satmaster Ierakstīts Februāris 17, 2009 Share Ierakstīts Februāris 17, 2009 OPTICUM 9500 HD PVR 2CI2CXE Plus Izskatās pagaidām lētākais HD un ar šaringa iespējām. Main Features: 2x Card Reader slot with Conax embedded 2x Common Interface slot for CAM modules Ethernet supported USB 2.0 Host support HDMI supported Video resolution 1080i, 720p, 576p, 576i Software & Channel Database Transfer via USB Blind scan Multi-LNB Controlled by DiSEqC control Version 1.0, 1.1, 1.2 and USALS Teletext support Multi picture display Powerful channel control by favorites, lock, skip, move and delete Multi-language supported (OSD & Menu) Optical Output for Digital Audio General Data System Resources Main Processor: 400 MIPPS based CPU Flash Memory: 8Mbytes [Optional Expand] DDR SDRAM: 1024+512Mbits [Optional Expand] Tuner/Channel 1tuner: Decoding Input Connector: F-Type, Connector, Female Loop Through: F-Type, Connector, Female Signal Level: -65 to -25 dBm LNB Power & Polarization: -Vertical: +13V/+14V - Horizontal: +18V/+19V - Current: Max 500mA - Overload Protection 22KHz Tone: Frequency: 22±1KHz DiSEqC Control: Amplitude: 0,6±0,2V, Version 1.0, 1.1, 1.2, USALS Available Demodulation: 8PSK/QPSK Input Symbol Rate: 2-45 Mbps, Convolution Code rate 1/2, 2/3, 3/4, 5/6, 7/8 and Auto MPEG TS A/V Decoding Transport Stream: MPEG-2/H.264 Input Data Rate: 120Mbit/s max Aspect Ratio: 4:3, 16:9, Letter Box Video Decoding: 1920x1080i Video Resolution: 720x576 (PAL), 720x480 (NTSC) Audio Decoding: MPEG-1 Layers 1/2, Dolby AC-3 Audio Mode: Left / Right / Stereo Sampling Rate: 33KHz, 44,1KHz, 48KHz A/V & Data Input/Output TV-SCART: Video CVBS/RGB output, Audio L/R output VCR SCART: Video CVBS output, Audio L/R output, Video CVBS, RGB input, Audio L/R input RCA A/V: 1x YPbPr output, Video CVBS output, Audio 2x L/R output S/PDIF: Optical, Coaxial Digital Audio or Dolby AC-3 Bit Stream Output RS-232C: Transfer rate 115,2Kbps, 9 pin D-sub type USB: USB 2.0, Compatible w/independent power supply output HDMI: VER1.2 Type A RF-Modulator (Optional) PLL type: CH21~69 for the Demodulation TV Standard: PAL BG/I/DK selectable RF Connector: 75 Ohms, Male/Female Frequency Range: UHF : 470~860MHz Power Supply Input Voltage: 100-250 VAC, 50/60Hz Type: SMPS Power Consumption: 30W Max. Protection: Separate Internal Fuse and Chassis Grounding. The input shall have lighting or electric shock protection Physical Specification Size[W*H*D]: 360mm x 266mm x 65mm Net Weight: 2,49 kg Environment: Operation Temperature: 0°C~+45°C Storage Temperature: -10°C~+70°C Storage Humidity: 5~95°RH (Non Condensing) Pieejams ir pagaidām šeit pa 150Ls vajadzēs sarunāt uz testu, tad arī varēšu ko vairāk pastāstīt. Varbūt kāds jau tetē un kautko zina vairāk, tad lai klāj vaļā. Link to comment Share on other sites More sharing options...
RMV Februāris 18, 2009 Share Februāris 18, 2009 Kur var palasiit par shaaringa iespeejaam shim dzelzim? Link to comment Share on other sites More sharing options...
Gyrkis Februāris 18, 2009 Share Februāris 18, 2009 (labots) Skat kā cenas slīd.. jau 150Ls nuuu ilgi nebus jagaida lidz bus 100Ls :-D seit var dabut jaunakas fw sim aparatam Seit Labots Februāris 18, 2009 - Gyrkis Link to comment Share on other sites More sharing options...
