  • Kas ir tiešsaistē   21 biedri, 0 Anonīmi, 247 viesi (Skatīt pilnu sarakstu)
    • krabis
    • Ermis
    • bedrens
    • Regisss
    • kurtka
    • Arnis2002
    • marter
    • kava
    27466
    MareksLukaševics
    MareksLukaševics
      Es no tā maz saprotu, bet šis varētu būt šis kontrolieris. Visdrīzāk iemesls varētu būt kāds sensors. https://www.naturela-bg.com/en/product/39-npbc-v2-controller-for-pellet-burner Pēc idejas, ja ieslēgtu pliku kontrolieri uz displeja vajadzētu paradīties kādai kļūdai. Kāpēc visu laiku padod granulas? https://www.naturela-bg.com/files/NPBC-V3M-1_TM_2_1_EN.pdf Nezinu cik nopietni ir prasīt čatiņam? A boot freeze on an NPBC-V3M electronic pellet burner controller usually means the controller is not getting past its internal initialization — in other words the embedded electronics are failing to start the software/display properly when powered on. There isn’t an official “NPBC-V3M troubleshooting FAQ” for this specific symptom online, but based on how the controller is built and how similar embedded controllers behave, the common causes are: 🔌 1. Power supply issues If the controller isn’t receiving stable voltage (either too low, too high, or noisy power), its microprocessor can hang while booting. Loose power connection or bad mains supply. Faulty internal voltage regulator. Electrical noise from motors or other boiler equipment interfering with startup. 🧠 2. Firmware or software malfunction The NPBC-V3M runs embedded firmware that must initialize sensors and display at startup. If its firmware is corrupted, incomplete, or stuck during self-check, the display won’t progress past the boot screen. Corrupt firmware (power glitch during previous operation). Failed software update or incompatible version. Faulty flash memory inside the controller. 📡 3. Faulty sensors or inputs causing deadlock The controller self-diagnoses connected sensors early in boot. If a required sensor (like flame or temperature) is shorts/disconnected or providing invalid signals, the controller can hang waiting for a good reading. Open/shorted thermistor (temperature) connections. Faulty flame sensor or incorrect feedback input. Note: In the user manual, many sensor faults are shown as error codes during operation — but during boot some invalid sensor conditions can freeze the startup routine. 🔄 4. Hardware failure Internal electronic components on the board (microcontroller, RAM, capacitors) can fail: Bad solder joints or damaged microcontroller. A failed display/interface module that stops the boot process. Failing passive components (capacitors/filters) that distort the startup sequence. 🪜 5. External interference or wiring problems Poor grounding, electromagnetic interference (from motors/fans), or incorrect wiring can cause the controller to never complete its initialization and appear “stuck”. 🧩 How to narrow it down Here are practical steps you can take (safely with power off where needed): Check mains power and secure connections Ensure stable 220 V mains (or appropriate supply) and solid wiring to the controller. Disconnect non-essential sensors/actuators temporarily Unplug flame sensor, temperature probes, blower/fan connectors one at a time (power off first) to see if the controller boots without external inputs. Inspect wiring for shorts/opens A disconnected or shorted temperature/thermistor lead is a common fault that can confuse the controller early. Try resetting If there’s any reset button or process described in your manual, try that. Power cycle from the mains (off for ~30 s) before powering up again. Test with minimal configuration Remove all optional devices; power up with just the core controller module connected to power and display. Look for error indicators If the display ever shows an “E” with a code during boot attempts, note it — NPBC controllers use on-display codes for sensor/system errors. 🧠 When to consider replacement or repair If none of the above helps, it’s likely: Internal controller hardware failure Firmware corruption that requires service tool/PC update — NPBC-V3M supports RS-232/monitoring software for configuration and possibly firmware reflashing. In that case, contact the manufacturer/technical support or an electrician experienced with pellet boiler controllers.
      Viņu DTV (bijušais Baltkom) piedāvājumā ir lietuviešu "LRT", igauņu "Eesti Television", kā arī vācu/franču "Arte". Tiesa, tikai daudzīvokļu namos.
      Rudenī  Jau 4.gads kā jau kursē mākoņstūmēju vilciens    LETA   2015. gada 21. decembris Būvniecība tikšot veikta pa kārtām, minimizējot neērtības. Plāns esot braukt uz lidostu pa trasi 2022.gadā.   «Rail Baltica» projekta pirmajā kārtā Latvijai Brisele piešķīrusi 238 miljonus eiro, kas pārsvarā paredzēti dzelzceļa posma no Rīgas Centrālās stacijas līdz lidostai būvniecībai.
      Man pašam vācu kanāli nav aktuāli (neprotu vācu valodu), bet bērnam skolā ieteica pamācīties vācu valodu, skatoties https://www.ardmediathek.de. Kaut kādam "Das Erste" pieejama arī tiešraide - https://www.ardmediathek.de/live/Y3JpZDovL2Rhc2Vyc3RlLmRlL2xpdmUvY2xpcC9hYmNhMDdhMy0zNDc2LTQ4NTEtYjE2Mi1mZGU4ZjY0NmQ0YzQ
      Visticamāk. Tā kā nebiju drošs par pieslēgšanu, tad sākumā nepieslēdzu vispār. Rezultāts tāds pats.
