Technology : Yes Luuk... zheel ka tagad nav laika njemties ap to OC, bet principaa uzliekot vecaaku bios'u kas ljaus manam preskotam mainiit voltaazhu - ieshu uz priekshu, so 6000Mb/s paari tikt vajadzeetu Link to comment Share on other sites More sharing options...
IMAGin Augusts 5, 2004 Share Augusts 5, 2004 Nu luuk... ar @4Ghz tiku paari 6000Mb/s schiet bija pat nepilni 6100Mb/s so peec baroklja mainjas meeriijumu veikshu veelreiz Link to comment Share on other sites More sharing options...
VIL Augusts 5, 2004 Author Share Augusts 5, 2004 Nu luuk... ar @4Ghz tiku paari 6000Mb/s schiet bija pat nepilni 6100Mb/s so peec baroklja mainjas meeriijumu veikshu veelreiz Iespaidīgi. Un tas ar visu to, ka nelieto asus p4p800 deluxe... Link to comment Share on other sites More sharing options...
IMAGin Augusts 5, 2004 Share Augusts 5, 2004 Nu luuk... ar @4Ghz tiku paari 6000Mb/s schiet bija pat nepilni 6100Mb/s so peec baroklja mainjas meeriijumu veikshu veelreiz Iespaidīgi. Un tas ar visu to' date=' ka nelieto asus p4p800 deluxe...[/quote'] Nu principaa cik skatiijos testus tad gan tas ASUS P4P800 E Deluxe gan ASUS P4C800 E Deluxe uzraadiija pavisam nedaudz labaakus rezultaatus... Otrkaart ja es nemaldos tad maximaalais iespeejamais atminjas pluusmas aatrums bija lielaaks 875P chipam... So tas ko es ieguutu lietojot sho ASUS plati buutu nu teixim... maximums 100Mb/s klaat... Link to comment Share on other sites More sharing options...
