plugin.video.playstream - Kodi adons replay.lsm.lv, skaties.lv, lattelecom.tv u.c. satura skatīšanai
ivars777
(labots)
pielikuma iestatījumi - shortcut.lv un norādīti logina datus
Labots - CAP
maigais
‎04‎.‎03‎.‎2019 , 17:46, Arturs371 teica:
Tikko tikai uzzināju par šo kodi spraudni. Ieinstalēju, bet nevaru saprast kā es varu ielogoties savā shortcut kontā.
  • 2 weeks later...
maigais
vai nu ir salabots , be man stradā..
Labots - maigais
  • 2 months later...
  • 3 months later...
LMT straume neiet - satura nosaukumus rāda, bet nepalaižas raidījumi.
Kaut kā shortcut vairs negrib rādīt:
Citēt
2019-10-05 21:12:34.273 T:140189495977728 WARNING: [kodiswift] No converter provided, unicode should be used, but returning str value
2019-10-05 21:12:34.276 T:140189495977728 WARNING: Previous line repeats 15 times.
2019-10-05 21:12:34.276 T:140189495977728  NOTICE: [kodiswift] Request for "/ltc::tiesraide" matches rule for function "main"
2019-10-05 21:12:34.587 T:140189495977728   ERROR: Traceback (most recent call last):
2019-10-05 21:12:34.587 T:140189495977728   ERROR:   File "/home/lieta/.kodi/addons/plugin.video.playstream/addon.py", line 134, in main
2019-10-05 21:12:34.587 T:140189495977728   ERROR:     items = get_list(data)
2019-10-05 21:12:34.587 T:140189495977728   ERROR:   File "/home/lieta/.kodi/addons/plugin.video.playstream/addon.py", line 148, in get_list
2019-10-05 21:12:34.587 T:140189495977728   ERROR:     content = sources.get_content(data)
2019-10-05 21:12:34.587 T:140189495977728   ERROR:   File "/home/lieta/.kodi/addons/plugin.video.playstream/resources/lib/content/ContentSources.py", line 70, in get_content
2019-10-05 21:12:34.587 T:140189495977728   ERROR:     content0 = self.plugins[source].get_content(data)
2019-10-05 21:12:34.587 T:140189495977728   ERROR:   File "/home/lieta/.kodi/addons/plugin.video.playstream/resources/lib/content/sources/ltc.py", line 145, in get_content
2019-10-05 21:12:34.588 T:140189495977728   ERROR:     for item in self.get_channels():
2019-10-05 21:12:34.588 T:140189495977728   ERROR:   File "/home/lieta/.kodi/addons/plugin.video.playstream/resources/lib/content/sources/ltc.py", line 685, in get_channels
2019-10-05 21:12:34.588 T:140189495977728   ERROR:     for i,item in enumerate(r["items"]):
2019-10-05 21:12:34.588 T:140189495977728   ERROR: TypeError: 'NoneType' object has no attribute '__getitem__'
ivars777
(labots)
Jauna versija:
**0.2.15** (06.10.2019):
- [fix] salabots lmt.lv (Facebook video)
- [fix] content autonomā git projektā
Shortcutam jāiet (vismaz man iet). Varbūt vajag updeitot plugina versiju. Varbūt vajag atslēgt statusa saglabāšnu starp izsaukumiem (dažkārt kaut kas nenostrādā).
Vispār šī šortkata versija ir  uz veciem API un pamazām norakstāma. Kaut kad būs jaunākā ar Android TV API (kas attiecīgi strādās arī ne no ltc tīkla).
Enigmai, nav laika taisīt ipk failu (nomigrēju datoru un nav sainstalēti ipk būvēšanas tūļi). Kam vajag, var iekopēt jauno content saturu manuāli.
Labots - ivars777
Šobrīd ir versija 0.2.14, jaunāku neatrod. Statusa saglabāšana starp izsaukumiem atslēgta.
ivars777
Izskatās, ka kaut kādu iemeslu dēļ nenostrādā izsaukums
https://manstv.lattelecom.tv/api/v1.4/get/tv/channels
Vajag pamēģināt no browsera. LTC tīkls?
