Taapat Decembris 2, 2016 Share Decembris 2, 2016 Varbūt kāds zin, kur var paskatīties no OpenPli imidžu Python kodu? Pieņemu ka domāts bija tomēr ne OpenPli. Vistuvākais no brīvi pieejamiem varētu būt vuplus: http://code.vuplus.com/gitweb/?p=vuplus_dvbapp;a=tree Atrast OpenPli enigmas izejas kodus jau nu nav problēma: https://github.com/OpenPLi/enigma2 Link to comment Share on other sites More sharing options...
MartiniB Decembris 2, 2016 Share Decembris 2, 2016 sensenos laikos kauch kas tamliidziigs liidzeeja opkg install enigma2-src Link to comment Share on other sites More sharing options...
DreamMuca Decembris 2, 2016 Share Decembris 2, 2016 nu jau cits "AttributeError" action -> WizardActions okLooking for embedded skinallocating new converter![PlayStream] SelectionChanged: current= ('My TV', 'config::my_tv', 'default', 'Mani TV kan\xc4\x81li (tie\xc5\xa1raide)')[PlayStream] SelectionChanged: current= ('My TV', 'config::my_tv', 'default', 'Mani TV kan\xc4\x81li (tie\xc5\xa1raide)')nr_read 1123 nr_write 157sum 1280 prev_sum 1280hdd IDLE![iDLE] 162.364326 30 True[EPGC] abort non avail viasat reading[EPGC] nownext finished(1480701938)nr_read 1123 nr_write 157sum 1280 prev_sum 1280hdd IDLE![iDLE] 164.979986906 30 Trueaction -> MenuActions menu[PlayStream] optionsLooking for embedded skinTraceback (most recent call last): File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action res = self.actions[action]() File "/usr/lib/enigma2/python/Plugins/Extensions/PlayStream/PlayStream.py", line 620, in item_menu self.session.openWithCallback(self.cb_item_menu, ChoiceBox2, title = title, list = lst) #TODO File "/usr/lib/enigma2/python/mytest.py", line 447, in openWithCallback dlg = self.open(screen, *arguments, **kwargs) File "/usr/lib/enigma2/python/mytest.py", line 457, in open dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs) File "/usr/lib/enigma2/python/mytest.py", line 387, in instantiateDialog return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop) File "/usr/lib/enigma2/python/mytest.py", line 418, in doInstantiateDialog dlg.applySkin() File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin self.createGUIScreen(self.instance, self.desktop) File "/usr/lib/enigma2/python/Components/GUISkin.py", line 30, in createGUIScreen if val.applySkin(desktop, self): File "/usr/lib/enigma2/python/Components/GUIComponent.py", line 39, in applySkin skin.applyAllAttributes(self.instance, desktop, self.skinAttributes, parent.scale) File "/usr/lib/enigma2/python/skin.py", line 281, in applyAllAttributes applySingleAttribute(guiObject, desktop, attrib, value, scale) File "/usr/lib/enigma2/python/skin.py", line 155, in applySingleAttribute guiObject.setFont(parseFont(value, scale))AttributeError: 'eListbox' object has no attribute 'setFont'(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x23395a8>>,('MenuActions', 'menu')) failed)]]> Link to comment Share on other sites More sharing options...
ivars777 Decembris 2, 2016 Author Share Decembris 2, 2016 Protams, ne OpenPli sources. Atradu problēmu, labota versija 0.5h. Domāju, ka tagad strādās. Atziņa ir tada, ka starp imidžiem komponenšu (konkrēti ChoiceBox) API ir atšķirīgs (nemaz nerunājot par to, ka tas būtu dokumentēts) un visurejošu pluginu taisīšana ir zināms izaicinājums OpenATV: class ChoiceBox(Screen): def __init__(self, session, title="", list=None, keys=None, selection=0, skin_name=None, text=""): OpenPLI: class ChoiceBox(Screen): def __init__(self, session, title="", list=[], keys=None, selection=0, skin_name=[], reorderConfig="", windowTitle=None): VuPlus: class ChoiceBox(Screen): def __init__(self, session, title = "", list = [], keys = None, selection = 0, skin_name = []): Link to comment Share on other sites More sharing options...
