HotaimLV Ierakstīts Marts 23, 2013 Share Ierakstīts Marts 23, 2013 sveicināti nekādi nevaru atrast kadu Ram varu likt savā pc ! man tagad stāv 3x512mb un 1x256mbkopā apm 1750mb ramsGribu uzzināt vai ir verts pirkt kaut 4x1GB vai 2x2GB vai 4x1GB un Kadu DDR vai DDR2 utt. Šeit vairāk par manu PC matesplates NR. 929 REV OK S22 ir 4 RAM sloti kur likt. Tāda izskatās Link to comment Share on other sites More sharing options...
Grossmeister Marts 23, 2013 Share Marts 23, 2013 Priekš tās plates tev atmiņas tur pietiekami - RAM`a apgreids šeit būtu naudas mešana vējā . Link to comment Share on other sites More sharing options...
HotaimLV Marts 23, 2013 Author Share Marts 23, 2013 Vai tad Būs sliktāk ja ieliktu 4x pa 1GB. jo ir ta ka gribas dazas labakas gams uzraut bet pa isu ram. videokarte pietiek. lago nedaudz viss tas. speļu pasākums. Link to comment Share on other sites More sharing options...
nevertell Marts 23, 2013 Share Marts 23, 2013 A kas par processoru ? Link to comment Share on other sites More sharing options...
nnoname Marts 23, 2013 Share Marts 23, 2013 sliktāk nebūs, bet jēgas arī nē, ar ddr cenām esi iepazinies? Link to comment Share on other sites More sharing options...
HotaimLV Marts 23, 2013 Author Share Marts 23, 2013 System Information ------------------ Time of this report: 3/23/2013, 15:52:27 Machine name: HOTAIMLV Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158) Language: English (Regional Setting: Latvian) System Manufacturer: Hewlett-Packard System Model: HP Compaq dc7100 CMT(DX438AV) BIOS: Default System BIOS Processor: Intel® Pentium® 4 CPU 3.00GHz (2 CPUs) Memory: 1792MB RAM Page File: 1119MB used, 2059MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode Link to comment Share on other sites More sharing options...
raiviic Marts 23, 2013 Share Marts 23, 2013 (labots) Ja tiešām tev tā MB, kas linkā, tad, pēc šīs specifikācijas tev der tikai DDR. Ja nauda spiež kabatu, vari ņemt maksimālo - 4 x1 GB 400MHz (DDR 400MHz ir maksimums) - piemēram divus šādus 2GB kit. Bet - liels ieguvums, īpaši ņemot vērā DDR cenas, nebūs, nekādas jaunās spēles pat nesapņo dzenāt. Labāk jau pakrāj kādu laiku un ņem jaunu PC. Labots Marts 23, 2013 - raiviic Link to comment Share on other sites More sharing options...
nevertell Marts 23, 2013 Share Marts 23, 2013 Šeit būs tavs botlneks. Intel® Pentium® 4 CPU 3.00GHz Link to comment Share on other sites More sharing options...
nnoname Marts 23, 2013 Share Marts 23, 2013 labākais ko tai kārbai vari izdarīt - uzliec 3. servispaku, un krāj jaunai kastei 1 Link to comment Share on other sites More sharing options...
HotaimLV Marts 23, 2013 Author Share Marts 23, 2013 (DDR 400MHz ir maksimums) - piemēram divus šādus 2GB kit. Tad jau labāk Transcend DDR 1GB 400MHz CL3 Trīs par to cenu sanāk. Link to comment Share on other sites More sharing options...
intervall Marts 23, 2013 Share Marts 23, 2013 Par tām izmaksām,ko tu iztērētu Ram iegādē,piemestu kādu "dvatcāri" unbvarētu labāk nopirkt jau palietotu,bet labāku kasti. Link to comment Share on other sites More sharing options...
Borja Marts 23, 2013 Share Marts 23, 2013 Peec shiis lapas:http://h18000.www1.hp.com/products/quickspecs/11948_na/11948_na.HTML#Memory2GB modulju konfiguraacija nav piemineeta, kompis taadus var arii nenjemt pretii.Sanaak - 4x1GB ir maksimums.Bet taa kaa jau ir 1792 MB, tad lietderiibu likt vairaak atminju prieksh winxp apshaubu.Prieksh speeleem labaakais, ko var izdariit, ir ielikt labaaku videokarti(starp citu - patreizeejaa nav nosaukta). 1 Link to comment Share on other sites More sharing options...
HotaimLV Marts 23, 2013 Author Share Marts 23, 2013 Display Devices --------------- Card name: ATI Radeon HD 5450 Manufacturer: Advanced Micro Devices, Inc. Chip type: ATI display adapter (0x68F9) DAC type: Internal DAC(400MHz) Device Key: Enum\PCI\VEN_1002&DEV_68F9&SUBSYS_E157174B&REV_00 Display Memory: 1024.0 MB Current Mode: 1280 x 1024 (32 bit) (75Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: ati2dvag.dll Driver Version: 6.14.0010.7279 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 10/24/2012 02:32:26, 305664 bytes WHQL Logo'd: No WHQL Date Stamp: None VDD: n/a Mini VDD: ati2mtag.sys Mini VDD Date: 10/24/2012 02:42:18, 6812160 bytes Device Identifier: {D7B71EE2-2BB9-11CF-9468-5DC1A1C2CB35} Vendor ID: 0x1002 Device ID: 0x68F9 SubSys ID: 0xE157174B Revision ID: 0x0000 Revision ID: 0x0000 Video Accel: ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run Link to comment Share on other sites More sharing options...
nevertell Marts 23, 2013 Share Marts 23, 2013 AGP Status: Enabled Uz agp ? Link to comment Share on other sites More sharing options...
IT_chunthia Maijs 7, 2013 Share Maijs 7, 2013 Nedaudz kretinē tie cilvēki, kuri domā, ka sistēmas ātrdarbība ir atkarīga tikai no RAM lieluma. Tas, ka iegādāsies 4GB RAM'a uz sava Pentium 4 ar AGP videokarti, nenozīmē, ka tagad varēsi uz max grafiku spēlēt jaunākās un pat vecākās spēles. Link to comment Share on other sites More sharing options...
Mezavecis Maijs 7, 2013 Share Maijs 7, 2013 Un kā pēdējais citāts iet kopā ar tēmā apspriesto? Link to comment Share on other sites More sharing options...
Baigais Janka Maijs 8, 2013 Share Maijs 8, 2013 Vispār jau iet kopā, jo topika autors tak saka, ka grib ielikt vairāk atmiņas, lai labākas games varētu uzraut Link to comment Share on other sites More sharing options...