No browsera strādā:
Citēt
status    "ok"
items
0
id    "101"
lang    "lv-LV"
state    "1"
ordering    "1"
name    "LTV1"
LTC tīkls.
Labots - Lieta
ivars777
Tur ir tā pati problēma, kas ar ltcproxy. Visdrīzāk SSL nestrādā un urllib2 defaultā lido ārā.
Vai nu jāsalabo CA sertifikāti vai arī jālabo python sourcēs visi urllib2 izsaukumi pēc parauga.
import urllib2, ssl
request = urllib2.Request('https://somedomain.co/')
response = urllib2.urlopen(request, context=ssl._create_unverified_context())
Anyway izskatās, ka tā ir konkrētās mašīmas problēma
Strādā. Fix bija šāds:
Citēt
The remote site in the example uses a small DH key [0]. If you can't get owner to upgrade the site and want still to access the site I suggest to remove
CipherString = DEFAULT@SECLEVEL=2
from /etc/ssl/openssl.cnf.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=907788
manstv.lattelecom.tv izmanto vāju (1024 bitu) DH atslēgu. https://weakdh.org
Labots - Lieta
  • 2 weeks later...
2019.10.8. , 09:00, Lieta teica:
Man šo issue neizdevās salabot - android root browseris neatrada tādu failu. Ir plānots šo salabot nākamajā relīzē? Šobrīd workaround man ir downgrade uz 0.2.12 versiju.
Sveiki. Jau 1,5 gadus lietoju playstream android tvbox un stacionārajā datorā, viss ir forši.
Bet windows planšetē ASUS t100 ta win10 saskāros ar erroru: "ascii" codec can't decode byte 0xc4 in position kodi position 10: ordinal not in range(128). Googlē atradu rakstus par citām position. Diemžēl par  šo manas zināšanas ir skopas un netieku galā.
P.S Arī Helio jaunā windows lietotne nestrādā, jo nepiekļūst vajadzīgajam portam. Pagaidām arī no viņiem neesmu saņēmis palīdzību.
Iespējams, ka šīs divas lietas ir saistītas.
Ļoti ceru, ka kādam būs idejas, kā tikt ar to galā.
vai tad tas kas jauns? :D
tas nav tas pats, kas principā jau tagad ir.. helio klientiem ir helio app.. shortcut savs ceļš.. kā no vēstules teksta noprotams, ka individuālam abonentam tas vairs nebūs pieejams, ne visiem.
Labots - CAP
Es to Shortcut lietotni izmantoju uz savas sat kastes caur Playstream pluginu.
Tagad nāksies vilkties uz otru istabu, lai caur Tet dekoderi tieši 25.datumā iekš 360tv noskatītos trešo Šausmenītes filmu. Nu nav kaifa skatīties filmas uz 5 collu telefona ekrāna.
Izņēmums būtu tad, ja sēdētu korķī uz Brīvības ielas ?
IMO tā ziņa domāta tiem TET Helio ITV abonentiem, kuriem Šortkats bija vēl joprojām bez maksas esošā pieslēguma ietvaros . bija tādi, kuri šortkatu pārsvarā lietoja datorā un tiem tad tas bezmaksas periods tika pagarināts, līdz būs gatava Helio TV datora versija.
Kaut kā neticas,  ka 25-jā visās šortkata aplikācijās (parastajā un for Android TV) visiem lietotājiem pazudīs "TV" sadaļa...
Tieši tā.. Tas viss saistīts ar jau vasarā atdalīt noņemto bonusa pakalpojumu itv lietotājiem.
  • 3 weeks later...
Kā lai ar Playstream pluginu {raspberijā} var skatīties BEZMAKSAS Lv-kanālus?   Man prasa autorizāciju un neiet nekas no Lv. :[
  • 2 weeks later...
Palīdziet cirvim (man) - ir LTC nets un Helio TV. Gribēju pārslēgties uz to jauno Shortcut, lai bez tās debīlās kastes var skatīties, bet līgumsods attur :)
Cik sapratu no LTC - es bez maksas varu skatīties Helio planšetē/telefonā/datorā, tik problēma, ka datorā ir Linux, bet apps esot tikai Win.