Rudiger Februāris 18, 2009 Share Februāris 18, 2009 Palasīt var te http://www.wizardfox.net/showthread.php?t=14004 (jāreģistrējas ).Bet šis teikums ne sevišķi patīk...,,Все розобрался все работает поверхность, платформа , +++ , только +++ хд неработают,,подтверждаю +++ хд неработают на поверхности HD нет звука совсем,, Link to comment Share on other sites More sharing options...
Dexs Februāris 18, 2009 Share Februāris 18, 2009 Nu NTV HD tak tikai 4 vai 5 kanāli pagaidām ir, diži nekāds lielais zaudējums nav... Tad jauj 9E pat pievilcīgāks ir... Link to comment Share on other sites More sharing options...
Rudiger Marts 6, 2009 Share Marts 6, 2009 Ja kādam interesē-īss forumu un savu iespaidu kopsavilkums.Plusi-lieliska bilde SD un HD kanāliem, lēts -180 EUR ar piegādi(tagad gan vairāk) http://www.satsklep.com , medus tek gan SD, gan HD, SW atjauno caur USB Flash,var pieslēgt ārējo HDD caur USB, strādā oficiālās kartes, kanāli pārslēdzas ātri.Izņēmums- pašlaik lēnāk (4-5 sek)atveras Platforma DV un HD, bet atveras un iet stabili.Var ielikt iekšā SATA disku ar kūleri, ir vieta arī DVB-T tjunerim.Mīnusi-pašlaik negatavs softs-problēmas sarakstīt un noskenēt NTV + transponderus (bet viss ir atrisināms), NTV+ medus tek normāli tikai no stropiem ar 2 skrejām SD un HD , citādi bites maldās. Ir arī daži stropi ar vienu skreju, kur viss ir OK.Bet jau pašlaik viss vajadzīgais iet. Ir baumas, ka turpmāk softs būs maksas, toties normāls.Tiek apspriests wizardfox.net , sat-expert.com forumos.Pašlaik vienīgais normālais softs te http://www.agsat.com.ua/docs/Opticum_9500HD_1.0.85_flash.rarJa neskatās 36E vai 9E, tad der arī jaunais softs 1.0.1, ar to neiet 3K. Link to comment Share on other sites More sharing options...
norico Aprīlis 27, 2009 Share Aprīlis 27, 2009 Nu vismaz man ar pēdējo 1.0.1 softu Platformas medus tek bez problēmām, reizem gan pārslēdzot kanālus mazliet jāuzgaida. Bet tas jau nu tāds sīkums, galvenais, ka viss notiek. Link to comment Share on other sites More sharing options...
maigais Aprīlis 29, 2009 Share Aprīlis 29, 2009 ja šadu tendenci noveroju opticumam 4100tscxe uz+++ un triko, jo katrs ports jaraksta atsvišķi,un pie kanalu parslēgšanās ilgi domā ,bet atver.laikam līdziba ir visiem opticumiem. Link to comment Share on other sites More sharing options...
maigais Maijs 6, 2009 Share Maijs 6, 2009 OPTICUM 9500 HD iznācis jauns softs STi7101 03000200 globo fairy ps 2.0.00 flash Link to comment Share on other sites More sharing options...
Rudiger Maijs 6, 2009 Share Maijs 6, 2009 Diemžēl tas ir tas pats vecais 1.0.86, kas nez kāpēc vairākos forumos tiek pārsaukts par 2.0.0.Nekā jauna trumana lapā nav...Var ieliet klona YUMATU HD softu http://www.wizardfox.net/showthread.php?t=16658 Link to comment Share on other sites More sharing options...
rashns Maijs 9, 2009 Share Maijs 9, 2009 Ir vērts ņemt šo kasti, vai tomēr krāt naudu kādam dārgākam? Kādi vispār lielākie mīnusi? Link to comment Share on other sites More sharing options...
