Kas ir tiešsaistē 17 biedri, 0 Anonīmi, 166 viesi (Skatīt pilnu sarakstu)
- Broox2
- kava
- djamber
- M@R$$
- vekio
- spameris
- saf
- binary
- base7
- Murlo
- Pukinens
- formens
- Aigus
- Damn
- AlCohol
27303
Izmet to failu trashbinā. Man nekādu artefaktu nav. Rips no ripa atšķiras ļoti reizēm. Vai aizmirsti par iebūvēto pleijeri. Te jau teica to, ka var būt visādi brinumi Pleijeris - Nokia 8000 ar Plex app vai RasPlex . Complete name : L:\filmas_mkv1\Prometheus (2012) [BDRip.1080p.LV-ENG-RU].mkv Format : Matroska Format version : Version 4 File size : 14.2 GiB Duration : 2 h 3 min Overall bit rate : 16.5 Mb/s Frame rate : 23.976 FPS Movie name : Prometheus (2012) Encoded date : 2017-06-19 15:11:15 UTC Writing application : mkvmerge v7.9.0 ('Birds') 32bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 Cover : Yes Attachments : cover.jpg Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 3 min Bit rate : 14.0 Mb/s Width : 1 920 pixels Height : 800 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.380 Stream size : 12.1 GiB (85%) Title : Prometheus (2012) Writing library : x264 core 128 r2216 198a7ea
Jā, man ir bezmaksas ATX korpuss (20x45x45cm). Nelīda miskastes konteinerā 🤪 Var saņemt darbdienu rītos 7:30 pie RCHV. vai 24/7 Berģos
nu, taads forseejoshais kondikjis, jau pat SUhovam bija. Es vairaak par teemu - kaa tie kondikji iesleegti. Kondikji pret OPampa izeju, bet tam spogulim tranji pret baroshanu... Bet, par to paareejo - kadrs mieriigi nonaak totaalaas pretrunaas, bet tikpat mieriigi turpina betoneet ************************** Mans projekts leenaam, bet tomeer iet uz priekshu.
divi peedeejie kungi teemu nesaprata. Nu, neskumstiet, gan arii buus kaadas, kas jums patiks/derees
iPhone 12 Pro256gb - 250 eur, 82%, vizuāli kā jauns ar keisiņu un stikliņu virsū iPhone 7 plus 32gb - 50 eur, jauns ekrāns, aizmugure ar svīkām iPhone 6s 128gb + 5s 16gb - 30 eur Samsung Galaxy A52S - 95 eur
Par ko par ko? Par to ka nopērk TV nevis lai skatītotos filmas, bet lai jātos ar GUI 😂
Par ko cepiens? tu kkur nokačāji kkādu filmu kas izrādās sūdīgā kvalitātē un tagad taisies pārlodēt tv? Kādi tv? Marka modelis? Kur novilki to Prometeus?
Kaut kā nemanu, uz vecumu gan redze labāka nepaliek. Kaut kādu Samsung S95F slavē testos, ka bilde esot laba.
nee, es esmu truuciigs cilveeks. Vecais ir LG izliektais, jaunais - Samsung [modelis te kaut kur augstaak bija]. Bet, man chujs/njuhs saka, ka tur GUI bus kas liidziigs liimenja zinjaa
ja ir šaubas un iemests aliexpress links, tad ko tur vairs piedāvāt pārliecībai. cilvis tāpat atradis lētāko savai kategorijai tur. tas kā pateikt @biomass979, ka ir normāli samaksāt piečuku par windof pārinstalēšanu.
Jā, jā... es tā pat - pirms mēneša/diviem kādus piecus saplacināju lūžņos! Tagad meklēju kādu - kurš vēl nav izmetis!
Kur tu agrāk biji Pagājušo mēnesi 4 jaunus korpusus palaidu uz materiāliem
Jaunajam OLED, savukaart, Brightness uzvedas PILNIIGI savaadaak! Veertiibas 0..50. 25..50 - praktiski 0 ietekmes. Zem 20 - spilgtums samazinaas, melnaa Offset paliek nemainiigs [shim, patiesiibaa, Brightness darbojas kaa Contrast vecajam TV]. Contrast - ar nelielu ietekmi, iespeejams, bisku ar koefu 1.X izcelj spilgtuma ''vidusdalju''. Tb., Black level es piereguleet nevaru vispaar. Un saldajaa eedienaa: jaunaa TV menu un teksts zem taas. Taatad, man ir pults ar ''wheel'', pa labi/kreisi - es mainu value. Tagad jautaajums - man jaaspiezh ''enter'', lai izpildiitu ''exit/cancel'' darbiibu, savukaart, lai akcepteetu: left/right? left/right man maina veertiiibu, nevis ''akceptee''. Izskataas, ka GUI programmeejushi kaadi indusi ar chatinja paliidziibu. Sore, shajaa briidii man bezceriibaa nolaidaas rokas, par kraanu nerunaajot. Tas buutu reeciigi, ja nebuutu tik skumji.
Luuk, atbilde - ziimeejumaa. Shim modelim Brightness patiesiibaa maina Offset! Tb., pie 48..50 [videejaas veertiibas] grafiks [dati/atteelotais] iet caur 0 punktu. Ja Brightness ir virs 50, Offset tiek nobiidiits zem 0, tumshajaas detaljaas paraadaas visi artefakti un veelaak - tupa peleekais. Ja Brightness ir zem 48, paraadaas ''trepe'', tb., liidz zinamam datu value X atteelots netiek nekas. Atceros, kaa TV nopircis ciinijos ar to Brightness. Probleema tamaa, ka dazhaadiem source/failiem tas ''lietderiigais'' melnaa liimenis tomeer atskjiras. Attieciigi, uzliekot, piem., 48 shaadai 3 dias ir ok, bet ir filmas, kuraas pazuud mikrodinamika tuvu pie melnaa. Bet reeciigaakais - shim ''regulatoram'' ir relatiiivi nekaada ietekme videejaas/gaishaas ainaas/detalaajas, bet MILZU ietekme tieshi pie melnaa robezhas! Nu, manupraat, drusku fail sanaacis.
Nu ko, turpinam! Sho postu vareetu nosaukt - es esmu dolbajobs! Dalju no vecaa TV piedziivojumiem biju piemirsis [sen nebiju chakareejis], naacaas atsaukt atminjaa. Taatad, shim OLED tv ir pamatsetingi: spilgtums [brightness] un kontrasts. Un veel ir ''OLED brightness'' - wtf? Pienjemu, ka palicis rudiments no LED seerijaam - neies tak menu paartaisiit/saspringt! Kontrasts 0..100, ietekme neliela. Spilgtums 0..100, uz normaalas bildes ietekme ne paaraak buutiska. BET. Luuk, 4 bildes. Mans miiljais pretiigais fails 3 dias. Spilgtuma poziicijas: 48/50/52/54 Virs 54 viss ekraans paliek gaishi peleeks. Bet, kaa jau mineeju, uz ''normaalu bildi'' ietekme neliela! Kaa tas iespeejams?
Nopirkšu pci-e LAN tīkla karti. 5eur + pakomāts
Ghost_az · Ierakstīts
Nepieciešams datorkorpuss "gandrīz labdarības" datoram. Nepieciešams, lai var ielikt full ATX plati. Daudz/maz normālā izskatā. Sūtiet bildes. 5 eur vai labākais piedāvājums. Varu arī samainīt pret Chieftec Mech CT-01B
Kopā tēmu101.8k
