  • Kas ir tiešsaistē   3 biedri, 0 Anonīmi, 90 viesi (Skatīt pilnu sarakstu)
    26631
    droopeks
    droopeks
    • camel
      Ok, iepriekšējo postu vajadzēja izdzēst, bišku samurgojos, nez, kāds īssavienojums bij prātiņā vai kas, bet pasteidzos ar secinājumiem. (Labi ka neviens nepamanija)   Lai nu kā, kautkas ir jau salipināts un apskatāms: https://github.com/Camel-RD/Klons3 lejuplādei: https://github.com/Camel-RD/Klons3/releases/latest/download/setup_klons3.zip   Īpaši lepns esmu par šo koda gabalu:   public void ClearLocalDbSet<T>() where T:class {     var state_manager = GetStateManager();     ClearIdentityMap();     ClearReferenceMap();     ClearLocalView();     void ClearIdentityMap()     {         var fi_identitymaps = Utils.GetField(state_manager.GetType(), "_identityMaps");         var identitymaps = (Dictionary<IKey, IIdentityMap>)fi_identitymaps.GetValue(state_manager);         var entoty_type = Model.FindEntityType(typeof(T));         var key = entoty_type.GetKeys().Single();         bool rt = identitymaps.TryGetValue(key, out var identitymap);         if (!rt) return;         identitymap.Clear();     }     void ClearReferenceMap()     {         var fi_referencemap = Utils.GetField(state_manager.GetType(), "_entityReferenceMap");         var referencemap = (EntityReferenceMap)fi_referencemap.GetValue(state_manager);         if (referencemap == null) return;         var fi_unchangedreferencemap = Utils.GetField(referencemap.GetType(), "_unchangedReferenceMap");         var unchangedreferencemap = (Dictionary<object, InternalEntityEntry>)fi_unchangedreferencemap.GetValue(referencemap);         if (unchangedreferencemap == null || unchangedreferencemap.Count == 0) return;         var entity_type = Model.FindEntityType(typeof(T));         var kv1 = unchangedreferencemap.Where(x => x.Value.EntityType != entity_type);         var new_unchangedreferencemap = new Dictionary<object, InternalEntityEntry>(kv1);         fi_unchangedreferencemap.SetValue(referencemap, new_unchangedreferencemap);         unchangedreferencemap.Clear();     }     void ClearLocalView()     {         var dbset = (DbSet<T>)GetDbSetByType(typeof(T));         if (dbset == null) return;         var localview = dbset.Local;         var tp_localview = localview.GetType();         var fi_observable = Utils.GetField(tp_localview, "_observable");         var _observable = (ObservableCollection<T>)fi_observable.GetValue(localview);         if (_observable != null && _observable.Count > 0)         {             var fi_items = Utils.GetField(_observable.GetType(), "items");             var items = (ICollection<T>)fi_items.GetValue(_observable);             items.Clear();         }         var fi_bindingList = Utils.GetField(tp_localview, "_bindingList");         var _bindingList = (ObservableBackedBindingList<T>)fi_bindingList.GetValue(localview);         if (_bindingList != null && _bindingList.Count > 0)         {             var fi_items = Utils.GetField(_bindingList.GetType(), "items");             var items = (ICollection<T>)fi_items.GetValue(_bindingList);             items.Clear();         }         var fi_countchanges = Utils.GetField(tp_localview, "_countChanges");         fi_countchanges.SetValue(localview, 0);         var fi_count = Utils.GetField(tp_localview, "_count");         fi_count.SetValue(localview, (int?)0);     } }
    • Tuubijs
      Lai Tu pēc tam te neraudātu, ka nevari putekli notīrīt, “pievilkt TV”, gaisa maiņa, etc random hujņa, ko Tu te izvērstu par kārtējo pasaules netaisnību pret tevi.
    • Tuubijs
    • MartiniB
      Vogel's vaurums modeļu ir kustināmi uz visām pusēm
      Nu man laikam arī, tāpēc šis būtu kā rezerves variants.
      var bīdīt pa labi pa kreisi - esmu šādus vairākus licis. Man patīk jo tuvāk sienai jo labāk
      Šāda tipa kronšteiniem nav tā, ka kā uzliek to TV, tā arī paliek? Var viņu tā brīvi bīdīt pa labi, pa kreisi pa to kronšteinu?
      Konfekšu vākšanas sacensības.
      Divus šādus un slidinies uz vella paraušanu    VonHaus TV Wall Bracket for 32-70" Screens, Ultra-Slim TV Bracket with Spirit Level, Flat to Wall Mount, 45kg Capacity, Max VESA: 400x400mm https://amzn.eu/d/7PSnPqE
    • dainis61
      a kas būs vakarā?
      Nu ja, vislabākajās bootistu tradīcijās.
      kā variants , ja uzmanīgi stiprinās, tad nemaz nekas nebūs manāms ... un ja neuzmanīgi stiprinās, tad būs manāms nekas.
      Diez vai.   Pēc ražotāja lapā redzamajām bildēm to TV varētu stiprināt arī pilnībā pie sienas:   Bet nu šajā gadījumā vajadzētu kaut kādu sienā iebūvētu kronšteinu.   Šie paredzēti stiprināšanai "between studs" (starp profiliem/brusām). Varbūt tādu jāpameklē un jāmēģina nostiprināt gāzbetonā. Vietējos veikalos gan neesmu redzējis, bet nu pie mums jau daudz ko nevar atrast/nopirkt (neesmu gan arī meklējis ilgāk par vienu vakaru).   TV blakus kamīnam, pa restēm kamīna sānā var nākt >100° gaiss, tāpēc gribu iespēju pavākt to TV malā, citādi jāpērk mazāku TV un naivi jācer, ka nekas tam TV karstuma ietekmē nenotiks.   ... nav un nebūs.
      Ambilight smukāk izskatās
      Varbūt pareizai ventilācijai?
      Nu ja reiz saod neeksistējošu problēmu, tad gan jau arī risinājums tavā uztverē neeksistē un nemaz nav iespējams. Tad kāda jēga prasīt modeli? Tai pat laikā daži labi dzelžu ražotāji un/vai to pārstāvji problēmas uzskata par eksistējošām un domā, kā tās risināt.   Kāpēc starp paneli un sienu jābūt 5-7 cm spraugai, ja varētu būt 2x mazāka?   Jebšu tev kur citur deguns lien un saož kaut ko neeksistējošu?
    • oxx
      Šeit https://www.ilota.lv/e-store/571/ noteikti varēs piemeklēt nepieciešamo.
      Saožu kārtējo neeksistējošo problēmu. Iedod TV modeli
    • Metrs
      Vai kādam no dalībniekiem ir ierakstīts Wecat? Lai sāktu izmantot jau reģistrētam biedram (vismaz 6 mēneši) vajag noskanēt QR kodu.  Ja kāds var izlīdzēt, raksiet PM.
      Attālums starp sienām palielinājies, laptopa 17" kļuvis par mazu priekš multenēm 🤪
      101.5k