Rudiger Maijs 9, 2009 Share Maijs 9, 2009 Mīnuss tikai 1- pašlaik lēni atveras Platforma HD un DV kanāli-4-6 sek.Visi pārējie HD, kādus esmu skatījies-NTV+,Cyfra+,Canal Digital(0.8W), Poverhnostj-normāli.Vēl nedaudz lēnāk (2-3 sek)-kinoreisi.Šo problēmu cenšas risināt stropi, jo uztvērējs Krievijā ,Ukrainā kļūst par tautas aparātu, bet cerams, ka būs softs ar kanālu piesaisti identam kā Openboxam.Un katram HD aparātam pašlaik ir savas problēmas... Link to comment Share on other sites More sharing options...
MartiniB Maijs 9, 2009 Share Maijs 9, 2009 vot tauta, visas probleemas jaarisina stropam, jo lietotaajam jaaapeerk leetaakais hlams un itnemaz nav jaaiedziljinaas kaa kas straadaa lai serveri nebombardeetu ar nevajadziigu spamu un emulaatoram atvieglotu izveeli vienc no pieprasiijumiem jaaignoree, piemeers priex camd3.ignore: # Platforma HD # ESP HD #4AE1:000000:001E:006E 4AE1:000000:001E:006F # Kinopokaz 2 HD #4AE1:000000:0050:0078 4AE1:000000:0050:0079 # Teleputeshestviya HD #4AE1:000000:0046:0078 4AE1:000000:0046:0079 ... .. . Link to comment Share on other sites More sharing options...
janispauls Maijs 9, 2009 Share Maijs 9, 2009 (labots) Tautai pofig ,lai būtu lēts un būtu atbalsts ,ar to atbalstu ,no sākuma var būt līdz vienam laikam un stop Labots Maijs 9, 2009 - janispauls Link to comment Share on other sites More sharing options...
Gyrkis Maijs 14, 2009 Share Maijs 14, 2009 (labots) Iznacis jauns softs Opticum 9500 HD PVR 2CI2CXE Plus Version : 1.1.12 1.1.12: Имеем + Во-первых, появилась возможность отключения прогресс бара каналов + работает гладко, исправлено HD качество изображения. Стремительное движение, как представляется, должно быть плавным. (конечно prz5 50Hz) + корректно работает и быстрее EPG, (также с польскими шрифтами) + Добавлена поддержка в меню таймера + Повышение скорости в сравнении с неофициальным программным обеспечением - 1.1 .09 (это всего лишь тестовая версия ) + улучшена работа шаринга. Данный софт, безусловно, является лучшим. Testejam,testejam,testejam.... Labots Maijs 14, 2009 - Gyrkis Link to comment Share on other sites More sharing options...
Rudiger Maijs 14, 2009 Share Maijs 14, 2009 Jau iztestējām- tās pēdējās 2 rindiņas-bez komentāriem.Kam interesē-palasiet wizardfox.net atsauksmes.Visi 1.xx softi bombardē stropus ar kļūdainiem pieprasījumiem pa visiem portiem (paketēm )reizē.Arī standby režīmā!Seko stropa bans.3Kolor neiet pavisam.Kirilicu vispār nepanes-kā uzliek RU setingos, tā pārstartējas.To gan nekonstatēju, jo lietoju EN.Poļiem, protams, viss OK.Tiem, kas skatās 9E,36E, diemžēl jāatgriežas pie 0.85 un 0.86 versijas. Link to comment Share on other sites More sharing options...
norico Maijs 14, 2009 Share Maijs 14, 2009 Nu nezinu gan, man menu ir krievu valodā, arī kanāli no 9*E ir kirilicā. Platforma iet bez problēmām. Softs 1.1.12 Link to comment Share on other sites More sharing options...
Gyrkis Maijs 14, 2009 Share Maijs 14, 2009 Es ari pagaidam nemanu problemas.Kaut ari neskatos krievus,bet Sky uk iet viss normali(banu no stropa neviens vel pagaidam nav iedevis) Link to comment Share on other sites More sharing options...
norico Maijs 14, 2009 Share Maijs 14, 2009 Pēc rūpīgākas pārbaudes tomēr izrādījās, ka tas 1.1.12 softs ir gļukains, lieku atpakaļ veco 1.1.01 Link to comment Share on other sites More sharing options...
