Yankijs 0 Posted August 18, 2014 Share Posted August 18, 2014 Sveiki! Man ir problēma, ar kuru nekādīgi nevaru tikt galā. Nopirku priekš vecāsmātes portatīvo - Packard Bell, bez diskdziņa un ar boot-up linux os. Vēlos uzlikt Windows 7, kuru var ielikt tikai caur USB. Tā kā šijam portatīvajam ir UEFI bios, man nācās savā datorā lietot command promt lietotni, lai pārveidotu usb bootable uz fat32 bāzes. Biosā, protams, uzlieku tā, lai dators startējas no USB. Pēc Packard Bell simbola parādās teksts: Windows failet to start. A recent hardware or software change might be the cause. To fix this problem: 1. Insert your Windows installation disc and restart your computer. 2. Choose your language settings, and then click "Next" 3. Click "Repair your computer" If you do not have this disc, contact your system administrator or computer manufacturer for assistance. File: \EFI\Microsoft\Boot\BCD Status: 0xc000000d Info: An error occurred while attempting to read the boot configuration data. ENTER=Continue ESC=EXIT" Vēlos ielikt Windows 7 home premium 64bit. Help! Quote Link to post Share on other sites
deriksx 295 Posted August 18, 2014 Share Posted August 18, 2014 °Nebūt neiedziļinājos bet nevajag/ nav ACHI mode jāliek, vismaz citiem tā jābūt. Quote Link to post Share on other sites
EmilsM 0 Posted August 18, 2014 Share Posted August 18, 2014 nav kautkāda neriktīga windows'a instalācija? Quote Link to post Share on other sites
Rubenis 41 Posted August 18, 2014 Share Posted August 18, 2014 (edited) Kā tu liki Windows 7 tajā USB?? Iekopēji iso failu, vai iededzināji ar kādu programmu?? P.S. Kaut kādiem Packard Bell, cik atceros, vajadzēja Legacy mode BIOSā ieslēgt, lai varētu instalēt Windows 7. Edited August 18, 2014 by Rubenis Quote Link to post Share on other sites
Red 2 Posted August 18, 2014 Share Posted August 18, 2014 Liec 8to + Classic Shell un būs tev miers mājās. Nav ko meklēt problēmas, mēģinot uzstumt septīto. 2 Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Nē, ar to Windows esmu instalējis vairākus datorus. Windows bija ISO failā. Exctractoju failus folderī un visu saturu liku USB. BET, pirms tam pārveidoju to. Uzslēdzot Command promt, rakstīju: DiskPart List Disk Select Disk 1 Clean Create Partition Primary Active Format fs=FAT32 quick Assign Pēc tam usb ievietoju savu Windows 7 Home Premium 64bit. Quote Link to post Share on other sites
drunk_lizard 1,253 Posted August 18, 2014 Share Posted August 18, 2014 Nebūt neiedziļinājos bet nevajag/ nav ACHI mode jāliek, vismaz citiem tā jābūt. mulkjiiba vajadzēja Legacy mode BIOSā ieslēgt tiesji taa vai ar rufus sagatavot uefi instalaacijas flesjku Packard Bell, bez diskdziņa un ar boot-up linux os un, ja tur bija linux, tad tur var uzlikt dajebko, iesleedzot legacy bios. punkts. 1 Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Rubeni - vienīgais Boot Mode, kas man tur ir pieejams ir tikai un vienīgi UEFI. drunk_lizard - pamēģināšu ar RUFUS Neizdevās ar RUFUS... Liku GPT formātu priekš UEFI. Pamēģināšu tagad ar MBR formātu. Došu ziņu Quote Link to post Share on other sites
Rubenis 41 Posted August 18, 2014 Share Posted August 18, 2014 Rubeni - vienīgais Boot Mode, kas man tur ir pieejams ir tikai un vienīgi UEFI. Cik atceros bija biosā UEFI mode un to varēja nomainīt uz Legacy. Tas arī bija viss čakars. Tieši ne boot mode, bet tip bios režīms. Quote Link to post Share on other sites
Pirkss 23 Posted August 18, 2014 Share Posted August 18, 2014 vai ar rufus sagatavot uefi instalaacijas flesjku Tīri ziņkārībai - vai tas Microsoft tūlis "Windows 7 USB installer" kas no ISO taisa bootablu USBi, neprot sagatavot UEFI instalācijas flešku? Quote Link to post Share on other sites
