0xDEAD BEEF
Konkurss 3 (closed)
59 posts in this topic
bet tā kā sākumā uzdevums tika dots tikai ar Dekartu, tad varētu tā būt, ka atrisināt to var arī bez čoma Pitagora?
Share this post
:swoon2:
Share this post
naziic 9b63ff35c69dd9300cec581be0808a1582d764d9
Tak topiks jāpakustina..
test:
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
Labots - naziic
Share this post
Sorry naziit - nav pareizi!
Beefs
Share this post
Izskatās, ka šī atbildi līdz deadline tā arī neiegūsim, it kā esmu atšķirojis 70% randoma nost, bet tālāk nekas neveicas un jau diezgan ilgu laiku (aptuveni 1.5 dienu), Beef negribi ielikt vēl kādu hintu?
Labots - aģents nulle septiņi
Share this post
Nu ok :) ! Pielauzāt uz vēl vienu hintu!
Iepriekšējajā darbā (Accenture) man bija lielisks priekšnieks (tiešais) Viktors, bet es viņu nekad neredzēju nēsājam cepuri.
Beefs
Edit: es nešaubos, ka pēc šī hinta saņemšanas risinājums nebūs ilgi jāgaida. Iedodiet, lūdzu, kopā ar pareizo atbildi, arī savu personīgo novērtējumu, cik ilgi tas prasītu atrisināt šo uzdevumu uz papīra (speciāli priekš Ļešij)
Labots - 0xDEAD BEEF
Share this post
paldies
Share this post
wtf? kas tas par hintu?! :D
Share this post
Viktors arī bildēs cepuri nenēsā.. http://lv.linkedin.com/in/viktors
kā arī kāds Viktora citāts "Я считаю, что безработных нет, есть пидарасы безрукие.".
EDIT: Nu jā, daudzi tie viktori Jums tur strādājuši.
Labots - naziic
Share this post
Tas nav īstais Viktors!
http://lv.linkedin.c...vskis/5/951/586
Beefs
Edit: cmon naziic - tas čalis ir senior Java developer. Uz šefa pozīciju var sākt kandidēt no system analyst.
Share this post
Hints ir Viktors vai cepure? :mrgreen:
Share this post
Varbūt vari iepostēt izejas datus, bet bez 70% randoma?
Protams, bez balvām...
Share this post
Val, tos izejas datus, lai liek pēc konkursa beigām..
Share this post
Labāk pagaidīt līdz pirmdienai. Šitais uzdevums nav risināms darba dienās (pat ņēmot verā visus "hintus" :D )
Share this post
Pagarinu konkura termiņu līdz 29. aprīļa 23:59 (Latvijas laiks).
Konkurss beidzies
Beefs
Konkurss ir beidzies, bet varat parisināt tā pat. Atceraties hintus:
* Dekarts
* randoms izmantojot pitagora teorēmu
* Viktors un cepure (vai tomēr vektors?)
Vilx- bija ļoti tuvu atrisinājumam.
Beefs
Share this post
Nemaz nebiju pamanījis, ka šis nav atrisināts :)
Nezinu kā "pareizi" šo risināt, bet nu ~30 minūtēs (no kurām 10 aizgāja uz korektas pyglet versijas dabūšana) sanāca šāds risinājums (python'ā ar pyglet bibliotēku):
from math import sqrt
S = "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"
import pyglet
window = pyglet.window.Window()
@window.event
def on_draw():
 window.clear()
 s = 20
 i = 0
 while i < len(S):
   a = ord(S[i+0:i+2].decode("hex"))
   b = ord(S[i+2:i+4].decode("hex"))
   i += 4
   c = ord(S[i+0:i+2].decode("hex"))
   d = ord(S[i+2:i+4].decode("hex"))
   i += 4
   dx = a-c
   dy = b-d
   if dx*dx+dy*dy<25:
     pyglet.graphics.draw(2, pyglet.gl.GL_LINES,
       ('v2i', (s*a, s*b, s*c, s*d))
pyglet.app.run()
Slinkajiem programmas rezultāts bildē: http://dl.dropbox.co...des/boot-k3.png
Labots - bubu
Share this post
kauko ar ziimeeshanu meegjinaaju bet laikam sashkjiebu kautko ar winapi vai arii tie 70% liekie maisiija kautko saprast
Share this post
Man tās liekās līnijas īpaši neko netraucēja. Kad uzzīmēju visas (bez if'a kodā), arī tad varēja ieraudzīt pirmajā rindā tekstu ATBILDE IR. Otro rindu gan bija grūti saprast, tāpēc kautkā nācās mest ārā liekās līnijas - sākumā gan mēģināju randomā mest 10%, 20%, 30%..., pēc tam pirmos 10%,20%, pēc tam pēdējos, pēc tam visas ne-horizontālās un ne-vertikālās, līdz nonācu līdz garuma pārbaudei.
Share this post
  • Kas ir tiešsaistē   3 biedri, 0 Anonīmi, 10 viesi (Skatīt pilnu sarakstu)
    • Blessed
    • GE (DX)
    • Anonīms Alkoholiķis
  • Biedru statistika
    22 479
    Kopā biedri
    456
    Bieži tiešsaistē
    Edma
    Newest Member
    Edma
    Pievienojies
