intssed
Adobe Creative Cloud Kolekcija neuzliekas. Lūdzu palīdziet!
intssed
Sveiki!
Windows 10, x64 instalēšana vienmēr apstājas pēc 3 minūtēm un sākas "Rollback". Lūdzu, palīdziet!
Paldies!
Log faila saturs zemāk:
Spoiler
02/13/20 12:38:23:263 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Build Version - 1.15.0.126
02/13/20 12:38:23:263 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Logging Level verbosity Set  to 4
02/13/20 12:38:23:301 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Successfully fetched the optionXML content from MSI database ...
02/13/20 12:38:23:336 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | The OS language detected for Acrobat (en_US)
02/13/20 12:38:23:341 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | MSI ProductCode ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) is not installed on the system ...
02/13/20 12:38:23:344 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | The install language for Acrobat (APRO19.0) from the fallback map (en_US)
02/13/20 12:38:23:344 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 12:38:23:345 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 12:38:25:094 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Build Version - 1.15.0.126
02/13/20 12:38:25:094 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Logging Level verbosity Set  to 4
02/13/20 12:38:25:094 | [ERROR] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | The Bootstrapper Process return code is (21).
02/13/20 12:38:25:094 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 12:38:25:094 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 12:38:54:667 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Build Version - 1.15.0.126
02/13/20 12:38:54:667 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Logging Level verbosity Set  to 4
02/13/20 12:38:54:667 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | The return code from the Bootstrapper Process is (0).
02/13/20 12:38:54:681 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe" --nonRIBSMode="1" --deploymentFile="C:\Users\ADMINI~1\AppData\Local\Temp\\{F0A7044B-DC5B-4CFC-B266-1965D610F3D4}"
02/13/20 12:39:59:115 | [INFO] |  | ASU | OPM | OPM |  |  | 3184 | Build Version - 10.0.0.130
02/13/20 12:39:59:115 | [INFO] |  | ASU | OPM | OPM |  |  | 3184 | Logging Level verbosity Set  to 4
02/13/20 12:39:59:117 | [INFO] |  | ASU | OPM | OPM |  |  | 3184 | Schema version and schema compatibility version are same or greater than current
02/13/20 12:39:59:302 | [INFO] |  | ASU | OPM | OPM |  |  | 3184 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 12:39:59:302 | [INFO] |  | ASU | OPM | OPM |  |  | 3184 | No Record found for the input fields in opm_getValueForKey
02/13/20 12:40:04:717 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Process creation completed.
02/13/20 12:40:04:717 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | The return code from the Adobe Installer Process is (0).
02/13/20 12:40:04:718 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /i "C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi" /qn
02/13/20 12:40:06:147 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2032 | Build Version - 1.15.0.126
02/13/20 12:40:06:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2032 | Logging Level verbosity Set  to 4
02/13/20 12:40:06:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2032 | Executing immediate custom action for install mode.
02/13/20 12:40:06:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2032 | The CustomActionData string is : mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi;installLang=
02/13/20 12:40:06:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2032 | Successfully executed the immediate custom action for install mode .
02/13/20 12:40:09:503 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:09:503 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:09:503 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Executing the deferred custom action.
02/13/20 12:40:09:505 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Obtained the following as CustomActionData
02/13/20 12:40:09:506 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | (mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi;installLang=)
02/13/20 12:40:09:506 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Original database path is : C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi
02/13/20 12:40:09:517 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | OptionXML saved at location :: C:\Users\ADMINI~1\AppData\Local\Temp\{7E2D1708-AE97-4645-856D-78DC9BF20780}\\{E995CB2F-F316-48EF-AE8D-6CE841C3778C}
02/13/20 12:40:09:545 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | CustomAction Parameters obtained...
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |  optXMLPath :: C:\Users\ADMINI~1\AppData\Local\Temp\{7E2D1708-AE97-4645-856D-78DC9BF20780}\\{E995CB2F-F316-48EF-AE8D-6CE841C3778C}
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |  setupBasePath :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |  installDirPath ::
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |  installLang ::
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Initializing Custom Action Data from parameters
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Provisioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{7E2D1708-AE97-4645-856D-78DC9BF20780}\\{DE487F2C-4584-467C-8531-C6A4F76D3E58}).
02/13/20 12:40:09:546 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Preconditioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{7E2D1708-AE97-4645-856D-78DC9BF20780}\\{C55F334B-5538-42BE-BB64-5C2A9DB045CB}).
02/13/20 12:40:09:547 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Starting to run the custom action for install mode
02/13/20 12:40:09:547 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | STEP 1: Starting to parse Option XML.
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Match OS lang option selected
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Added OS Language (en_US) to the install language fallback.
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Install language fallback contains following languages :
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |     (en_US)
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 |     (en_GB)
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Self-Update BootStrapper Relative Path doesn't exist.
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failure in getting Self-Update Folder Path.
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | No of updates found (0).
02/13/20 12:40:09:590 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | No of HD products found (14).
02/13/20 12:40:09:591 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:591 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (LIBS3.6.1)...
02/13/20 12:40:09:593 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:593 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (COCM1.0)...
02/13/20 12:40:09:599 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:599 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (COSY4.3.24)...
02/13/20 12:40:09:601 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:601 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (KANC1.0.1)...
02/13/20 12:40:09:602 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | The media info tag marked for auto-install (KANC) (1.0.1)
02/13/20 12:40:09:604 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:604 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (CCXP3.4.0)...
02/13/20 12:40:09:607 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:607 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (CORG1.1)...
02/13/20 12:40:09:613 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:613 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (CORE1.0)...
02/13/20 12:40:09:615 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get value for conflicting processes...
02/13/20 12:40:09:615 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to parse the conflictProcessInfo for HD media (COPS1.0)...
02/13/20 12:40:09:632 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Custom deployment path doesnt exist in options XML
02/13/20 12:40:09:649 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to find Royalty Bearing attribute info.