MartiniB Decembris 2, 2016 Share Decembris 2, 2016 un DMM veel savaadaaki untumi uz "vecaa" dm8000 ar Newnigma2 baazeeta uz DMM OE2.0 PlayStream iet, bet deelj liikajiem driveriem dazhas minuutes raada un tad saak iepauzeet ik peec 15 sec uz dm7080 ar Newnigma2 baazeeta uz jaunaas DreamOS OE2.5 zaljie kaadrez, kad negaazaas ~4b ? 4d, raadiija bez raustiishanaas Link to comment Share on other sites More sharing options...
ivars777 Decembris 3, 2016 Author Share Decembris 3, 2016 Kurā brīdī lido ārā. Vajadzētu pythona kļūdas paziņojumu no loga Link to comment Share on other sites More sharing options...
MartiniB Decembris 3, 2016 Share Decembris 3, 2016 ieksh PM suutiiju Link to comment Share on other sites More sharing options...
ivars777 Decembris 3, 2016 Author Share Decembris 3, 2016 (labots) 0.5j versija. Palabots, lai (cerams) strādā uz opendreambox enigmas (http://git.opendreambox.org/). Pieņemu (bet nezinu) vai tas ir DreamOS OE2.5. Izrādās, ka ka iekš opendreambox enigmas taimera API ir atšķirīgs no OpenPLI atvasinājumiem Ja joprojām problēma, tad vajag kaut kādā veidā paskatīties enigma2 python kodu (/usr/lib/enigma2/python) Labots Decembris 3, 2016 - ivars777 1 Link to comment Share on other sites More sharing options...
MartiniB Decembris 3, 2016 Share Decembris 3, 2016 nu ir priimaa! Link to comment Share on other sites More sharing options...
norico Decembris 3, 2016 Share Decembris 3, 2016 Uz BlackHole 3.0.2.J ar darbojas. Test in progress Link to comment Share on other sites More sharing options...
Taapat Decembris 3, 2016 Share Decembris 3, 2016 (labots) Atziņa ir tada, ka starp imidžiem komponenšu (konkrēti ChoiceBox) API ir atšķirīgs (nemaz nerunājot par to, ka tas būtu dokumentēts) Man liekas, ka enigmā vispār nekas nav dokumentēts. Bieži strādā princips - kā pirmais uztaisījis tā visiem jālieto. Tas protams netraucē pēc tam mainīt nerēķinoties ar to, kā tas ir bijis pirms tam, un kā tas ir citiem. Kā reiz lasīju, enigma tas ir kods bez konkrēta īpašnieka, tas nozīmē bez atbildības un garantijas. Tādēļ es aicinu neuztrauktos par imidžiem kuriem nav pieejami izejas kodi. Viņi ir izvēlējušie šādu ceļu, kas pārsvarā ir pretrunā ar enigmas GPL kodu. DM mēģina lavierēt publiski atļaujot piekļuvi tikai tam kodam, kurš viņu izpratnē ir zem GPL, bet tas viss ir ļoti slideni un dīvaini. Labots Decembris 3, 2016 - Taapat Link to comment Share on other sites More sharing options...
MartiniB Decembris 4, 2016 Share Decembris 4, 2016 DMM tak arii var saprast, GPL Enigma bija domaata lai sisteema atiistiitos un zeltu nevis paraadiitos neskaitaami konkurenti, kas panjemot gatavu softu, vareetu tirgot dzelzhus leetaak un leetie bokshi skaadee ne tikai DMM veelmei ko nopelniit, bet visam cs pasaakumam kopumaa Link to comment Share on other sites More sharing options...
saf Decembris 4, 2016 Share Decembris 4, 2016 Ar VTi tagad viss notiek! Paldies! Link to comment Share on other sites More sharing options...
