[Raksts] Olympus PEN E-P2
Žaks Noriss
Atklāti skakot man nav skaidra šāda aparāta vieta foto tirgū.....ne īsti DSLR - ne mazais ziepis. Pats atzini, ka spogulis nepatīk nēsāt līdzi - šis ir tāds pats klucis ar lielu stiklu, kaut "bodijs" ir maza izmēra....Nu zipenes neesamība, padara to vēl nepraktiskāku....un jā jāizmet jau piķis papildus par tā ne "lēto" aparātu....IMHO stila aparāts un vienīgi....kā šim ar slavenajiem trokšņiem ? derētu bilde ar iso 800 un 400.
imho divas izvēles - lielais zūms (vai dslr) vai arī ixus veidīgais ja negribi staipīt ķieģeļi. pašam ir divi verķi, kaut 99% staipu mugureni līdzi....mazo šad tad izmantoju.
bet nu apraksts labs!
Igelkott
Man ļoti patīk arhaiskums. Tas robustais kantainums, kas ļāva fotogrāfam izskatīties svarīgam...
palasīju sīkāk - omg. cik mīnusi viņas darbībā....gan par video, gan nestandarta štekeriem un ergonomiku...plus dynamic range.
relatively limited Micro Four Thirds lens selection from Olympus (as of April, 2010)
Short battery life (especially compared to an SLR)
No built-in flash
New accessory port devices hijack flash hot shoe, and don't daisy-chain -- so accessories can't be used together or with a flash strobe
Nowhere to store easy-to-lose hot shoe / accessory mount covers while you're using the EVF or mic adapter
External viewfinder is fairly bulky, doesn't lock in place when mounted
Shallow handgrip means single-handed shooting is uncomfortable for those with large hands
Awkward button placement (especially for accessory EVF button) makes single-handed shooting awkward for those with small hands
Camera doesn't detect when accessory EVF is brought to your eye
Menu system is clumsy and occasionally counterintuitive
Battery and flash card can't be changed while tripod-mounted
Low-res LCD screen
Too easy to turn main dial while trying to press arrow buttons, causing incorrect menu settings
External mic jack accessory lacks any dummy hot shoe or mount on which to attach an external mic
D-ring straps require metal-to-metal coupling rather than quieter metal-to-cloth, introducing rattle into audio tracks of movies
Internal mic fairly prone to picking up noise from behind camera and from user handling; also found some background hissing in recorded audio
No control over audio levels / amplification
Fly-by-wire focusing means even focusing manually adds noise to movie audio
Contrast-detect AF means hunting around point of focus in continuous AF mode
Some Art filters reduce frame rate so much as to be barely usable, especially in movie mode
Leveling screen doesn't offer basic aperture and shutter speed information or histogram
Although slightly faster than P1, lenses are still very slow to focus relative to SLRs and competing designs from Panasonic. New firmware should improve this, but we don't yet know by how much.
AF system appears to be programmed to cycle through a broad focal range with each focusing operation, particularly troublesome when autofocusing while recording video
14-42mm kit lens is sensitive to shutter vibration when handheld between ~1/100 - 1/200 second
Clipped highlights in video mode
More motion blur than expected in video mode
Video mode stabilization seems not to use sensor shift, and subjectively feels less effective than still-image stabilization
Video stabilization increases crop factor significantly, making wide-angle video hard to achieve
Auto white balance leaves tungsten lighting a little warm
Slight oversharpening leaves halo artifacts
Aperture-priority AE didn't do well in our low-light test, though the camera could have chosen slower shutter speeds and done fine
Very low dynamic range scores in JPEG images
Slow power-on time
User manual often vague or simply doesn't mention features or caveats (eg. which items aren't returned to default with a Custom Reset)
Igelkott
Diemžēl, jāatzīst, ka aparāts ir neatbilstošs savai cenai (skatījos salidzini.lv), bet nu gribētos redzēt reālas bildes, ko arī gaidu/-ām no autora. Tikai attiecībā uz zibeni gan nepiekritīšu, ka iebūvētā trūkums ir liels mīnuss.
Žaks Noriss
Tie visi uzskaitītie mīnusi... nu nezinu. Jābūt baigam feinšmekeram, lai pat trešo daļu reāli dzīvē izjustu.
No built-in flash
Low-res LCD screen
Slow power-on time
Bildes solu tikai uz piektdienas vakaru, jo šobrīd aparātu aizņēmās cits ģimenes loceklis.
Par cenu jau minēju - bija ārprāta salda, patiesībā gribējās sazvejot E-PL1, jo cena cena cena, bet Elkorā dabūju tāāādu atlaidi+ skatu meklētāju (ap 70Ls) un aķīti (vismaz 25Ls) bonusā, ka nevarēja neņemt. Ar to visu E-P2 sanāca mazāk kā E-P2 cena Amerikā.