02/13/20 12:40:09:649 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Found the AppsPanel attribute info (true)
02/13/20 12:40:09:649 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Found the AdminPrivilege attribute info (false)
02/13/20 12:40:09:649 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Number of Medias found = 1
02/13/20 12:40:09:653 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Deployment XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{53A1CD69-1CE5-48AA-8E6D-3B82FE537B5E}\\{F28968AD-CAAB-4771-97A9-495198E55FF6}
02/13/20 12:40:09:657 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Override XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{53A1CD69-1CE5-48AA-8E6D-3B82FE537B5E}\\{B28159D3-18D0-4537-B26D-D0739E2C2ECE}
02/13/20 12:40:09:658 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Conflict process info retrieved (<ConflictingProcess headless="false" forceKillAllowed="false" adobeOwned="false">
	<RegularExpression>^[Pp][Oo][Ww][Ee][Rr][Pp][Nn][Tt]\.[Ee][Xx][Ee]$</RegularExpression>
	<ProcessDisplayName>Microsoft PowerPoint</ProcessDisplayName>
	<ParentRegularExpression></ParentRegularExpression>
	<ParentDisplayName></ParentDisplayName>
	<RelativePath></RelativePath>
</ConflictingProcess><ConflictingProcess headless="false" forceKillAllowed="false" adobeOwned="true">
	<RegularExpression>^[Aa][Cc][Rr][Oo][Bb][Aa][Tt]\.[Ee][Xx][Ee]$</RegularExpression>
	<ProcessDisplayName>Adobe Acrobat X</ProcessDisplayName>
	<RelativePath>[INSTALLDIR]\Acrobat 10.0\Acrobat\Acrobat.exe</RelativePath>
</ConflictingProcess><ConflictingProcess headless="false" forceKillAllowed="false" adobeOwned="false">
	<RegularExpression>^[Ww][Ii][Nn][Ww][Oo][Rr][Dd]\.[Ee][Xx][Ee]$</RegularExpression>
	<ProcessDisp
02/13/20 12:40:09:658 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Deployment Manager is running in Install Mode.
02/13/20 12:40:09:659 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | STEP 2: Starting to launch ASU AAM.
02/13/20 12:40:09:659 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0
02/13/20 12:40:09:665 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Latest AAM version with the package is (5.0.0.354)...
02/13/20 12:40:09:666 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 12:40:11:397 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:11:397 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:11:398 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | The return code from the Bootstrapper Process is (21).
02/13/20 12:40:11:398 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9
02/13/20 12:40:11:399 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Latest AAM version with the package is (4.9.0.515)...
02/13/20 12:40:11:399 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 12:40:13:049 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:13:049 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:13:049 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | The return code from the Bootstrapper Process is (0).
02/13/20 12:40:13:051 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
02/13/20 12:40:13:051 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Starting apply CCP ASU.
02/13/20 12:40:13:051 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU2\Set-up.dat
02/13/20 12:40:13:052 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:13:052 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:13:052 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to launch the Bootstrapper process.Stopping the installation process.
02/13/20 12:40:13:052 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | CCP ASU installation failed with ErrorCode (81). Ignoring this ASU failure.
02/13/20 12:40:13:052 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2012 | Skipping custom installs, either path does not exist or not directory (C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\pre)
02/13/20 12:40:13:167 | [INFO] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 2012 | Conflict processes not running or killed successfully ...
02/13/20 12:40:13:184 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to find the pdb database.
02/13/20 12:40:13:184 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get the local payload database handle.
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | STEP 3: Starting to launch Bootstrapper of Media (APRO19.0).
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | The Bootstrapper seems to be missing(C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Setup\APRO19.0\Set-up.dat). Skipping the installation process.
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Correcting Dependencies in local db.
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | No media db present on the machine.
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | STEP 4: Starting to launch Adobe Installer.
02/13/20 12:40:13:184 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping exception: APRO19.0.
02/13/20 12:40:16:335 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:16:335 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:16:335 | [FATAL] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 2012 | The HDPIM Setup Process return code is (195).Stopping the installation process.
02/13/20 12:40:16:335 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Product Media (ILST, 24.0.2) installation failed ...
02/13/20 12:40:16:335 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | No Conflict Process defined, skipping the conflict file creation ...
02/13/20 12:40:18:970 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Build Version - 1.15.0.126
02/13/20 12:40:18:970 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Logging Level verbosity Set  to 4
02/13/20 12:40:18:970 | [FATAL] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 2012 | The HDPIM Setup Process return code is (195).Stopping the installation process.
02/13/20 12:40:18:970 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Product Media (KANC, 1.0.1) installation failed but allowFailure tag is true so continuing...
02/13/20 12:40:18:974 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Starting to clean the partially installed payloads.
02/13/20 12:40:19:035 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping Product Media (ILST, 24.0.2) uninstallation, product not installed ...
02/13/20 12:40:19:036 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping Product Media (KBRG, 10.0.2) uninstallation, product not installed ...
02/13/20 12:40:19:037 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping Product Media (LRCC, 3.1) uninstallation, product not installed ...
02/13/20 12:40:19:039 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping Product Media (LTRM, 9.1) uninstallation, product not installed ...
02/13/20 12:40:19:040 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Skipping Product Media (PHSP, 21.0.3) uninstallation, product not installed ...
02/13/20 12:40:19:041 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | Failed to get/verify the UpdaterCore inventory base path (C:\Program Files (x86)\Common Files\Adobe\AAMUpdaterInventory\1.0\)
02/13/20 12:40:19:041 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | sendAnalytics : Unable to find deviceId.
02/13/20 12:40:19:060 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 2012 | The output of process received  in execWithOutput :
Microsoft Windows [Version 6.3.9600]
02/13/20 12:40:19:062 | [INFO] |  | ASU | DeploymentManager |  |  |  | 2012 | Event Guid generated is: 'f445132a-ab39-4e94-a07e-af4953569008'
02/13/20 12:40:19:068 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 2012 | GetIEProxyInfo - Failed to get proxy for the url, error:12180
02/13/20 12:40:19:639 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3124 | HTTP Request Status code 200.
