Lieta Ierakstīts Novembris 23, 2021 Share Ierakstīts Novembris 23, 2021 Kurš varētu palīdzēt savest kārtībā cietni, nep..išot datus? # gdisk -l /dev/sda GPT fdisk (gdisk) version 1.0.5 Warning! Disk size is smaller than the main header indicates! Loading secondary header from the last sector of the disk! You should use 'v' to verify disk integrity, and perhaps options on the experts' menu to repair the disk. Caution: invalid backup GPT header, but valid main header; regenerating backup header from main header. Warning! One or more CRCs don't match. You should repair the disk! Main header: OK Backup header: ERROR Main partition table: OK Backup partition table: ERROR Partition table scan: MBR: protective BSD: not present APM: not present GPT: damaged **************************************************************************** Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk verification and recovery are STRONGLY recommended. **************************************************************************** Disk /dev/sda: 17579413694 sectors, 8.2 TiB Model: WDC WD100EFAX-68 Sector size (logical/physical): 512/4096 bytes Disk identifier (GUID): E965D649-FADC-4450-BB9A-EA0B7E6191DE Partition table holds up to 128 entries Main partition table begins at sector 2 and ends at sector 33 First usable sector is 2048, last usable sector is 19532873694 Partitions will be aligned on 2048-sector boundaries Total free space is 0 sectors (0 bytes) Number Start (sector) End (sector) Size Code Name 1 2048 671090687 320.0 GiB 8300 2 671090688 19532873694 8.8 TiB 8300 Ir: Disk /dev/sda: 17579413694 sectors, 8.2 TiB Jābūt Disk /dev/sda: 9,1 TiB, 10000831348736 bytes, 19532873728 sectors Šobrīd sanāk, ka otrā partīcija ir lielāka par disku. Link to comment Share on other sites More sharing options...
ImissimI Novembris 23, 2021 Share Novembris 23, 2021 Ko smārts rāda? Labais tonis ir klonēt uz citu disku ar piem. ddrescue un tad mocīt kopiju. Labi, ka tad, kad ar šito čakarējos vēl nebija 6TB+ hdd Ir arī gadījies ka kabelis gļukains. 2 Link to comment Share on other sites More sharing options...
Lieta Novembris 23, 2021 Author Share Novembris 23, 2021 Smārts rādīja šo: root@lieta:/home/lieta# smartctl -a /dev/sda smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.11.0-38-generic] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD100EFAX-68LHPN0 Serial Number: JEJ5YALM LU WWN Device Id: 5 000cca 267dee302 Firmware Version: 83.H0A83 User Capacity: 9 000 659 811 328 bytes [9,00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Nov 23 17:16:48 2021 EET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED Bet es jau pats sāku niekoties ar to disku. Izpildīju sekojošo: # hdparm -N /dev/sda /dev/sda: max sectors = 17579413694/19532873728, HPA is enabled # hdparm -N p19532873728 /dev/sda /dev/sda: setting max visible sectors to 19532873728 (permanent) max sectors = 19532873728/19532873728, HPA is disabled un aizlaidu viņu pavisam pie dieviem. Šobrīd viņu pat BIOS vairs neredz. Link to comment Share on other sites More sharing options...
ImissimI Novembris 23, 2021 Share Novembris 23, 2021 Domāju ka nekas traģisks vēl nav noticis. Nestreb karstu ar šīm lietām, bišķi vairāk pagūglē un palasi. Link to comment Share on other sites More sharing options...
DJWoX Novembris 23, 2021 Share Novembris 23, 2021 Ja dati svarīgi tad nes vien datu atjaunošnas specam, man ļoti labi ir palīdzējis Tritons 29413995 20+ gadus darbojas šajā biznesā Bet lēti nebūs par šiem lielajiem diskiem. 2 Link to comment Share on other sites More sharing options...
ArnisR Novembris 23, 2021 Share Novembris 23, 2021 Ja pat BIOS neredz, bet dati vērtīgi un bez backup, tad jādod profiņiem. Tipa https://www.ontrack.com/pl-pl Diagnostika ir bezmaksas (tik sūtīšanas izmaksas). Tāmi un kādas ir izredzes izcelt datus atsūtīs. Link to comment Share on other sites More sharing options...
versatile Novembris 23, 2021 Share Novembris 23, 2021 Tritons. Link to comment Share on other sites More sharing options...
Lieta Novembris 24, 2021 Author Share Novembris 24, 2021 pirms 9 stundām , ImissimI teica: Ir arī gadījies ka kabelis gļukains. Šķiet, ka tev taisnība. Nomainot kabeli disks aizgāja. 1 2 Link to comment Share on other sites More sharing options...
ImissimI Novembris 24, 2021 Share Novembris 24, 2021 Es pa šo frumu agrāk rakājos, kad vajadzēja kādas cietā diska mistērijas risināt - https://forum.hddguru.com/ Tur var diezgan padziļinātu info izkast. Kabeļa nomaiņa arī sākotnējo problēmu atrisināja? Palaid smārta testu kaut vai -t short un iemet reportu. Link to comment Share on other sites More sharing options...