nevertell 33 Posted August 18, 2014 Share Posted August 18, 2014 UEFI ar MBR nestrādā, vajag GPT. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Tīri ziņkārībai - vai tas Microsoft tūlis "Windows 7 USB installer" kas no ISO taisa bootablu USBi, neprot sagatavot UEFI instalācijas flešku? Jā, RUFUS sagatavo tieši priekš UEFI, bet man ne GPT, ne MBR neiet. Tā pati BCD problēma uzmetās. Var arī sagatavot pats caur Run Command, ierakstot "diskpart" un tālāk veicot nepieciešamās darbības. Cik atceros bija biosā UEFI mode un to varēja nomainīt uz Legacy. Tas arī bija viss čakars. Tieši ne boot mode, bet tip bios režīms. Izgāju visu BIOS un nekur neatradu Legacy. Quote Link to post Share on other sites
Rubenis 41 Posted August 18, 2014 Share Posted August 18, 2014 Izgāju visu BIOS un nekur neatradu Legacy. Skaidrs. Tad Packardi ir patīrījuši BIOS un iespējams atstājuši tikai UEFI. Tādā variantā mēģinis Windows 8.1 uzlikt. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Skaidrs. Tad Packardi ir patīrījuši BIOS un iespējams atstājuši tikai UEFI. Tādā variantā mēģinis Windows 8.1 uzlikt. Yup, jau lieku fleškā caur Windows USB/DVD Download tool. Ziņošu par jaunumiem Bļin, pie 99% apstājās ... tas tač Windows --> 7 <-- USB/DVD download tool .... zajebal lab, turpinu. Quote Link to post Share on other sites
Rubenis 41 Posted August 18, 2014 Share Posted August 18, 2014 Bļin, pie 99% apstājās Palaidi kā administrators?? Quote Link to post Share on other sites
Donkeyhot 38 Posted August 18, 2014 Share Posted August 18, 2014 Var visu mierīgi uzlikt, fleška pareizi jāsagatavo. Jā, vēl iekš BIOS derētu atslēgt secure boot, kā arī(ja ir) fast boot uz normal. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Palaidi kā administrators?? ISO failā bija vēlviens ISO fails, kurā ir Windows 8. Tagad lieku caur RUFUS. Var visu mierīgi uzlikt, fleška pareizi jāsagatavo. Jā, vēl iekš BIOS derētu atslēgt secure boot, kā arī(ja ir) fast boot uz normal. BIOSā ir atslēgts Secure Boot un neko nevar mainīt. Quote Link to post Share on other sites
INTRASERVERNET 58 Posted August 18, 2014 Share Posted August 18, 2014 Tev tur taa Windows instalaacija liika. Quote Link to post Share on other sites
beryl 0 Posted August 18, 2014 Share Posted August 18, 2014 Ta ir. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Tev tur taa Windows instalaacija liika. Kā jau minēju, esmu pāris desmit datorus ar to Windows uzinstalējis. Bet izskatās, ka tieši šajam portatīvajam nekas neies krastā ar Windows 7. Ja nu vienīgi tiešām kāds atrod risinājumu. Jo es līdz šim neesmu. Tāpēc vēršos šeit Quote Link to post Share on other sites
INTRASERVERNET 58 Posted August 18, 2014 Share Posted August 18, 2014 UEFI/BIOS ir ieslegts Legacy Mode. Isleegts Secure Boot. Flash ir GPT struktura? Un tad taisiiji installaaciju. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 UEFI/BIOS ir ieslegts Legacy Mode. Isleegts Secure Boot. Flash ir GPT struktura? Un tad taisiiji installaaciju. Tieši tā. Bet nekā. Tieši tā pati bilde uzmetās tieši pēc Packard Bell logo. Tagad pieliku USB ar Win8. Instalācija ir procesā. Pašlaik viss notiek Quote Link to post Share on other sites
raiviic 715 Posted August 18, 2014 Share Posted August 18, 2014 ...bez diskdziņa un ar boot-up linux os.... Tātad nevar tā būt, ka tikai W8 uz šī iet. Kaut ko ne tā dari. Quote Link to post Share on other sites
Yankijs 0 Posted August 18, 2014 Author Share Posted August 18, 2014 Tātad nevar tā būt, ka tikai W8 uz šī iet. Kaut ko ne tā dari. Esmu padsmit stundas nočakarējies gar šo. Man vairs roka neceļās Bet ja kādam ir kāds risinājums - sakiet! Lai vai kā - Windows 8 ir uzinstalēts! Viss notiek! Tagad tikai draiveri jāsameklē Paldies visiem par ieteikumiem! Quote Link to post Share on other sites
