Guest Darkheart Ierakstīts Augusts 25, 2006 Share Ierakstīts Augusts 25, 2006 Mana hosta provaideris nomainīja serverus un pārcēla visus datus uz jaunu serveri. Tagad ir šāds kļūdas paziņojums, ja spiež uz galeriju linka: Warning: main() [function.main]: open_basedir restriction in effect. File(/lang_hierarchy_album.php) is not within the allowed path(s): (/var/www/vhosts/ankh.id.lv/httpdocs:/tmp) in /var/www/vhosts/ankh.id.lv/httpdocs/language/lang_latvian/lang_main_album.php on line 24 Warning: main(lang_hierarchy_album.php) [function.main]: failed to open stream: Operation not permitted in /var/www/vhosts/ankh.id.lv/httpdocs/language/lang_latvian/lang_main_album.php on line 24 Warning: main() [function.main]: open_basedir restriction in effect. File(/lang_hierarchy_album.php) is not within the allowed path(s): (/var/www/vhosts/ankh.id.lv/httpdocs:/tmp) in /var/www/vhosts/ankh.id.lv/httpdocs/language/lang_latvian/lang_main_album.php on line 24 Warning: main(lang_hierarchy_album.php) [function.main]: failed to open stream: Operation not permitted in /var/www/vhosts/ankh.id.lv/httpdocs/language/lang_latvian/lang_main_album.php on line 24 Warning: main() [function.include]: Failed opening 'lang_hierarchy_album.php' for inclusion (include_path='.:') in /var/www/vhosts/ankh.id.lv/httpdocs/language/lang_latvian/lang_main_album.php on line 24 Kas varētu būt par problēmu? Link to comment Share on other sites More sharing options...
root Augusts 25, 2006 Share Augusts 25, 2006 php.ini norādīts lai met ārā warningus iemet skripta sākumā error_reporting(0); Link to comment Share on other sites More sharing options...
Guest Darkheart Augusts 26, 2006 Share Augusts 26, 2006 Brīdinājumu problēmu atrisināju ar pilna ceļa norādi: include('language/lang_latvian/lang_hierarchy_album.' . $phpEx); Taču tagad, atverot albumu, redzama tikai balta lapa! :cry: Pamanīju vēl vienu kļūdu (varbūt tā saistīta ar iepriekšējo?) - pirmais tiek ielādēts fails index.php, nevis index.html Man failā index.html uzlikta pāradresācija uz portal.php, tāpēc vajag lai index.html ielādējas vispirms. Link to comment Share on other sites More sharing options...
Guest Darkheart Augusts 26, 2006 Share Augusts 26, 2006 Vai tiešām nevienam nav jausmas, kas tās par problēmām? To pašu datubāzi un visus failus pārkopēju uz citu hostu, un tur viss strādā. Tātad vaina ir serverī, bet kas tur nav kārtībā? Link to comment Share on other sites More sharing options...
Mezavecis Augusts 26, 2006 Share Augusts 26, 2006 Vismaz cik esmu manījis, tad konfigurējot webserveri tiek norādīti ielādes faili, un droši vien, servera konfigurētājs norādījis primāro index.php. Nu tad pārsauc savu index.html par index.php, nedaudz pamaini saturu un ņemies tālāk un rezultāts būs tas pats. Vēl izskatās, ka mainījusies mapju struktūra un man liekas, ka nav norādīta pareiza atrašanās vieta dažiem failiem iekš lang_main_album.php. Apskaties, kas tev tai failā notiek. Varbūt nav uzrādīts relatīvais ceļš bet pilnais. Link to comment Share on other sites More sharing options...
Guest Darkheart Augusts 26, 2006 Share Augusts 26, 2006 Ar to provaidera atbalstu ir tā pašvaki - vakar ap astoņiem vakarā uzrakstīju meilu (patiesībā divus), bet atbildes vēl nav :/ index.php ir foruma sākuma fails, tāpēc to nevaru mainīt no sākuma bija relatīvais ceļš, bet ar to bija tas kļūdas ziņojums.. kad uzrakstīju pilno, tad kļūda pazuda, bet tāpat ir balta lapa Link to comment Share on other sites More sharing options...
Guest Darkheart Augusts 26, 2006 Share Augusts 26, 2006 Albumu problēmu atrisināju. Kļūda bija tāpēc, ka 2 failos bija lietota php4 sintakse, kas pēc updeita uz php5 versiju nedarbojās. Nomainīju failos "$this" uz "$this1" un tagad darbojas. Link to comment Share on other sites More sharing options...
Guest Darkheart Augusts 27, 2006 Share Augusts 27, 2006 Otro problēmu arī esmu atrisinājis, nodefinējot ielādes failu kārtību .htaccess failā. Tagad vairs pat pāradresācija no index.html uz portal.php nav vajadzīga, jo uzliku kā primāro portal.php .htaccess attiecīgajai mapei var uzlikt sekojoši (varbūt kādam noder): 1) Izveidojam ar Notepad teksta failu; 2) Ierakstām tajā: DirectoryIndex index.html index.htm index.php ...vai arī izvēlamies savādākas failu ielādes prioritātes, piemēram, es uzstādīju šādi: DirectoryIndex portal.php index.php index.html index.htm 3)Ielādējam failu savas lapas sākuma direktorijā (vai citā, ja vajag) un pārsaucam par ".htaccess" Link to comment Share on other sites More sharing options...
