Aivis2 Decembris 3, 2011 Share Decembris 3, 2011 (labots) <newcamd_port>15055</newcamd_port> <newcamd_port>15055</newcamd_port> CWS = 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 CWS = 127.0.0.1 34001 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan newcs Logos man izmet šādas rindiņas: Dec 02 17:58:49 22.22.22.104 [newcamd] Connecting to 127.0.0.1:34000... Dec 02 17:58:49 22.22.22.104 [newcamd] Connection to 127.0.0.1:34000 failed (28ms) Dec 02 17:59:00 22.22.22.104 [newcamd] Connecting to 127.0.0.1:34000... Dec 02 17:59:00 22.22.22.104 [newcamd] Connection to 127.0.0.1:34000 failed (19ms) Dec 02 17:59:11 22.22.22.104 [newcamd] Connecting to 127.0.0.1:34000... Dec 02 17:59:11 22.22.22.104 [newcamd] Connection to 127.0.0.1:34000 failed (9ms) Dec 02 17:59:23 22.22.22.104 [newcamd] Connecting to 127.0.0.1:34000... Dec 02 17:59:23 22.22.22.104 [newcamd] Connection to 127.0.0.1:34000 failed (0ms) Dec 02 17:59:34 22.22.22.104 [newcamd] Connecting to 127.0.0.1:34000... Nu seit ar restartu nav nekaada sakara tomeer! Skaidri redzams ka nevar savienoties ar portu 34000 JO portu nummuri serverim ir 15055 Labots Decembris 3, 2011 - Aivis2 Link to comment Share on other sites More sharing options...
MaskaV Decembris 3, 2011 Share Decembris 3, 2011 (labots) Lipka,bet pilns restarts pie izmaiņām taču ir viss parastākā ābece un to nezināt ir jocīgi.Es sava slinkuma dēļ pat netaisu restartu,bet vienkārši izrauju štepseli un palaižu pa jaunam. Tankistiem: # /var/tuxbox/config/newcamd.conf # Cardserver list # # <hostname> <port> <username> <password> <14 byte triple-des key in hex> <lan/wan> <cardserver name> # # wan connections will be dropped and rebuild if newcamd is told so by camdcmd # (see admin options) # # hostname = uds to use betad, port is the serial port in that case # #CWS = uds 1 premiere premiere #CWS = 127.0.0.1 10001 local local 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan cardserv CWS = 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan newcs CWS = 127.0.0.1 34001 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan newcs Visu garo sākuma penteri nerakstīju,tāpat nerakstu garo penteri newcs.xml,tikai to kas viss tiešāk skar mūsu vajadzības. <?xml version="1.0"?> ** This is the example file for Dreambox/TD etc. that use SCI interfaces. <newCSconfig> <readers name="Card Readers"> <device> <name>lower</name> <type>sci</type> <mhz>357</mhz> <node>/dev/sci0</node> <parity>odd</parity> <reset>normal</reset> <export>Yes</export> <enabled>Yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <!-- <boxkey>0000000000</boxkey> --> <!-- <rsa>0000000000</rsa> --> <irdeto-camkey>0000000000000000</irdeto-camkey> Te biki izlaižu,slinkums un turpinājums <PTShandshake>No</PTShandshake> <carddetect>yes</carddetect> <newcamd_port>34000</newcamd_port> <autosid>Yes</autosid> <Seca-PPV>no</Seca-PPV> <pincode>0000</pincode> <priority>round</priority> </device> atkal izlaižu <newcamdserver> <enabled>Yes</enabled> <name>newcs</name> <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey> <user> <name>dummy</name> <password>dummy</password> <hostname>localhost</hostname> <port>12000</port> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>dummy1</name> <password>dummy1</password> <hostname>localhost</hostname> <port>12000</port> <au>No</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> 12000 neattiecas uz klientiem,dummu vari rakstīt tālāk cik gribi,tas attiecas uz tiem,kas no kastes ņem šaru. newcamd.list CWS_KEEPALIVE = 120 #CWS_INCOMING_PORT = 21000 CWS = 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 Šis jāraksta kastē,kurā ir kartiņa. Labots Decembris 3, 2011 - MaskaV Link to comment Share on other sites More sharing options...
