PlayStream.bundle - Plex plugins (channel) replay.lsm.lv, skaties.lv, lattelecom.tv u.c. satura skatīšanai
ivars777
Plex versija Kodi Enigma2 pluginam (skat. attiecīgo tēmu)
PlayStream
Plex plugin to to play various online streams (mostly Latvian). Stream sources are in subfolder "Libraries/Shared/content/sources" and can be added/customized.
Currently implemented:
  • Main menu and manual stream definition in sources/streams.cfg file
  • replay.lsm.lv - Latvian TV live streams and archive (Latvian)
  • skaties.lv - skaties.lv streams (Latvian LNT, TV3, TV3+, TV6, TV2)
  • lattelecom.tv(shortcut.lv) - live, archive and video (Latvian, English, Russian), account required
  • play24.lv - RigaTV24 live and archive (Latvian)
  • viaplay.lv - video streams (partly working, only non-DRM - Latvian, Russian)
  • LMT straume - LMT video streams (Latvian)
  • cinemalive.tv - movies and series in Latvian (partly working)
  • dom.tv - live and archive of Latvian and Russion TV channels, registration required
  • BBC iPlayer - BBC live and archive, UK IP address (VPN) required
  • Euronews - Euronews live and archive
  • filmon.tv - media portal content
  • ustvnow.tv - USA live TV (only SD), registration required
  • filmix.net - movies and series in Russian
Copyright (c) 2016 ivars777 (ivars777@gmail.com) Distributed under the GNU GPL v3. For full terms see http://www.gnu.org/licenses/gpl-3.0.en.html Used fragments of code from
Instalēšana:
  1. Lejupielādējam aktuālo plugina versiju no šejienes http://files.blue.lv/PlayStream.bundle/
  2. Atarhivējam folderi PlayStream.bundle Plex servera plugin folderī (iekš Windows - %LOCALAPPDATA%\Plex Media Server\Plug-ins\)
  3. Pārstartējam Plex serveri
  4. Plex klientā palaižam kanālu PlayStream un sakonfigurējam paroles avotiem, kuriem tas nepieciešams (lattelecom.tv, tvdom, iplayer u.c.)
  5. Failā %LOCALAPPDATA%\Plex Media Server\Plug-ins\PlayStream.bundle\Contents\Libraries\Shared\content\sources\streams.cfg var sakonfigurēt menu/favorītus
  6. Jaunas versijas atjaunināšana notiek vienkārši uzkopējot folderī jauno versiju (streams.cfg tiek pārrakstīts, tāpēc izmaiņas tajā manuāli jāiekopē pēc atjaunināšas)
Problēmas/ierobežojumi:
  1. Nestrādā subtitri (diemžēl Plex pluginos pagaidām subtitri netiek atbalstīti, varbūt nākotnē)
  2. Pagaidām nav video lejupielādes, saglabāšana favorītos u.c., jo Plex pluginiem nav custom menu iespējas (vēl jāpapēta, kā šo apiet)
  3. Back no menu var nenostrādāt (tur kaut kādi haotiski izskaukumi pa vidu notiekās, tāpēc var sajukt), Home\Back poga strādā.
  4. Nav īsti skaidrs, kā izvēlēties no vairākiem strīmiem (dažādas kvalitātes/valodas) vajadzīgo. Visus strīmus rāda ar getInfo, bet nav pogas kā izvēlēties  (vismaz Web klientam neredzēju)
  5. Windows u.c. klientos ir tizla Search ievade, jo šajos klientos nav normālas teksta ievades
  6. Ir kaut kādas nesaprotamas kļūdas dažos menu (kaut kas nelabi ar tekstiem).
  • 4 weeks later...
VebKamera
Mani komplimenti - ļoti labs plagins uz Plekša. Ja nu kāds uz reiz nevar palaist - uz Linukša man tomēr nācās restartēt visu serveri, vienkāršs Plex procesa restarts nenostrādāja.
Pārstartējot serveri viss ielādējās normāli.
  • 1 month later...
Updeitota versija atbilstoši enigma 0.7o versijai.
Man jautājums publikai - vai  un cik lietotāji ir Plex versijai? Vai ir vērts to turēt aktuālu?
  • 2 months later...
uldii12345
(labots)
Diemžēl uz Samsung un LG smartiem nedarbojās, uz windows PC, android tv darbojas. Ir kādam izdevies palaist uz smart tv?