02/13/20 12:40:19:639 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 2012 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/13/20 12:40:19:640 | [INFO] |  | ASU | DeploymentManager |  |  |  | 2012 | Waiting for the async thread to get the task completed
02/13/20 12:40:19:640 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3604 | Async thread is completed. Now exiting from function.
02/13/20 12:40:19:644 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 2012 | The install workflow is terminating.
02/13/20 12:40:20:042 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Process creation completed.
02/13/20 12:40:20:042 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 |  The return Code from Create Process (1603).
02/13/20 12:40:20:042 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Trying to rollback the Acrobat installation ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) ...
02/13/20 12:40:20:042 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /x "{AC76BA86-1033-FFFF-7760-0C0F074E4100}" /qn
02/13/20 12:40:24:236 | [INFO] |  | ASU | OPM | OPM |  |  | 2760 | Build Version - 10.0.0.130
02/13/20 12:40:24:236 | [INFO] |  | ASU | OPM | OPM |  |  | 2760 | Logging Level verbosity Set  to 4
02/13/20 12:40:24:238 | [INFO] |  | ASU | OPM | OPM |  |  | 2760 | Schema version and schema compatibility version are same or greater than current
02/13/20 12:40:24:417 | [INFO] |  | ASU | OPM | OPM |  |  | 2760 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 12:40:24:417 | [INFO] |  | ASU | OPM | OPM |  |  | 2760 | No Record found for the input fields in opm_getValueForKey
02/13/20 12:40:33:150 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3940 | Build Version - 10.0.0.253
02/13/20 12:40:33:150 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3940 | Logging Level verbosity Set  to 4
02/13/20 12:40:33:150 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3940 | AAMIU_Uninstall started...
02/13/20 12:40:33:150 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | Get RIBS Product count
02/13/20 12:40:33:157 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | PDB does not exits on machine.
02/13/20 12:40:33:157 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | RIBS Products install status :0
02/13/20 12:40:33:157 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | Get NON RIBS Product count
02/13/20 12:40:33:158 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM |  |  | 3940 | AAMRef file :ACC.aamref exists at path :C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMRefs
02/13/20 12:40:33:158 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | NON RIBS Products install status :1
02/13/20 12:40:33:158 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3940 | There are some non-ribs products using AAM. NON RIBS product use flag is 1.
02/13/20 12:40:33:158 | [INFO] | 1692 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3940 | Ignored AAM Uninstall... uninstall status :1
02/13/20 12:40:39:306 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 3776 | Process creation completed.
02/13/20 12:40:39:306 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Acrobat rolled back successfully ...
02/13/20 12:59:25:160 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 3776 | Setup exiting with return code (6)
02/13/20 13:33:05:905 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Build Version - 1.15.0.126
02/13/20 13:33:05:905 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Logging Level verbosity Set  to 4
02/13/20 13:33:05:951 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Successfully fetched the optionXML content from MSI database ...
02/13/20 13:33:05:986 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | The OS language detected for Acrobat (en_US)
02/13/20 13:33:05:992 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | MSI ProductCode ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) is not installed on the system ...
02/13/20 13:33:05:994 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | The install language for Acrobat (APRO19.0) from the fallback map (en_US)
02/13/20 13:33:05:995 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 13:33:05:995 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 13:33:07:964 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Build Version - 1.15.0.126
02/13/20 13:33:07:965 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Logging Level verbosity Set  to 4
02/13/20 13:33:07:965 | [ERROR] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | The Bootstrapper Process return code is (21).
02/13/20 13:33:07:965 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 13:33:07:965 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 13:33:41:139 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Build Version - 1.15.0.126
02/13/20 13:33:41:139 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Logging Level verbosity Set  to 4
02/13/20 13:33:41:139 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | The return code from the Bootstrapper Process is (0).
02/13/20 13:33:41:253 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe" --nonRIBSMode="1" --deploymentFile="C:\Users\ADMINI~1\AppData\Local\Temp\\{0269104C-3FDA-4920-AFC4-9F4602726B69}"
02/13/20 13:35:03:075 | [INFO] |  | ASU | OPM | OPM |  |  | 3340 | Build Version - 10.0.0.130
02/13/20 13:35:03:075 | [INFO] |  | ASU | OPM | OPM |  |  | 3340 | Logging Level verbosity Set  to 4
02/13/20 13:35:03:079 | [INFO] |  | ASU | OPM | OPM |  |  | 3340 | Schema version and schema compatibility version are same or greater than current
02/13/20 13:35:03:271 | [INFO] |  | ASU | OPM | OPM |  |  | 3340 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 13:35:03:271 | [INFO] |  | ASU | OPM | OPM |  |  | 3340 | No Record found for the input fields in opm_getValueForKey
02/13/20 13:35:11:283 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Process creation completed.
02/13/20 13:35:11:284 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | The return code from the Adobe Installer Process is (0).
02/13/20 13:35:11:286 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /i "C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi" /qn
02/13/20 13:35:12:836 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4364 | Build Version - 1.15.0.126
02/13/20 13:35:12:836 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4364 | Logging Level verbosity Set  to 4
02/13/20 13:35:12:836 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4364 | Executing immediate custom action for install mode.
02/13/20 13:35:12:836 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4364 | The CustomActionData string is : mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi;installLang=
02/13/20 13:35:12:836 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4364 | Successfully executed the immediate custom action for install mode .
02/13/20 13:35:17:097 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:17:097 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:17:097 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Executing the deferred custom action.
