Populārs ieraksts ivars777 Ierakstīts Marts 24, 2017 Populārs ieraksts Share Ierakstīts Marts 24, 2017 Kodi versija Enigma2 pluginam (skat. attiecīgo tēmu) PlayStream Kodi plugin to to play various online streams (mostly Latvian). Stream sources are in subfolder "resources/lib/sources" and can be added/customized, Currently implemented: Main menu and manual stream definition in sources/streams.cfg file replay.lsm.lv - Latvian TV live streams and archive (Latvian) skaties.lv - skaties.lv streams (Latvian LNT, TV3, TV3+, TV6, TV2) lattelecom.tv(shortcut.lv) - live, archive and video (Latvian, English, Russian), account required! play24.lv - RigaTV24 live and archive (Latvian) viaplay.lv - video streams (partly working, only non-DRM - Latvian, Russian), account required! cinemalive.tv - movies and series in Latvian (partly working) movieplace.lv - movies and series in Latvian (partly working) dom.tv - live and archive of Latvian and Russion TV channels, registration required! BBC iPlayer - BBC live and archive, UK IP address (VPN) required! Euronews - Euronews live and archive filmon.tv - media portal content ustvnow.tv - USA live TV (only SD), registration required, registration required! filmix.net - movies and series in Russian serialguru.ru - movies and series in Russian (partly working) additional sources in future Copyright (c) 2016 ivars777 (ivars777@gmail.com) Distributed under the GNU GPL v3. For full terms see http://www.gnu.org/licenses/gpl-3.0.en.html Used fragments of code from enigma2-plugin-tv3play by Taapat (https://github.com/Taapat/enigma2-plugin-tv3play) Kodi plugin script.module.stream.resolver (https://github.com/kodi-czsk/script.module.stream.resolver) enigma2-plugin-youtube by Taapat (https://github.com/Taapat/enigma2-plugin-youtube), originally from https://github.com/rg3/youtube-dl/blob/master/youtube_dl Instalēšana: File Manager -> Add source, ievadām http://repo.blue.lv un sources vārdu (piemēram, ivars777 repo) Add-ons -> Add-on browser (kastīte) -> Install from zip file, norādam ivars777 repo, izvēlamies repository.ivars777.zip Add-ons -> Add-on browser (kastīte) -> Install from repository, Video add-ons, izvēlamies PlayStream Palaižam PlayStream addonu, Add-on settings, ievadām lietotājvārdus/paroles servisiem Lietošana: Viss ir +/- acīmredzams. Galvenais menu un favorīti ir iekš add-on foldera/resources/lib/sources/streams.cfg. Var ar roku pielabot kā gribas. Var izmantot/sasinhronizēt ar Enigma2 cfg failu Strādā linku pievienošana PlayStream favorītiem Subtitri strādā lattelecom.tv, BBC iplayer Downloads pagaidām nestrādā Vairāki avoti arī pagaidām nestrādā vai slikti strādā (viaplay, movieplace, cinemalive) 8 1 Link to comment Share on other sites More sharing options...
roko Marts 28, 2017 Share Marts 28, 2017 Kādam viaplay iet? Man visulaiku prasa pārbaudīt loginu un paroli. Link to comment Share on other sites More sharing options...
MasteR's Marts 28, 2017 Share Marts 28, 2017 Pašlaik neiet, plugins taču vēl zaļš, ar laiku strādās. 1 Link to comment Share on other sites More sharing options...
ivars777 Marts 28, 2017 Author Share Marts 28, 2017 Vajag upgreidoties uz 0.1.31 versiju, kur Viaplay strādā Vienīgi saistībā ar viaplay jāņem vērā, ka 1) strādā tikai krievu/lokālais kontekts (viss arzemju kontents ir ar videwine DRMu, kuru nevar īsti apiet) 2) Jāseko līdzi viasat profilā vai nav par daudz iekārtu (atļutas piecas). Nevajadzīgās jādzēš 3) Šobrīd pēc pārinstalēšanas tiek nodzēsts cfg gails ar saglabāto iekārtas id, tāpēc katra pārinstalēšana papildina iekārtu skaitu Link to comment Share on other sites More sharing options...
roko Marts 28, 2017 Share Marts 28, 2017 Paldies pēc update aizgāja Link to comment Share on other sites More sharing options...
ivars777 Marts 28, 2017 Author Share Marts 28, 2017 (labots) Jauna versija. Config faili tiek tagad saglabāti user_data folderī, tāpēc pēc updeita netiek izdzēsti. **0.1.32** (28.03.2016): - [feature] sources config files stored in user_data area (remains after update) - [feature] option to use persistent storage to store sources objects (including login status) between calls (experimental, not very useful currently) - [feature] proxy server to play encoded hls streams as well as hqq and some other resolved streams (experimental, not working correctly) - [bugfix] viaplay login Labots Marts 28, 2017 - ivars777 Link to comment Share on other sites More sharing options...
