Problēma laižot ArchiCad 12 uz MAC
Lietins
Nav laba doma sestdienas rītā tik smagu jautājumu laikam celt, bet tomēr mēģināšu, jo pašam pagrūti sagremot ;) ...
OS: Leopard + All updates
Problēmas ar: Archicad 12 un laikam quickime player
Info:
Machine Name: Power Mac G5
Machine Model: PowerMac11,2
CPU Type: PowerPC G5 (1.1)
Number Of CPUs: 2
CPU Speed: 2.3 GHz
L2 Cache (per CPU): 1 MB
Memory: 2.5 GB
Bus Speed: 1.15 GHz
Errors ko saņemu palaižot Archicad:
Problem: QuickTime is outdated or missing.
ArchiCAD requires QuickTime 7.0 or later, image compressors and decompressors.
Make sure you have QuickTime installed with the "Recommended"
option chosen at installation and not with the minimal option selected.
Uninstall QT then reinstall it with the recommended option selected.
Protams, ka QuickTime ir pēdējā versija: 7.6.6 + mēģināju arī pārinstalēt to ...
Papildus informācija:
Iepriekš šis dators bija ar TIGER, to upgreidoja uz Leopard, un tad vēl nomigrēja ar Migration Assistant lietotāju no Snow Leopard ar visām aplikācijām uz šo LEOPARD datoru.
Logos ir sekojošā info:
9/8/10 8:23:36 PM com.apple.dyld[447] warning, could not bind /System/
Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/
QuickTimeMPEG4 because realpath() failed on /System/Library/
PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/
CoreMediaAuthoring
9/8/10 8:23:36 PM com.apple.dyld[447] update_dyld_shared_cache[447]
for arch=ppc failed: read failure copying dylib. Read of 5017600 bytes
at file offset 126976 returned 475376 for /System/Library/Frameworks/
ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/
Versions/A/Resources/libPng.dylib while copying /System/Library/
Frameworks/ApplicationServices.framework/Versions/A/Frameworks/
ImageIO.framework/Versions/A/Resources/libPng.dylib to shared cache
Cita info:
problēma ir no citiem lietotājiem arī;
archicad tika pārinstalēts, nepalīdzēja
disk utility - verify disk, repair permissions arī tika izmantots
ice clean applikācijas utilities arī tika izmantotas
Vai ir vēl kādas idejas?
Sheit ir iespejams problema:
Snow Leopard ir tikai Intel Mac, tad vari megjinat saprast, ka dalja no INTEL Mac us PPC Mac neies.
Crash Report - ArchiCad ko raada?
Papildinajums uzinstalee QuickTimeMPEG Component.
Edited by Nettwerk
šobrīd netieku pie tā MAC pieslēgties, teamviewers nojūdzies kaut ko, bik vēlāk apskatīšos.
To komponenti es meklēju, bet nesapratu, kur to var novilkt, un kur viņu var atrast (ir vairāki maksas produkti, bet savādāk neko nemanīju)
