nestrādā ACamd
biedri, nevaru tecinat medu, kaut kas nesanāk
Lietoju:
ACamd
DVS-2 PCI karte
DVBdream
DVBdream plugin folderī iemetu visu amcad ar attiecīgu cardclient informāciju:
newcamd2://serveris:ports:user:pasword:0102030405060708091011121314
Log no ACamd?
17:04:24.682: ACamd v0.6.2.0
17:04:24.715: MD-API Version 03.00 - 1.06
17:04:24.724: systems: registering CA system Cardclient, pri -15, ident 1000
17:04:24.724: structloaders: registering loader cardclient config
17:04:24.724: cardclients: registering cardclient Newcamd
17:04:24.724: cardclients: registering cardclient Newcamd2
17:04:24.724: cardclients: registering cardclient CCcamN
17:04:24.724: cardclients: registering cardclient Radegast
17:04:24.724: cardclients: registering cardclient Camd35
17:04:24.724: structloaders: registering loader smartcard data
17:04:24.724: systems: registering CA system SC-Irdeto, pri -10, ident 1001
17:04:24.724: feature: using feature SMARTCARD
17:04:24.724: registering Irdeto smartcard (id 49726474)
17:04:24.724: systems: registering CA system SC-Seca, pri -10, ident 1002
17:04:24.724: registering Seca smartcard (id 53656361)
17:04:24.724: systems: registering CA system SC-Viaccess, pri -10, ident 1003
17:04:24.724: registering Viaccess smartcard (id 56696173)
17:04:24.724: systems: registering CA system SC-Conax, pri -10, ident 1004
17:04:24.724: registering Conax smartcard (id 436f6e78)
17:04:24.724: systems: registering CA system SC-Cryptoworks, pri -10, ident 1005
17:04:24.724: registering Cryptoworks smartcard (id 4372576f)
17:04:24.724: systems: registering CA system SC-Nagra, pri -10, ident 1006
17:04:24.724: registering Nagra smartcard (id 4e616772)
17:04:24.724: systems: registering CA system SC-NDS, pri -10, ident 1007
17:04:24.724: registering NDS smartcard (id 56694732)
17:04:24.872: Monitor listen on port 49415
17:04:25.097: B:Betatunnel, CAID:1833 with Provider:00000000 to CAID:1702 with Provider:00000000
17:04:25.097: Engine [MD-API]
17:04:25.097: loading smartcard data from C:\dvbdream\Plugins\smartcard.conf
17:04:25.098: loaded 0 smartcard data from C:\dvbdream\Plugins\smartcard.conf
17:04:25.098: loading cardclient config from C:\dvbdream\Plugins\cardclient.conf
17:04:25.098: now using protocol version 525 (cdLen=8)
17:04:25.098: init of cardclient 'newcamd2' failed
17:04:25.098: file C:\dvbdream\Plugins\cardclient.conf has error in line #1
17:04:25.098: ** registered systems:
17:04:25.098: ** SC-NDS (pri -10)
17:04:25.098: ** SC-Nagra (pri -10)
17:04:25.098: ** SC-Cryptoworks (pri -10)
17:04:25.098: ** SC-Conax (pri -10)
17:04:25.098: ** SC-Viaccess (pri -10)
17:04:25.098: ** SC-Seca (pri -10)
17:04:25.098: ** SC-Irdeto (pri -10)
17:04:25.098: ** Cardclient (pri -15)
17:04:25.098: no smartcard interface defined!
17:04:25.107:
17:04:25.108: Ch: 1104 - Digi Sport Hu
17:04:25.108: Programm crc: D277018C
17:04:27.352: PMT not found...