MasteR's Marts 29, 2017 Share Marts 29, 2017 (labots) Ir iespēja uzlikt, lai Lattelecom filmas neaprautos pēc 6min? Sanāk skatīties pa 6 min gabaliem. Vismaz lai automātiski sāk no vietas kur apstājas? Labots Marts 29, 2017 - MasteR's Link to comment Share on other sites More sharing options...
ivars777 Marts 29, 2017 Author Share Marts 29, 2017 Visām filmām un tieši 6 min vai kā? Link to comment Share on other sites More sharing options...
MasteR's Marts 29, 2017 Share Marts 29, 2017 Izskatās, ka filmām kuras ir jāpērk atsevišķi, bet dīvaini, ka "demonstrācija 5 minūtes" strādā neierobežotu reižu skaitu. Pa fragmentiem visu filmu var noskatīties bez maksas. Link to comment Share on other sites More sharing options...
markanato Marts 30, 2017 Share Marts 30, 2017 Labais! Respect addona autoram! Ja veel vareetu straume lmt pievienot, tad vispaar buutu... Link to comment Share on other sites More sharing options...
ivars777 Marts 31, 2017 Author Share Marts 31, 2017 Var to LMT straumi kaut kad pielikt (vismaz to daļu, kas strādā ne LMT tīklā) Link to comment Share on other sites More sharing options...
ivars777 Aprīlis 1, 2017 Author Share Aprīlis 1, 2017 Tiešām Kodi uz lattelekom maksas filmām pēc 6 minūtēm iestājas 403 kods. Tā ir kaut kāda Kodi pleiera īpatnība, jo uz enigma2 u.c. pleieriem viss strādā bez ierobežojumiem. Visdrīzāk kodi pleieris kaut ko lieku/ne to sūta uz serveri, kā rezultātā serveris acīmredzot noreseto sesijas tokenu Jāpēta dziļāk, ko tas kodi pleiereris ne tā dara, varbūt ko var labot. Ļaunākajā gadījumā jātaisa proxy Downloadam arī būtu jāstrādā (šobrīd izstrādē, kaut kad būs) Link to comment Share on other sites More sharing options...
CAP Aprīlis 2, 2017 Share Aprīlis 2, 2017 vairāk nestrādā kā strādā, bet nu tas jau bija gaidāms Link to comment Share on other sites More sharing options...
Lieta Aprīlis 4, 2017 Share Aprīlis 4, 2017 (labots) Palaižot izmet kļūdu Error: Script failed Kodi log fails: kodi.log Kodi versija 14.2. Labots Aprīlis 4, 2017 - Lieta Link to comment Share on other sites More sharing options...
ivars777 Aprīlis 4, 2017 Author Share Aprīlis 4, 2017 Stipri veca kodi versija, kā rezultātā lido ārā uz API importiem. Var protams mēģināt tās kļūdas pārtvert (kādā nakamajā versijā), bet garantijas ka strādās nav, tāpēc ieteiktu upeitoties uz aktuālāku kodi versiju. Link to comment Share on other sites More sharing options...