02/13/20 13:35:17:102 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Obtained the following as CustomActionData
02/13/20 13:35:17:102 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | (mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi;installLang=)
02/13/20 13:35:17:102 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Original database path is : C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Adobe202002.msi
02/13/20 13:35:17:117 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | OptionXML saved at location :: C:\Users\ADMINI~1\AppData\Local\Temp\{94D804C5-0127-47A4-B1C1-F061B8C7E834}\\{35045D00-127E-4416-B2D3-A15E4AF3035F}
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | CustomAction Parameters obtained...
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |  optXMLPath :: C:\Users\ADMINI~1\AppData\Local\Temp\{94D804C5-0127-47A4-B1C1-F061B8C7E834}\\{35045D00-127E-4416-B2D3-A15E4AF3035F}
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |  setupBasePath :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |  installDirPath ::
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |  installLang ::
02/13/20 13:35:17:146 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Initializing Custom Action Data from parameters
02/13/20 13:35:17:147 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Provisioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{94D804C5-0127-47A4-B1C1-F061B8C7E834}\\{A009D624-3DB2-4C49-8CAD-3B9C70229AD0}).
02/13/20 13:35:17:147 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Preconditioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{94D804C5-0127-47A4-B1C1-F061B8C7E834}\\{D5A3786E-95F0-4B0F-B10A-4EF628A74B09}).
02/13/20 13:35:17:147 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Starting to run the custom action for install mode
02/13/20 13:35:17:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | STEP 1: Starting to parse Option XML.
02/13/20 13:35:17:195 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Match OS lang option selected
02/13/20 13:35:17:195 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Added OS Language (en_US) to the install language fallback.
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Install language fallback contains following languages :
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |     (en_US)
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 |     (en_GB)
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Self-Update BootStrapper Relative Path doesn't exist.
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failure in getting Self-Update Folder Path.
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | No of updates found (0).
02/13/20 13:35:17:196 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | No of HD products found (14).
02/13/20 13:35:17:196 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:196 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (LIBS3.6.1)...
02/13/20 13:35:17:199 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:199 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (COCM1.0)...
02/13/20 13:35:17:207 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:207 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (COSY4.3.24)...
02/13/20 13:35:17:209 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:209 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (KANC1.0.1)...
02/13/20 13:35:17:209 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | The media info tag marked for auto-install (KANC) (1.0.1)
02/13/20 13:35:17:212 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:212 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (CCXP3.4.0)...
02/13/20 13:35:17:215 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:215 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (CORG1.1)...
02/13/20 13:35:17:223 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:223 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (CORE1.0)...
02/13/20 13:35:17:226 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get value for conflicting processes...
02/13/20 13:35:17:226 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to parse the conflictProcessInfo for HD media (COPS1.0)...
02/13/20 13:35:17:243 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Custom deployment path doesnt exist in options XML
02/13/20 13:35:17:267 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to find Royalty Bearing attribute info.
02/13/20 13:35:17:267 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Found the AppsPanel attribute info (true)
02/13/20 13:35:17:267 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Found the AdminPrivilege attribute info (false)
02/13/20 13:35:17:267 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Number of Medias found = 1
02/13/20 13:35:17:322 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Deployment XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{1A205697-9E0A-4511-B378-033B9B6921F6}\\{DE86B97A-F928-4512-B446-DF2C6A0F4487}
02/13/20 13:35:17:358 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Override XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{1A205697-9E0A-4511-B378-033B9B6921F6}\\{F7F0F3FE-D3CF-465E-A6F1-B64FEF0E9357}
02/13/20 13:35:17:358 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Conflict process info retrieved (<ConflictingProcess headless="false" forceKillAllowed="false" adobeOwned="false">
	<ProcessDisp
02/13/20 13:35:17:358 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Deployment Manager is running in Install Mode.
02/13/20 13:35:17:360 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | STEP 2: Starting to launch ASU AAM.
02/13/20 13:35:17:360 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0
02/13/20 13:35:17:406 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Latest AAM version with the package is (5.0.0.354)...
02/13/20 13:35:17:406 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_5.0\Set-up.dat
02/13/20 13:35:19:662 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:19:662 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:19:663 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | The return code from the Bootstrapper Process is (21).
02/13/20 13:35:19:663 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Going to install C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9
02/13/20 13:35:19:667 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Latest AAM version with the package is (4.9.0.515)...
02/13/20 13:35:19:667 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU_4.9\Set-up.dat
02/13/20 13:35:21:640 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:21:640 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:21:641 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | The return code from the Bootstrapper Process is (0).
02/13/20 13:35:21:646 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
02/13/20 13:35:21:646 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Starting apply CCP ASU.
02/13/20 13:35:21:646 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\ASU2\Set-up.dat
02/13/20 13:35:21:647 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:21:647 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:21:647 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to launch the Bootstrapper process.Stopping the installation process.
02/13/20 13:35:21:647 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | CCP ASU installation failed with ErrorCode (81). Ignoring this ASU failure.
02/13/20 13:35:21:647 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3104 | Skipping custom installs, either path does not exist or not directory (C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\pre)
02/13/20 13:35:21:762 | [INFO] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3104 | Conflict processes not running or killed successfully ...
02/13/20 13:35:21:779 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to find the pdb database.
02/13/20 13:35:21:779 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get the local payload database handle.
02/13/20 13:35:21:779 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | STEP 3: Starting to launch Bootstrapper of Media (APRO19.0).
02/13/20 13:35:21:779 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | The Bootstrapper seems to be missing(C:\Users\Administrator\Downloads\Adobe202002_en_GB_WIN_64\Adobe202002\Build\Setup\APRO19.0\Set-up.dat). Skipping the installation process.
02/13/20 13:35:21:779 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Correcting Dependencies in local db.
02/13/20 13:35:21:780 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | No media db present on the machine.
02/13/20 13:35:21:780 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | STEP 4: Starting to launch Adobe Installer.
02/13/20 13:35:21:780 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping exception: APRO19.0.
02/13/20 13:35:24:896 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:24:896 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:24:896 | [FATAL] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3104 | The HDPIM Setup Process return code is (195).Stopping the installation process.