lipka Decembris 4, 2011 Author Share Decembris 4, 2011 Es nupat vēl novilku no neta 4 us Newcs.xml un neko nemainot,tik pareizi ierakstot newcamdlisti viss darbojas,ka prieks.Pat eksperimenta nolūkos padzēsu kādas rindiņas (un ne mazums) un viss notiek.Tā jau ir,atliek tik vienreiz palaist un liekas,kāpēc iepriekš negāja!?.Tas restarts ir drusku tā kā slinkuma iezīme,to ir daudz,jo katra viena izmaiņa ir restarts un gribās,lai tas viss ātrāk noris.Pats lietoju parasto DM500s un tur pietiek ar zilo,zaļo caur BP,bet ne visur tas der. P.s Es vēl tā iedomājos,cik daudz tā pults cieš,kamēr tiek apgūta kāda fiška.Parasts lietotājs tik daudz neizspaida par visu gadu kā experts pa vienu nedēļu. Link to comment Share on other sites More sharing options...
MartiniB Decembris 5, 2011 Share Decembris 5, 2011 > Parasts lietotājs tik daudz neizspaida par visu gadu kā experts pa vienu nedēļu "experc" lieto telnet konsoli un noskadro probleemu paaris minuutees, nevis uz aklo kauchko no pults .. > Pats lietoju parasto DM500s tur arii vajadzeeja kartes lasiishanas pasaakumu likt, sexa noteikti mazaak buutu bijis > Es nupat vēl novilku no neta 4 us Newcs.xml un neko nemainot,tik pareizi ierakstot newcamdlisti viss darbojas atliek vien publiceet savu IP adresi lai visi var izmeegjinaat logini/paroles/deskey ir jaamaina!!! Link to comment Share on other sites More sharing options...
kernell Oktobris 11, 2021 Share Oktobris 11, 2021 Vai varat padalīties ar oscam config priekš Conax , kur aktivizēts AU? Karte ir uztvērēja rīderī. Link to comment Share on other sites More sharing options...
MartiniB Oktobris 12, 2021 Share Oktobris 12, 2021 pirms 18 stundām , kernell teica: aktivizēts AU? kad reizi meenesii vajag, uz 10 minuuteem palaizhu mgcamd kaa klientu, bet oscam paliek kaa lasiitaajs paareejaa laikaa divi oscam paraleeli, taads setups, lai lasoshais nav jaarausta, briizhos kad klienta dalju maina uz ko nu kuraa briidii vajag 1 Link to comment Share on other sites More sharing options...
kernell Oktobris 12, 2021 Share Oktobris 12, 2021 Paldies, mēģināšu. Link to comment Share on other sites More sharing options...
kernell Oktobris 12, 2021 Share Oktobris 12, 2021 pirms 4 stundām , MartiniB teica: kad reizi meenesii vajag, uz 10 minuuteem palaizhu mgcamd kaa klientu, bet oscam paliek kaa lasiitaajs paareejaa laikaa divi oscam paraleeli, taads setups, lai lasoshais nav jaarausta, briizhos kad klienta dalju maina uz ko nu kuraa briidii vajag Paldies, viss izdevās. Link to comment Share on other sites More sharing options...
base7 Oktobris 9, 2023 Share Oktobris 9, 2023 Pacelšu šo tēmu, lai nebūtu jātaisa jauna. Jautājums, kā uz Vu+ uztvērēja palaist Baltkom kanālus izmantojot viņu oficiālo pieejas karti (Conax)? Viņu kopā ar moduli Ievietojot slotā, neko neatkodē (tumšs ekrāns). Iekš uzstādījumiem (common interfeiss) to karti uzrāda. Pārbaudīju uz 3 tv+Amiko Impulse kastītes. Tur visu skaisti rāda, bet uz vu+ neizdodas palaist. Ir Wicardd (1.19), ja kas. Ja kāds var palīdzēt piekurbulēt, var privāti atsūtīt PM. Paldies. Link to comment Share on other sites More sharing options...
base7 Oktobris 9, 2023 Share Oktobris 9, 2023 Situācija atrisināta. Jautājumu vairs nav. 1 Link to comment Share on other sites More sharing options...
