edw Ierakstīts Decembris 2, 2006 Share Ierakstīts Decembris 2, 2006 ar ko var atvert SYS failu??? Link to comment Share on other sites More sharing options...
Krelin Decembris 2, 2006 Share Decembris 2, 2006 Ar Notepad nevar? Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 ar notepad Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 emm tas ir fails ar kuru man kipa ir jauzinstale draivers, ar notepad kka nesanaks... :/ Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 man labaak patiit notepad2 ko tad tu tur nomurgoji ??? Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 Nesam cauri edw? Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 man reademe noradits ka jatver sis fails lai uzinstaletu draiveri... :? pat nesaprotu... Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 iekopā to tekstu... Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 un arii pasaki kaadu os lieto un kaadu devaisu meigini pieenstaleet. Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 ÉĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶ» ŗ ŗ ŗ Compex RE100TX 10/100 PCI Fast Ethernet Adapter ŗ ŗ © Copyright PDS, 1999. All Rights Reserved. ŗ ŗ ŗ ČĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶĶ¼ ŚÄÄÄÄÄÄÄÄÄÄÄÄÄÄę ³ INTRODUCTION ³ ĄÄÄÄÄÄÄÄÄÄÄÄÄÄÄŁ Each Network OS directory in this disk contain installation procedure. Its a text base file with the extension .TXT e.g Netware v4.xx, the installation procedure file name and directory A:\NW4X\NW4X.TXT Windows NT v4.0, the installation instruction file and diretory A:\NT40\NT40.TXT Due to the many drivers provided in this disk, space is a constrain. Some support files are compressed. To install, copy them to the local hard disk and run to extract before you start the installation. The files contained in this driver diskette is designed to support the following adapter: Compex RE100TX 10/100 PCI Fast Ethernet Adapter ŚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄę ³ DESCRIPTION OF FILES AND DIRECTORY STRUCTURE ³ ĄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄŁ General Information of driver disk ----------------------------------- A:\README.TXT This file A:\DISKID.TXT Information about this disk User Diagnostic Utility ----------------------- A:\UTILITY\DIAGNOST.TXT User document file \DIAGNOST.EXE Diagnostic utility Microsoft Windows 95 Rel.B (OSR2), Windows 98, and Windows NT v4.0 ------------------------------------------------------------------- * Action: During installation when prompt for driver, enter A:\ A:\WIN95\WIN95.TXT Installation guide for Windows 95 driver. \UNRE95.BAT Quick delete of RE100TX installed files in Win95 A:\WIN98\WIN98.TXT Installation guide for Windows 98 driver. \UNRE98.BAT Quick delete of RE100TX installed files in Win98 A:\NT40\NT40.TXT Installation guide for NDIS driver for Windows NT 4.0. A:\RE100ND4.SYS NDIS 4 driver for Windows NT 4.0, Windows 98 A:\OEMSETUP.INF Installation setup file for Windows NT 4.0 A:\RE100ND4.INF Installation setup file for Windows 98. A:\RE100TX.HLP Installation help file for Windows NT 4.0 Microsoft Windows 95( First release version) -------------------------------------------- * Action: During installation when prompt for driver, enter A:\NDIS3 A:\NDIS3\NDIS3.TXT Installation guide for Microsoft Windows \RE100ND3.SYS NDIS3 driver for Windows 95(earlier release version) \RE100ND3.INF Installation setup file for Windows 95 Microsoft Windows NT v3.51 -------------------------- * Action: During installation when