02/13/20 13:35:24:897 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Product Media (ILST, 24.0.2) installation failed ...
02/13/20 13:35:24:897 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | No Conflict Process defined, skipping the conflict file creation ...
02/13/20 13:35:27:494 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Build Version - 1.15.0.126
02/13/20 13:35:27:494 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Logging Level verbosity Set  to 4
02/13/20 13:35:27:494 | [FATAL] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3104 | The HDPIM Setup Process return code is (195).Stopping the installation process.
02/13/20 13:35:27:495 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Product Media (KANC, 1.0.1) installation failed but allowFailure tag is true so continuing...
02/13/20 13:35:27:496 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Starting to clean the partially installed payloads.
02/13/20 13:35:27:551 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping Product Media (ILST, 24.0.2) uninstallation, product not installed ...
02/13/20 13:35:27:552 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping Product Media (KBRG, 10.0.2) uninstallation, product not installed ...
02/13/20 13:35:27:553 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping Product Media (LRCC, 3.1) uninstallation, product not installed ...
02/13/20 13:35:27:554 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping Product Media (LTRM, 9.1) uninstallation, product not installed ...
02/13/20 13:35:27:555 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Skipping Product Media (PHSP, 21.0.3) uninstallation, product not installed ...
02/13/20 13:35:27:556 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | Failed to get/verify the UpdaterCore inventory base path (C:\Program Files (x86)\Common Files\Adobe\AAMUpdaterInventory\1.0\)
02/13/20 13:35:27:556 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | sendAnalytics : Unable to find deviceId.
02/13/20 13:35:27:581 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3104 | The output of process received  in execWithOutput :
02/13/20 13:35:27:582 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3104 | Event Guid generated is: 'b8d0170b-25cb-4587-805e-67798d035103'
02/13/20 13:35:27:590 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3104 | GetIEProxyInfo - Failed to get proxy for the url, error:12180
02/13/20 13:35:28:244 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 4416 | HTTP Request Status code 200.
02/13/20 13:35:28:245 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3104 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/13/20 13:35:28:246 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3104 | Waiting for the async thread to get the task completed
02/13/20 13:35:28:246 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3220 | Async thread is completed. Now exiting from function.
02/13/20 13:35:28:248 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3104 | The install workflow is terminating.
02/13/20 13:35:28:734 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Process creation completed.
02/13/20 13:35:28:734 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 |  The return Code from Create Process (1603).
02/13/20 13:35:28:734 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Trying to rollback the Acrobat installation ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) ...
02/13/20 13:35:28:734 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /x "{AC76BA86-1033-FFFF-7760-0C0F074E4100}" /qn
02/13/20 13:35:33:780 | [INFO] |  | ASU | OPM | OPM |  |  | 5108 | Build Version - 10.0.0.130
02/13/20 13:35:33:780 | [INFO] |  | ASU | OPM | OPM |  |  | 5108 | Logging Level verbosity Set  to 4
02/13/20 13:35:33:784 | [INFO] |  | ASU | OPM | OPM |  |  | 5108 | Schema version and schema compatibility version are same or greater than current
02/13/20 13:35:33:984 | [INFO] |  | ASU | OPM | OPM |  |  | 5108 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 13:35:33:984 | [INFO] |  | ASU | OPM | OPM |  |  | 5108 | No Record found for the input fields in opm_getValueForKey
02/13/20 13:35:46:849 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3908 | Build Version - 10.0.0.253
02/13/20 13:35:46:850 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3908 | Logging Level verbosity Set  to 4
02/13/20 13:35:46:850 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3908 | AAMIU_Uninstall started...
02/13/20 13:35:46:850 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | Get RIBS Product count
02/13/20 13:35:46:856 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | PDB does not exits on machine.
02/13/20 13:35:46:856 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | RIBS Products install status :0
02/13/20 13:35:46:856 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | Get NON RIBS Product count
02/13/20 13:35:46:857 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM |  |  | 3908 | AAMRef file :ACC.aamref exists at path :C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMRefs
02/13/20 13:35:46:857 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | NON RIBS Products install status :1
02/13/20 13:35:46:857 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 3908 | There are some non-ribs products using AAM. NON RIBS product use flag is 1.
02/13/20 13:35:46:857 | [INFO] | 4160 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 3908 | Ignored AAM Uninstall... uninstall status :1
02/13/20 13:35:54:086 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4876 | Process creation completed.
02/13/20 13:35:54:086 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Acrobat rolled back successfully ...
02/13/20 13:38:18:264 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4876 | Setup exiting with return code (6)
02/13/20 13:38:33:789 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Build Version - 1.15.0.106
02/13/20 13:38:33:789 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Logging Level verbosity Set  to 4
02/13/20 13:38:33:828 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Successfully fetched the optionXML content from MSI database ...
02/13/20 13:38:33:865 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | The OS language detected for Acrobat (en_US)
02/13/20 13:38:33:870 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | MSI ProductCode ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) is not installed on the system ...
02/13/20 13:38:33:873 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | The install language for Acrobat (APRO19.0) from the fallback map (en_US)
02/13/20 13:38:33:874 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\ASU\Set-up.dat
02/13/20 13:38:35:655 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Build Version - 1.15.0.106
02/13/20 13:38:35:655 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Logging Level verbosity Set  to 4
02/13/20 13:38:35:655 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | The return code from the Bootstrapper Process is (0).
02/13/20 13:38:35:668 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\DEBox\Setup.exe" --nonRIBSMode="1" --deploymentFile="C:\Users\ADMINI~1\AppData\Local\Temp\\{41A183CE-5E78-402B-8A79-34DF252D288C}"
02/13/20 13:39:36:609 | [INFO] |  | ASU | OPM | OPM |  |  | 4204 | Build Version - 10.0.0.130
02/13/20 13:39:36:609 | [INFO] |  | ASU | OPM | OPM |  |  | 4204 | Logging Level verbosity Set  to 4
02/13/20 13:39:36:610 | [INFO] |  | ASU | OPM | OPM |  |  | 4204 | Schema version and schema compatibility version are same or greater than current
02/13/20 13:39:36:801 | [INFO] |  | ASU | OPM | OPM |  |  | 4204 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 13:39:36:802 | [INFO] |  | ASU | OPM | OPM |  |  | 4204 | No Record found for the input fields in opm_getValueForKey
02/13/20 13:39:42:208 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Process creation completed.