Labots - uldii12345
ivars777
Par Plexi. Biju ievērojis to problēmu, ka spēlē video tikai bakstot uz pašu bildi, bet nezinu kas par iemeslu(izskatās, ka tas kaut kāds plekša gļuks, jo nevajadzētu būt starpībai, kā piestartē pleijeri).
Vispār runākot par Plex pluginu frameworku/API tas it kā ir jēdzīgs no arhitektūras viedokļa (nodalīts klients un serveris), taču  salīdzinot ar Kodi/enigma ir ļoti nabadzīgs un slikti dokumentēts (piemēram, nav iespējas pluginos pielikt subtitrus, nav jēdzīga UI datu ievadei/dialogiem u.c.).
Tāpēc no funkcionlitātes viedokļa ar Pleksi ir/būs problēmas.
Bet toties uz Plex ir vien killer fīča. Ar Plex klientu var skatīties visus strīmus da jebkurā vietā (arī ārzemēs) bez geo/ip ierobežojumiem  (serveris faktiski transkodē strimus un tādēji faktiski strīma avotam konektējas serveris nevis klients).
uldii12345
Uz samsung, LG joprojām neiet. Uz samsung vai LG var tikt līdz skatīšanās izvēlnei, piemēram, shorcutā uzspiest uz kanāla. Uzspiežot uz kanāla izlec logs - There was a problem playing this item.
Uz androida izdarot to izlec izvēlne, kur jāuzspiež play, lai skatītos. Sanāk, ka LG un samsung plex klients to nesaprot
ivars777
Jāskatās, kas logos. Varbūt kādas python bibliotēkas trūkst vai kaut kas tāds.
Jautājums par shortcut videonomu? vai pareizi saprotu, ka izvēloties filmu,tā tiek automātiski abonēta/nomāta un sākta atskaņošana?
uldii12345
2018.03.16. , 17:49, ivars777 teica:
Logus lejupielādēju, tur daudz failu, kurā skatīties?
uldii12345
Ieliku citus kanālus, piemēram HD serials, ar tiem viss ok un uz LG un samsung darbojas.
Būtu baigi forši palaist tavu pluginu uz LG, tad nevajadzētu papildus kastes, lai uz tā paretam palaistu shortcutu
  • 3 weeks later...
VebKamera
Klau, a kā Plex pluginam var versiju apskatīties? Interfeisā es tādu iespēju neredzu.
  • 1 month later...
ivars777
Vēl nav uztaisīta. Kaut kad vajadzēs uztaisīt gan versijas info, gan updeitu čekošanu, gan arī citas lietas, kas ir enigma2 un kodi
  • 1 month later...
ivars777
Jauna versija. Salabots replay u.c. atbilstoši Kodi/Enigma2 statusam.
Pielikta klāt iespēja no menu updeitot versiju (var arī redzēt tekošo)
  • 2 weeks later...
Laiskais007
2018.06.26. , 16:13, VebKamera teica:
Super, megapaldies!
Pievienojos! Tiešām labs darbs! ;)
Kristīne Mīļā
Sveiki! šodien izmocījām(pēc instrukcijas) ,neparādās...Bezmaksas konts...
uldii12345
2018.03.25. , 05:32, ivars777 teica:
Logs/PMS Plugin Log/com.plexapp.plugins.playstream.log
Kā LOG pareizi skatīties, es spiežu uz help un tur var lejupielādēt log failus, tajos nekā saistīta ar PMS plugin nav?
pirms 15 stundām , Kristīne Mīļā teica:
Kur bezmaksas konts? Ja plex, tam nav nekādas nozīmes.
ivars777
Logs jāmeklē Plex servera attiecīgajā folderī
Kas neparādās, plugins? Ja viss sakopēts kā vajag, tad vajag skatīties playstream logu, lai saprastu, kas neiet.
