27284
Kā domājat, feiks, dzeltenā prese? https://newatlas.com/cancer/universal-cancer-vaccine/
Laikam nevarēšu. Jo te tomēr publiska vieta un raksts ir autortiesību aizsargāts. Bišķi bail, ka nepiesienas kāds.
Vari iemest tekstu šeit, lai lombardu karaļi bez tvnet abonementa arī var izlasīt?
Droši var piedāvāt barterus - interesē foto Canon, kāds 2x CPU workstation, 16TB+ HDD, vecāki High End dzelži. VGA - Gigabyte RTX 4070 Gaming OC = 400€ iepakojumā MB - ASUS ROG STRIX Z790-E Gaming WiFi II = 350€ iepakojumā, garantija līdz 29.01.2026 no 1A, piesaistīts W11 Pro, uzlikts svaigākais BIOS. MB - EK-Quantum MSI MPG X570S CARBON EK X D-RGB = 300€ pilns komplekts, iepakojumā, lietota gadu, gadu nostāvēja kastē. RAM - SK Hynix 128GB 16x8GB DDR3 ECC 1866MHz CL13 = 150€ ACC - WC rezervuārs EK-Quantum Reflection² PC-O11D EVO D5 PWM D-RGB = 250 kopā ar EK-Quantum Convection D5 pump cower un EK-Loop Connect Temperature Plug Sensor ACC - GPU WB EK-Quantum Vector² AMP/Trinity RTX 4090 D-RGB - Nickel + Plexi = 150€ ACC - CPU WB EK-Quantum Velocity² D-RGB LGA1700 Full Nickel = 100€ ACC -WC radiators EK-Quantum Surface P360M - Black = 90€ ACC -WC radiators EK-Quantum Surface S360 - Black = 60€ pieejami 2gb ACC - WC Pump EK-Loop DDC 4.2 PWM Motor = 50€ ACC - Aquacomputer Flow sensor high flow NEXT G1/4 = 50€ ACC - EK WC fitting and tube starter mega pack = 350€ EK-Quantum Torque HDC 12 - Black - 21pcs EK-Quantum Torque Micro HDP 12 - Black - 4pcs EK-Quantum Torque Extender Static MF 28 - Black - 4pcs EK-Quantum Torque Rotary 90° - Black - 12pcs EK-Quantum Torque Rotary Offset 14 - Black - 2pcs EK-Quantum Torque Rotary Offset 7 - Black - 6pcs EK-Quantum Torque STC-10/13 - Black - 5pcs EK-Quantum Torque Micro Extender Static MF 7 - Black - 10pcs EK-Quantum Torque Drain Valve - Black - 1pc EK-HD Tube Reamer EK-Loop Soft Tube Cutting Tool EK-Loop Hard Tube 12mm 0.8m Pre-Bent 90° - Acrylic (6pcs) - divas vēl nesagrieztas EK-Loop Soft Tube 10/13mm 3m - Clear EK-Loop Hard Tube 12mm 0.5m - Acrylic (2pcs) x2 EK-HD Tube D.I.Y. Kit 10&12mm EK-Loop Foldable Filling Bottle EKWB Filling Bottle, 1000mL ACC - Lian Li UNI FAN AL 120 RGB Black 10pack = 150€ 10 gabali, visi vadi plus kontrolieris, bez putekļiem, lietoti 2 gadi. ACC - Antec Fusion 120 ARGB 3+1 pack 80€ var teikt jauni, padarbināti pāris reizes testam komplektējot datoru, pamainījās dizaina vēlmes. Iepakojumos, ar kontrolieri. ACC - MSI M.2 XPANDER-AERO = 50€ ACC - inLine SATA RAID 4 port PCI 76698 = 20€ jauna, nelietota, LV garantija. Sūtot sapisos, nepiefiksēju ka uz PCI, nevis PCIE. ACC - HP Prodesk/Elitedesk WiFi Antenna 910151-001 WLAN ANT Kit M2 340/250 Ara Entl17 SFF = 20€ ACC - Ikea UPPSPEL regulējams sistēmbokla statīvs uz riteņiem = 10€ ACC - Turing 3.5" LCD PC Smart Screen = 10€ bez USB kabeļa, ar parasto statīvu Komplektācija un garantijas nav, ja nav norādīts savādāk. Mantas atrodas pļavniekos/centrā. Varam sarunāt piegādi. Izskatīšu arī maiņas. Cenas (dažreiz) runājamas.