Caur Kodi es to mēslu varu "piekurbulēt" ?
helio? nē..
līgumsods mainot no helio tv uz shortcut? hmm..ltc pašiem esi rakstījis un prasījis?
Labots - CAP
Par līgumsodiem matemātika vienkārša - zvans Tet:"Vai nu dodiet man pakalpojumu bez līgumsaistībām, jo maybe man tas nepatiks/nederēs..vai arī ejiet ellē.."
@CAP - es pats to neizdomāju, to man LTC paši man to klārēja zvana laikā.
Man ir divu gadu līgums ar tjipa "super cenu" - pats to esmu izvēlējies :)
Iemainīt Helio pret Shortcut nekādi viņi negrib. Kārtējais stāsts, ka man nets + TV šobrīd ir lētāks nekā viņi vispār netu piedāvājot, u.t.t. Es pats negribēju ieslīgt diskusijā ar LTC, jo reāli p*s to televīziju, es to skatos 2x gadā.
Ja ar Kodi nevar šo palaist, tad tās pāris reizes, kad būs vajadzība, izlīdzēšos ar trubu un screencast :)
Pirms 2 minūtēm , martinno teica:
ja palasās to viņu līgumu, tad ļoti interesanti paliek. divu gadu līgums nozīmē "atlaidi no standartcenas" uz šo laiku. un līgumsods par pirmstermiņa izbeigšanu var būt un var nebūt.
bet protams, pof.
tagad parasti ir daudz no kā izvēlēties, tajā skaitā mazāk ambiciozi pakalpojuma sniedzēji.
pirms 2 stundām , ervie teica:
Man arī tā likās (jo iepriekšējais bija tāds - bez termiņa un sankcijām, bet cena spēkā divus gadus) un to pārjautāju LTC darbonim. Šis ir savādāks un es esmu parakstījis tādu. Nu i p*s :)
Līgumos ar līgumsodu tā arī ir ierakstīts un norādīta līgumsoda summa.
Nu neko.. vai nu atsakies un maksā, vai vk maksā, vai lieto as is.. tāpēc es vk pieslēdzu netu, bez kādām tv un brīvi varu izvēlēties pieslēgt, atslēgt shortcut :D
Labots - CAP
Pirms 43 minūtēm , CAP teica:
Tu domā, ka es to līgumu lasīju? :)
Lietošu kāds ir - tāpat šobrīd par netu+TV maksāju mazāk, nekā par pliku netu.
Tā TV iegriba tāds mirkļa vājums un tāpat ikdienā netiks izmantota.
  • 2 weeks later...
Juris Krēgers
Nupat līdz aprīļa beigām, shortcut + filmas = 4.99 teica, ka beztermiņa- paņēmu palietot.
Sent from my POT-LX1 using Tapatalk
pirms 3 stundām , martinno teica:
beztermiņa
nav runa par cenu, ir runa par līguma termiņu.. tobiš martā vari atcelt, lai ar aprīli, kad stātos spēkā jau jaunā summa vsjo.. :D
Tur tak rakstīts viss.
Labots - CAP
tēma tak ir plugin.video.playstream,  nesaprotu ko var spriest par abonēšanu , jo adons tapat nešeptēs,
vai abonē vai nē ..
cik noprotu api ir izmainijies, nav kas izlabo :shout:
atradu vienu kodi strādājošu variantu
nupat pārbaudīju
iet, tikai, sasodīti visu uz HD met..
neesmu iemācījies vēl savaldīt.. :)
principā - liekas ka var gan x86 libre, gan coreelec amlogic, gan arm ...
bik gan jāpielasa pluginu kombinācijas ..
nu, ar officiālo ticketu, tas gan..
būtībā, pat divi varianti ... :)
ja man, nesauksim kas, nesados pa ausīm :)
Labots - runcs
nu, es viņu pamēģināju
iet
gan ar pvr.iptv
sakārojās saskrūvēt viņu ar pvr.puzzle.tv- tikai man arm laikam pie rokas nav.. ja nu vienīgi.. hmm 1rasps..  gribas paskatīties, vai iekožas arhīvos arī..
kāds te vod listes solīja :))
Labots - runcs
