MareksLV Ierakstīts Marts 26, 2013 Share Ierakstīts Marts 26, 2013 (labots) Sveiki man ir tāda problēma met visu laiku apakšā kautādu paziņojumu. Man uzlec šādi Interactive services detection has stopped working Problem signature: Problem Event Name: APPCRASH Application Name: UI0Detect.exe Application Version: 6.1.7600.16385 Application Timestamp: 4a5bc8c3 Fault Module Name: ntdll.dll Fault Module Version: 6.1.7600.16915 Fault Module Timestamp: 4ec4b137 Exception Code: c0000005 Exception Offset: 000000000009c524 OS Version: 6.1.7600.2.0.0.768.3 Locale ID: 1062 Additional Information 1: 4c0d Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433 Additional Information 3: 4c0d Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt Un šorīt uz leca šāds paziņojums Windows has recoverd from am unexpected shutdown Ko varētu darīt lietas labā kād varbūt var palīdzēt?? UZtaisīju updeitus bet tā patās lec tie sūdi Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
Tufjord Marts 26, 2013 Share Marts 26, 2013 lec tie sūdi Nu vienkārši iztīri mēslus! http://www.windowsanswers.net/articles/fix-appcrashBet ne obligāti ar to kas manā linkā. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 ok pameiģināšu Link to comment Share on other sites More sharing options...
Borja Marts 26, 2013 Share Marts 26, 2013 Tjuford - pats esi lietojis to Fixcleaneri?Mans Trend Micro Web Security saka: The requested site is either a known or suspected source of malware. Event Details: URL: http://www.fixcleaner.com/?aid=5174&cid=3142&tid=windowsanswers&p=2&gid=1048921873&from=windowsanswers Content rating rule: Web Reputation - Low Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 ES pameiģināju caur CCleaner iztīrīt bet tas pats Link to comment Share on other sites More sharing options...
Tufjord Marts 26, 2013 Share Marts 26, 2013 Tjuford - pats esi lietojis to Fixcleaneri? Mans Trend Micro Web Security saka: Nē.Tādēļ jau teicu.Bet ne obligāti ar to kas manā linkā. pameiģināju caur CCleaner iztīrīt bet tas pats Tak no zarazas patīri sākumā.CC tur nelīdzēs. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 kā tad var tikt galā ar tām huiņām Link to comment Share on other sites More sharing options...
mafijs Marts 26, 2013 Share Marts 26, 2013 http://www.malwarebytes.org/ Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) Pameiģināju viss tas pats zb jau man tas kompis Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
Inspektors Caps Marts 26, 2013 Share Marts 26, 2013 OS Version: 6.1.7600 Tas ir Windows 7 bez SP1. Tātad Tavs datora instalētājs defaultā ir auns, kas nozīmē, ka visa sistēma tur ir sainstalēta līki! Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 nu bet visu laiku gāja tā tak nevar būt. nu vienīgais ka viņu atveda no Anglijas Link to comment Share on other sites More sharing options...
Borja Marts 26, 2013 Share Marts 26, 2013 Tieshaam Windows bez servispakas?Tad njem un uzinstalee:http://www.microsoft.com/en-us/download/details.aspx?id=5842Prieksh 64bit windows versijas:windows6.1-KB976932-X64.exePrieksh 32bit windows versijas:windows6.1-KB976932-X86.exe Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) A KĀ TO VAR REDZĒT IR VAI NAV??? TĀ servispakas varbūt ka ir man Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
ribons Marts 26, 2013 Share Marts 26, 2013 Start->Control Panel->(System and Security)->System ... Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 un kur tam ir jāparādās?]] Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 service pack un numurs Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) man nav nekur rakstīts man tikai rādās 64 bit Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
ribons Marts 26, 2013 Share Marts 26, 2013 un kur tam ir jāparādās?]] tur,kur tas rakstīts -izlasi... Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 tu te nes cauri visus Link to comment Share on other sites More sharing options...
Inspektors Caps Marts 26, 2013 Share Marts 26, 2013 Bļin, 6.1.7600 ir RTM, bet SP1 ir 6.1.7601. Par ko jūs te vēl izmisīgi mēģināt pārliecināties? Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 fotogrāfē un liec te bildi Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 Prieksh 64bit windows versijas:windows6.1-KB976932-X64.exe tad man kačāt viņu Link to comment Share on other sites More sharing options...