uldii12345
No playstream loga:
CRITICAL (core:574) - Exception setting attribute 'title2' of object <Framework.modelling.objects.MediaContainer object at 0x075E3490> to TV tiešraides (type: <type 'str'>) (most recent call last):
  File "C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-fd05be322\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\modelling\objects.py", line 71, in _set_attribute
    el.set(convert_name(name), value)
  File "lxml.etree.pyx", line 699, in lxml.etree._Element.set (..\src\lxml\lxml.etree.c:34531)
  File "apihelpers.pxi", line 563, in lxml.etree._setAttributeValue (..\src\lxml\lxml.etree.c:15781)
  File "apihelpers.pxi", line 1366, in lxml.etree._utf8 (..\src\lxml\lxml.etree.c:22211)
ValueError: All strings must be XML compatible: Unicode or ASCII, no NULL bytes or control characters
Ja nepieciešams, varu visu logu nosūtīt
uldii12345
Plugins sakopēts pareizi, uz android kastēm viss rullē. Neiet uz samsung un lg smart tv. Varu tikt līdz, piemēram, shourtcut kanāla izvēlei, bet uzspiežot uz kanālu izlec error. (Uz android ,uzspiežot uz kanālu, parādās izvēlne, uz kuras nospiežōt play sāk rādīties attiecīgais kanāls
ivars777
Izskatās, ka uz tv ir kāda vecāka plex versija. Laikam vajag vairāk loga, lai ko saprastu
Updeitoda versija, play24 salabots
uldii12345
Starp citu uz lg smart ar web os 3 arī viss darbojas.  Būtu labi, ja settingos varētu pielikt arī filmix kontu
  • 1 month later...
  • 2 weeks later...
Jauna versija. Pievienota iespēja skatīties Enigma2 kastes strīmus.
Tā rezultātā var attāli skatīties mājas satTV strīmus.
  • 2 weeks later...
Sveiki - Mīļš paldies par lielo darbu ražojot šo foršo uzņēmumu!  Tik labi vēl nepārzinu Plex un gribētu palūgt palīdzību lai varētu uztvērt Latvijas televīzijas stacija no Amerikas.
Man ir Plex uzlādēts uz Ubuntu 18.04. Esmu sekojis instrukcijām un atarhivējis un ievietojis PlayStream.bundle Plex servera plugin folderī. Pārstartēju Plex Serveri. Bet ka atsāku Plex klientu, nevaru atrast PlayStream kanālu.  Ko es esmu izdarījis nepareizi un kā varu tikt pie PlayStream kanāļa un galvenais Latvijas stacijām?  Redzu ka streams.cfg ir zem Libraries/shared.content/sources zem PlayStream.bundle foldera.  Sirsnīgs paldies par jūsu palīdzību!
Labots - ERoze
Kļūdu labotājs automātiski bija ierakstijis muļķības - bija jāizlabo!
  • 2 weeks later...
uldii12345
Jaunajā plex versijā neatrod playstream pluginu, kaut gan viss ir iekopēts pluginu folderī vairākas reizes, restartēts utt.
uldii12345
Es izdarīju tā, uzinstalēju, piemēram history chanell pluginu, pēc tam history chanell vietā plugin folderī, history chanell mapē iekopēju playstream saturu un tagad plex serveris redz playstream pluginu
Labots - uldii12345
Varbūt kādas problēmas ar pieejas tiesībām attiecīgajam folderim. Vajag chown + chmod uzlikt attiecīgam lietotājam zem kura Plex serveris strādā
Daudzi Latvijas strīmi var nestrādāt deļ ģeo ierobežojumiem. Vajadzēs Latvijas VPNU lai skatītoes
Lūgums kļūdas pieteikt http://git.blue.lv/. (lielāka varbūtība, ka tiks novērstas).
Pirms tam nepieciešams ielogoties ar Google vai Github kontu (kaut kad uztaisīšu arī Facebook, Twitter u.c.)
Ja, kas tur klonējami arī attiecīgie projekti (ja nu kādam gribas kaut ko pašam sadarīt).
Labots - ivars777
  • 1 month later...
2018.11.4. , 21:00, ivars777 teica:
Sliktas ziņas. Plex plānot piebeigt pluginus nānotnē.
https://www.plex.tv/blog/subtitles-and-sunsets-big-improvements-little-housekeeping/
Žēl, jo no arhitektūras/potenciālo iespēju viedokļa Plex noteikti ir labāks par Kodi u.c.
Saimniekiem diemžēl izskatās ir citas intereses...
"But don’t panic—while the Plugin Directory will soon be gone, you can still manually install plugins for the foreseeable future."
Pa lielam jau pilnība neiznīcinas, nebūs vairs lamerfrendly viņus lietot, beidzot bus jakustina smadzene, lai piedabūtu darboties nevis vienkarši plug&play
  • 1 month later...
Laiskais007
.... Šodien nedarbojas Plugins....
Projekts beidzies?
Labots - Laiskais007