02/13/20 13:39:42:208 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | The return code from the Adobe Installer Process is (0).
02/13/20 13:39:42:210 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /i "C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\Adobe4PCx64.msi" /qn
02/13/20 13:39:43:741 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4504 | Build Version - 1.15.0.106
02/13/20 13:39:43:741 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4504 | Logging Level verbosity Set  to 4
02/13/20 13:39:43:741 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4504 | Executing immediate custom action for install mode.
02/13/20 13:39:43:742 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4504 | The CustomActionData string is : mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\Adobe4PCx64.msi;installLang=
02/13/20 13:39:43:742 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 4504 | Successfully executed the immediate custom action for install mode .
02/13/20 13:39:47:316 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:47:317 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:47:317 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Executing the deferred custom action.
02/13/20 13:39:47:320 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Obtained the following as CustomActionData
02/13/20 13:39:47:320 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | (mode=install;sourceDir=C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\;installDir=;origDB=C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\Adobe4PCx64.msi;installLang=)
02/13/20 13:39:47:320 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Original database path is : C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\Adobe4PCx64.msi
02/13/20 13:39:47:329 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | OptionXML saved at location :: C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{9E139F6B-B1E8-4AB0-A721-376619EEF6A3}
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | CustomAction Parameters obtained...
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |  optXMLPath :: C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{9E139F6B-B1E8-4AB0-A721-376619EEF6A3}
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |  setupBasePath :: C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |  installDirPath ::
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |  installLang ::
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Initializing Custom Action Data from parameters
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Provisioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644}).
02/13/20 13:39:47:356 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Preconditioning Tool path is (C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{F44C83C3-DB88-4696-92E9-7A98848F49C8}).
02/13/20 13:39:47:357 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Starting to run the custom action for install mode
02/13/20 13:39:47:357 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | STEP 1: Starting to parse Option XML.
02/13/20 13:39:47:393 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Latest AAM version with the package is (4.9.0.515)...
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Match OS lang option selected
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Added OS Language (en_US) to the install language fallback.
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Install language fallback contains following languages :
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |     (en_US)
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 |     (en_GB)
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Self-Update BootStrapper Relative Path doesn't exist.
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failure in getting Self-Update Folder Path.
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | No of updates found (0).
02/13/20 13:39:47:394 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | No of HD products found (28).
02/13/20 13:39:47:394 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:394 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (SPRK21.2.12)...
02/13/20 13:39:47:408 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:408 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (CORG1.1)...
02/13/20 13:39:47:411 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:411 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (COMP1.1)...
02/13/20 13:39:47:417 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:417 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (CORE1.0)...
02/13/20 13:39:47:426 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:426 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (CDEC1.0.0)...
02/13/20 13:39:47:429 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:429 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (CCXP3.0.1)...
02/13/20 13:39:47:429 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The media info tag marked for auto-install (CCXP) (3.0.1)
02/13/20 13:39:47:432 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:432 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (LIBS3.2)...
02/13/20 13:39:47:432 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The media info tag marked for auto-install (LIBS) (3.2)
02/13/20 13:39:47:447 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:447 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (COPS1.0)...
02/13/20 13:39:47:450 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:450 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (COSY4.3.0)...
02/13/20 13:39:47:450 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The media info tag marked for auto-install (COSY) (4.3.0)
02/13/20 13:39:47:456 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:456 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (COCM1.0)...
02/13/20 13:39:47:465 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:465 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (PPRO13.1.4)...
02/13/20 13:39:47:482 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get value for conflicting processes...
02/13/20 13:39:47:482 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to parse the conflictProcessInfo for HD media (KASU2.0)...
02/13/20 13:39:47:485 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Custom deployment path doesnt exist in options XML
02/13/20 13:39:47:495 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to find Royalty Bearing attribute info.
02/13/20 13:39:47:495 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Found the AppsPanel attribute info (false)
02/13/20 13:39:47:495 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Found the AdminPrivilege attribute info (false)
02/13/20 13:39:47:495 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Number of Medias found = 1
02/13/20 13:39:47:499 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Deployment XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{3514303A-9A6F-489B-8CB6-FB701DEE3E95}\\{04DE345E-8B3D-47E3-AAED-E4AD9409C763}
02/13/20 13:39:47:503 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Override XML created at path :: C:\Users\ADMINI~1\AppData\Local\Temp\{3514303A-9A6F-489B-8CB6-FB701DEE3E95}\\{6259C767-4520-4C34-8DF6-86382D8520B8}
02/13/20 13:39:47:504 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Conflict process info retrieved (<ConflictingProcess headless="false" forceKillAllowed="false" adobeOwned="true">
	<ProcessDisplayName>Adobe Acrobat XI</ProcessDisplayName>
	<RelativePath>[INSTALLDIR]\Acrobat 11.0\Acrobat\Acrobat.exe</RelativePath>
	<ProcessDisplayName>Adobe Acrobat 2015</ProcessDisplayName>
	<RelativePath>[INSTALLDIR]\Acrobat 2015\Acrobat\Acrobat.exe</RelativePath>
02/13/20 13:39:47:504 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Deployment Manager is running in Install Mode.
02/13/20 13:39:47:505 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | STEP 2: Starting to launch ASU AAM.
02/13/20 13:39:47:505 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\ASU\Set-up.dat
02/13/20 13:39:49:258 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:49:258 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:49:258 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The return code from the Bootstrapper Process is (0).
02/13/20 13:39:49:259 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
02/13/20 13:39:49:259 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Starting apply CCP ASU.