Tufjord Marts 26, 2013 Share Marts 26, 2013 Pirms saulriera windows6.1-KB976932-X64.exe tad man kačāt viņu Met mieru un sameklē,kas pārliek visu. nav te jēgas. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) poh iekačās Ā un pēdējais ko gribēju pajautāt vai pēc tā ieinsalēšanas kaut kas no kompi pazudīs vai nē windows6.1-KB976932-X64.exe Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
Tufjord Marts 26, 2013 Share Marts 26, 2013 Ja kreisais tad iespēja,ka pēc mēneša melns displeijs un palūgs Tev iegādāties aktivizāciju.Bet dokumenti,bildes un faili nepazudīs. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) windows6.1-KB976932-X64.exe tu domā ja kreisā lejuplāde ja? Tad ekrāns pēc mēneša paliks melns Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 ja ari paliks melns, nekas nepazudīs. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 a kā lai es zinu vai tas ir legālais vai nav?? Link to comment Share on other sites More sharing options...
zibins Marts 26, 2013 Share Marts 26, 2013 Runa iet par Tava windows legālumu nevis servispakas. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 aa nu sk nu tad sliktākajaā gadījumā nesīšu uz remontu lai ieliek jaunu windows 7...Tad ja kaut kas notiks Paldies visiem par atsauksmi.. UN varat vērt ciet šo tēmu Link to comment Share on other sites More sharing options...
Zux Marts 26, 2013 Share Marts 26, 2013 (labots) sliktākajaā gadījumā nesīšu uz remontu lai ieliek jaunu windows 7 Ja tev uzlīme ar key apakšā nav,tā pa vienkāršo, win legālu nedabūsi. (vis maz svaiga instalācija būs) Runa iet par Tava windows legālumu nevis servispakas Labots Marts 26, 2013 - Zuxters Link to comment Share on other sites More sharing options...
jakslis Marts 26, 2013 Share Marts 26, 2013 (labots) "ieliek jaunu windows 7...Tad ja kaut kas notiks" Nelasīju visu to ūdeni,bet šis........ izsaka visu . Labots Marts 26, 2013 - jakslis Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 Man ir uzlīme uz key Link to comment Share on other sites More sharing options...
jakslis Marts 26, 2013 Share Marts 26, 2013 (labots) Man ir uzlīme uz key Uzlīme nav uz key ,bet uz Case . Tad novelc OEM ! Tas ņems pretī Tavu "UZLĪMI". Labots Marts 26, 2013 - jakslis Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 (labots) tas poh bet kapē met ārā no spēlēm vienkārši aizvers un paliek apakšā Tad novelc OEM kur viņu var novilkt Labots Marts 26, 2013 - MareksLV Link to comment Share on other sites More sharing options...
Inspektors Caps Marts 26, 2013 Share Marts 26, 2013 nesīšu uz remontu lai ieliek jaunu windows 7...Tad ja kaut kas notiks Kad servisa gudrītis būs instalējis, tad notiks tieši tas pats, kas tagad... Windows 7 vairs nav jāvelk speciāli OEM. Ar uzlīmē esošo key aktivizēsies jebkura atbilstošās versijas tīra instalācija. Tīrs un zināms Windows 7 SP1, visas versijas vienā. Un arī šie. Link to comment Share on other sites More sharing options...
MareksLV Marts 26, 2013 Author Share Marts 26, 2013 kapē met ārā no spēlēm vienkārši aizvers un paliek apakšā???? Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 interesanti 100 posti savāksies? Link to comment Share on other sites More sharing options...
Arnolds Piepe Marts 26, 2013 Share Marts 26, 2013 Autors ir antiņš kvadrātā. Un tiem, kas te kaut ko mēģina palīdzēt, laikam ir pārāk daudz brīvā laika - vai tad tiešām neredzat, ka te ir tikai un vienīgi viens risinājums - iedot to datoru kādam, kuram ir vismaz kaut kāda sajēga par to, ko viņš dara? Link to comment Share on other sites More sharing options...
deriksx Marts 26, 2013 Share Marts 26, 2013 +++++ Link to comment Share on other sites More sharing options...