prompt for driver, enter A:\NT351 A:\NT351\NT351.TXT Installation guide for Microsoft Windows NT v3.51 \OEMSETUP.INF Installation setup file for Windows NT v3.51 \RE100ND3.SYS NDIS3 driver for Windows NT 3.51 Microsoft Windows 2000 ---------------------- * Action: During installation when prompt for driver, enter A:\WIN2000 A:\NT351\WIN2000.TXT Installation guide for Microsoft Windows 2000 \OEMSETUP.INF Installation setup file for Windows 2000 \RE1005.CAT Installation support for Windows 2000 \RE100ND5.SYS NDIS5 driver for Windows 2000 Microsoft Windows for Workgroup v3.11 ------------------------------------- * Action: During installation when prompt, enter A:\WFW311 for driver. A:\WFW311\WFW311.TXT Installation guide for Windows for Workgroup driver. A:\WFW311\RE100.386 NDIS3 driver for Microsoft Windows for Workgroups v3.11. A:\WFW311\OEMSETUP.INF Adapter installation file for NDIS driver in Windows for Workgroups environment. Microsoft LAN Manager --------------------- * Action: During installation when prompt for driver, enter A:\ A:\MSLANMAN.DOS The directory for LAN Manager DOS. | |___ DRIVERS |___ ETHERNET | |___ RE100 | |___ RE100.DOS | |___ PROTOCOL.INI |___ NIF |_____ RE100.NIF A:\MSLANMAN.OS2 The directory for LAN Manager OS/2. | |___ DRIVERS |___ ETHERNET | |___ RE100 | |___ RE100.OS2 | |___ PROTOCOL.INI |___ NIF |_____ RE100.NIF Novell NetWare -------------- DOS workstation driver ---------------------- * Action: Follow instructions in DOSODI.TXT to load the client drivers to connect to the server. A:\DOSODI\DOSODI.TXT NetWare Client for DOS installation guide A:\DOSODI\RE100TX.COM NetWare DOS ODI workstation driver for NetWare 2.x, 3.1x and 4.xx and IntranetWare. A:\DOSODI\RE100TX.INS NetWare Client configuration file \NET.CFG Sample configuration file for DOS ODI workstation driver. Windows 95 and NWClient32 support --------------------------------- * Action: During installation when prompt for driver, enter A:\NW4.X A:\CLIENT32\CLIENT32.TXT Installation guide \ODIRE100.INF Setup file for NetWare Client32 using RE100.LAN driver NetWare OS/2 Requester for OS/2 workstation driver -------------------------------------------------- * Action: During installation when prompt for driver, enter A:\ A:\OS2\OS2ODI.TXT Installation guide for OS/2 Requester \RE100S2.SYS NetWare OS/2 Requester Server driver ------------- NetWare v4.xx ------------- * Action: During installation when prompt for driver, ener A:\NW4.X A:\NW4.X\NW4X.TXT Installation guide for NetWare v4.xx \R100A.LAN Loadable RL100ATX ODI server driver for NetWare 4.x. \R100A.LDI Installation support file for RL100A.LAN. \4XLDR.PAT\.. Server loader patch utility \NLM4X.EXE Compressed file of ** Listing in compressed file ** \ETHERTSM.NLM Support files for NetWare v4.0, and v4.10 \MSM.NLM \NBI.NLM NetWare v3.12 ------------- * Action: During installation when prompt for driver, enter A:\NW3.12 A:\NW3.12\NW312.TXT Installation guide for R100A.LAN. \R100A.LAN Loadable RL100ATX ODI server driver for NetWare 3.12. \NW312.PAT\.. Server loader patch utility \NLM312.EXE Compressed of support NLMs ** Listing in compressed files ** ETHERTSM.NLM, Support files for NetWare v3.12 MSM31X.NLM, NBI31X.NLM NetWare v3.11 ------------- * Action: Download from FTP server and follow the NW311.TXT installation instruction file to install. IBM OS/2 Warp and LAN Server ---------------------------- * Action: During installation when prompt for driver, enter A:\IBMLS A:\NDIS2\IBMLS.TXT