02/13/20 13:39:49:259 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Bootstrapper launch location is :: C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\ASU2\Set-up.dat
02/13/20 13:39:49:260 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:49:260 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:49:260 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to launch the Bootstrapper process.Stopping the installation process.
02/13/20 13:39:49:260 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | CCP ASU installation failed with ErrorCode (81). Ignoring this ASU failure.
02/13/20 13:39:49:260 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | Skipping custom installs, either path does not exist or not directory (C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\pre)
02/13/20 13:39:49:426 | [INFO] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3176 | Conflict processes not running or killed successfully ...
02/13/20 13:39:49:464 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to find the pdb database.
02/13/20 13:39:49:464 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get the local payload database handle.
02/13/20 13:39:49:464 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | STEP 3: Starting to launch Bootstrapper of Media (APRO19.0).
02/13/20 13:39:49:464 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The Bootstrapper seems to be missing(C:\Users\Administrator\Downloads\Adobe4PCx64_en_GB_WIN_64\Adobe4PCx64\Build\Setup\APRO19.0\Set-up.dat). Skipping the installation process.
02/13/20 13:39:49:464 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Correcting Dependencies in local db.
02/13/20 13:39:49:465 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | No media db present on the machine.
02/13/20 13:39:49:465 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | STEP 4: Starting to launch Adobe Installer.
02/13/20 13:39:49:465 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping exception: APRO19.0.
02/13/20 13:39:52:074 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:52:074 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:52:074 | [FATAL] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3176 | The HDPIM Setup Process return code is (195).Stopping the installation process.
02/13/20 13:39:52:074 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Product Media (AEFT, 16.1.2) installation failed ...
02/13/20 13:39:52:074 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | No Conflict Process defined, skipping the conflict file creation ...
02/13/20 13:39:59:700 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:39:59:700 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:39:59:700 | [INFO] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3176 | The return code from the HDPIM Setup Process is (0). Successfully installed.
02/13/20 13:39:59:700 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Product Media (COSY, 4.3.0) successfully installed ...
02/13/20 13:39:59:701 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Starting to launch Provisioning Tool for EULA suppression ...
02/13/20 13:39:59:701 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Provisioning tool launch location is :: C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644}
02/13/20 13:39:59:701 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | Path to Process :C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644} Process Directory :C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E} arguments being passed :"C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644}" --tool=EULA --leid=V7{}CoreSync-2.4.1-Win-GM --eulasuppress
02/13/20 13:39:59:874 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | Process creation completed.
02/13/20 13:39:59:874 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The return Code from Provisioning Tool (6).
02/13/20 13:39:59:874 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Provisioning Tool has failed to suppress EULA for the product.
02/13/20 13:39:59:874 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | No Conflict Process defined, skipping the conflict file creation ...
02/13/20 13:40:32:506 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Build Version - 1.15.0.106
02/13/20 13:40:32:506 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Logging Level verbosity Set  to 4
02/13/20 13:40:32:506 | [INFO] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3176 | The return code from the HDPIM Setup Process is (0). Successfully installed.
02/13/20 13:40:32:506 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Product Media (LIBS, 3.2) successfully installed ...
02/13/20 13:40:32:507 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Starting to launch Provisioning Tool for EULA suppression ...
02/13/20 13:40:32:507 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Provisioning tool launch location is :: C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644}
02/13/20 13:40:32:507 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | Path to Process :C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644} Process Directory :C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E} arguments being passed :"C:\Users\ADMINI~1\AppData\Local\Temp\{D8E7729C-6EEB-44EA-A01D-E80763DF671E}\\{8935F68C-3252-4FDC-B350-C0BA394CA644}" --tool=EULA --leid= --eulasuppress
02/13/20 13:40:32:554 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | Process creation completed.
02/13/20 13:40:32:554 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The return Code from Provisioning Tool (1).
02/13/20 13:40:32:554 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Provisioning Tool has failed to suppress EULA for the product.
02/13/20 13:40:32:555 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Starting to clean the partially installed payloads.
02/13/20 13:40:32:610 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (AEFT, 16.1.2) uninstallation, product not installed ...
02/13/20 13:40:32:611 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (AICY, 14.0.2) uninstallation, product not installed ...
02/13/20 13:40:32:613 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (AME, 13.1.3) uninstallation, product not installed ...
02/13/20 13:40:32:615 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (AUDT, 12.1.2) uninstallation, product not installed ...
02/13/20 13:40:32:618 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (CHAR, 2.1.1) uninstallation, product not installed ...
02/13/20 13:40:32:620 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (DRWV, 19.2) uninstallation, product not installed ...
02/13/20 13:40:32:621 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (FLPR, 19.2.1) uninstallation, product not installed ...
02/13/20 13:40:32:623 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (IDSN, 14.0.2) uninstallation, product not installed ...
02/13/20 13:40:32:624 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (ILST, 23.0.3) uninstallation, product not installed ...
02/13/20 13:40:32:625 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (KBRG, 9.1) uninstallation, product not installed ...
02/13/20 13:40:32:627 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (LRCC, 2.3) uninstallation, product not installed ...
02/13/20 13:40:32:628 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (LTRM, 8.3.1) uninstallation, product not installed ...
02/13/20 13:40:32:629 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (PHSP, 20.0.5) uninstallation, product not installed ...
02/13/20 13:40:32:631 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (PPRO, 13.1.4) uninstallation, product not installed ...
02/13/20 13:40:32:632 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (PRLD, 8.1.1) uninstallation, product not installed ...
02/13/20 13:40:32:633 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (RUSH, 1.1) uninstallation, product not installed ...
02/13/20 13:40:32:635 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Skipping Product Media (SPRK, 21.2.12) uninstallation, product not installed ...
02/13/20 13:40:32:636 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | Failed to get/verify the UpdaterCore inventory base path (C:\Program Files (x86)\Common Files\Adobe\AAMUpdaterInventory\1.0\)
02/13/20 13:40:32:636 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | sendAnalytics : Unable to find deviceId.
