Guest Ierakstīts Jūnijs 2, 2005 Share Ierakstīts Jūnijs 2, 2005 uztaisi bat failu, kurā ierakstirunas /noprofile /env /savecred /user:administrator "programma" Pirmo reizi paprasīs ievadīt paroli... Otro reizi vairs nevajadzētu... Link to comment Share on other sites More sharing options...
Guest Jūnijs 2, 2005 Share Jūnijs 2, 2005 Aleksejs: RUNAS USAGE: RUNAS [/profile] [/env] [/netonly] /user:<UserName> program /profile if the user's profile needs to be loaded /env to use current environment instead of user's. /netonly use if the credentials specified are for remote access only. /user <UserName> should be in form USER@DOMAIN or DOMAINUSER program command line for EXE. See below for examples Examples: > runas /profile /user:mymachineadministrator cmd > runas /profile /env /user:mydomainadmin "mmc %windir%system32dsa.msc" > runas /env /user:user@domain.microsoft.com "notepad "my file.txt"" NOTE: Enter user's password only when prompted. NOTE: USER@DOMAIN is not compatible with /netonly. runas /? nav nekas teikts par /savecred tachu cik es aatrumaa pagugleeju, tiktieshaam ir taa, kaa tu saki. tb Tavs piemers ir korekts :O) Man shitaa fiicha ljoti noderees )))))) Alinsh no manis )) Link to comment Share on other sites More sharing options...
wxy Augusts 1, 2005 Share Augusts 1, 2005 pats pashlaik ciinos ar bat failinjiem.. starp citu /savecred to use credentials previously saved by the user. This option is not available on Windows XP Home Edition and will be ignored. Link to comment Share on other sites More sharing options...