ivars777 Decembris 4, 2016 Author Share Decembris 4, 2016 Nu te jau sākās "idejiska" diskusija . Es varētu piebilst, ka DMM (tāpat kā visu) vēlme nopelnīt ir saprotama. Cits jautājums, vai ir ok prakse uztaisīt savu produktu izmantojot GPL softu un pēc tam pretēji GPL principiem to slēgt. Nezinu detaļas par Enigma2 sākotnējo izstrādi (kādā mērā tā balstīta uz GPL komponentēm) un vai uz to attiecas GPL copyleft prasība. bet diemžēl šāda prakse no firmu puses ignorēt GPL prasības ir ļoti izplatīta. Ļoti līdzīgi ir ar Synology NASiem, kur Synology visādi mānās, lai neļautu citiem izmantot sau GPL bāzēto softu. No kopējā tirgus attīstības viedokļa lētiie opensourcīgie DVB uztvērēji ir pilnīgi normāla parādība (kā jebkurā jomā, premim lietas pēc dažiem gadīem klūst par comodity) un DMM stratēģija saglabāt konkurētspēju mākslīgi bremzējot attīstību bija pilnīgi muļķīga, kas rezultātā arī noveda savas pozīijas zaudēšanas un Enigma2 fragmentācijas (ar ko tad nākas tagad cīnities mēģinot uzrakstīt dažādos imidžos ejošu pluginu). 1 Link to comment Share on other sites More sharing options...
DreamMuca Decembris 6, 2016 Share Decembris 6, 2016 lab. pietix idejisku diskusiju... parunaasim par teemu ;o) Menu nu straadaa, bet vai var arii "Download Video" ? jeb tas pagaidaam "Not jet implemented" ? Link to comment Share on other sites More sharing options...
saf Decembris 6, 2016 Share Decembris 6, 2016 Ar VTi strādā. Link to comment Share on other sites More sharing options...
ivars777 Decembris 6, 2016 Author Share Decembris 6, 2016 (labots) Strādā download (nav ļoti testēts, bet principā strādā). Vidoe failiem ar tupu download, hls/dash ar gstreamer. Ja ir titri, nolādē arī tos. Pirms tam jānočeko/jāuzstāda download folderis. Download notiek fonā saliekot visus downloadus rindā. Tekošo downlod rindu var paskatīties un kaut ko ar viņu sadarīt ar zilo pogu vai caur menu. Live strīmus arī downlodē, tikai tos manuāli jāpārtauc. Strīmu skatīšanās paralēli downloadam var bremzēt/nestrādāt. Ja kāds strīms nedownloadējās, lūgums dot ziņu (iespējams nekorekti atpazīst srīma tipu vai kas cits neparedzēts) TODO listā ir vesela apakšfoldera lejupielāde (piemēram, sezonas visi video). Update: šobrīd downloads strādās tikai ar imidžiem, kur ir gstreamer 1.x + tikai faili (mp4,flv) un hls (m3u8). gstreamer 0.x, dash, rstp var pielikt bez lielām problēmām. RTMPx būs problemātiski (cik saprotu enigma nemāk RTMP spēlēt vispār). Labots Decembris 7, 2016 - ivars777 Link to comment Share on other sites More sharing options...
goicis Decembris 8, 2016 Share Decembris 8, 2016 sveiki!ir tāda problēma iepriekš jau minēta!!!uzliku šo pluginu uz vū+zero ar openpli imidžu šo te:https://www.tapatalk.com/topic/112199-46835 bet problēma ir,ka paiet līdz minūtei un karas nost!!!vai kāds varētu kaut ko ieteikt bez imidža maiņas? paldies jau iepriekš! Link to comment Share on other sites More sharing options...