02/13/20 13:40:32:657 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3176 | The output of process received  in execWithOutput :
02/13/20 13:40:32:659 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3176 | Event Guid generated is: '0df302a3-02f2-4ea2-9989-f7b85ca552b7'
02/13/20 13:40:32:665 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3176 | GetIEProxyInfo - Failed to get proxy for the url, error:12180
02/13/20 13:40:33:234 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3244 | HTTP Request Status code 200.
02/13/20 13:40:33:236 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3176 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/13/20 13:40:33:237 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3176 | Waiting for the async thread to get the task completed
02/13/20 13:40:33:237 | [INFO] |  | ASU | DeploymentManager |  |  |  | 4548 | Async thread is completed. Now exiting from function.
02/13/20 13:40:33:241 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3176 | The install workflow is terminating.
02/13/20 13:40:33:728 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Process creation completed.
02/13/20 13:40:33:728 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 |  The return Code from Create Process (1603).
02/13/20 13:40:33:729 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Trying to rollback the Acrobat installation ({AC76BA86-1033-FFFF-7760-0C0F074E4100}) ...
02/13/20 13:40:33:729 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Path to Process :C:\WINDOWS\system32\msiexec.exe Process Directory :C:\WINDOWS\system32 arguments being passed : /x "{AC76BA86-1033-FFFF-7760-0C0F074E4100}" /qn
02/13/20 13:40:38:518 | [INFO] |  | ASU | OPM | OPM |  |  | 4972 | Build Version - 10.0.0.130
02/13/20 13:40:38:518 | [INFO] |  | ASU | OPM | OPM |  |  | 4972 | Logging Level verbosity Set  to 4
02/13/20 13:40:38:520 | [INFO] |  | ASU | OPM | OPM |  |  | 4972 | Schema version and schema compatibility version are same or greater than current
02/13/20 13:40:38:687 | [INFO] |  | ASU | OPM | OPM |  |  | 4972 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
02/13/20 13:40:38:687 | [INFO] |  | ASU | OPM | OPM |  |  | 4972 | No Record found for the input fields in opm_getValueForKey
02/13/20 13:40:48:254 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 2840 | Build Version - 10.0.0.253
02/13/20 13:40:48:254 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 2840 | Logging Level verbosity Set  to 4
02/13/20 13:40:48:254 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 2840 | AAMIU_Uninstall started...
02/13/20 13:40:48:254 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | Get RIBS Product count
02/13/20 13:40:48:261 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | PDB does not exits on machine.
02/13/20 13:40:48:261 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | RIBS Products install status :0
02/13/20 13:40:48:261 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | Get NON RIBS Product count
02/13/20 13:40:48:262 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM |  |  | 2840 | AAMRef file :ACC.aamref exists at path :C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMRefs
02/13/20 13:40:48:262 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | NON RIBS Products install status :1
02/13/20 13:40:48:262 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-Uninstall |  |  | 2840 | There are some non-ribs products using AAM. NON RIBS product use flag is 1.
02/13/20 13:40:48:262 | [INFO] | 4792 | ASU | PIM-ASUInstaller | PIM-ASUInstaller |  |  | 2840 | Ignored AAM Uninstall... uninstall status :1
02/13/20 13:40:54:840 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 5012 | Process creation completed.
02/13/20 13:40:54:840 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 5012 | Acrobat rolled back successfully ...
Edited by intssed
Share this post
Jainit
paslēp to savu palagu zem spoilera.
Share this post
staylez
Jāsaka gan ka datoram jāuzliek jauns krakots Windows10 un jāmēģina instalēt pa jaunu krakoto Adobe vēlreiz.
Share this post
raiviic
Pirms 57 minūtēm , intssed teica:
vienmēr apstājas pēc 3 minūtēm un sākas "Rollback"
1. Kaut kas no visa (Win, Adobe) arī legāls (šķiet, ka nez vai) - tad sazinies ar supportu.
2. Ko tieši no tā visa gribi uzlikt? Photoshop, Lightroom, Premiere, AfterEffects var instalēt arī atsevišķi (vismaz man vajag tikai tās un smuki instalējas, tiesa, legāli, no Adobe saita).
3. To tavu palagu neviens nelasīs, bet varianti: problēmas ar dzelžiem/draiveriem, problēmas ar "nopirkto" softu (ticamāk), problēmas ar Windows (nez vai, jo jaunais Adobe softs ir tikai 64bit un raksti, ka liec uz 64 bit Win).
Share this post
intssed
Pirms 11 minūtēm , raiviic teica:
Paldies, raiviic, par atbildi!
Šis ir gadījums kad softs un dzelži legāli. Diemžēl atsevišķi nevar likt jo paka ir kā atlasīts kopums :(. Līdz šim problēmas nav bijušas.
Share this post
jema
Ja jau Adobe legāla, taisi jaunu download paku un mēģini vēlreiz!
Share this post
intssed
Pirms 2 minūtēm , jema teica:
Paldies, jema, par atbildi!
Šī jau ir 2. uztaisītā paka. Domāju ka Adobes pakā nav problēma?
Share this post
intssed
Paldies, ju, šis pagaidām nepalīdz.
Share this post
Zh
vai tik nav šis?
The error is ' Failed to launch the Bootstrapper process. Stopping the installation process. CCP ASU installation failed with ErrorCode (81)'
This issue mainly occurs when there is another adobe installer running in the background. To troubleshoot this try the following: Close all adobe processes, rename the PDApp folder.
https://community.adobe.com/t5/enterprise-teams/re-troubleshoot-creative-cloud-apps-installation-and-uninstallation-errors/td-p/10577264?page=1
Share this post
intssed
pirms 14 stundām , Zh teica:
vai tik nav šis?
Paldies, Zh, par atbildi. Pamēģināšu!
Share this post