Installation guide for NDIS 2.01 driver in IBM Lan Server A:\NDIS2\OS2\RE100.NIF Configuration file for IBM OS/2 Warp Connect and IBM LAN Server A:\NDIS2\OS2\RE100.OS2 OS/2 NDIS 2.01 driver. IBM AS400 DOS client support ---------------------------- \AS400\SAMPLE.TXT Installation guide and sample configuration files. UNIX ---- SCO UNIX OpenServer5 -------------------- * Action: During installation when prompt for driver, insert disk in drive A and click OK. A:\SCO\SCO5MDI.TXT Installation guide for SCO OpenServer 5 \CUSTOM.DST SCO OpenServer 5 driver * Action: Compilation of the driver required to run on various releases of Linux Refer to the respective Linux version for instruction. Linux Red Hat ------------- \LINUX\RE100TX.C Source code for compilation on different version Linux \INSTALL.TXT Driver install guide. Banyan Vines ------------ * Action: During installation when prompt for driver, enter A:\NDIS2 A:\BANYAN\BANYAN.TXT Installation guide and sample Protocol.ini file \PROTOCOL.INI General NDIS2 driver support ---------------------------- * Action: During installation when prompt for driver, enter A:\NDIS2 A:\NDIS2\NDIS2.TXT General information about NDIS2 driver support \MSC30.TXT Installation guide for Microsoft Client v3.0 \OEMSETUP.INF Microsoft Client 3.0 and WFW v3.11 setup file \RE100.DOS NDIS2 DOS driver \RE100.OS2 NDIS2 OS/2 driver \PROTOCOL.INI sample configuration file General packet driver for PC/TCP and other softwares ---------------------------------------------------- * Action: During installation when prompt for driver, enter A:\PKT A:\PKT\PKT.TXT Installation guide \RE100PD.COM Packet driver Digital Pathworks ----------------- * Action: During installation when prompt for driver, enter A:\NDIS2 A:\PATHWORK\PATHWORK.TXT Installation guide for Pathworks SunSoft PCNFS ------------- * Action: During installation when prompt for driver, enter A:\NDIS2 A:\PCNFS\PCNFS.TXT Installation guide for PCNFS ------------------------ so debesu davanu!!!! http://www.boot.lv/forums/index.php?showtopic=57886 Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 nu viens uzciitiigs cilveeks kurs pat readme failu lasa pirms instalaacija , tagad tik vel atliek uzzinaat kaada os un no kaada datu neseeja meigini draivuku iemaaniit Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 xp profesional un divaina karta vins neatpazist un neinstale tos draiverus automatiski... Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 pameigini caur control paneli -> add hardwari un manuaali noraadi celu uz draiveri Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 ok, meginasu.... nelauj noradit vinju... :? kipa piedava sys formata bet to naparada vienkārši neatrod, kad norada atrasana vietu.. :? vel jautajums ko nozime ta roka kas 1 ikonai apaksa??? :? Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 ar karotiiti mutiitee jaastumj kad atveeras add hardware logs spiezam next iespiezam yes next liftu lidz lejai un izveelamies add new hardwari ..... next un izveelamies pashrociigi noraadiit celu uz draiveri ja taalaap nemaaceesi tad izsauc uz maju speceaalistu pa 10 ls srtundaa kursh nepilnu 2 stundu laikaa pieinstalees 3 latus veertu devaisu lidzi naaca diskete, a vispaar tai disketee ir draivuks prieksh winxp? tu man liekas esi pelnijis kartiigu speerienu pa pecpusi bildee tak labi redzams ka tev taa otra tiiklene jau sen ir pieinstaleeta un taa roka roraada ka tikls ir noshaareets. Link to comment Share on other sites More sharing options...