Rudiger Maijs 14, 2009 Share Maijs 14, 2009 Ja skatās vienu SkyUK ar vienu identu, tad jau nekas, bet ja pakešu daudz...Vienīgā cerība uz vietējiem softa cepējiem.No poļiem neko labu nesagaidīt.Un to, ka arī standby režīmā iet pieprasījumi, var redzēt, pavērojot rūtera lampiņas.Norico-un cik ātri Tev atveras Platforma?Tikai nesaki, ka momentā.Šis laiks gan stipri atšķiras dažādiem stropiem. Link to comment Share on other sites More sharing options...
norico Maijs 14, 2009 Share Maijs 14, 2009 (labots) Nu Platforma 50% gadījumos atveras 3-4 sekunžu laikā, 50% gadījumos atveras momentāli, standby režīmā tiktiešām pieprasījumi tiek sūtīti. Bet vai tad ar 85 vai 86 softu Platforma atveras zibenīgi un pieprasījumi standby režīmā netiek sūtīti? Labots Maijs 14, 2009 - norico Link to comment Share on other sites More sharing options...
Rudiger Maijs 14, 2009 Share Maijs 14, 2009 Nē, diemžēl, man arī tāpat 3-6 sek.Momentā-ja starp savas paketes kanāliem.Wizard forumā var atrast atsauci uz stropu, kur it kā atfiltrēti liekie identi un arī Platforma atveras ātrāk.Tikai tur ir 2x dārgāka VIP pakete kā citur.Jāgaida, kad arī citi stropi darīs ko līdzīgu, jo normāls softs diez kad būs.Ar 0.85-86 softu pieprasījumi neiet standby.Un 3kol iet.1.xx softi tam kļūdo atslēgas.Ar 86 nestrādā visi fleši,bet iet audio pa optisko izeju, kam vajag, citu atšķirību nav.Arī setingi 85 un 86 sakrīt. Link to comment Share on other sites More sharing options...
norico Maijs 17, 2009 Share Maijs 17, 2009 Nu par cik es no Krievijas Tv provaideriem varu uztvert tikai Platforma DV, tad palikšu vien pie 1.1.01 versijas. Wizard forumā minētajā stropā Platformu diemžēl nevar dabūt atsevišķi, tā kā arī tas man neder. Tā kā atliek vien gaidīt labāku softu. Radās ideja izveidot nelielu medus kārotāju pulciņu, kurā strops būtu Opticum 9500. Iesākumā izmēģinājām to lietu divu Opticum starpā, viens atrodas LV otrs Īrijā. Viss jau it kā darbojas, bet tikai vienā virzienā. Tas ir, ar Īrijā atrodošos Opticum var baudīt medu no LV Opticum, bet otrādi nekā. Radās doma, ka tas varētu būt Eircom rūteris, kas kaut kādā veidā neļauj no LV tikt pie Īrijas medus. Un te lūk jautājums - vai kādam ir ideja ko vajadzētu pamainīt rūtera iestatījumos, tā lai medus tecētu abos virzienos? Rūteris ir Netopia 2247-02. Jau iepriekš saku paldies! Link to comment Share on other sites More sharing options...
maigais Jūnijs 27, 2009 Share Jūnijs 27, 2009 (labots) bildes http://laki.dvhk.pl/warsztat/opticum9500hd.htm Labots Jūnijs 27, 2009 - maigonis Link to comment Share on other sites More sharing options...
MartiniB Jūnijs 27, 2009 Share Jūnijs 27, 2009 bildeec kopaa ar 8k driimu lai katram zirgam skaidrs ka dizains kretinee :-D Link to comment Share on other sites More sharing options...
Rudiger Jūnijs 27, 2009 Share Jūnijs 27, 2009 Jā, man arī tā liekas, ka Drīms izskatās tizli! Tikai par paliktni šis kalpo ! Link to comment Share on other sites More sharing options...
Dexs Jūnijs 27, 2009 Share Jūnijs 27, 2009 Martini laikam otrādāk domāja... Link to comment Share on other sites More sharing options...
MartiniB Jūnijs 27, 2009 Share Jūnijs 27, 2009 katram sava meeraukla :-) Link to comment Share on other sites More sharing options...