Lieta Novembris 24, 2021 Author Share Novembris 24, 2021 pirms 1 stundas , ImissimI teica: Kabeļa nomaiņa arī sākotnējo problēmu atrisināja? Iespējams, ka sākotnējo problēmu atrisināja # hdparm -N p19532873728 /dev/sda pirms 1 stundas , ImissimI teica: Palaid smārta testu kaut vai -t short un iemet reportu. $ sudo smartctl -a /dev/sda smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.11.0-40-generic] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red Device Model: WDC WD100EFAX-68LHPN0 Serial Number: JEJ5YALM LU WWN Device Id: 5 000cca 267dee302 Firmware Version: 83.H0A83 User Capacity: 10 000 831 348 736 bytes [10,0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Nov 24 16:36:11 2021 EET SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 93) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1105) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0004 129 129 054 Old_age Offline - 112 3 Spin_Up_Time 0x0007 168 168 024 Pre-fail Always - 425 (Average 360) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 33 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0 8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18 9 Power_On_Hours 0x0012 097 097 000 Old_age Always - 22328 10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 25 22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 919 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 919 194 Temperature_Celsius 0x0002 154 154 000 Old_age Always - 42 (Min/Max 22/58) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 22328 - # 2 Short offline Completed without error 00% 22321 - # 3 Short offline Completed without error 00% 22312 - # 4 Extended offline Interrupted (host reset) 90% 22310 - # 5 Short offline Completed without error 00% 22304 - # 6 Short offline Completed without error 00% 22280 - # 7 Short offline Completed without error 00% 22256 - # 8 Short offline Completed without error 00% 22232 - # 9 Short offline Completed without error 00% 22207 - #10 Extended offline Completed without error 00% 22205 - #11 Short offline Completed without error 00% 22183 - #12 Short offline Completed without error 00% 22159 - #13 Short offline Completed without error 00% 22135 - #14 Short offline Completed without error 00% 22111 - #15 Short offline Completed without error 00% 22087 - #16 Short offline Completed without error 00% 22063 - #17 Short offline Completed without error 00% 22039 - #18 Extended offline Completed without error 00% 22036 - #19 Short offline Completed without error 00% 22015 - #20 Short offline Completed without error 00% 21991 - #21 Short offline Completed without error 00% 21967 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. Link to comment Share on other sites More sharing options...
ImissimI Novembris 24, 2021 Share Novembris 24, 2021 Izskatās dzīvotājs 👍 Link to comment Share on other sites More sharing options...
uldise Novembris 24, 2021 Share Novembris 24, 2021 jautājums tikai, kurš to HPA tam diskam tur uzmeta. agrāk bija manītas plates, kur BIOS taisija mazu HPA un pirmā diska, lai būtu kur backupus likt.. bet nu te jau 1TB.. Link to comment Share on other sites More sharing options...
ImissimI Novembris 24, 2021 Share Novembris 24, 2021 Vabūt kādreiz klonēts no mazāka diska. Link to comment Share on other sites More sharing options...
Lieta Novembris 24, 2021 Author Share Novembris 24, 2021 Pirms 17 minūtēm , ImissimI teica: Vabūt kādreiz klonēts no mazāka diska. Nē. Link to comment Share on other sites More sharing options...
Jānis Kvadrāts Novembris 8, 2022 Share Novembris 8, 2022 Sveiki, Kā pareizi saucās šī pieslēgvieta, skat bildi t.i. kāds ir atslēgas vārds meklējot jaunu moduli paldies! Link to comment Share on other sites More sharing options...
superKrona Novembris 8, 2022 Share Novembris 8, 2022 (labots) m.2 rakstīts uz moduļa B+M gan nav rakstīts Labots Novembris 8, 2022 - superKrona 1 Link to comment Share on other sites More sharing options...
Jānis Kvadrāts Novembris 8, 2022 Share Novembris 8, 2022 paldies Tev, vai tas ir kaut kāds arhaisms, jo, ja meklēju ar M.2 tad atrodu ļoti maz šādu disku, vai arī tā pieslēgvieta ir tikai ar vienu "robiņu" Link to comment Share on other sites More sharing options...
superKrona Novembris 8, 2022 Share Novembris 8, 2022 (labots) ir mātes redzētas, kur tikai tādus var iespraust, un gana svaigas. Jābūt pie FORM Factoriem: Form factors 1630 Key E • 2230 Key E • 3030 Key A • 2242 Key B+M • 3042 Key A • 2260 Key M • 2280 Key B+M Te smuki Labots Novembris 8, 2022 - superKrona 2 Link to comment Share on other sites More sharing options...
ju Novembris 8, 2022 Share Novembris 8, 2022 Varb;ut veikalniekiem bija slinkums klasificēt. Iespējams, slēpjas arī zem nVME Link to comment Share on other sites More sharing options...
noname Novembris 8, 2022 Share Novembris 8, 2022 Nu principā var teikt ka M.2 disks ar sata interfeisu ir arhaisms. jo pēdējo 6-8 gadu dzelžos pārsvarā izmanto PCIe/NVMe interfeisu Link to comment Share on other sites More sharing options...
Anonīms Alkoholiķis Novembris 8, 2022 Share Novembris 8, 2022 (labots) Vel labāka lieta par m.2 ssd arhaismu, ir kad viņš sharo sata vai pcie interfeisus un jaizvelas starp m.2 ssd disku vai pci/sata devaisu. Labots Novembris 8, 2022 - Anonīms Alkoholiķis Link to comment Share on other sites More sharing options...
binary Novembris 8, 2022 Share Novembris 8, 2022 Ja atmiņa neviļ, man laptopam strādā vai nu 2.5" SATA + m.2 SATA, vai arī m.2 nVME. Kad pamēģināju m.2 nVME ar 2.5" HDD/SSD - nestrādāja. Tas tā, par arhaismiem runājot. Link to comment Share on other sites More sharing options...
