Guest moe002 Ierakstīts Septembris 30, 2007 Share Ierakstīts Septembris 30, 2007 Man ir 2 datori un es gribu ar draugu speeleet cs ar vienu es tieku citos serveros ar otru es nevaru man pat neuzraadas server list nekas man ir DL-604 Etheernet broadband router plz pal'iidz ! Link to comment Share on other sites More sharing options...
D-avi-S Septembris 30, 2007 Share Septembris 30, 2007 man tas pats Link to comment Share on other sites More sharing options...
Grossmeister Septembris 30, 2007 Share Septembris 30, 2007 Un kā ar port forwarding - http://portforward.com/cports.htm ? Link to comment Share on other sites More sharing options...
D-avi-S Septembris 30, 2007 Share Septembris 30, 2007 tas pa maksu kautkaads ? variet palīdzēt plzz Link to comment Share on other sites More sharing options...
Nettwerk Septembris 30, 2007 Share Septembris 30, 2007 (labots) Nekas nav par maksu... Tikai nepiecieshamas zinaashanas... Routerii ir.To var atrast zem NAT sadaljas... Protams ne visos.Edimax routerim ir zem NAT > Port Forwarding sadaljas... Labots Septembris 30, 2007 - Nettwerk Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 1, 2007 Share Oktobris 1, 2007 es atradu rootera pamaaciibaa shitaadu Filters - MAC Filter Use MAC Filters to deny computers within the local area network from accessing the Internet. You can either manually add a MAC address or select the MAC address from the list of clients that are currently connected to the unit. Select Only allow MAC address listed below to access Internet from LAN (Local Area Network) if you only want selected computers to have Internet access and all other computers not to have Internet access. Select Only deny MAC address listed below to access Internet from LAN (Local Area Network) if you want all computers to have Internet access except the computers in the list. tas ir kautkas saistiits ar manu prob ? plzz es neko daudz nesaprotu taadeell arii raxtiiju sheit plz.. Link to comment Share on other sites More sharing options...
wolf Oktobris 1, 2007 Share Oktobris 1, 2007 Nē nav saistīts... Tev jau rakstīja: Un kā ar port forwarding - http://portforward.com/cports.htm ? Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 1, 2007 Share Oktobris 1, 2007 bet kas man tur jaizdara tajaa port forwarding nu luuudzu... Link to comment Share on other sites More sharing options...
MrGreen Oktobris 1, 2007 Share Oktobris 1, 2007 port forwarding nepaliidzees, jo tas ir nepiecieshams tikai, tad ja serveris atrodaas aiz pashu ruutera. shajaa gadiijumaa jaaskataas otra datora tiikla konfiguraacija, vai arii speeles konfiguraacija, vai arii varbuut vainiigi nepareizi firewall iestaadiijumi nemaaku teikt kas par vainu, jo vainiigi var buut vairaaki apstaaklji Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 1, 2007 Share Oktobris 1, 2007 emm man ir taa kad es iedalu dmz to ip adresi kas ir man shitam datoram tad atkal otram nerukaa i nets nuu rukaa tikai neraadas server list un t.t plz paliidzat es dzirdeeju ka te visi pro taadaas lietaas Link to comment Share on other sites More sharing options...
Guest ADEX Oktobris 1, 2007 Share Oktobris 1, 2007 Vai tik te pie vainas nebūs tas, ka serveris no vienas IP atļauj tikai 1 konekciju? Pats spēlītes nedzenāju, tāpēc nezinu, vai tā varētu būt. Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 1, 2007 Share Oktobris 1, 2007 emm man kad kautvai tas dators izsleegts neiet shitam un serveri ir daudz bet neuzraad nevienu P.S Help me please Link to comment Share on other sites More sharing options...
MrGreen Oktobris 1, 2007 Share Oktobris 1, 2007 nu taadaa gadiijumaa izskataas, ka tev tam otram datoram visdriizaak firewall kaut ko blokjeee un nav tur routers iesaistiits Link to comment Share on other sites More sharing options...
Aicis Oktobris 1, 2007 Share Oktobris 1, 2007 (labots) Cilvēk, liec mierā DMZ! Ja šī fīča būs ieslēgta, tad protams ka tiksi savos cs serveros tikai ar to datoru, kura iekšēja tīkla IP norādīta pie DMZ. Jebkuram citam datoram tavā mājas tīklā būs pieejams nets minimālā apjomā. Atslēdz DMZ, tad abiem datoriem izmantojot, jau pieminēto, pamācību atver rūtera portus priekš cs. Labots Oktobris 1, 2007 - Aicis Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 2, 2007 Share Oktobris 2, 2007 Es izdariiju visu kas ir peec pamaaciibas tajaa port forwarding bet nekas nesanaak ! ( Link to comment Share on other sites More sharing options...
Grossmeister Oktobris 2, 2007 Share Oktobris 2, 2007 Iemet skrīnšotu no forwarding sadaļas - paskatīsimies , kas tev tur ir . Link to comment Share on other sites More sharing options...
hero Oktobris 2, 2007 Share Oktobris 2, 2007 nafiga portforwards ? nets tam kompim maz straadaa ? ja kompis sleedzas uz pasauli nafig vispaar kaut kaada portu translaacija jaataisa ? translee parasti uz feikajaam IP. Labaak piecreiz paarbaudi vai normaali NATs straadaa pareizas ip adreses un vai uz taa viena lokaalaa kompja nav cs kaut kaadaa deny FW rullee ielikts. Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 2, 2007 Share Oktobris 2, 2007 Es ieliku screenus no mana rootera varb'ut man tur kautkas netaa ir uzlikts paskataties plzz http://yy.lv/download.php?f=71861 Link to comment Share on other sites More sharing options...
Grossmeister Oktobris 2, 2007 Share Oktobris 2, 2007 Bildēs maz ko var saprast . Tavam cs jaforwardē TCP portu grupa no 27020-27039 un UDP - 1200 un grupa no 27000-27015 . To linku vispār apskatījies ? Link to comment Share on other sites More sharing options...
D-avi-S Oktobris 2, 2007 Share Oktobris 2, 2007 jaa aspkatiijos es iydariiju visu itkaa bet man vienalga nerukaa ew kas tiessi ir static ip ? (tag es spēlēju wolfenstein enemy territory un tas pats arii server list neraada takaa speelee nav vainas ) Link to comment Share on other sites More sharing options...
Grossmeister Oktobris 3, 2007 Share Oktobris 3, 2007 kas tiessi ir static ip ? Kad tu ar roku ievadi parametrus - IP address , subnet mask , DNS server , tad tā tev būs statiskā IP adrese , ja tu izvēlies DHCP vai "obtain IP address automatically" - tad tā tev būs dinamiskā IP adrese . Link to comment Share on other sites More sharing options...
Guest moe002 Oktobris 5, 2007 Share Oktobris 5, 2007 °kur ko ar roku es varu ievadiit ? Vai tiessaam neviens nevar paliidzeet ? Link to comment Share on other sites More sharing options...
Guest drunk_lizard Oktobris 5, 2007 Share Oktobris 5, 2007 pirmkaart dubultacc otrkaart -daargais sjizoiid, nav ko lieki piepuuleet savas nieciigaas smadzenes un njemt nost resursus elementaaro refleksu pildiisjanai SAMAKSAA KAADAM,KURSJ DOMAA UN MAAK! IBIO Link to comment Share on other sites More sharing options...