Pamata tekstam pievienots I papildinājums.
man pietiek ar 3 mīnusiem , lai so izsvītrotu no saraksta:
1. šutter lag - 1.sec !!!!
2. švaks jpeg dinamiskais diapazons
3. ieslēgšanās laiks - 2.3s
Pat vecajiem (6 gadīgajiem) canon šie parametri ir 3x labāki,,,,,
nē nu ja ir tev stikli krājumos, tad jau ok.
nu,šitais jau tāpat ir stilam,ne nopietnai bildēšanai
Labs raksts. Ja vēl pieliksi vairāk savu izjūtu un mazāk specifikācijā lasāmo lietu, būs pērle.
Padomju laikos tautai bija pieejamas 4 kompakto kameru klases. Savirknēšu pēc lepnuma augoši:
1) puse no 35mm kadra: skolnieku variants, kas ļāva uz filmiņas iegūt 72 bildes. Nekādas automātikas. Objektīvs nemaināms.
2) 35mm kompaktā kamera (smena 8m utml). Ikdienas aparāts bez automātikas. Objektīvs nemaināms. Sanāk labas bildes, ja ir labs acumērs un pa rokai eksponometrs.
3) 35mm kompaktā kamera ar maināmiem objektīviem (FED, Zorkij). Optiskais tālmērs. Par eksponometru neatceros. --> Šī ir klase, kas atbilst revolucionārajam Olympus PEN <--
4) 35mm spoguļkameras (Zenit, Kijev). Maināmie objektīvi, fokusēšanās caur objektīvu. Vairumam iebūvēts eksponometrs. --> šī klase atbilst mūsdienu spoguļkamerām <--
FED un Zorkij aparāti padomju laikos bija iecienīti foto mīlētāju vidū, bija pieejamāki un lētāki par spoguļkamerām. Arī tolaik vairums staigāja ar KIT objektīviem. :)
Manuprāt, arī mūsdienās šai klasei būtu panākumi pie ļaudīm, kam nav nepieciešams spogulis (likt aci pie skatumeklētāja), bet kam interesē kvalitatīvas kameras un maināmās optikas piedāvātās iespējas.
VIL,nejauc.
Ar tālmēru šitai kamerai nav nekāda sakara... vienīgais normālais digitālais tālmērs ir Leica M9
Tolaik nebija autofokusa, tādēļ fokusēšanās notika ar roku.
Spoguļiem skatījāmies uz miglu bildi, cenšoties to padarīt asu.
ne-spoguļiem skatījāmies uz rimbulīti, kurā centāmies sabīdīt 2 svītriņas.
Ja kamera pati iemācās fokusēties, tad atsevišķs tālmērs nav nepieciešams, bet stilam par sliktu nenāktu.
rangefinderam ir pavisam citāda objektīvu uzbūve... tam ar AF saistības nav.
un Leica ir ar MF.
Žaks Noriss
(labots)
Pievienots papildinājums II
Nododu apskatei ISO400 un ISO800 sampļus. Ārā jau bija patumšs, līdz ar to viena 400 bilde ir izkustināta. Pilnie EXIF dati pieejami tur pat labajā pusē!
http://foto.inbox.lv/jackamo/30-07-2010_PEN-E-P2
Pievienotas Rīta pārdomas
Tā! Paša iedvesmots sapūtu vaigus un iegādāju pāreju no Canon FD uz micro4/3, bet ne nolādēto Novoflex, bet čainu par 20$ ar šipingu. Jāsaka kā ir - godājams rīks, atnāca 3 dienu laikā. Uzbūve pietiekami stabila, praktiski viss no metāla, tai skaitā bajonetes. Iespējama bezgalība. Tikai manuālais fokuss. Diemžēl nav sanācis laiciņš neko jēdzīgu uzbliezt. Nekas, brīvdienās ņemšu 300mm Canon un došos kaut ko pabildēt, ja meteoroloģiskie apstākļi nesacūkāsies. Ja reiz par pārejām, tad ebay iehavotais 4/3 uz micro4/3 jau arī ir kabatā. Būs vienas velna brīvdienas!
Labots - Žaks Kustō
  • 9 months later...
mironis augšā kā ir pēc laika ar to FD pāreju un manuālajiem stikliem
Žaks Noriss
Jāatzīst, ka daudz nav darbināta pāreja, jo slinkums staipīt stiklu. Gan jau vasarā izstiepšos ārā ar visu technīku.
Es tomēr uzskatu ja viņam laba cena tika dota, tad daudz maz ok.
Bet no šīs klases neko labāku par Sony NEX-5 neesmu redzējis :)
AdatuGalva
Redzēt ir viena lieta, bet reāli ir pavisam kas cits...
Un reāli vislabākās būsPanasonic m4/3 kameras.
Bet tur būs cita sāpe - krāsas...
Njāā piekrītu tur gan dizains labāks. Vēl tur video mode labs, grozāmais displejs un viss kaut kādas jaunas fīčas !