ivars777 Aprīlis 9, 2017 Author Share Aprīlis 9, 2017 Labota versija 1.34 **0.1.34** (09.04.2016): - [feature] proxy hack to play full lattelecom.tv videos (more than 5-6 minutes), turn on proxy in settings and restart kodi **0.1.33** (01.04.2016): - [feature] LMT straume (without TV streams) Pielikta LMT straume (bez TV, jo šie strīmi strādā tikai LMT tīklā). Plus it kā uztaisīts, ka lattelecom.tv video strādā ilgāk par 5 min. Lai varētu skatīties maksas filmas ilgāk par 5 min, jālieto proxy (plugina settingos jāieslēdz, pēc tam jāpārstartē Kodi). Problēmas būtība ir tāda, ka maksas strīmiem konkrētais fragmentu saraksts (chunklist) dzīvo tikai tikai 5-6 min. Tas nozīmē, ka pēc šī laika jāpārlādē playlist.m3u8 un jāiegūst jauns chunklist. Enigma2/gstreamer izrādās to dara pats, Kodi u.c. pleieri nē, tāpēc vienīgais risinājums ir proxy (var mēģināt kādu labojumu Kodi pleierim izveidot, bet tas nebūs ātri). Diemžēl proxy dēļ kādos brīžos var ķerties pleibeks (īpaši brīžos kad pārlādē chunklistu) + seek var būt ar pauzēm, bet kopumā izskatās, ka strādā (kamēr lattelecom neizdomās ko piegriezt). Lattlecom.tv arhīvs Kodi īsti labi nestrādā, jo Kodi nesaglabā statusu starp izsaukumiem (kaut kad mēģināšu sataisīt) Link to comment Share on other sites More sharing options...
ivars777 Aprīlis 11, 2017 Author Share Aprīlis 11, 2017 Palabota versija 1.38 **0.1.38** (11.04.2016): - [feature] options to set local proxy port (by default 8880), proxy url in order to use remote proxy **0.1.35** (10.04.2016): - [feature] option to save plugin status state between calls (necessary for lattelecom.tv archive) Izrādās uz androida normāli strādā porti>1024 tāpēc nācās nomainīt defaulto proxy portu + pielikti papildus konfigurācijas parametri. Principā ir iespēja proxy laist uz arī uz cita datora (kaut vai enigma2). It kā sataisīta statusa saglabāšana starp izsaukumiem, taču lattecom.tv arhīvs vienalga mēdz šķībi strādāt (kaut kas jādomā ar jēdzīgu epg dabūšanu/saglabāšanu) Link to comment Share on other sites More sharing options...
MasteR's Jūnijs 25, 2017 Share Jūnijs 25, 2017 Kā sokas ar plugina attīstīšanu? Pēdējais apdeits aprīlī. Link to comment Share on other sites More sharing options...
CAP Jūnijs 25, 2017 Share Jūnijs 25, 2017 cik esmu novērojis attīstās paralēli otrajā tēmā norādītajam pluginam.. bet nu trūkumu daudz.. ļoti daudz kas arī īsti nestrādā.. daudz kur metas ārā.. no stream found.. Link to comment Share on other sites More sharing options...
ivo Augusts 2, 2017 Share Augusts 2, 2017 (labots) 2017.03.24. , 17:32, ivars777 teica: Add-ons -> Add-on browser (kastīte) -> Install from zip file, Mēģinu apgūt to kodi. Man nekur nav opcijas install from zip flle - kur var atrast? Vēl gribu uzlikt torent TV, bet tas plugins arī nav ielādējamo pluginu sarakstā Kodi versija pēdējā no play veikala, dzelzis Xiaomi Mi Box. Palīdziet lūdzu! Uzliku LV kontentu, bet jautājums par torent TV joprojām aktuāls. Labots Augusts 2, 2017 - ivo Link to comment Share on other sites More sharing options...
CAP Augusts 2, 2017 Share Augusts 2, 2017 tas install from zip mazliet paslēpies vecākās versijās bija redzamāks. par to TV.. nu tur jau jāsameklē kāda IPTV liste un aidā.. Link to comment Share on other sites More sharing options...
ivo Augusts 2, 2017 Share Augusts 2, 2017 (labots) To es atradu, bet lai uzliktu Torent TV addon man laikam tur no sākums kaut kāds leprozorijs jāuzinstalē un tas man kaut kā nesanāk. Sanāca tikai kodi uzkārt Tā, status update - leprozoriju dabūju, bet nerāda vienalga, lamājas par kaut kādu Noxbit, kuru nekur nevaru atrast, bez tam - kā pie velna var ieiet tajā sranajā plugina menu??? Nekur tādu opciju neatrodu. Uhh, kaut kā tiku galā, nu bet viss čerez žopu Labots Augusts 2, 2017 - ivo Link to comment Share on other sites More sharing options...