Taapat Decembris 8, 2016 Share Decembris 8, 2016 Varu ieteikt pamēģināt serviceapp: http://taapat.blogspot.com/2016/04/mtg-play.html?showComment=1479230845298#c1816768908256812308 1 Link to comment Share on other sites More sharing options...
ivars777 Decembris 8, 2016 Author Share Decembris 8, 2016 Uz kura strīma karas? Ir novērtots, ka gstreamer mēdz uzkārties uz t.s. adaptīvajiem strīmiem (m3u8 saitē faktiski ir saraksts ar citām m3u8 satēm, kuras gstreamer izvēlas atkarībā no savienojuma ātruma u.c.). Tāpēc vairākiem sourciem adaptīvā strīmu vietā es uz pleijeri padodu jau konkrēto (vislabāko) strīmu. Vispār būtu jāredz logs, lai ko pateiktu 1 Link to comment Share on other sites More sharing options...
goicis Decembris 9, 2016 Share Decembris 9, 2016 Liels paldies Taapat!!!Tagad izskatās viss ir ok!!!Paldies!!! Uz kura strīma karas? sveiki!kārās pa piemēru paņemot to pašu skaties.lv arhīvu,bet tajā paša laikā!piemēram film.net gāja bez bēdas... protams tagad pēc cienījamā Taapat palīdzības viss iet,ko esmu mēģinājis!!! Link to comment Share on other sites More sharing options...
ivars777 Decembris 11, 2016 Author Share Decembris 11, 2016 Pamēģināju serviceapp uz openatv. Strādā un izskatās tiešām vieglāks/ātrāks. Vienīgais ko nesapratu, kādā veidā standarta servicemp3 tiek pārslēgts uz serviceapp (droši vien kodā redzams, bet nebija laika pētīt). Tas ir kāds patch (hooks) enigma2, vai arī tas izdarāms ar "standarta" enigmu un strādās visos imidžos uz kuriem savākts serviceapp/exteplayeris Plus ārējā pleijera izmantošana (un iespēja kaut ko sadarīt pirms viņa izsaukšanas) tas paver iespējas daudz jēdzīgāk spēlēt IPTV strīmus (gan veikt faktiskā strīma resolvēšanu, gan pievienot EPG un titrus). Link to comment Share on other sites More sharing options...
Taapat Decembris 11, 2016 Share Decembris 11, 2016 Serviceapp izmanto enigmas standarta funkcijas kas nodrošina attiecīgā koda izmantošanu atkarībā no servisa tipa. Viņam būtu jāstrādā visos imidžos. Es pat domāju, ka daļai imidžu nemaz nevajag speciāli kompilēt serviceapp. Vajadzētu strādāt uzstādot to no cita imidža ar līdzīgu enigmas kodu. Link to comment Share on other sites More sharing options...
Prime Decembris 12, 2016 Share Decembris 12, 2016 Gada jautājums - Kā šo visu dabūt caur KODI? Link to comment Share on other sites More sharing options...
ivars777 Decembris 12, 2016 Author Share Decembris 12, 2016 Kodi pluginu principā varētu viegli uztaisīt (tipa wraperi, kas darbina visus avotus ASIS). Pašam īsti nav laika/intereses (nelietoju kodi). Ja kāds uzņemas varu noinstruēt. -->Taapat Ideja ir nedaudz paspēlēties ar serviceapp. TIpa uztaisīt hooku, kas izsauc ārēju (python) url resolveri, kas atgriež aktuālos strīmu (strīmus) + titrus/epg. Tas ļautu strīmus normali skatīties ar standarta pleyri buķetēs u.c. Principā kaut ko līdzīgu DMM savā enigmā ir iztaisījuši http://dreambox.de/board/index.php?thread/21305-eserviceuri-a-proxy-service-for-python-powered-dynamic-stream-url-resolving/ Jautājumi: 1) Kā nokompilēt to serviceapp (tikai kopā ar visu imidžu, kur viņu likt kā lokālo recepti vai arī var autonomi kaut kā). 2) Varbūt ir idejas kā no serviceapp koda (kas kā saprotu ir daļa no enigma2) izsaukt ārēju pythona kodu. It kā teorētiski varētu embdēt jaunu python instanci iekš c, bet varbūt var kaut kā tikt atpakaļ pie jau esošā pythona, kas jau dzīvo zem enigmas. Link to comment Share on other sites More sharing options...