Šodien TVNETā raksts par pašu sludinājumu pērli - par ss.com. Plus skrīnšoti par SIA SS no manas datubāzītes. https://www.tvnet.lv/8287981/dinozaurs-kas-pelna-miljonus-ka-darbojas-ss-com
https://karsuveikals.lv/lv/veikals/prece/?shop_id=33785
Šādu priekšzināšanu man nav. Bet nu ja tā, planšete logā un rullē. 🤷♂️
Te taču runa par taksistiem. Tiem tak vajag braukšanas laikā atvērt visus Waze, Bolt, kautādus messendžerus, vienlaicīgi runāt pa telefonu un apstiprināt citus braucienus, kā arī protams fonā skatīties Santu Barbaru. Nu jā, laika ziņas vēl laikam vajag.
Viņš jau ir domāts tikai spoguļot dažas aplikācijas, ko vajag braukšanas laikā, ne gluži YT skatīties. Ja neskaita, ka iekš KIA mans vecais Xiaomi bezvadu variantā šad tad atvienojas, tad citādi iekāpi un viss notiek pats no sevis - navigācija ieslēdzās, mūzika turpina skanēt. Ja kāds zvana, no stūres varu atbildēt. Ko tad vēl tur braukšanas laikā varētu vajadzēt?
ju · Ierakstīts
Ceru, ka modeli nesajaucu. Darbojas. Akumulators kaut ko vēl velk, neesmu testējis, bet 10min noteikti iztur Lādētājs nav. Virsū kaut kāds Android 6. Nav arī nomuļļāts. Bildēt slinkums. Pašsavākšana Jūrmalā, Asaros. Ak jā, ir vēl kaut kāds pocketbook e-grāmatu lasītājs (touch, wi-fi), ko neesmu aiznesis līdz atbilstošam konteineram. Viņam tur kaut kāda šleife uz ekrānu vai tml. čakarejās, it kā pirms tam pietika reizi pusgadā to atvienot/pievienot. Pēc manas pēdējās iejaukšanās it kā vairs neslēdzas iekšā 😁 -
CarPlay ir priekš Apple telefoniem. Android Auto priekš Android. Un tiem appiem vienmēr bijis samērā ierobežots funkciju apjoms.
Nez vai tur ko var darīt. Auto gan jau garantija, un, ja arī būtu, citu aparātu jau tagad neliksi. Ja būs kāds atjauninājums, iespējams, pie kārtējās apkopes to ieliks. Un kas tad ir tas, kas pietrūkst?
Edis7 · Ierakstīts
Šonedēļ veikalā saņēmu savu jauno mašīnīti Toyota Corolla, Sports T, Hybrid. Protams esmu priecīgs par viņas degvielas patēriņu pilsētā braucot ar viņu "korķos",-3,2L uz 100km! Bet sākot jaunu tēmu, CarPlay app ar Toyota ir pilnīgā @irsā! Piekonektējot savu tel. caur carplay sapratu, ka esmu pieslēdzies pie veca/primitīva , softa, kurš neatbalsta vairāk kā 80% Android tel. funkcijas. Tādēļ tēmas sākumā ir jaut. Ar ko sākt,kurā virzienā? upgrate lai carplay app nebūtu vienīgi mašīnas displeja rudiments ar primitīvām iespējām? -
Nezinu, neesu pētījis par ko Briedis fani, neesu arī redzējis neko, kur fanotu par krieviem. Par to ka visādas glupibas runā, tas gan manīts.
Nu tad tagad fano par maļčikiem trusikos, re, pats saprati
Bet vai tad tas nebūtu normāli? (ja apprecētu un brazītieti un fantazētu par karnevāliem)
Tikai novērota saistība, ka šādās jauktās ģimenēs, kur sieva gudrāka, iznākums ir šāds. Apprecējis viņš būtu kādu brazīlieti, moshka jau karnevālus katru vasaru pieprasītu.
Nu tās jau vienkārši sekas ka no tā ka dumjš. Bet nu pie visa krievi vainīgi, ka cilvēki dumji 😂
Dumjš ir viegli ietekmējams. Tur tā loģika. Lasīju interviju ar viņu un sievu, kas daudzus gadus veca jau un jau tur bija manāmas pazīmes, ka šī visu nosaka mājās. Un tādi gadījumi ir vairāki. Tas pats Točš vai kā viņu tur. Sieva ir no tā gala, un daudz, daudz gudrāka, tad nu Točš skrien ar Z burtu riņķī un raud par apspiestajiem Latvijā.