CAP Augusts 2, 2017 Share Augusts 2, 2017 http://torrent-tv.ru/viewing_on_xbmc.php - te jau it kā viss ir aprakstīts Link to comment Share on other sites More sharing options...
ivo Augusts 3, 2017 Share Augusts 3, 2017 pirms 8 stundām , CAP teica: te jau it kā viss ir aprakstīts Kas tad tur aprakstīts - nestrādājoši linki un neesoši (veci) ekrānšāviņi? Link to comment Share on other sites More sharing options...
CAP Augusts 3, 2017 Share Augusts 3, 2017 forums ir.. lasi vienkārši gan nav, cik nu palasīju.. arī superrepo grēko... čo ta gļuko.. Link to comment Share on other sites More sharing options...
ivars777 Augusts 27, 2017 Author Share Augusts 27, 2017 Jauna versija 0.1.40 (atbilstoši enigma2 versijai 0.7b). Ceru ka strādā (Windows it kā strādā, nebija laika notestēt uz Android kastēm u.c.) **0.1.40** (27.08.2017 - [change] Salabots TVDom atbilstoši jaunajam API (papildus parametri - reģions, valoda) - [bugfix] Salabots Euronews - [change] Nestrādājošie avoti noslēpti menu, kad tiks salaboti parādīsies atkal - [change] Sataisīts izmainītais Filmix.me 1 Link to comment Share on other sites More sharing options...
maigais Septembris 2, 2017 Share Septembris 2, 2017 (labots) tv dom tukša live stream, kodi ir uz datora'. pevienoju kodi logu kodi.zip Labots Septembris 2, 2017 - maigais Link to comment Share on other sites More sharing options...
CAP Septembris 2, 2017 Share Septembris 2, 2017 41 versijā filmix čota negāja.. tāpat pa lielam izmantoju tikai priekš skaties.lv (tv3) Link to comment Share on other sites More sharing options...
ivars777 Septembris 15, 2017 Author Share Septembris 15, 2017 (labots) Updeitota versija - 0.1.43. Cerams, ka strādā (nebija laika īpaši notestēt). Kodi playera īpatnību dēļ ir problēmas ar dažu avotu strīmiem (lattelekom filmas pārtrūkst pēc 5-6 minūtēm, pa taisno nespēlē arī viaplay (nekodētos) strīmus). Tāpēc plugins iekļauj arī proxy (playstreamproxy) caur kuri šie strīmi tiek spēlēti un kurš it kā mēģina to salabot. Diemžēl defaultais Python web serveris (vismaz uz manām kastēm) kaut kā lēni strādā, tāpēc defaultā šobrīd proxy ir atslēgts (ja kas, ir opcijās parametrs, kur to var ieslēgt). Dodiet ziņu, ja kādam tomēr strādā lattelecom arī caur proxy. **0.1.43** (03.09.2017) - [bugfix] Salaboti video avoti atbilstoši PlayStream 0.7e (lattelekom u.c.) - [change] pārstrukturets kods (video satura avoti atseviškā git modulī) - [change] opcija nelietot proxy problemātiskajiem strimiem (lattlecom.tv, viaplay u.c.), izskatās, ka Web serveris stradā par lēnu **0.1.41** (03.09.2017) - [bugfix] Salabots filmix (pamainīts direct url avots uz html5 + dekodēšana kods) Plus, ja ziņojat par problēmām, tad lūgums pievienot Kodi loga fragmentu, ar kļūdas paziņojumu (kodi.log failā meklēt EXCEPTION) Labots Septembris 15, 2017 - ivars777 Link to comment Share on other sites More sharing options...
CAP Septembris 15, 2017 Share Septembris 15, 2017 (labots) @ivars777 tam filmix nav iespēja dabūt kaut ko labāku par max 720p? Labots Septembris 15, 2017 - CAP Link to comment Share on other sites More sharing options...
ivars777 Septembris 15, 2017 Author Share Septembris 15, 2017 HD un labākas kvalitātes strīmi iekš filmix pieejami tikai Pro+ lietotājiem https://filmix.me/pro.html Šobrīd plugins rāda to, kas pieejams bez reģistrācijas (sanāk, ka vairāk par 720p nav pieejams). Principā kaut kad varētu mēģināt uzraisīt loginu arī filmixam, domāju, ka tad arī HD+ strīmi būtu pieejami Link to comment Share on other sites More sharing options...
ivars777 Septembris 17, 2017 Author Share Septembris 17, 2017 Jauna versija. **0.1.44** (03.09.2017) - [change] Sakārtotas pikonas, u.c. Ja kas ir testa variants Plex pluginam Link to comment Share on other sites More sharing options...