Gyrkis Jūnijs 30, 2009 Share Jūnijs 30, 2009 Iznacis jaunais softs 1.1.26 Release note for software 1.1.26 - Fixed the hanging problem. - Add HDD Sleep function. - Fixed other small bugs. Release note for software 1.1.18 - For improve operations, Move the menu of VCR LIST to Preference menu. - Add subtitle auto display function in the live channel. - Add the subtitle function in the playback(need manual to open). - Fixed some bugs in the Timer Config. - Fixed some bugs in the epg more, discover scarcity some event. - Fixed can not obtain MAC Addr Bug, MAC Addr is 0 of some receivers. - Fixed the problem with Digital audio output. - Fixed the subtitles displayed with delay in the playback. - Fixed the bug: in one of FAV list and press RECALL, switch to ALL channels. - Fixed the bug: in the infobar now/next event time. Link to comment Share on other sites More sharing options...
Rudiger Jūnijs 30, 2009 Share Jūnijs 30, 2009 Jā, beidzot ir skaņa Music HD 36E,HDD miega režīms, atkal strādā Digi TV AU..Ar medu diemžēl nekas nav izlabots. Link to comment Share on other sites More sharing options...
norico Jūlijs 11, 2009 Share Jūlijs 11, 2009 Starp citu, top jauns šāres serveris, tendēts tieši uz Opticum 9500 HD. Dabūju testu uz nedēļu, Platforma HD kanāli pārslēdzas gandrīz momentāli. Tā kā būs vien pie šiem jāpāriet. Link to comment Share on other sites More sharing options...
Rudiger Jūlijs 11, 2009 Share Jūlijs 11, 2009 Patestēju, par Platformu taisnība, bet citu problēmu pietiek.Tā iet, ja mēģina pielāgot stropu kļūdainam softam Vietējie meistari pielāgojuši klona GIS-980HD softu 1.26 Optikumam,tikai nedaudz jāpārtaisa pults( jāieliek mikro slēdzītis Opti-GIS režīmu pārslēgšanai).Nedaudz labāks interfeiss, rāda bildi arī Menu režīmā,EMU ,diemžēl, tas pats. Link to comment Share on other sites More sharing options...
mailto Jūlijs 27, 2009 Share Jūlijs 27, 2009 Un kas uz shodienu aktuaals shim dzelzim? meegjinu te testeet dazjaadus soft. Labi ka ar stropu var vienoties un pretenzijas neizsaka. Link to comment Share on other sites More sharing options...
Rudiger Jūlijs 28, 2009 Share Jūlijs 28, 2009 (labots) Izvēle N:1)softs 0.85 patch un 0.86.Plusi-iet visas paketes (lēnāk vai ātrāk atveras-atkarīgs no stropiem).Ja skatās VIP paketi, tā ir vienīgā izvēle.Mīnusi-zūd EPG,nav skaņas MusicHD (36E) 2)1.30 un 1.32Gold- strādā DIGI TV AU ,skaņa Music HD,EPG nepazūd(ar 1.30 EPG pazūd tāpat kā 0.85).GIS versijai ir labāks interfeiss-menu režīmā redz TV,uz displeja kirilica.Pašlaik izvēlējos to, vienīgi jāpadarbojas ar pulti-jāielodē mikroslēdzītis, ar ko pārslēgt GIS-Opticum režīmu, novietojas zem bateriju nodalījuma un pārslēdzams, noņemot vāciņu.Mīnusi-sākot ar 1.01 versiju, medus ir sabojāts, konkrēti 3Kol, Platf un Via*** reizē skatīties nav iespējams-jāizvēlas 2 no trijiem. 3)klona YUMATU softs-jaunākā versija 1.33, atšķiras tikai interfeiss, ir kam patīk, man nē. Visa info Te Nu jau ir 1.30 Optikumam un 1.32 GIS 980HD.Labuma gan nekāda...Arī NTV+++HD piemeta jaunu identu, kura ECM šis uztvērējs nespēj sagremot un pārstartējas... Betdzot softā 1.34new ,1.35 un 1.38 izlabota uztvērēja pārstartēšanās +++HD ,,,NTV,, un ,,1,, kanāliem!Cerams, ka reāli sagaidīsim identa piesaisti kanālam! Labots Oktobris 7, 2009 - Rudiger Link to comment Share on other sites More sharing options...
mailto Maijs 21, 2010 Share Maijs 21, 2010 Gandriiz gadu cilveeks buus ar ieliktajiem softiem lietojis tuneri. Atkal kaste nonaaca pie manis uz updeitiem. Suudziibas kinoreisi, kinoxiti restartee iekaartu. Ko uz shodienu ieteiktu ieshuut? Enigma 2, dualboti utt. Kas taads aktuaals? Un kas uz shodienu aktuaals shim dzelzim? meegjinu te testeet dazjaadus soft. Labi ka ar stropu var vienoties un pretenzijas neizsaka. Link to comment Share on other sites More sharing options...