17:04:27.352: PMT: ACamd_PMT.txt, search, not found PMT=0450 (AND SID=03EC)
17:04:27.354: 0x0450 0x03EC 0x1802 0x00000000 0x1046 0x0082 11111110
17:04:28.960: Incomming PackageSize [184]
17:04:30.137:
17:04:30.137: Ch: 2120 - BBC World
17:04:30.137:
17:04:30.137: Programm crc: AB67D432
17:04:30.138: PMT: ACamd_PMT.txt, search, not found PMT=0848 (AND SID=0848)
17:04:30.138: 0x0848 0x0848 0x090F 0x00000000 0x084F 0x00C0 11111110
Kas ir nepareizi?
Nav ne jausmas, par ko ir runa, bet redzu, ka faila C:\dvbdream\Plugins\cardclient.conf pirmajā rindā ir kļūda.
Man ir tikai acamd, vai jābūt vēl kaut jādiem newcs failiem?
Vienkārši parkopēju info no medus tecinātāja izmēģinājuma. Cardclient failā, bet kur kļūda?
Pa vidu vēl e093/00000
Ir divi stropi nevienu nesanāk palaist
#newcamd2:192.168.7.54:34000:1/0000/0000:username:password:0102030405060708091011121314
aizgāja, kaut kāda iemesla pēc ignoreeju tās 0000/0000
tagad ir vshrots :yahoo:
newcamd:192.168.7.54:34000:1/093E/ffff:username:password:0102030405060708091011121314
Var arí šádi,tas vieninieks norāda ka jālieto newcamd protokols-network sharing
ACamd_PMT.text
# When use a sample line remove first char #
# Index PMT & SID
#PMT SID CAID Provider ECM EMM Name
#0840,0FAC,0100,0000006A,0644,00B6,NED2
#0501,1F42,0100,00000080,0633,0000,C CINEMA EMOTION (fra)
[P] Preferred
# Same CAID is possible, the higer line and with a providerid is prefered.
# When zero provider-id then preferred caid
# CAID Provider Name
#P:0100:00000000:caid only
#P:0500:000306000 #NTV+
P:0500:00040600 #NTV+
P:093E:00000000 #Vias
P:0963:00000000 #SkyUK
P:4AE1:00000015 #Platforma
#P:4AE1:00000013 #3k
P:0B00:00000000 #Thorsat
P:1702:00000000 #SKY GE
P:0D02:00000000 #UPC
P:1880:00000000 #Digi
Ignore
I:0500:00023700
#I:0500:00030600
#I:0500:00040600
I:0500:00040610
I:0500:00040620
#I:0500:00041700
#I:0500:00042700
I:0500:00050100
I:5601:00000000
I:4AE0:00000000
I:4AE1:00000002
I:4AE5:00000000
I:0960:00000000
I:0961:00000000
I:1802:00000000
I:1815:00000000
I:0B02:00000000
I:0D97:00000000
# [R] Rename from to
# CAID Provider CAID Provider Name
#R:0500:00030600:0500:00023700:NTV+
#R:0500:00040600:0500:00023700:NTV+
#R:0500:00040610:0500:00023700:NTV+
#R:0500:00040620:0500:00023700:NTV+
#R:0500:00050100:0500:00023700:NTV+
# Betatunneling
B:1833:00000000:1702:00000000:HD-Mapping
# [F] Filter PMT data, minimal 1 byte, max 49 bytes
# CAID Filterdata Name
#F:0500:050100:NTV+
#F:0100:006CFF: Filter all 006C
#F:0100:006AFFFF: Filter Canal Digital 6A Seca3
#F:0622:09040622: Filter Irdeto 2
# Sample
#P:0100:0000006A:Preferred Canal Digital
#I:0622:00000000:Ignore Canal Digital Irdeto
#I:0100:0000006B:Ignore Canal Digital 6B
#I:0100:0000006C:Ignore Canal Digital 6C
#I:0100:0000006D:Ignore Canal Digital 6D
#F:0100:006AFF00:Filter Canal Digital 6A Seca2
#F:0100:006AFFFF:Filter Canal Digital 6A Seca3