      Motora pieslēgšana visticamāk, pofig. Nezin vai no motora nāk fīdbeks. Te drīzāk izskatās, ka kaut kāda atmiņa padzisusi.
      tieši tā!    Vispār piedāvājumu parasti regulē pieprasījums. Nezinu, vai pie mums tas strādā, bet pieņemu, ka kaut cik strādā. Iespējams, tava gaume ir atšķirīga no meinstrīma un nekādu sazvērestību teoriju nav..
      Principā, iespējams, sanāktu laba preču zīme  - "Briškena pālis".
    • Māšuks
      Kas tad liek abonēt viņu pakalpojumus? Ja jau nav īsti pa prātam.
    • motleyman
      Kādam vajag, kādam varbūt nevajag. Man, piemēram, nevajag pat pusi no tā, ko Bite piedāvā. Satelīts HD kvalitātē ... Nu ir tā kā 2026. gads, kad tehnoloģijas ir attīstījušās, lai vairs nevajadzētu stellēt šķīvi uz jumta. Ja jau vācieši negribētu, ka viņu ARD/ZDF skatās citās valstīs, tad jau tos sat saignālus sen būtu nokodējuši. Te Latvijā ticamāks variants ir tāds, ka atbildīgajiem neplp/seplp ir pilnīgi vienalga. Kaut kādu kanālu čupu apstiprinājuši un guļ kā sūnu ciemā nākošos desmit gadus. Ka tik krievi nav redzami. Latvija itkā Eiropā ? Neizskatās gan. Tādai Bitei nav pat neviena kanāla no kaimiņiem igauņiem un lietuviešiem. Bet ziemeļu un dienvidu pierobežā tās programmas labprāt skatītos legāli.
      Vēl rudenī bija ziņa, ka Eiropa meta pakaļ 80 ļamus, lai mēs, tizleņi, dabūvētu to fakin tiltu līdz otram krastam. Kas notika? Kāpēc vairs nemet? Un vai tiešām Briškena gaumē, nevis Linkaiša vai Vitenberga gaumē? @Racer, vai šis nav no tiem gadījumiem, kad "konceptuāli lēmumi bija pieņemti un neko tur mainīt nevarēja"?   Pie reizes vēlos apsveikt visus nacapu 🤡 fanus ar kārtējo lielisko triku! 👏🏻👏🏻👏🏻
      Vēl, protams, variants, ka kko ne tā pieslēdzu atpakaļ. Bet nu visus kontaktus izzvanīju, neesmu pārliecināts tik par 1 motoru, kuru tāpat neizmantoju. Man tā 3.3a vietā tagad rādās -.-
      Var jau arī internetā šo to redzēt, vācu kanālus te reizēm paskatos, tur gan ir dažas nianses lai skatītos visu un protams tieši interesantākajiem. https://schoener-fernsehen.com/ARD/
      Neizdevās, kā jau te teica, trafs beigts. Tagad ir ārējs. Pieslēdzu, bet pults paliek uz please wait un nonstopā dod granulas   Skaties PM
    • Māšuks
      Vai tad te baigi vajag tos kanālus , ja visu to ar sat šķīvīti var par brīvu redzēt HD kvalitātē. Tas gan nederēs , ja dzīvo daudzdzīvokļu namā
    • motleyman
      Jā, nav ko darīt. Jo nesēžu soctīklos. neesmu ne tiktokos, ne instagramos, ne feisbukos, kur jūs savu laiku izniekojiet. Skolā mācījos vācu valodu. Meitas ģimene dzīvo Vācijā. Regulāri braucu uz Vāciju paciemoties. Bet kāpēc vācu tv kanāli nav tv piedāvājumā Latvijā, tiešām nesaprotu. Nu ja - kādreiz krievu kanāli rullēja. Tagad ukraiņi. Neko citu no Eiropas jau bauriem nevajag ...
      Ok. Kā ar iebūvētā impulsnika remontu veicās?
      Pag, Tev ir šāda pati plate? Meistars izdarīja to ko iesakāt, pielika barokli atsevišķi. Procis strādā, vadības bloks ieslēdzas, bet paliek Please wait... statusā - jābrauc mājās, jāslēdz klāt, un jāskata, vai pieslēdzot pie visiem sensoriem, ir izmaiņas.   Ja Tev ir šāda plate un man nestrādās, gaidi PM.
      Kā teica viens dižgars, baumas par manu nāvi ir stipri pārspīlētas.
      Nebiji mājās kad humora sajūtu dalīja?  Atslābsti - Tu kaut kā visu laiku kā dzīves apbižotais te paudies. Turies - neviens Tev te ļaunu nevēl!
      101.9k
