mastersblasters Ierakstīts Decembris 12, 2017 Share Ierakstīts Decembris 12, 2017 Sveiki. Tika parinstalets win7, uzmetas pec laika bluescreen, atveru dump failu. Kads varbut var palidzet. Vai tiesam chrome var but vainigs? Sads info: Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17514.amd64fre.win7sp1_rtm.101119-1850 Machine Name: Kernel base = 0xfffff800`02858000 PsLoadedModuleList = 0xfffff800`02a9de90 Debug session time: Tue Dec 12 05:35:39.883 2017 (UTC - 5:00) System Uptime: 0 days 1:05:21.678 ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 00006d8006e884e0, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000000, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff800028c0f88, address which referenced memory Debugging Details: ------------------ TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2 READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002b090e8 GetUlongFromAddress: unable to read from fffff80002b09198 00006d8006e884e0 Nonpaged pool CURRENT_IRQL: 2 FAULTING_IP: nt!MiRestoreTransitionPte+c8 fffff800`028c0f88 488b18 mov rbx,qword ptr [rax] CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT BUGCHECK_STR: 0xA PROCESS_NAME: chrome.exe TRAP_FRAME: fffff88009204730 -- (.trap 0xfffff88009204730) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=00006d8006e884e0 rbx=0000000000000000 rcx=fffff8800080001b rdx=0000098000000000 rsi=0000000000000000 rdi=0000000000000000 rip=fffff800028c0f88 rsp=fffff880092048c0 rbp=0000000000000001 r8=0000000000000001 r9=0000000000000001 r10=0000000000000002 r11=000000000000007f r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei pl nz na pe nc nt!MiRestoreTransitionPte+0xc8: fffff800`028c0f88 488b18 mov rbx,qword ptr [rax] ds:00006d80`06e884e0=???????????????? Resetting default scope LAST_CONTROL_TRANSFER: from fffff800028d7be9 to fffff800028d8640 STACK_TEXT: fffff880`092045e8 fffff800`028d7be9 : 00000000`0000000a 00006d80`06e884e0 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx fffff880`092045f0 fffff800`028d6860 : 00000000`00000000 00000000`00000000 00000000`00000000 fffffa80`017fbcb0 : nt!KiBugCheckDispatch+0x69 fffff880`09204730 fffff800`028c0f88 : fffffa80`017fbcb0 00000000`00000000 fffffa80`01839390 fffffa80`12f896f8 : nt!KiPageFault+0x260 fffff880`092048c0 fffff800`02925e69 : 00000000`00003ef8 00003ef7`00000001 fffffa80`017fbcb0 00000000`0007fa98 : nt!MiRestoreTransitionPte+0xc8 fffff880`09204950 fffff800`028e9453 : 00000000`00000002 00000000`00000002 fffff880`09204a40 fffffa80`12f896f8 : nt!MiRemoveLowestPriorityStandbyPage+0x1d5 fffff880`092049d0 fffff800`028e5bfe : 00000000`00000001 000000b9`6edff000 fffff880`09204c20 fffff680`5cb76ff8 : nt!MiResolveDemandZeroFault+0x6f3 fffff880`09204ac0 fffff800`028d676e : 00000000`00000001 000000b9`6edff000 00000000`00fbbf01 000000b9`6edfefd9 : nt!MmAccessFault+0x5de fffff880`09204c20 00000337`764c5a8d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e 00000000`002bca98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x337`764c5a8d STACK_COMMAND: kb FOLLOWUP_IP: nt!MiRestoreTransitionPte+c8 fffff800`028c0f88 488b18 mov rbx,qword ptr [rax] SYMBOL_STACK_INDEX: 3 SYMBOL_NAME: nt!MiRestoreTransitionPte+c8 FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt DEBUG_FLR_IMAGE_TIMESTAMP: 4ce7951a IMAGE_NAME: memory_corruption FAILURE_BUCKET_ID: X64_0xA_nt!MiRestoreTransitionPte+c8 BUCKET_ID: X64_0xA_nt!MiRestoreTransitionPte+c8 Followup: MachineOwner Link to comment Share on other sites More sharing options...
Firza Decembris 12, 2017 Share Decembris 12, 2017 Nē. Prastām lietojuma programmām nav tiesību izraisīt "zilos logus", un arī Chrome to nevar izdarīt. "Zilos logus" uz Windows var izraisīt divas lietas: Problēmas ar dzelžiem Problēmas ar draiveriem Draiveru problēmas attiecas arī uz virtuālo ierīču draiveriem: antivīruss, firewall, DVD emulators, u.c. Link to comment Share on other sites More sharing options...
Firza Februāris 17, 2018 Share Februāris 17, 2018 (labots) Ja FireFox eksperimentālas funkcijas var izraisīt "zilos logus", tad tā nav FireFox vaina - tā ir Windows problēma. OS uzdevums ir menedžēt atmiņu, pieejas tiesības tā lai parasta lietojuma programma, sliktākajā gadijumā nograutu tikai pati sevi, nevis visu sistēmu kopumā. Labots Februāris 17, 2018 - Firza Link to comment Share on other sites More sharing options...
raiviic Februāris 17, 2018 Share Februāris 17, 2018 pirms 9 stundām , Developer teica: kā esiet uzmanīgi uz Windows 7 ar FireFox versijām, kas vecākas par 42! Nu nez. Lietoju FF uz W7 kopš neatminamiem laikiem, praktiski visas versijas kopš pirmsākumiem, bet nekādu zilo logu nav bijis. Bremze reizēm jā - tas ir novērots. Drīzāk problēma ir konkrētas kastes dzelžos vai lietotāja roku leņķī. Link to comment Share on other sites More sharing options...
Tuubijs Februāris 17, 2018 Share Februāris 17, 2018 tak neņemiet to muļķi pa pilnu, jams vakar tak pacēla vairākus 2 vai vairāk mēnešus vecus topikus, ierakstija savu kaku un atkal pazuda. šito pat varētu banot uz laiku, bet nav jēga, jo tagad viņš te nerādīsies mēnesi/divus, bet jams pat banu nejutīs. Link to comment Share on other sites More sharing options...