MasteR's Septembris 28, 2017 Share Septembris 28, 2017 (labots) Uz kodi v18 svaiga instalācija 21:05:58.542 T:9184 WARNING: CAddonSettings[plugin.video.playstream]: failed to parse old setting definition for "general_ttl" of type "int" 21:06:01.808 T:7968 ERROR: XFILE::CDirectory::GetDirectory - Error getting 21:06:01.938 T:5468 ERROR: Previous line repeats 6 times. 21:06:01.938 T:5468 WARNING: CAddonSettings[plugin.video.playstream]: failed to parse old setting definition for "general_ttl" of type "int" 21:06:01.938 T:5468 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.ValueError'> Error Contents: invalid literal for int() with base 10: '' Traceback (most recent call last): File "C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.playstream\addon.py", line 20, in <module> storage_ttl = plugin.get_setting("general_ttl",int) File "C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.playstream\kodiswift\xbmcmixin.py", line 223, in get_setting return int(value) ValueError: invalid literal for int() with base 10: '' -->End of Python script error report<-- 21:06:01.965 T:1876 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.playstream/ 21:06:01.965 T:1876 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.playstream/) failed Labots Septembris 28, 2017 - MasteR's Link to comment Share on other sites More sharing options...
CAP Septembris 29, 2017 Share Septembris 29, 2017 Pēdējās dienas gļuko skaties.lv (tvplay) last video sadaļa.. Link to comment Share on other sites More sharing options...
ivars777 Oktobris 5, 2017 Author Share Oktobris 5, 2017 Jauna versija, it kā tā v18 kļūda ir novērsta, varbūt strādās **0.1.45** (05.10.2017) - [change] Salabots ltc, replay, cnemalive u.c. Link to comment Share on other sites More sharing options...
ivars777 Oktobris 14, 2017 Author Share Oktobris 14, 2017 (labots) Jauna versija 0.1.46, atbilst PlayStream 0.7m Labots Oktobris 14, 2017 - ivars777 1 Link to comment Share on other sites More sharing options...
Racer Novembris 8, 2017 Share Novembris 8, 2017 Man viss strādā, paldies, tik jautājums: ir kaut kāda iespēja tā kā plugins to dara tikt klāt saturam kā failiem, lai dažus varētu nokopēt? Dažkārt vajag un tad eju caur tvplay.lv, attaisu attiecīgo video, sagaidu reklāmas beigas un novelku. Gribētos mazliet ērtāk to izveikt. Link to comment Share on other sites More sharing options...
CAP Novembris 8, 2017 Share Novembris 8, 2017 @Racer paturot uz attiecīgā raidījuma parādās poga download.. tik laikam iestatījumos jānorāda download mape vai tml, pats gan neesmu mēģinājis šo funkciju. @ivars777 kaut kur pazudis.. LTC arī vairs nestrādā.. ar tvplay slepenajiem linkiem arī dīvainības, bet nu ok.. Link to comment Share on other sites More sharing options...
Racer Novembris 8, 2017 Share Novembris 8, 2017 Man jau vairāk interesēja princips, lai win vidē varētu tur piekļūt... Link to comment Share on other sites More sharing options...
l30ns Novembris 16, 2017 Share Novembris 16, 2017 Sveiks, @ivars777! 1) Kas ir domāts ar "playstream.m3u" un kā to lietot? Vai vari parādīt tukšu piemēra failu, lai zinām kā to ar roku aizpildīt, jo caur Kodi menu to papildināt neizdodas? 2) Vai ir iespēja ar izveidot tādu Menu sadaļu, kas Replay vai RigaTV24 spēj vienā sarakstā dabūt vairākus raidījumus? Vai vari pateikt priekšā to kā pielāgot Tavu kodu šim? Es meģinu salikt Kodi vidgetus pa populārākajiem raidījumiem, ko skatos un Tavs plugins lieliski tos atfiltrē. P.S. Paldies par šo! Tas ir tieši tas ko esmu meklējis! Link to comment Share on other sites More sharing options...