Edis7 Decembris 12, 2016 Share Decembris 12, 2016 Kungi, ir Ok topiks, Respect! Bet domāju, E2+Chromium, laikam tajā virzienā tālāk būs jāstūrē 1 Link to comment Share on other sites More sharing options...
Taapat Decembris 12, 2016 Share Decembris 12, 2016 @ivars777 1) Kā piemērs: https://github.com/Taapat/vuplus-fulan-openpli-oe-core/blob/master/meta-openpli/recipes-openpli/enigma2-plugins/enigma2-plugin-extensions-serviceapp_git.bb 2) Man liekas ka priekš tā būtu jāraksta pašam savs C++ kods, kurš veic visu nepieciešamo. Bet kāpēc nevar darīt tā kā to dara livestreamer? Pāradresēt vajadzīgo uz iekšējās adreses (127.0.0.1) noteiktu portu no kura tad arī tālāk apstrādāt un koriģēt strīmu. Link to comment Share on other sites More sharing options...
ivars777 Decembris 12, 2016 Author Share Decembris 12, 2016 @taapat 1) Baidos, ka neesmu vēl iebraucis, kā tās tās bitbake strādā. Kā saprotu, šitais ir daļa no imidža builda. Vai var vienkārši noklonēt pēdējo serviceapp versiju un autonomi to nokompilēt (vai arī tas darāms būvējot visu imidžu). Varbūt ir kāda instrukcija netā (kaut kā nevarēju atrast). 2) Parastu proxy, kurš piekorigē strimu es jau uztaisīju, lai apietu dažādus ierobežojumus. Šis ceļš nav īsti ok. Nav problēmu resolvēt url un atriezt īsto saturu kā downlodējamu failu (kā to dara livestreamer, cik es saprotu), bet tad hls/dash strīmiem nestrādā seek. Var protams emulēt hls/dash fragmentu apstrādi, bet tas ir baigais čakars un nav jēgas to darīt, jo ar hls/dash labi tiek galā gan gst, gan ffmpeg (tikai vajag viņiem iebarot pareizo url). Principā serviceapp to visu var sadarīt (arī pielikt ārējos titrus/epg). To python hooku laikam tiešām visjēdzīgāk taisīt kā lokālu REST izsaukumu (izskatās python embedēšana ir drausmīgi čakarīga). Link to comment Share on other sites More sharing options...
Taapat Decembris 12, 2016 Share Decembris 12, 2016 (labots) 1) Serviceapp izmanto enigmu, tādēļ neatkarīgi no tās to nevar kompilēt. Teorētiski varētu, iebarojot vajadzīgos include, bet tik un tā tas viss būs nedaudz caur di... Instrukcija kā kompilēt imidžu piemēram šeit: http://users.telenet.be/spstefansp/openpliubuntu.html Kā strādāt ar openembedded, spēj tik googlei prasīt. 2) Ja ir runa par hls strīmu izvēli, tad to jau mx3L sen ir izveidojis: https://github.com/mx3L/serviceapp/commit/761bb5f2048a2e983b7dc9fb1bc31de7e53471df var norādīt vēlamo ātrumu vai izvēlēties no strīmiem kā subservisu. Labots Decembris 12, 2016 - Taapat Link to comment Share on other sites More sharing options...
lipka Decembris 14, 2016 Share Decembris 14, 2016 Vu+zero,Openpli-4,atjaunināju programmatūru,caur Telnet sarakstīju visas komandas (pēc katras rindiņas apstiprinot"enter") ,restartēju deķi,bet caur menušku serviceapp neparādās.Ko daru nepareizi? Link to comment Share on other sites More sharing options...