Vilx- Decembris 2, 2006 Share Decembris 2, 2006 .SYS ir reaalais mashiinkods, kas ir tas draiveris. Lai vinju pieinstaleetu nepiecieshams .INF fails, kursh apraksta kaa tas draiveris jaapieinstalee un par ko vinjsh ir atbildiigs. Es pienjemu, ka tai tiikla kartei naaca liidzi disketiite, uz kuras tas viss ir, vai ne? Ja .INF faila nav tajaa pashaa folderii, kuraa .SYS fails, tad tas vareetu buut root folderii (pats "augstaakais" folderis diskaa). Pameegjini noraadiit to. Ak, jaa - noraadiishanu veic shaadi - panjem ar labo pogu uz My Computer, nospied Manage. Ej uz Device Manager. Atrodi vainiigo tiikla karti (vajadzeetu buut ar dzeltenu trijstuuriiti) un njem Update Driver. Seko instrukcijaam. Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 ar karotiiti mutiitee jaastumj kad atveeras add hardware logs spiezam next iespiezam yes next liftu lidz lejai un izveelamies add new hardwari ..... next un izveelamies pashrociigi noraadiit celu uz draiveri ja taalaap nemaaceesi tad izsauc uz maju speceaalistu pa 10 ls srtundaa kursh nepilnu 2 stundu laikaa pieinstalees 3 latus veertu devaisu lidzi naaca diskete, a vispaar tai disketee ir draivuks prieksh winxp? tu man liekas esi pelnijis kartiigu speerienu pa pecpusi bildee tak labi redzams ka tev taa otra tiiklene jau sen ir pieinstaleeta un taa roka roraada ka tikls ir noshaareets. es visu ta dariju, nekas nenotika... neesmu tik pasists lai to nesaprastu... Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 tas ir tas cilveks kas mokas jo grib esoshajai iebuvetajai tiklakartei pielikt PCI compex firmas tikleni otru, bet es redzu vinja darbibas rezultata winda uzlikusi to kaa realteku - tagad vinjam butu tas shit janonjem un ta vieta pareizie compex easylink tiklenes draiveri jaiestumj bet to vinsh nespees - garanteju, shitajaa limenii par agru... bernudarzs ezw - pasaki - tad kapec tev vajadzeja to otru tikleni vispar ? disketiiti cilveeks pazaudeeja vai nu nebija vispaar jo taa compex tiklene ir kaukada ultra-kreisaa vismaz labi ka cilveks reali sastopas ar problemam un risina ! taa tureet ! istie sisadmini visi taa saka, pashi, ar rocinjaam... Link to comment Share on other sites More sharing options...
maize Decembris 2, 2006 Share Decembris 2, 2006 Visu neizlasīju, varbūt tu jau tā darīji, bet seko Vilx- norādījumiem + mēģini barot Windows 2000 paredzēto draiveri, vai novelc: http://network.free-driver-download.com/Co...T4-2000-XP.html Link to comment Share on other sites More sharing options...
Krelin Decembris 2, 2006 Share Decembris 2, 2006 ..bet to vinsh nespees - garanteju, shitajaa limenii par agru... bernudarzs... Un Tev liimenis labaaks, ja shitaa brauc augumaa? Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 ja naca lidz tikai man nav flipika un nevaru to nolasit atradu neta to pasu un iegaju kur teici man rada sadi... kipa uzinstaleta, bet kada velna pec vinja nestrada... ? :? Link to comment Share on other sites More sharing options...
Moon Decembris 2, 2006 Share Decembris 2, 2006 izlasi velreiz peedeejo MainFrame postu un veic secinaajumus kapeec tava tiikla karte nestraadaa. Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 .... Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 winda pieinstaleejusi ne to draiveri tavai nic. Taisi update driver un noraadi pareizi Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 tas ir tas cilveks kas mokas jo grib esoshajai iebuvetajai tiklakartei pielikt PCI compex firmas tikleni otru, bet es redzu vinja darbibas rezultata winda uzlikusi to kaa realteku - tagad vinjam butu tas shit janonjem un ta vieta pareizie compex easylink tiklenes draiveri jaiestumj bet to vinsh nespees - garanteju, shitajaa limenii par agru... bernudarzs ezw - pasaki - tad kapec tev vajadzeja to otru tikleni vispar ? disketiiti cilveeks pazaudeeja vai nu nebija vispaar jo taa compex tiklene ir kaukada ultra-kreisaa vismaz labi ka cilveks reali sastopas ar problemam un risina ! taa tureet ! istie sisadmini visi taa saka, pashi, ar rocinjaam... es teicu ka vajag sasleg 2 datorus un man ir ta diskete, bet NAV FLOPIKA!!!un ja man kads normali spetu paskaidrot tad to izdaritu! Visu neizlasīju, varbūt tu jau tā darīji, bet seko Vilx- norādījumiem + mēģini barot Windows 2000 paredzēto draiveri, vai novelc: http://network.free-driver-download.com/Co...T4-2000-XP.html dariju jau entas reizes parada ERRORU!!!!! Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 Vajadziigie faili (tb draiveri) var arii nebuut uz disketes. Svariigaakais, ka tev vinji _ir_. Vai tomeer nav? Un ko noziimee? - "man nav diskete, bet nav flopika" Un vispaar shajaa http://network.free-driver-download.com/ur...EST0&link=0 arhiivaa ir viss vajadziigais tb 3 faili winxp direktorijaa, ja vien draiveris ir iistais. dariju jau entas reizes parada ERRORU!!!!! konkreetaak... Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 Un Tev liimenis labaaks, ja shitaa brauc augumaa? jaa krelin, ir, nee, nebraucu - tas tikai taa izskataas ... patiesiiba ir tur aaraa ... tef interneta vads ir ar ko tos divus saslegt ? ja vel to japaskaidro kaa taisiit, tad pateikshu, ka tev vajag "crossover" kabeli {ja izdoma veikala pirkt} jo ir kabelji "no rutera/switcha uz kompi" un "starp kompi un kompi, jeb starp divam tiklenem" - crossover ja kas; Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 Vajadziigie faili (tb draiveri) var arii nebuut uz disketes. Svariigaakais, ka tev vinji _ir_. Vai tomeer nav? Un ko noziimee? - "man nav diskete, bet nav flopika" Un vispaar shajaa http://network.free-driver-download.com/ur...EST0&link=0 arhiivaa ir viss vajadziigais tb 3 faili winxp direktorijaa, ja vien draiveris ir iistais. konkreetaak... ludzu tur ir paradits tas errors! Link to comment Share on other sites More sharing options...
eziitiss Decembris 2, 2006 Share Decembris 2, 2006 Centiishos iisi pastaastiit: Probleema tagad ir taa, ka tev WinXP ir uzlicis nepareizaas tiikla kartes draiveru, taadeel, 1) novelc no neta sho un atarhivee 2) atver uz device manangeru 3) atrodi jauno tiikleni 4) uzspied uz vinas un izveelies izspeeju "update driver.." 5) Spiezam "No not this time" ->next 6) izveelamies "Instal from list or specific location" ->next 7) atrodi atarhiveeto mapi/WinXP ->OK P.S. Ja ar sho vinsh nobreecas, ka vina pashreizeejais draiveris ir labaaks nekaa tas ko tu gribi instaleet, tad meegini vispirs to devaicu(tiikleni) atinstaleet un pieinstaleet pa jaunam ar pareizajiem draiveriem, nelaujot Winam neko mekleet pasham (taa kaanoraadiijju saakumaa) Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 jaa krelin, ir, nee, nebraucu - tas tikai taa izskataas ... patiesiiba ir tur aaraa ... tef interneta vads ir ar ko tos divus saslegt ? ja vel to japaskaidro kaa taisiit, tad pateikshu, ka tev vajag "crossover" kabeli {ja izdoma veikala pirkt} jo ir kabelji "no rutera/switcha uz kompi" un "starp kompi un kompi, jeb starp divam tiklenem" - crossover ja kas; es to visu zinu un ja man ir crossover kabelis!!!! bet man vel vajag viena datora 2 ejosas tiklenes, bet nez kada velna pec ta viena neiet!!!! Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 ludzu tur ir paradits tas errors! nemaaku ieraudziit Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 es pienjemu, ka ta compex tiklene ir ieskruveta kompii un vads nekads nav pieslegts - tapec ari sarkans krustinsh ka nav stravas +5 uz kontaktiem uz bildites ar sarkano krustinju spied labo peles pogu, izvelies: status, nospied ar kreiso peles pogu; pec tam ar kreiso spied properties: tur, kur ieksh General rakstits: Connect using: tavakarte - spied Configure; izvelies sadalju Driver; spied Update driver; parliec melno punktinju uz Install from a list or specific location un spied Next; ieleic zaljo punktinju pie vardiem: Don't search; spied Next; neskaties, ko raksta; spied Have disk; spied Browse; izvelies mapi, kur tu atarhiveji pirms tam draiveri savai tiklenei un automatiski jau mekle inf tipa failu; tad, kad atrodi to inf failu spied open un seko noradijumiem; man pat sak interesanti palikt, vai es speshu atrast pareizos vardus, kaa paskaidrot lai iznak, un vai mums pietiks pacietibas sagaidit to bridi, kad musu foruma biedrs iesauksies - hurraaaa - iznaaca, paldies, vechi ! ato visu dzivi taisu shito ar aizvertam acim - un she tev nu bij' nevaru pastastit saprotami... Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 Tas briidis pienaaks... Link to comment Share on other sites More sharing options...