Gyrkis Maijs 22, 2010 Share Maijs 22, 2010 (labots) Vari likt enigmu2...bet vel pagaidām pazaļa visa tā lieta. Es personīgi lietoju Opticum9500 ILTV EdiVIP 1.1.25-3 HD+.dld...skatos visus tavus minētos kanālus no problem. Protams tā jau būtu labāk likt Enigmu2...personīgi nepatīk tapēc ka ja kanāls sak raustīties(signāla vai shares problēmas)vinš vienkārši neparstāj raustīties un ķerties kamēr uzkarās pa visam ...atliek vien celties augšā un ar aizmuguras slēdzi visu pa jaunam. Labots Maijs 22, 2010 - Gyrkis Link to comment Share on other sites More sharing options...
Rudiger Maijs 22, 2010 Share Maijs 22, 2010 (labots) Nu kinoreisi, kinohīti iet ar pilnīgi visiem softiem bez problēmām.Restarti bija uz +++ HD ,первый,НТВ kanāliem, sen jau novērsti jaunajos softos.Un E2 arī jau iet normāli.Gyrkis minētā raustīšanās ir TIKAI SkyUK,SkyIt , kam vajadzīgs ātrs Inets un maz klientu kartei.Citiem operatoriem pie frīza bilde vienkārši sastingst un atjaunojas. Tomēr klientam E2 vēl likt par agru, jāgaida relīze-sola uz jūniju , jūliju.Toties pašam , ja patīk eksperimentēt, jau ir lietojama-medus tek, torrentklients strādā, .avi, .mkv rāda ,internetradio arī.Vēl ir problēmas ar ierakstīšanu,tāpēc neredzu jēgu likt iekšā cietni. Pagaidām lietoju ārējo USB HDD. Labots Maijs 23, 2010 - Rudiger Link to comment Share on other sites More sharing options...
lipka Augusts 15, 2010 Share Augusts 15, 2010 Sveiki! Man ir nesaprašana par softa atjaunināšanu.Iegādājos Optikumu 9500 HD un pēc pārinstalēšanas uz 1.2.53 ,nezkāpēc nav emulatora?!Spiežu 9339 un man parādās,ka tāda kanāla nav.Apskatos info un tur man smuki parāda,ka versija ir 1.2.53.Kur tad emulators?!Lādēju vēlreiz,bet citu-ps variantu un tur viss notiek,nopriecājos.Lādēju atkal conax versiju un atkal nav emulatora.Lādēju mpcs versiju un atkal nav emu.Nesaprotu,vai kaut ko ne tā daru,šķibs softs,vai uztvērējs? Link to comment Share on other sites More sharing options...
Rudiger Augusts 15, 2010 Share Augusts 15, 2010 Ir vairāki softa varianti-conax (tikai Conax kartēm), Mcas-dažādu kodējumu -multiCAS-kartēm) un _ps-ar EMU!Ņem šo STi7101_03000200_globo_fairy_ps_1.2.57_all.rar un viss ies.Pēdējais softs normāli atver gandrīz visas paketes. Link to comment Share on other sites More sharing options...
lipka Augusts 15, 2010 Share Augusts 15, 2010 Paldies Rudiger,mēģinu. Es gan te palasījos pa forumiem un tomēr iesaka 1.2.53 versiju.Kādi jūsu viedokļi? Paldies Rudiger ,nu jau AB motors iet bez aizķeršanās un emu strādā.Vairāk neeksperimentēšu,jo sazin kas!Pieļauju,ka kreisie softi,kaut gan kaimiņam ar to pašu iet. Link to comment Share on other sites More sharing options...