Taapat Decembris 15, 2016 Share Decembris 15, 2016 @lipka tu raksti nepareizā forumā. Tev vajadzētu rakstīt forumā kur apgrozās gaišreģi un ekstrasensi. Vai uzstādāmās paketes vispār iekopēji /tmp mapē? Vai rakstot komandas telnetā nebija nekādu kļūdu paziņojumu? Link to comment Share on other sites More sharing options...
goicis Decembris 15, 2016 Share Decembris 15, 2016 Pa priekšu lejuplādē visas paketes no šejienes:http://taapat.ho.ua/serviceapp-openpli-4/ Pēc tam šīs paketes samet {pēc kārtas kā to norādījis taapat}uztvērēja /tmp mapē..... Un tad caur telnetu instalē!!! Visam vajadzētu būt ok! Veiksmi! Link to comment Share on other sites More sharing options...
lipka Decembris 16, 2016 Share Decembris 16, 2016 Nupat šovakar saliku un iet.Iepriekš mani mulsināja tā telnet komandas pielietojums.Tak krietni vienkāršāk ir caur plugin/programmatūras pārvaldīšana un atkrīt tā trakā rakstīšana telnetā. Link to comment Share on other sites More sharing options...
MartiniB Decembris 17, 2016 Share Decembris 17, 2016 kaada rakstiishana? ieziimee teksta blaakji un Copy-Paste vairaaku pielikumi instalaacijas gadiijumaa telnet konsole ir pulku eertaaka Link to comment Share on other sites More sharing options...
maigais Decembris 17, 2016 Share Decembris 17, 2016 ieslēdzu "ceturto studiju" ,paliek viss zaļš vai arī uzkarās Lietoju exteplayer3 e.zip Link to comment Share on other sites More sharing options...
ivars777 Decembris 18, 2016 Author Share Decembris 18, 2016 Logā nev redzams kreša info (tik vien kā extepleireris neveiksmīgi izpildījis https pieprasījumu). Varbūt crashlogā kaut kas vairāk redzams kā dēļ nokrēšo. Vai ar gstreamer pleyreri strādā? Vēl var mēģināt atslēgt HLS explore (+/- tā saucās tas ķeksis) serviceapp parametros. Link to comment Share on other sites More sharing options...
maigais Decembris 18, 2016 Share Decembris 18, 2016 (labots) Nav jau redzams jo talāk viss uzkarās un zaļš ekranā, palīdz tikai ja no rozetes izraut Tāpēc jau provēju exteplayer3 jo gstreamer pleyrerī nestrādā. varbūt tapec ka man 1.11 versija mēģināju atslēgt HLS explore , viss tapat zaļš un uzkarās paldies par uzmanību , sāka strādāt gstreamer pleyrerī pie vainas bija šis GLib-Net-WARNING **: couldn't load TLS file database: Failed to open file '/etc/ssl/certs/ca-certificates.crt': No such file or directory izdariju tā opkg install ca-certificates Viss aizgāja Labots Decembris 18, 2016 - maigais Link to comment Share on other sites More sharing options...
MartiniB Decembris 26, 2016 Share Decembris 26, 2016 mistika uz vecajiem Driimiem(dm8000;dm7020hd;dm500hd) ar OE2.0 baazeetu Newnigma2 imidzju pirmo reizi uzliekot viss darbojas, bet peec paarlikshanas, vienalga vai uz topashu vai jaunaaku, pazuud iespeeja straumeet no pasha boksha "Removing package" itkaa neparaada, ka veel kaadu elementu rautu sev liidz root@dm500hd:~# root@dm500hd:~# /usr/script/install.playstream Removing package enigma2-plugin-extensions-playstream from flash... Downloading http://feed.newnigma2.to/weekly/oe2.0/mips32el/Packages.gz. Inflating http://feed.newnigma2.to/weekly/oe2.0/mips32el/Packages.gz. Updated list of available packages in /var/tmp/mips. Downloading http://feed.newnigma2.to/weekly/oe2.0/dm500hd/Packages.gz. Inflating http://feed.newnigma2.to/weekly/oe2.0/dm500hd/Packages.gz. Updated list of available packages in /var/tmp/nn2. Downloading http://feed.newnigma2.to/weekly/oe2.0/emu/Packages.gz. Inflating http://feed.newnigma2.to/weekly/oe2.0/emu/Packages.gz. Updated list of available packages in /var/tmp/softcammipsel. Package python-json (2.7.2-r2.17-dream2-newnigma2_1) installed in flash is up to date. Package python-twisted-web (12.0.0-r2) installed in flash is up to date. Package python-simplejson (2.2.1-r1) installed in flash is up to date. Package python-html (2.7.2-r2.17-dream2-newnigma2_1) installed in flash is up to date. Package gst-plugins-bad-fragmented (0.10.23.1+git12254+cef47d8-r5) installed in flash is up to date. Downloading http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5j.ipk.'