eziitiss Decembris 2, 2006 Share Decembris 2, 2006 Itkaa forumaa pastaasta kas un kaa, taadaa veidaa cilveeks pats iemaacaas tikt galaa ar probleemaam un otreiz vairs visticamaak ka nejautaas, bet ir gadiijumi, kad paskaidrot ir bezceriigi, jo ir kaut kaada komunikaacijas barjera (edw - neuztver paaraak personiski) Varbuut shaados gadiijumos cilveekam paraadiit kaa un ko dariit uz vina pasha ekraana, piemeeram, izmantojot VNC ? Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 drikst es shaja topika iemetishu "easter egg" un pajautashu vai kads ir stradajis ar pakeshu rakstishanu uz cd-rw vai dvd-rw matricaam: tas ir taa kad uzliec softu, kas ljauj gandriz ka uz lielas disketes rakstit datus uz cd vai dvd - rakstit, nolasit, palaist, dzest utml Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 nu nestrada neviens no jusu variantiem!!!! :( Link to comment Share on other sites More sharing options...
Val Decembris 2, 2006 Share Decembris 2, 2006 Sorii, edw, bet ir jaabuut galiigam [ieliec ko gribi sheit] lai no shitaa visa teksta nesanaaktu uzstelleet tiikleni. Ja kautkaadu tekstu nesaprati, tad prasi, kameer visi veel nav aizmigushi Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 es pienjemu, ka ta compex tiklene ir ieskruveta kompii un vads nekads nav pieslegts - tapec ari sarkans krustinsh ka nav stravas +5 uz kontaktiem uz bildites ar sarkano krustinju spied labo peles pogu, izvelies: status, nospied ar kreiso peles pogu; pec tam ar kreiso spied properties: tur, kur ieksh General rakstits: Connect using: tavakarte - spied Configure; izvelies sadalju Driver; spied Update driver; parliec melno punktinju uz Install from a list or specific location un spied Next; ieleic zaljo punktinju pie vardiem: Don't search; spied Next; neskaties, ko raksta; spied Have disk; spied Browse; izvelies mapi, kur tu atarhiveji pirms tam draiveri savai tiklenei un automatiski jau mekle inf tipa failu; tad, kad atrodi to inf failu spied open un seko noradijumiem; man pat sak interesanti palikt, vai es speshu atrast pareizos vardus, kaa paskaidrot lai iznak, un vai mums pietiks pacietibas sagaidit to bridi, kad musu foruma biedrs iesauksies - hurraaaa - iznaaca, paldies, vechi ! ato visu dzivi taisu shito ar aizvertam acim - un she tev nu bij' nevaru pastastit saprotami... vinajai nevar atver status!!! tas ir iespejam tikai tai kam nav krusta!!! Sorii, edw, bet ir jaabuut galiigam [ieliec ko gribi sheit] lai no shitaa visa teksta nesanaaktu uzstelleet tiikleni. Ja kautkaadu tekstu nesaprati, tad prasi, kameer visi veel nav aizmigushi nu smejos vai raudu BET NESTRADA!! Link to comment Share on other sites More sharing options...
Guest MainFrame Decembris 2, 2006 Share Decembris 2, 2006 open network connections > uz tas otras kartes > properties un talak tapat ka jau rakstiju es neieshu gulet kamer neiemocisim .. a tu zini ka uztaisit lai internets ari otram kompim ietu pec tam kad saslegsi ? Link to comment Share on other sites More sharing options...
edw Decembris 2, 2006 Author Share Decembris 2, 2006 nu ok izdariju ka teizi noradiju mapi atradu to failu uzunstaleju, bet tik un ta neatpazist.... :? ja zinasu... es saku si tiklene ir kautkads ipasai gadijums!!!! visu laiku man ir normali sanacis.... bet ar so ne ka.. :? Link to comment Share on other sites More sharing options...