>http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5j.ipk. Installing enigma2-plugin-extensions-playstream (0.5j) to flash... Configuring enigma2-plugin-extensions-playstream. root@dm500hd:~# root@dm500hd:~# root@dm500hd:~# root@dm500hd:~# cat /usr/script/install.playstream #!/bin/sh # # Ivars777 @@@ http://www.boot.lv/forums/index.php?/topic/166792-playstream-enigma2-plugins-replaylsmlv-skatieslv-uc-satura-skatīšanai/ # # BoxTYPE=`cat -u /proc/stb/info/model| head -n1` case "$BoxTYPE" in dm7080|dm820|dm520|dm525|dm900) exit 0;; esac opkg remove enigma2-plugin-extensions-playstream opkg update opkg install python-json python-twisted-web python-simplejson python-html gst-plugins-bad-fragmented # ok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.2h.ipk # nok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.3a.ipk # ok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.3e.ipk # ok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.4b.ipk # ?? opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.4c.ipk # ok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.4d.ipk # ?? opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5a.ipk # Nok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5b.ipk # ?? opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5e.ipk # ?? opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5f.ipk # Nok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5g.ipk # Nok opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5h.ipk # OK opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5i.ipk opkg install http://www.xxxx.lv/m/Dreambox/Plugins_E2/enigma2-plugin-extensions-playstream_0.5j.ipk exit 0 root@dm500hd:~# p.s.uz jaunaa tipa Driima(dm7080) instaleeju ar roku 1. no telnet konsoles apt-get install python-json python-twisted-web python-simplejson python-html python-requests gstreamer1.0-plugins-bad-fragmented 2. kopeeju visu '/usr/lib/enigma2/python/Plugins/Extensions/PlayStream' folderi no cita driima 3. izdzeeshu visus *.pyo Link to comment Share on other sites More sharing options...
ivars777 Decembris 27, 2016 Author Share Decembris 27, 2016 Ko logs saka, kāpēc nestrādā (visdrīzāk kaut kas gstrīmerī nav ok). Ar gst-inspect+grep var paskatīties vai relevantie plugini ir ok Ivasr Link to comment Share on other sites More sharing options...
MartiniB Decembris 27, 2016 Share Decembris 27, 2016 nezkamdeelj /usr/bin/streamproxy tiek izdzeestspat ne atinstaleets, sisteema uzskata, ka "up to date" root@dm500hd:~# root@dm500hd:~# ls -l /usr/bin/streamproxy ls: /usr/bin/streamproxy: No such file or directory root@dm500hd:~# root@dm500hd:~# opkg install enigma2-streamproxy Package enigma2-streamproxy (3.999+git15+37a3f19-r4) installed in flash is up to date. root@dm500hd:~# root@dm500hd:~# opkg install --force-reinstall enigma2-streamproxy Removing package enigma2-streamproxy from flash... Installing enigma2-streamproxy (3.999+git15+37a3f19-r4) to flash... Downloading http://feed.newnigma2.to/weekly/oe2.0/mips32el/enigma2-streamproxy_3.999+git15+37a3f19-r4_mips32el.ipk. Configuring enigma2-streamproxy. root@dm500hd:~# root@dm500hd:~# ls -l /usr/bin/streamproxy -rwxr-xr-x 1 root root 10264 Mar 19 2016 /usr/bin/streamproxy root@dm500hd:~# root@dm500hd:~# Link to comment Share on other sites More sharing options...
